I am using manjaro xfce
and I tried to connect to my Bluetooth speaker which is of Boat Stone
and my Bluetooth manager is not showing any audio device it showing just Mobiles and Pc’s
I tried many solutions installed other packages which I have found missing by following the solution articles but still no success
My kernel is up-to-date too
Here is my system info a real quick
[ayushk@ayush-inspiron3441 ~]$ inxi -F
Host: ayush-inspiron3441 Kernel: 5.15.12-1-MANJARO x86_64 bits: 64
Desktop: Xfce 4.16.0 Distro: Manjaro Linux
Type: Portable System: Dell product: Inspiron 3441 v: N/A
serial:
Mobo: Dell model: Inspiron 3441 v: A07 serial:
BIOS: Dell v: A07 date: 11/27/2015
Info: quad core model: AMD A6-6310 APU with AMD Radeon R4 Graphics bits: 64
type: MCP cache: L2: 2 MiB
Speed (MHz): avg: 997 min/max: 1000/1800 cores: 1: 998 2: 997 3: 998
4: 998
Device-1: AMD Mullins [Radeon R4/R5 Graphics] driver: radeon v: kernel
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
Display: x11 server: X.Org 1.21.1.2 driver: loaded: ati,radeon
unloaded: modesetting resolution: 1366x768~60Hz
Device-1: AMD Kabini HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD FCH Azalia driver: snd_hda_intel
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.42 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
IF: enp2s0 state: down mac: 20:47:47:53:db:2d
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
driver: ath9k
IF: wlp3s0 state: up mac: b0:c0:90:62:24:ff
Device-1: Qualcomm Atheros AR9462 Bluetooth type: USB driver: btusb
Local Storage: total: 465.76 GiB used: 21.11 GiB (4.5%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
ID-1: / size: 450.29 GiB used: 20.9 GiB (4.6%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 7.2 GiB used: 214.1 MiB (2.9%)
dev: /dev/sda2
System Temperatures: cpu: 54.0 C mobo: 51.0 C gpu: radeon temp: 55.0 C
Fan Speeds (RPM): cpu: 0
Processes: 218 Uptime: 1h 43m Memory: 3.27 GiB used: 1.83 GiB (55.8%)
Shell: Bash inxi: 3.3.11
Any help would be appreciated
Thanks Manjaro Community
serial: <superuser required>
Mobo: Dell model: Inspiron 3441 v: A07 serial: <superuser required>
4: 998
driver: ath9k
dev: /dev/sda2
I have already provided my system info
Have you already tried with kernel 5.10 ?
no I haven’t I am using kernel 5.15.12-1
as I recall my audio Bluetooth devices used to appear in manjaro a long time ago
but now they aren’t even appearing
in both Blueman and Blueberry Bluetooth manager
sure I will give it kernel 5.10 a try
hope it works
but nonetheless I would let you know the outcome after I have completed
thanks for the comment btw
Olli
14 January 2022 13:38
6
please check the forum for several threads, actually pulseaudio and pipewire are active, that doesn’t function. you’re not the first one with that problem, there are several threads describing this problem.
(I have downloaded kernel 10 and restarted my pc But I am still usng kernel 15)
my bluetooth manager is now showing the bluetooth audio devices
and I am able to connect them
but they are getting disconnected after some time automatically
and my wifi is also working very slow sometimes it gets disconnected by itself
can you help me in this too
thanks bro looks like we have solved half of the problem
can you give me the link of those threads ???
It would be very grateful of you
To get into kernel 5.10 you have to stop GRUB with ESC and to select kernel 5.10 manualy
my bluetooth problem have been solved by the way
I installed kernel 15 and removed kernel 10
and restarted my laptop
now my Bluetooth is working without any performance drop and other network instability
