Boot error: Failed to start D-Bus System Message Bus
I followed this guide, i.e.
  1. Open the crypted boot volume
  2. Mount it to some helper folder (e.g. /chroot)
  3. Mount the efi partition inside (/chroot/boot/efi)
  4. Add the additional mounts described, i.e.
mount --bind /proc /chroot/proc
mount --bind /dev /chroot/dev
mount --bind /sys /chroot/sys
  1. Chroot with `chroot /chroot’
Then I try to fix grub following this guide, shared by @soundofthunder:
  1. Instead of chroot /chroot' I use manjaro-chroot /chroot /bin/bash`
  2. Re-install grub with
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
  1. Then create the config with:
grub-mkconfig -o /boot/grub/grub.cfg
I end up at boot with message:
ERROR: device 'UUID=3e5e...'  not found. Skipping fsck
mount: /new_root: can't find UUID=3ef5....
ERROR: Failed to mount UUID=3ef5...
You are no being dropped to emergency shell.
I use
cryptsetup -v luksOpen /dev/<dev> <mapper_name>
for opening the luks.
For completeness, I also share my crypttab and fstab:
# /etc/crypttab: mappings for encrypted partitions.
# Each mapped device will be created in /dev/mapper, so your /etc/fstab
# should use the /dev/mapper/<name> paths for encrypted devices.
# See crypttab(5) for the supported syntax.
# NOTE: You need not list your root (/) partition here, but it must be set up
#       beforehand by the initramfs (/etc/mkinitcpio.conf). The same applies
#       to encrypted swap, which should be set up with mkinitcpio-openswap
#       for resume support.
# <name>               <device>                         <password> <options>
#luks-794e3e8d-403e-4dcf-9547-3a021ef2f604 /dev/disk/by-uuid/794e3e8d-403e-4dcf-9547-3a021ef2f604     /crypto_keyfile.bin luks
#luks-7f38ff02-ee3b-42f0-8f2d-ebb9ba67de56 /dev/disk/by-uuid/7f38ff02-ee3b-42f0-8f2d-ebb9ba67de56     /crypto_keyfile.bin luks
#luks-919c4578-3819-48c3-b125-ed4e33881fe7 /dev/disk/by-uuid/919c4578-3819-48c3-b125-ed4e33881fe7     /crypto_keyfile.bin luks
luks-794e3e8d-403e-4dcf-9547-3a021ef2f604 UUID=794e3e8d-403e-4dcf-9547-3a021ef2f604     /crypto_keyfile.bin luks
luks-7f38ff02-ee3b-42f0-8f2d-ebb9ba67de56 UUID=7f38ff02-ee3b-42f0-8f2d-ebb9ba67de56     /crypto_keyfile.bin luks
luks-919c4578-3819-48c3-b125-ed4e33881fe7 UUID=919c4578-3819-48c3-b125-ed4e33881fe7     /crypto_keyfile.bin luks
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=CD10-10B9                            /boot/efi      vfat    umask=0077 0 2
/dev/mapper/luks-794e3e8d-403e-4dcf-9547-3a021ef2f604 /              ext4    defaults,noatime 0 1
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
/swapfile none swap defaults 0 0
/etc/fstab (END)
That guide would be wrong if it told you to do what you said it did.
  • you mount your system root → /
  • you mount any other directories (which might reside on different partitions) to that system root
    not the other way around
you can’t mount /boot and then mount / (root) to it
that won’t work …
you’ll end up with an empty /boot
you mount / and then /boot to it …
and then you don’t need the “manual” process (which you didn’t describe accurately)
you can then simply use
manjaro-chroot /mountpoint
Puuh, I don’t get you point, sorry! So the guide is wrong?
Anyway, this is the requested output:
[manjaro /]# ls -al /dev/mapper/
total 0
drwxr-xr-x  2 root root      80 Nov 24 10:59 .
drwxr-xr-x 22 root root    5020 Nov 24 14:03 ..
lrwxrwxrwx  1 root root       7 Nov 24 10:59 boot_crypt -> ../dm-0
crw-------  1 root root 10, 236 Nov 24 10:53 control
I’ll try with more convenient `manjaro-chroot’ then.
Isn’t that what I’ve described:
I’ll not go analyzing the guide.
My guide is here …
mount /
mount anything important (like: /boot) to it
then chroot into where you mounted the stuff to
I read it differently, that’s why I said what I said.
you only answered half of the question … you gave the result, but not the command which produced the result
Is this what you are asking for?
yes
so: boot_crypt was what you chose for your <mapper_name>
you can choose whatever name you like - it is just a name, so pick one that is telling you something …
Using manjaro-chroot yields slighty different result, after re-installing and configuring grub. I stuck again at boot, this time, the message fits to my /etc/fstab:
ERROR: device 'UUID=luks-794e...'  not found. Skipping fsck
mount: /new_root: can't find UUID=794e....
ERROR: Failed to mount UUID=794e...
The corresponding /etc/fstab entry is:
The corresponding /etc/crypttab entry is:
I’d therefore conclude that the encrypted boot partition is not opened during boot.
I don’t know what to conclude from all that scattered information.
If you want to chroot (manjaro-chroot)
  • you open all the encrypted partitions that are needed - /boot is certainly one of them, /home is not needed …
  • then you mount / (which will then be called /dev/mapper/whatever_you_called_it)
  • then you mount /boot to it (which will then also be called /dev/mapper/whatever_name_you_called_it)
… shorthand: you open / and /boot as well - and mount /boot onto /
Why would you expect that your encrypted /boot would magically be opened and mounted through the chroot procedure?
It’s not.
You have to do that.
I appreciate your help, but we are not on the same page.
We are not?
How so?
Perhaps you can try to bring me and perhaps others up to speed?
Without that: I’d still like to help - but can’t - and will refrain from further comments.
maybe post the commands with the output you used for chroot…
also try chrooting using these commands:
sudo cryptsetup -v luksOpen /dev/nvme0n1p2 cryptDrive
sudo mount /dev/nvme0n1p1 /mnt/boot/efi
sudo mount /dev/mapper/cryptDrive /mnt
sudo manjaro-chroot /mnt
any errors? if not, run:
mkinitcpio -P && update-grub
any errors?
the EFI isn’t encrypted - it is just VFAT
but /boot is - this is where the EFI is mounted to …
and /boot is a separate encrypted partition
The system needs to be assembled correctly for anything to work in chroot
Maybe I misunderstood…
I chroot like this:
cryptsetup -v luksOpen /dev/nvm2 sys_crypt
mkdir /chroot
mount /dev/mapper/sys_crypt /chroot
mount /dev/nvm1 /chroot/boot/efi
@Nachlese : Is this ok?
Then I try to update grub like this:
Then:
  1. I reboot
  2. Stuck during reboot with the error message that my system partition cannot be mounted
@Nachlese: Since I started at some completely different point with this post, do you recommend to create new issues instead of continuing here?
I hope this makes it more clear now.
Thanks!
definitely not o.k.
for multiple reasons -
is just one of them
I don’t know what your current most pressing issue is anymore. :man_shrugging:
It’s probably better to start over.
Ok?
More precisely it is:
mount /dev/nvm0n1p1 /chroot/boot/efi
It is the efi partition and it is not encrypted. I don’t get it…?
But you have a separate (encrypted) /boot partition - or do you not?
You’d have to open this as well, attach it to the / (root) - and then mount the EFI to it.
It is a strange setup that you have - not easily created by the Calamares installer.
Much more custom, implying that you knew what you where doing and why you where doing it when you set this up.
Maybe the confusion stems from my selected name for the unencrypted root partition, which I called boot_crypt above.
I’d better call it sys_crypt. No additional boot partition is available. It’s the encrypted partition + the efi. This should be all.
It doesn’t matter what you name it.
Maybe you know what is what.
I don’t.
To explain, step by step, could we start with:
lsblk -f
after a fresh boot from USB?
From what I saw so far: you have three (3) encrypted partitions.
You should know, which encrypted partition is which
(which is /
which is /boot
which is /whatever).
If you don’t - let’s go from there.
How did we even end up here?
… from a perfectly well and booting system with some “exists in file system” errors
to discussing the intricacies of chroot …?
lsblk -f         ✔
NAME        FSTYPE      FSVER            LABEL            UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
loop0       squashfs    4.0        0   100% /run/miso/sfs/livefs
loop1       squashfs    4.0        0   100% /run/miso/sfs/mhwdfs
loop2       squashfs    4.0        0   100% /run/miso/sfs/desktopfs
loop3       squashfs    4.0        0   100% /run/miso/sfs/rootfs
sda         iso9660     Joliet Extension MANJARO_KDE_2412 2024-11-04-04-24-27-00                     0   100% /run/miso/bootmnt
├─sda1      iso9660     Joliet Extension MANJARO_KDE_2412 2024-11-04-04-24-27-00
└─sda2      vfat        FAT12            MISO_EFI         8BF0-EDB3
nvme0n1
├─nvme0n1p1 vfat        FAT32            NO_LABEL         CD10-10B9
├─nvme0n1p2 crypto_LUKS 1                                 794e3e8d-403e-4dcf-9547-3a021ef2f604
├─nvme0n1p3 crypto_LUKS 1                                 7f38ff02-ee3b-42f0-8f2d-ebb9ba67de56
└─nvme0n1p4 crypto_LUKS 1                                 919c4578-3819-48c3-b125-ed4e33881fe7
nvme0n1p1 => efi partition
nvme0n1p2 => /
nvme0n1p3 => data
nvme0n1p4 => data
You created them - do you know which is which?
Do you know how they need to be stacked together?
seems to be your / (root)
what are the others?
cryptsetup open /dev/nvme0n1p3 what_is_it
mount /dev/mapper/what_is_it /mnt
then look at it’s contents …
ls -al /mnt
afterwards:
umount /mnt
cryptsetup close what_is_it
Serious question - I truly don’t know anymore why we are even here:
Does your system boot or not?
Do you even need to use chroot?
