Booting to white error screen (please Contact System administrator)
booting to white error screen oh no something has gone wrong a problem has occurred and the system can t recover please Contact System administrator
Switch to TTY with Ctrl + Alt + F5 for example and run this commands one by one:
sudo pacman-mirrors -f && sudo pacman -Syyu
rm -r ~/.config/dconf
rm -r ~/.local/share/gnome-shell
systemctl reboot
Just tried this, after updating to latest testing and seeing this error. Unfortunately doesn’t seem to help in my case.
Make sure there was no partial update:
Make sure your GPU drivers are ok, try a different kernel too.
Disable the extensions and then enable them one by one to see if there is one that makes GDM fail.
I did run sudo pacman-mirrors -f && sudo pacman -Syyu as you suggested in your initial post.
I tried the 5.8 kernel, but I guess I could try an older one too.
How would I best check the GPU drivers?
It seems like a systemd-coredump is happening.
See if this might help
Usually the inxi -Fazy from terminal or TTY gives the complete information about the system to start investigating.
Disabling all extensions doesn’t seem to help.
Also tried the 5.7 kernel, but didn’t help.
inxi doesn’t show anything suspicious, I would upload it, but I’m not sure how to easily do that from tty.
The white Oh no error is generated by gnome-shell. The typical troubleshooting procedure is
  1. login to console
  2. disable all gnome extensions from cli
  3. systemctl restart gdm
  4. log into your desktop and start enabling extensions one by one to see which one is the culprit
In addition to extensions, gnome shell themes can cause breakage like this, so you may want to revert to defaults if you have something custom going on.
These commands revert all gnome settings to their defaults, so you can also try that as a nuclear option.
I already nuked those folders :slight_smile:
But didn’t fix it :confused:
I think I’m seeing this gnome-shell crashes when a cursor is not found (#355) · Issues · GNOME / mutter · GitLab
So I did run gsettings set org.gnome.desktop.interface cursor-theme 'Adwaita'
Running x or wayland from the tty works after that, but I still get the error screen on boot.
Here’s the inxi output:
  Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
  root=UUID=5d22ff53-87eb-4a34-b2c9-ea68e6d0729f rw quiet
  Console: tty 5 DM: GDM 3.38.1 Distro: Manjaro Linux
  Type: Convertible System: Acer product: Spin SP515-51GN v: V1.14
  serial: <filter>
  Mobo: KBL model: Buzz_KL v: V1.14 serial: <filter> UEFI: Insyde v: 1.14
  date: 01/09/2019
  ID-1: BAT0 charge: 37.1 Wh condition: 42.9/50.8 Wh (84%) volts: 16.1/15.3
  model: SMP-SDI3320 AC14B7K type: Li-ion serial: <filter> status: Discharging
  Device-1: hid-0003:04F3:25A1.0003-battery model: ELAN Touchscreen
  serial: N/A charge: N/A status: N/A
  Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 8E (142) stepping: A (10) microcode: D6
  L2 cache: 8192 KiB
  bogomips: 32012
  Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 880 2: 834 3: 844
  4: 841 5: 842 6: 891 7: 843 8: 843
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:5917
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile]
  vendor: Acer Incorporated ALI driver: nvidia v: 450.80.02
  alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c8d
  Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus ID: 1-7:4
  chip ID: 04f2:b5f7
  Display: server: X.org 1.20.9 driver: modesetting,nvidia unloaded: nouveau
  alternate: fbdev,intel,nv,vesa tty: 240x67
  Message: Advanced graphics data unavailable in console. Try -G --display
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
  chip ID: 8086:9d71
  Sound Server: ALSA v: k5.7.19-2-MANJARO
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
  vendor: Lite-On driver: ath10k_pci v: kernel port: 3000 bus ID: 02:00.0
  chip ID: 168c:003e
  Local Storage: total: 1.38 TiB used: 159.24 GiB (11.3%)
  ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-21Z10T0
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: 1A02 scheme: GPT
  ID-2: /dev/sdb vendor: Micron model: 1100 MTFDDAV512TBN size: 476.94 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
  rev: A020 scheme: GPT
  ID-1: / raw size: 194.63 GiB size: 191.07 GiB (98.17%)
  used: 159.17 GiB (83.3%) fs: ext4 dev: /dev/sdb5
  System Temperatures: cpu: 37.0 C mobo: 30.0 C
  Processes: 209 Uptime: 5m Memory: 7.69 GiB used: 475.3 MiB (6.0%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1822
  pacman: 1819 lib: 467 pkg: 0 flatpak: 3 Shell: fish v: 3.1.2
  running in: tty 5 inxi: 3.1.05
