Hey,
I am new manjaro and so far everything works fine, except for one thing. My Bluetooth Mouse just stops working after a while. I normally use KDEBluetooth but I also tried it with blueman and bluetoothctl with the same result. When it stops working it is still shown as connected device and it is not possible to disconnect it. When it stops working I also can’t deactivate bluetooth, the only way to get it work again is to restart the system.
Here some outputs:
[olli@olli-ideapad ~]$ sudo systemctl status bluetooth.service
* bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2021-08-29 10:06:28 CEST; 1 day 7h ago
Docs: man:bluetoothd(8)
Main PID: 921 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18400)
Memory: 3.0M
CPU: 17.818s
CGroup: /system.slice/bluetooth.service
`-921 /usr/lib/bluetooth/bluetoothd
Aug 30 17:11:32 olli-ideapad bluetoothd[921]: Endpoint unregistered: sender=:1.42 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Aug 30 17:11:32 olli-ideapad bluetoothd[921]: Endpoint unregistered: sender=:1.42 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Aug 30 17:11:33 olli-ideapad bluetoothd[921]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSink/sbc
Aug 30 17:11:33 olli-ideapad bluetoothd[921]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/sbc
Aug 30 17:11:33 olli-ideapad bluetoothd[921]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Aug 30 17:11:33 olli-ideapad bluetoothd[921]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Aug 30 17:11:33 olli-ideapad bluetoothd[921]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Aug 30 17:11:33 olli-ideapad bluetoothd[921]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Aug 30 17:11:33 olli-ideapad bluetoothd[921]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Aug 30 17:11:33 olli-ideapad bluetoothd[921]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/sbc_xq_552
[olli@olli-ideapad ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0bef2ef0-ffa0-46be-8761-26920982d8fe rw quiet apparmor=1
security=apparmor resume=UUID=17d68ab8-e748-41bc-8f81-1c0912101501
udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 82LM v: IdeaPad 5 14ALC05
serial: <filter> Chassis: type: 10 v: IdeaPad 5 14ALC05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI: LENOVO
v: G5CN17WW(V1.05) date: 04/22/2021
ID-1: BAT1 charge: 52.7 Wh (90.5%) condition: 58.2/56.5 Wh (102.9%)
volts: 12.5 min: 11.5
model: 0x53 0x4D 0x50 0x00 0x32 0x30 0x 0x4C 0x31 0x39 0x4D 0x33 0x50 0x5650
type: Li-ion serial: <filter> status: Discharging cycles: 9
RAM: total: 14.99 GiB used: 6.77 GiB (45.2%)
Info: 8-Core model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 68 (104) stepping: 1
microcode: 8608103 cache: L2: 4 MiB bogomips: 57518
Speed: 1897 MHz min/max: 1400/1800 MHz boost: enabled Core speeds (MHz):
1: 1897 2: 1749 3: 1397 4: 1397 5: 1397 6: 1396 7: 1397 8: 1397 9: 1508
10: 1761 11: 1450 12: 1609 13: 1460 14: 1514 15: 1397 16: 1397
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:164c class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 04f2:b725 class-ID: fe01 serial: <filter>
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.12-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 04:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Realtek vendor: Lenovo driver: rtw89_pci v: N/A modules: rtw89pci
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8852 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Report: hciconfig ID: hci0 rfk-id: 5 state: up address: <filter>
Info: acl-mtu: 1021:6 sco-mtu: 255:12 link-policy: rswitch hold sniff park
link-mode: slave accept
Local Storage: total: 476.94 GiB used: 63.27 GiB (13.3%)
model: PC SN730 SDBPNTY-512G-1101 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11170001 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 460.08 GiB size: 451.79 GiB (98.20%)
used: 63.27 GiB (14.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 0bef2ef0-ffa0-46be-8761-26920982d8fe
label: NO_LABEL uuid: FF70-3EB2
ID-1: swap-1 type: partition size: 16.56 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 17d68ab8-e748-41bc-8f81-1c0912101501
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-3:2 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b725
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c4d class-ID: 0000
Device-2: 3-4:3 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:4852
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 55.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
Processes: 355 Uptime: 1d 7h 30m wakeups: 3161 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1315 lib: 381
flatpak: 0 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.06
[olli@olli-ideapad ~]$ bluetoothctl show
Controller 74:4C:A1:CB:A6:DA (public)
Alias: olli-ideapad
Class: 0x007c010c
Powered: yes
Discoverable: no
DiscoverableTimeout: 0x000000b4
Pairable: yes
UUID: Message Notification Se.. (00001133-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: OBEX Object Push (00001105-0000-1000-8000-00805f9b34fb)
UUID: Message Access Server (00001132-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
UUID: IrMC Sync (00001104-0000-1000-8000-00805f9b34fb)
UUID: Vendor specific (00005005-0000-1000-8000-0002ee000001)
UUID: Headset (00001108-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
UUID: Phonebook Access Server (0000112f-0000-1000-8000-00805f9b34fb)
UUID: Device Information (0000180a-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb)
UUID: Handsfree Audio Gateway (0000111f-0000-1000-8000-00805f9b34fb)
UUID: Audio Source (0000110a-0000-1000-8000-00805f9b34fb)
UUID: OBEX File Transfer (00001106-0000-1000-8000-00805f9b34fb)
Modalias: usb:v1D6Bp0246d053C
Discovering: no
Roles: central
Roles: peripheral
Roles: central-peripheral
Advertising Features:
ActiveInstances: 0x00 (0)
SupportedInstances: 0x0a (10)
SupportedIncludes: tx-power
SupportedIncludes: appearance
SupportedIncludes: local-name
SupportedSecondaryChannels: 1M
SupportedSecondaryChannels: 2M
SupportedSecondaryChannels: Coded
[olli@olli-ideapad ~]$ rfkill list
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
5: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Fabby
31 August 2021 21:34
2
Does this problem also arise:
on Kernel 5.10 LTS?
in a newly created user? (E.G. ollix4)
Riquez
6 September 2021 01:54
4
I have the same issue as @ollix3 , also with Lenovo laptop, realtek bt.
I could not get BT working on 5.10 so i updated to 5.13 & then BT worked fine. I have been using BT mouse without an issue for about a week, no disconnects.
However last night some more updates dropped in & since then BT mouse stops working at random interval. Cannot be re-connected until restart.
I tried turning BT off/on in settings - it turns OFF but wont turn back on, however systemctl says its running.
edit: oh, & now I just had the trackpad randomly stop working instead, but the bt mouse was ok. after reboot both seem fine … for now. Seems oddly coincidental pointer related issue.
I had the same problem several months ago.
Link to thread
But I could not find out, what to do.
It happened - and still happens - with every kernel version I have tried since.
I have two mice with the same problem on this manjaro machine.
When I boot to windows or use the mouse elsewhere, there is no problem.
In the end I got a wired mouse and I still love the machine with manjaro
Viele Grüße
Axel
Riquez
8 September 2021 00:02
7
It just happened & I was able to isolate the event in my log. I launched terminal seconds after.
Before 8:53 some rtkit processing msgs, then 4 mins later (8:57) Bluetooth stops working.
9月 08 08:57:57 Sulaco systemd[683]: Started Application launched by gnome-shell.
9月 08 08:57:46 Sulaco upowerd[846]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4
9月 08 08:57:46 Sulaco upowerd[846]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-3
9月 08 08:57:46 Sulaco kernel: usb 3-4: reset full-speed USB device number 3 using xhci_hcd
9月 08 08:57:45 Sulaco kernel: usb 3-3: reset full-speed USB device number 2 using xhci_hcd
9月 08 08:53:54 Sulaco rtkit-daemon[858]: Supervising 8 threads of 4 processes of 1 users.
9月 08 08:50:34 Sulaco rtkit-daemon[858]: Supervising 8 threads of 4 processes of 1 users.
9月 08 08:48:54 Sulaco rtkit-daemon[858]: Supervising 8 threads of 4 processes of 1 users.
9月 08 08:45:22 Sulaco rtkit-daemon[858]: Supervising 8 threads of 4 processes of 1 users.
9月 08 08:44:34 Sulaco rtkit-daemon[858]: Supervising 8 threads of 4 processes of 1 users.
9月 08 08:43:54 Sulaco rtkit-daemon[858]: Supervising 8 threads of 4 processes of 1 users.
9月 08 08:43:34 Sulaco org.fcitx.Fcitx5.desktop[1090]: I2021-09-08 08:43:34.981578 instance.cpp:1235] End au>
9月 08 08:43:34 Sulaco org.fcitx.Fcitx5.desktop[1090]: I2021-09-08 08:43:34.976048 instance.cpp:1233] Runnin>
9月 08 08:42:40 Sulaco rtkit-daemon[858]: Supervising 8 threads of 4 processes of 1 users.
9月 08 08:41:13 Sulaco wpa_supplicant[635]: wlp4s0: WPA: Group rekeying completed with 34:97:f6:61:20:80 [GT>
9月 08 08:38:54 Sulaco rtkit-daemon[858]: Supervising 8 threads of 4 processes of 1 users.
Other than BT mouse I do not have any other devices connected to laptop.
I had 2 day without the issue, so it seems there maybe days without, or it may happen several times a day.
Fabby
8 September 2021 11:54
8
That looks like your Bluetooth adapter was kicked off the Universal Serial Bus.
Was the system overheating at the time?
Do you run an overclocked system?
Which exact command did you run to get that output?
Riquez
8 September 2021 13:35
9
I do live on a pacific island, its pretty hot & humid, but air-con is on. It shouldnt be too hot, but its possible. I have not noticed the laptop getting hot at all since owning it.
I don’t run overclocked, its a recently new Lenovo Thinkbook unmodified.
Ive used the bluetooth with Ubuntu on another partition & did not have this issue, (but didnt test extensively, only a couple days use)
The output is from terminal journalctl -r which i ran about 15 seconds after the mouse stopped working.
Fabby
8 September 2021 14:33
10
If I get this sorted, I’m flying in with a bunch of food and I’m staying at your place until said food runs out…
Would you be prepared to remove the current Bluetooth adapter hardware and change it to an Intel one?
If not, can you provide an inxi --admin --verbosity=7 --filter --no-host --width so I can look for other options?
Riquez
9 September 2021 00:43
11
Perfect! We are desperate for good bread & wine. My wife is the only cheesemaker on island, so we got that part sorted.
Probably not at the moment. I’ll just make do with trackpad.
The model is specced as “Intel® Wi-Fi 6 AX200” but in reality the wifi & bt are both realtek, it seems to be luck of the draw from what other owners report.
of course!
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0b90181d-1eb7-44d7-bc37-80c878000293 rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 iommu=soft
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: LENOVO product: 20VF v: ThinkBook 14 G2 ARE
serial: <filter> Chassis: type: 10 v: ThinkBook 14 G2 ARE serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter>
UEFI: LENOVO v: FACN28WW(V1.11) date: 05/18/2021
ID-1: BAT1 charge: 41.1 Wh (94.3%) condition: 43.6/45.0 Wh (96.8%)
volts: 12.7 min: 11.5
model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x 0x4C 0x31 0x39 0x43 0x33 0x50 0x4500
type: Li-ion serial: <filter> status: Discharging cycles: 43
RAM: total: 19.41 GiB used: 2.1 GiB (10.8%)
Info: 6-Core model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64
type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 cache: L2: 3 MiB bogomips: 28453
Speed: 1397 MHz min/max: 1400/2375 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 13d3:56ff class-ID: 0e02
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa display-ID: 0
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.13-1-MANJARO LLVM 12.0.1)
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 05:00.1
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.34 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Device-2: Realtek vendor: Lenovo driver: rtw89_pci v: N/A modules: rtw89pci
port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 704.24 GiB used: 253.27 GiB (36.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ256HAJD-000L2
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: BL2QFXV7 temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 032 scheme: MBR
ID-1: / raw-size: 118.99 GiB size: 116.56 GiB (97.96%)
used: 41.56 GiB (35.7%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 0b90181d-1eb7-44d7-bc37-80c878000293
used: 4.6 MiB (0.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: EB07-8818
ID-3: /mnt/SSD500 raw-size: 465.76 GiB size: 457.45 GiB (98.22%)
used: 211.7 GiB (46.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: SSD500
uuid: a1936d96-6ea6-4cb5-b62d-618a8ec8a2a8
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 118.99 GiB fs: ext4 label: N/A
uuid: 0f80e24b-1488-4fd7-b5a4-c563182bf4f7
Device-1: 1-3:2 info: IMC Networks Integrated Camera type: Video
chip-ID: 04f3:0c4b class-ID: 0000
System Temperatures: cpu: 37.5 C mobo: N/A gpu: amdgpu temp: 36.0 C
Processes: 253 Uptime: 21m wakeups: 211 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1535 lib: 468 flatpak: 0 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Fabby
9 September 2021 08:44
12
Riquez:
Desktop: GNOME 40.4
And as you’re on Gnome and not KDE, I have no further ideas, except reclassifying your question to the Gnome category and adding a few tags…
Riquez
9 September 2021 14:44
13
It appears this issue only occurs when on battery power.
When the charging cable is connected I also see those reset full-speed USB device errors, but the mouse is not disconnected & BT still works. Only when the power cable is unplugged, BT will fail after some interval.
Yes I am on Gnome, but the OP is KDE describing the same/similar issue. I didnt mean to hijack it, I was hoping he would reply.
Yes, this was one thing we also found out in the thread that I liked to above…
Still don’t know if this is helpful, though…
Fabby
10 September 2021 10:49
15
Execute:
pamac install tlpgui
tlpgui
pamac install tlpui
tlpui
Turn off power saving for Bluetooth and the USB bus.
This is what I get:
~ >>> pamac install tlpgui
Fehler: Ziel nicht gefunden: tlpgui
My machine is still running Gnome. Is that something to consider?
Viele Grüße
Axel
Fabby
10 September 2021 15:26
17
I’m an idiot!
pamac install tlpui
tlpui
Entschuldigung!!!
No, sadly it didn’t
So I’m switching back to my wired mouse now…
Would be nice to have, but really doesen’t bother me much.
Thanks you!
Viele Grüße
Axel
ollix3
13 September 2021 15:58
20
For me it worked so far, i don’t use the laptop a lot so I’m not entirely sure if it’s fixed for good, but since I applied your fix the problem didn’t happen again.
I’ll try it a little more and mark your answer as the solution when I’m sure the problem is gone.
Either way thanks a lot for helping @Fabby
