@Nachlese, there is no system snapshot!
@soundofthunder, I apologize for the missing information: My HDD is ext4.
This is the system info:
inxi --admin --verbosity=8 --filter --no-host --width î˛ â
Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
lang=en_US keytable=de tz=UTC misobasedir=manjaro
misolabel=MANJARO_KDE_2412 quiet systemd.show_status=1 splash driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Laptop System: HP product: HP EliteBook 830 G6 v: SBKPF
Mobo: HP model: 854A v: KBC Version 52.6F.00 serial: <superuser required>
part-nu: 8NW86EC#ABD uuid: <superuser required> UEFI: HP v: R70 Ver. 01.27.00
date: 12/19/2023
ID-1: BAT0 charge: 24.7 Wh (73.5%) condition: 33.6/50.2 Wh (67.0%)
volts: 11.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging cycles: 20
System RAM: total: 32 GiB available: 31.04 GiB used: 3.17 GiB (10.2%)
Device-1: Bottom-Slot 1(left) type: DDR4 detail: synchronous size: 16 GiB
speed: 2400 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: Kingston part-no: 9905744-005.A00G serial: <filter>
Device-2: Bottom-Slot 2(right) type: DDR4 detail: synchronous size: 16 GiB
Info: model: Intel Core i5-8365U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xFC
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 400/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 30409
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Quanta HP HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:3 chip-ID: 0408:5343
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1392 built: 2018 res: 1920x1080
hz: 60 dpi: 166 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329
y: 0.557 blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
size: 293x165mm (11.54x6.5") diag: 336mm (13.2") ratio: 16:9
modes: 1920x1080
EDID-Warnings: 1: parse_edid: unknown flag 2
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
device-ID: 8086:3ea0 memory: 15.15 GiB unified: yes
API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu
name: Intel UHD Graphics 620 (WHL GT2) driver: mesa intel v: 24.2.4-arch1.0.1
device-ID: 8086:3ea0 surfaces: xcb,xlib
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_soc_avs, snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:9dc8
class-ID: 0401
API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bd class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
IF-ID-1: wwan0 state: down mac: N/A
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
Device-1: boot_crypt maj-min: 254:0 type: LUKS dm: dm-0 size: 250 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 250 GiB
Local Storage: total: 960.15 GiB used: 150.83 GiB (15.7%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Ultra Fit
size: 28.64 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.0
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: /chroot raw-size: 250 GiB size: 245.02 GiB (98.01%)
used: 150.79 GiB (61.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: boot_crypt label: N/A uuid: N/A
ID-2: /chroot/boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 43.6 MiB (14.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: CD10-10B9
ID-1: /dev/sda1 maj-min: 8:1 size: 3.87 GiB fs: iso9660
ID-2: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 8BF0-EDB3
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-8:2 info: Synaptics Fingerprint reader [HP G6]
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:00b7 class-ID: ff00 serial: <filter>
Device-2: 1-9:3 info: Quanta HP HD Camera type: video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 0408:5343 class-ID: 0e02 serial: <filter>
Device-3: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
Device-1: 2-2:2 info: SanDisk Ultra Fit type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5583 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 38.0 C pch: 34.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1267 libs: 331 tools: pamac pm: flatpak pkgs: 0
1: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
2: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
3: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
5: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
6: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
7: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
9: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
10: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
11: https://mirror.koddos.net/manjaro/stable/$repo/$arch
12: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
13: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
14: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
15: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
16: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
17: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
18: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
19: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
20: https://mirror.easyname.at/manjaro/stable/$repo/$arch
21: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
22: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
23: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
24: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
25: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
26: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
27: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
28: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
29: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
30: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
31: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
32: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
33: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
34: http://manjaro.grena.ge/stable/$repo/$arch
35: https://mirrors2.manjaro.org/stable/$repo/$arch
36: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
37: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
38: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
39: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
40: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
41: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
42: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
43: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
44: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
45: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
46: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
47: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
48: http://manjaro.mirror.ac.za/stable/$repo/$arch
49: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
50: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
51: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
52: https://repos.silknet.com/manjaro/stable/$repo/$arch
53: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
54: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
55: https://linorg.usp.br/manjaro/stable/$repo/$arch
56: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
57: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
58: https://muug.ca/mirror/manjaro/stable/$repo/$arch
59: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
60: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
61: https://mirror.init7.net/manjaro/stable/$repo/$arch
62: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
63: https://mirror.funami.tech/manjaro/stable/$repo/$arch
64: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
65: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
66: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
67: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
68: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
69: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
70: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
71: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
72: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
73: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
74: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
75: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
76: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
77: https://manjaro.kurdy.org/stable/$repo/$arch
78: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
79: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
80: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
81: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
82: https://mirror.seahost.de/manjaro/stable/$repo/$arch
83: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
84: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
85: http://mirror.fcix.net/manjaro/stable/$repo/$arch
86: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
87: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
88: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
89: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
90: https://mirrors.netix.net/manjaro/stable/$repo/$arch
91: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
92: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
93: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
94: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
95: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
96: https://mirror.zetup.net/manjaro/stable/$repo/$arch
97: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
98: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
99: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
100: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
101: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
102: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
103: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
104: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
105: https://manjaro.ynh.ovh/stable/$repo/$arch
106: https://mirror.dc.uz/manjaro/stable/$repo/$arch
107: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
108: https://mirror.23m.com/manjaro/stable/$repo/$arch
109: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
110: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
111: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
112: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
113: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
114: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
115: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
116: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
117: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
118: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
119: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
120: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
121: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
122: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
123: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
124: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
125: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
126: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
127: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
128: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
129: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
130: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
131: https://mirrors.manjaro.org/repo/stable/$repo/$arch
Processes:
CPU top: 5 of 248
1: cpu: 100% command: ps pid: 34985 mem: 3.40 MiB (0.0%)
2: cpu: 13.1% command: firefox pid: 2180 mem: 476.6 MiB (1.4%)
3: cpu: 7.5% command: zsh pid: 34829 mem: 8.22 MiB (0.0%)
4: cpu: 4.3% command: firefox pid: 2475 mem: 258.4 MiB (0.8%)
5: cpu: 2.9% command: kwin_x11 pid: 1252 mem: 187.9 MiB (0.5%)
Memory top: 5 of 248
1: mem: 476.6 MiB (1.4%) command: firefox pid: 2180 cpu: 13.1%
2: mem: 351.2 MiB (1.1%) command: plasmashell pid: 1295 cpu: 0.7%
3: mem: 258.4 MiB (0.8%) command: firefox pid: 2475 cpu: 4.3%
4: mem: 231.7 MiB (0.7%) command: konsole pid: 2763 cpu: 0.4%
5: mem: 201.7 MiB (0.6%) command: firefox pid: 2599 cpu: 1.0%
Processes: 248 Power: uptime: 43m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.37 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.36
Uninstalling pamac-gtk worked:
sudo pacman -Rns pamac-gtk
Re-installing, however, failed:
[manjaro /]# pacman -Syu pamac
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: There are 2 providers available for pamac:
:: Repository extra
1) pamac-gtk 2) pamac-gtk3
Enter a number (default=1): 1
resolving dependencies...
Packages (4) archlinux-appstream-data-20240914-1 gtk4-1:4.14.5-1 libadwaita-1:1.5.4-1
pamac-gtk-11.7.2-0
Total Installed Size: 73.92 MiB
:: Proceed with installation? [Y/n] Y
(4/4) checking keys in keyring [##################################] 100%
(4/4) checking package integrity [##################################] 100%
(4/4) loading package files [##################################] 100%
(4/4) checking for file conflicts [##################################] 100%
error: failed to commit transaction (conflicting files)
pamac-gtk: /etc/xdg/autostart/pamac-tray-budgie.desktop exists in filesystem
pamac-gtk: /etc/xdg/autostart/pamac-tray.desktop exists in filesystem
pamac-gtk: /usr/bin/pamac-installer exists in filesystem
pamac-gtk: /usr/bin/pamac-manager exists in filesystem
pamac-gtk: /usr/bin/pamac-tray exists in filesystem
pamac-gtk: /usr/lib/libpamac-gtk.so exists in filesystem
pamac-gtk: /usr/share/applications/org.manjaro.pamac.manager.desktop exists in filesystem
pamac-gtk: /usr/share/applications/pamac-installer.desktop exists in filesystem
pamac-gtk: /usr/share/dbus-1/services/org.manjaro.pamac.manager.service exists in filesystem
pamac-gtk: /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/README.md exists in filesystem
pamac-gtk: /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js exists in filesystem
pamac-gtk: /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/metadata.json exists in filesystem
pamac-gtk: /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/stylesheet.css exists in filesystem
pamac-gtk: /usr/share/gnome-shell/search-providers/org.manjaro.pamac.manager.search-provider.ini exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/16x16/apps/system-software-install.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/32x32/apps/system-software-install.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/48x48/apps/system-software-install.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/actions/view-sidebar-end-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/actions/view-sidebar-start-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/emblems/globe-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/installed-check.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/pamac-tray-no-update.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/pamac-tray-update.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/software-install-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/software-remove-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/software-select-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/software-update-symbolic.svg exists in filesystem
Checking these pacnew and pacsave files yields this:
[manjaro /]# DIFFPROG=meld pacdiff -s
==> pacnew file found for /usr/share/icons/default/index.theme
:: (V)iew, (M)erge, (S)kip, (R)emove pacnew, (O)verwrite with pacnew, (Q)uit: [v/m/s/r/o/q] s
==> pacnew file found for /etc/passwd
==> pacnew file found for /etc/shells
==> pacnew file found for /etc/locale.gen
==> pacnew file found for /etc/default/grub
==> pacnew file found for /etc/pam.d/kde
==> pacnew file found for /etc/mkinitcpio.conf
==> pacnew file found for /etc/pacman.conf
==> pacnew file found for /etc/makepkg.conf.d/rust.conf
==> pacnew file found for /etc/pacman-mirrors.conf
==> pacnew file found for /etc/pam.d/sddm
==> pacnew file found for /etc/sudoers
==> pacsave file found for /etc/texmf/web2c/fmtutil.cnf
:: (V)iew, (M)erge, (S)kip, (R)emove pacsave, (O)verwrite with pacsave, (Q)uit: [v/m/s/r/o/q] s
[manjaro /]#
This somehow looks less severe than from your explanation, but maybe I am comletely wrong, since I still have no clue.
What else should I try?
