Okay, I just tried that and still the same thing after a reboot then sleep.
Yeah, I tried with the reboot earlier
Fine, brute force is the option
Shall you enter sudo nano /lib/systemd/system-sleep/bt
, then paste the following:
#!/bin/sh
case $1 in
post)
modprobe -r btusb
sleep 1
service bluetooth restart
sleep 1
modprobe btusb
esac
After that, press ctrl + s to save, then ctrl + x to exit.
Then execute sudo chmod +x /lib/systemd/system-sleep/bt
to make it executable…
lets hope it works!!
Okay I created the bt file saved the script, made it executable will restart and sleep just now and see what happens
Same thing sadly
Okay, let’s try with a different script…
Then replace the previous script with this one
#!/bin/sh
case $1 in
post)
sleep 5
rfkill block `rfkill list | grep hci | cut -d: -f1`
sleep 1
rfkill unblock `rfkill list | grep hci | cut -d: -f1`
esac
Adapter still MIA afer this
Let’s see what happens if you downgrade the kernel to 5.8, shall we?
May install kernel 5.8 then remove 5.9, please!
I’ll give it a shot!
Still the same issue on 5.18.16-2
A guess - Maybe want to make sure those things are executable?
Hm, I could go with chmod 777, but this may become a flaw…
I will try to simulate his hardware, see what can be done…
Oh, let’s summon my friend, see if she has any suggestion …
I think we have to re-chmod the bt file.
Proceed once again with sudo chmod +x /lib/systemd/system-sleep/bt
The issue still persists, I tried with the second script.
Hellaw !
Could you try these, pleasie?
sudo pacman -Sy bluez bluez-utils
sudo pacman -Sy blueman
sudo systemctl start bluetooth
Wish it works!
Heloha
Still no adapters
When I open blueman it asks to enable bluetooth but when I do nothing happens
Oh oh…
May I ask what gives you inxi -J
, pleasie?
Of course!
[connor@StarReach ~]$ inxi -J
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
Hub: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 3-4:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID rev: 2.0
Device-2: 3-5:3 info: Elan Micro ELAN:Fingerprint type: <vendor specific> rev: 2.0
Device-3: 3-6:4 info: Lite-On Integrated Camera type: Video rev: 2.0
Hub: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1
P.S I’m using my adapter for this but usually it would be in another PC
These are potential partial-upgrades … please omit the y
or add a u
(actually 2 y
s may be necessary if pamac-mirrorlist.timer
is running)
[ex - -S
, -Syu
, -Syyu
… never -Sy
[sorry to keep butting in ]
Tried with the suggested -Syu still no luck
Ouu, fancy!
But the cozy little Bluetooth adapter is not showing!
Must not be loaded properly after a little nap…
Oh! May try the dkms modules!
We will type these little commands in the terminal😌:
sudo pacman -S dkms linux-headers
Would love the result of sudo lsusb | grep Bluetooth
, please!
Wish and hope !
