Hello I am able to boot and the wifi connects just right, but I get this error.
I’ve reinstalled the wpa_supplicant and wpa_tui. I am rebooting now to check for errors.
Have a look here:
At least it would good to have these information:
inxi -Nxxxa
journalctl -b -0 --grep="Error"
And please format it like this:
Ok , I will do that command in a couple of minutes.
inxi -Nxxxa
vendor: Lenovo driver: r8169 v: kernel port: 4000 bus ID: 08:00.0
chip ID: 10ec:8168
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Lenovo Z50-75 driver: rtl8723be v: kernel port: 3000
bus ID: 09:00.0 chip ID: 10ec:b723
-- Logs begin at Sat 2020-08-22 22:24:24 EEST, end at Sun 2020-08-30 17:49:32 E>
aug 30 16:34:41 popa-20384 kernel: mce: [Hardware Error]: Machine check events >
aug 30 16:34:41 popa-20384 kernel: mce: [Hardware Error]: CPU 0: Machine Check:>
aug 30 16:34:41 popa-20384 kernel: mce: [Hardware Error]: TSC 0 ADDR fef87300 M>
aug 30 16:34:41 popa-20384 kernel: mce: [Hardware Error]: PROCESSOR 0:40651 TIM>
aug 30 16:34:41 popa-20384 kernel: RAS: Correctable Errors collector initialize>
aug 30 16:36:21 popa-20384 gnome-session-c[1242]: Error creating FIFO: File exi>
aug 30 16:36:40 popa-20384 gnome-shell[1259]: Impossible to monitor trash: Gio.>
aug 30 16:36:40 popa-20384 gnome-shell[1259]: Impossible to enumerate trash chi>
aug 30 16:36:42 popa-20384 gnome-shell[1259]: Error looking up permission: GDBu>
aug 30 16:37:05 popa-20384 gnome-shell[1259]: Gio.IOErrorEnum: Error calling St>
aug 30 16:37:50 popa-20384 gnome-contacts-[1855]: backend-store.vala:435: Error>
aug 30 16:38:52 popa-20384 gnome-shell[1259]: JS ERROR: Exception in callback f>
_createIconByName@/usr/share/gnom>
_cacheOrCreateIconByName@/usr/sha>
_updateIconByType@/usr/share/gnom>
_updateIcon@/usr/share/gnome-shel>
_emit@resource:///org/gnome/gjs/m>
_onPropertiesChanged/<@/usr/share>
_onPropertiesChanged@/usr/share/g>
refreshPropertyOnProxy/<@/usr/sha>
aug 30 16:54:05 popa-20384 pipewire[4492]: [E][000001173.166913][backend-ofono.>
lines 1-22/22 (END)...skipping...
-- Logs begin at Sat 2020-08-22 22:24:24 EEST, end at Sun 2020-08-30 17:49:32 EEST. --
aug 30 16:34:41 popa-20384 kernel: mce: [Hardware Error]: Machine check events logged
aug 30 16:34:41 popa-20384 kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 6: ae0000000040110a
aug 30 16:34:41 popa-20384 kernel: mce: [Hardware Error]: TSC 0 ADDR fef87300 MISC b8a0000086
aug 30 16:34:41 popa-20384 kernel: mce: [Hardware Error]: PROCESSOR 0:40651 TIME 1598794472 SOCKET 0 APIC 0 microcode 26
aug 30 16:34:41 popa-20384 kernel: RAS: Correctable Errors collector initialized.
aug 30 16:36:21 popa-20384 gnome-session-c[1242]: Error creating FIFO: File exists
aug 30 16:36:40 popa-20384 gnome-shell[1259]: Impossible to monitor trash: Gio.IOErrorEnum: Operation not supported
aug 30 16:36:40 popa-20384 gnome-shell[1259]: Impossible to enumerate trash children: Gio.IOErrorEnum: Operation not supported
aug 30 16:36:42 popa-20384 gnome-shell[1259]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
aug 30 16:37:05 popa-20384 gnome-shell[1259]: Gio.IOErrorEnum: Error calling StartServiceByName for org.freedesktop.FileManager1: Timeout was reached
aug 30 16:37:50 popa-20384 gnome-contacts-[1855]: backend-store.vala:435: Error preparing Backend 'telepathy': The name org.freedesktop.Telepathy.AccountManager was not provided by any .service files
aug 30 16:38:52 popa-20384 gnome-shell[1259]: JS ERROR: Exception in callback for signal: icon: Error: Argument 'filename' (type filename) may not be null
_createIconByName@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:406:26
_cacheOrCreateIconByName@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:368:14
_updateIconByType@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:574:18
_updateIcon@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:601:14
_emit@resource:///org/gnome/gjs/modules/core/_signals.js:133:47
_onPropertiesChanged/<@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:220:22
_onPropertiesChanged@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/appIndicator.js:214:15
refreshPropertyOnProxy/<@/usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/util.js:51:19
aug 30 16:54:05 popa-20384 pipewire[4492]: [E][000001173.166913][backend-ofono.c:447 ofono_register_reply()] Register() failed: org.freedesktop.DBus.Error.ServiceUnknown
lines 1-22/22 (END)
oh also this:
I see no information about you wifi in the log, could you provide a full log?
journalctl -b -0 > /home/$USER/journal.txt
and also
systemctl status NetworkManager.service > /home/$USER/status_network.txt
The files are saved in your home folder.
optional: but maybe try the dkms driver in the AUR?
First check which kernel you have:
uname -r
then install the headers for this kernel (if it is 5.7.15-1-MANJARO then this):
pamac install linux57-headers dkms
then build the package:
pamac build r8169aspm-dkms
Sure, I will, give me a second.
both outputs are in the pastebin link.
I’ve installed dkms using pacaur.
That is weird:
aug 30 18:05:37 popa-20384 NetworkManager[874]: <info> [1598799937.4050] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "TP-Link_F09E"
Wifi is working, but here it is timed out:
aug 30 18:06:33 popa-20384 systemd[1]: Timed out waiting for device /sys/subsystem/net/devices/wlp9s0.
aug 30 18:06:33 popa-20384 systemd[1]: Dependency failed for WPA supplicant daemon (interface-specific version).
aug 30 18:06:33 popa-20384 systemd[1]: wpa_supplicant@wlp9s0.service: Job wpa_supplicant@wlp9s0.service/start failed with result 'dependency'.
aug 30 18:06:33 popa-20384 systemd[1]: sys-subsystem-net-devices-wlp9s0.device: Job sys-subsystem-net-devices-wlp9s0.device/start failed with result 'timeout'.
aug 30 18:06:33 popa-20384 systemd[1]: Reached target Network.
aug 30 18:06:33 popa-20384 systemd[1]: Reached target Network is Online.
The NetworkManager says:
aug 30 18:05:32 popa-20384 NetworkManager[874]: <info> [1598799932.3597] settings: Loaded settings plugin: keyfile (internal)
aug 30 18:05:32 popa-20384 NetworkManager[874]: <info> [1598799932.6439] device (lo): carrier: link connected
aug 30 18:05:32 popa-20384 NetworkManager[874]: <info> [1598799932.6446] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
aug 30 18:05:32 popa-20384 NetworkManager[874]: <info> [1598799932.6462] manager: (enp8s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
aug 30 18:05:32 popa-20384 NetworkManager[874]: <info> [1598799932.6474] device (enp8s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
aug 30 18:05:32 popa-20384 ModemManager[922]: <info> ModemManager (version 1.14.2) starting in system bus...
aug 30 18:05:32 popa-20384 kernel: Generic FE-GE Realtek PHY r8169-800:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-800:00, irq=IGNORE)
aug 30 18:05:32 popa-20384 kernel: r8169 0000:08:00.0 enp8s0: Link is Down
aug 30 18:05:32 popa-20384 systemd-networkd[398]: enp8s0: Link UP
aug 30 18:05:32 popa-20384 NetworkManager[874]: <info> [1598799932.8582] device (wlan0): driver supports Access Point (AP) mode
aug 30 18:05:32 popa-20384 NetworkManager[874]: <info> [1598799932.8603] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
aug 30 18:05:32 popa-20384 NetworkManager[874]: <info> [1598799932.8624] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
aug 30 18:05:33 popa-20384 systemd-networkd[398]: wlan0: Link UP
aug 30 18:05:33 popa-20384 systemd-networkd[398]: wlan0: Link DOWN
aug 30 18:05:33 popa-20384 NetworkManager[874]: <info> [1598799933.5394] device (wlan0): set-hw-addr: set MAC address to FE:92:D1:61:7A:0F (scanning)
Your wired connection gets renamed:
aug 30 18:05:15 popa-20384 kernel: r8169 0000:08:00.0 enp8s0: renamed from eth0
but not your wlan0 to wlp9s0.
I thing the network manager tries to start wlan0, this is this is the wrong name. It is wlp9s0. And there we have the interface-specific version Dependency error.
Could you post the output of:
ip a
Did you configure the WIFI somehow manually instead of using the network-manager? Is wlan0 set there or wlp9s0 as device?
What about the other errors?
~ >>> ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp8s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether ba:08:70:4b:ed:e5 brd ff:ff:ff:ff:ff:ff permaddr f8:a9:63:35:b2:97
inet 192.168.0.101/24 brd 192.168.0.255 scope global dynamic noprefixroute enp8s0
valid_lft 7080sec preferred_lft 7080sec
inet6 fe80::f842:81d6:11b2:9b64/64 scope link noprefixroute
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 38:b1:db:50:8b:65 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.104/24 brd 192.168.0.255 scope global dynamic noprefixroute wlan0
valid_lft 7081sec preferred_lft 7081sec
inet6 fe80::c532:edb7:adbc:8e61/64 scope link noprefixroute
4: proton0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 100
link/none
inet 10.16.0.24/16 brd 10.16.255.255 scope global proton0
inet6 fe80::10df:a860:988:1ec9/64 scope link stable-privacy
These errors are not related to the wifi. Create a new topic if you want to fix them, but in general these are UEFI problems.
Can you switch the device wlan0 to wlp9s0 in the NetworkManager? If not there, write it.
I guess it is this application: nm-connection-editor
I already did.
Does it work?
When the computer had booted there were no errors, only when I had closed the computer, before booting, but it was too fast for me to see.
I mean… is the Wifi Connection working?
No, it still doesn’t work. I can connect and it shows as connected but it doesn’t get me online. And if I disconnect the wired connection and reconnect it, I cannot go online.
Sorry myself i have no idea now. I buried out my laptop and started it with gnome.
eth0 gets renamed and wlan0 gets renamed
and the NetworkManager uses the new names.
eth0 (wired connection) gets renamed to enp8s0.
Your NetworkManager uses the name wlan0, but it should use the renamed wlp9s0.
I guess it has something to with protonvpn, not sure when your problems started.
On the clean installation there is not such a problem.
Maybe someone else with better knowledge could help you.
It really was a clean install, from USB.
vi /etc/udev/rules.d/70-persistent-net.rules
inserting this
> SUBSYSTEM==“net”, ACTION==“add”, DRIVERS=="?", ATTR{address}==“7c:fe:90:cb:76:02”, ATTR{dev_id}==“0x0”, ATTR{type}==“1”, KERNEL=="eth", NAME=“eth1”
> SUBSYSTEM==“net”, ACTION==“add”, DRIVERS=="?", ATTR{address}==“7c:fe:90:cb:76:03”, ATTR{dev_id}==“0x0”, ATTR{type}==“1”, KERNEL=="eth", NAME=“eth2”
then doing this:
cat /etc/sysconfig/network-scripts/ifcfg-eth1
DEVICE="eth1"
BOOTPROTO="static"
HWADDR="7c:fe:90:cb:76:02"
IPADDR=1.1.1.2
NETMASK=255.255.255.0
ONBOOT="yes"
then doing this
ifconfig
eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 1.1.1.2 netmask 255.255.255.0 broadcast 1.1.1.255
inet6 fe80::7efe:90ff:fecb:7602 prefixlen 64 scopeid 0x20<link>
ether 7c:fe:90:cb:76:02 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 23 bytes 3208 (3.1 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth2: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 7c:fe:90:cb:76:03 txqueuelen 1000 (Ethernet)
TX packets 0 bytes 0 (0.0 B)
is this a safe method? should I try it?
