Wow, you can tell I am great with Linux
[connor@StarReach ~]$ journalctl --system --boot=0 --since "2020-11-01 20:52:00" --until "2020-11-01 20:53:00"
-- Logs begin at Mon 2020-10-26 12:35:25 GMT, end at Sun 2020-11-01 20:53:04 GMT. --
Nov 01 20:52:06 StarReach sudo[2163]: pam_unix(sudo:session): session closed for user root
Nov 01 20:52:06 StarReach kernel: audit: type=1106 audit(1604263926.871:79): pid=2163 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/>
Nov 01 20:52:06 StarReach kernel: audit: type=1104 audit(1604263926.871:80): pid=2163 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/>
Nov 01 20:52:06 StarReach audit[2163]: USER_END pid=2163 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Nov 01 20:52:06 StarReach audit[2163]: CRED_DISP pid=2163 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Nov 01 20:52:37 StarReach ModemManager[627]: <info> [sleep-monitor] system is about to suspend
Nov 01 20:52:37 StarReach NetworkManager[605]: <info> [1604263957.7541] manager: sleep: sleep requested (sleeping: no enabled: yes)
Nov 01 20:52:37 StarReach NetworkManager[605]: <info> [1604263957.7542] device (enp1s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 01 20:52:37 StarReach NetworkManager[605]: <info> [1604263957.7626] device (p2p-dev-wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 01 20:52:37 StarReach NetworkManager[605]: <info> [1604263957.7628] manager: NetworkManager state is now ASLEEP
Nov 01 20:52:37 StarReach NetworkManager[605]: <info> [1604263957.7629] device (wlp0s20f3): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Nov 01 20:52:37 StarReach dbus-daemon[604]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=605 comm="/usr/bin/NetworkManag>
Nov 01 20:52:37 StarReach systemd[1]: Starting Network Manager Script Dispatcher Service...
Nov 01 20:52:37 StarReach dbus-daemon[604]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 01 20:52:37 StarReach systemd[1]: Started Network Manager Script Dispatcher Service.
Nov 01 20:52:37 StarReach audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:37 StarReach kernel: audit: type=1130 audit(1604263957.767:81): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res>
Nov 01 20:52:37 StarReach kernel: wlp0s20f3: deauthenticating from ec:f4:51:64:d6:c8 by local choice (Reason: 3=DEAUTH_LEAVING)
Nov 01 20:52:37 StarReach wpa_supplicant[798]: wlp0s20f3: CTRL-EVENT-DISCONNECTED bssid=ec:f4:51:64:d6:c8 reason=3 locally_generated=1
Nov 01 20:52:37 StarReach wpa_supplicant[798]: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=0 noise=9999 txrate=0
Nov 01 20:52:37 StarReach NetworkManager[605]: <info> [1604263957.7966] device (wlp0s20f3): supplicant interface state: completed -> disconnected
Nov 01 20:52:37 StarReach NetworkManager[605]: <info> [1604263957.7968] device (wlp0s20f3): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Nov 01 20:52:37 StarReach avahi-daemon[602]: Withdrawing address record for 2a00:23c8:303:c500:d449:2161:800e:1c48 on wlp0s20f3.
Nov 01 20:52:37 StarReach avahi-daemon[602]: Withdrawing address record for fdaa:bbcc:ddee:0:4637:3cd8:ae54:9d1b on wlp0s20f3.
Nov 01 20:52:37 StarReach avahi-daemon[602]: Leaving mDNS multicast group on interface wlp0s20f3.IPv6 with address fdaa:bbcc:ddee:0:4637:3cd8:ae54:9d1b.
Nov 01 20:52:37 StarReach avahi-daemon[602]: Joining mDNS multicast group on interface wlp0s20f3.IPv6 with address fe80::b8da:eb76:f10e:1579.
Nov 01 20:52:37 StarReach avahi-daemon[602]: Registering new address record for fe80::b8da:eb76:f10e:1579 on wlp0s20f3.*.
Nov 01 20:52:37 StarReach avahi-daemon[602]: Withdrawing address record for fe80::b8da:eb76:f10e:1579 on wlp0s20f3.
Nov 01 20:52:37 StarReach avahi-daemon[602]: Leaving mDNS multicast group on interface wlp0s20f3.IPv6 with address fe80::b8da:eb76:f10e:1579.
Nov 01 20:52:37 StarReach avahi-daemon[602]: Interface wlp0s20f3.IPv6 no longer relevant for mDNS.
Nov 01 20:52:37 StarReach NetworkManager[605]: <info> [1604263957.8087] dhcp4 (wlp0s20f3): canceled DHCP transaction
Nov 01 20:52:37 StarReach NetworkManager[605]: <info> [1604263957.8087] dhcp4 (wlp0s20f3): state changed bound -> done
Nov 01 20:52:37 StarReach NetworkManager[605]: <info> [1604263957.8089] dhcp6 (wlp0s20f3): canceled DHCP transaction
Nov 01 20:52:37 StarReach NetworkManager[605]: <info> [1604263957.8090] dhcp6 (wlp0s20f3): state changed bound -> done
Nov 01 20:52:37 StarReach avahi-daemon[602]: Interface wlp0s20f3.IPv4 no longer relevant for mDNS.
Nov 01 20:52:37 StarReach avahi-daemon[602]: Leaving mDNS multicast group on interface wlp0s20f3.IPv4 with address 192.168.1.240.
Nov 01 20:52:37 StarReach avahi-daemon[602]: Withdrawing address record for 192.168.1.240 on wlp0s20f3.
Nov 01 20:52:37 StarReach NetworkManager[605]: <info> [1604263957.8238] device (wlp0s20f3): set-hw-addr: set MAC address to BE:78:02:65:39:6C (scanning)
Nov 01 20:52:38 StarReach avahi-daemon[602]: Joining mDNS multicast group on interface wlp0s20f3.IPv4 with address 192.168.1.240.
Nov 01 20:52:38 StarReach avahi-daemon[602]: New relevant interface wlp0s20f3.IPv4 for mDNS.
Nov 01 20:52:38 StarReach avahi-daemon[602]: Registering new address record for 192.168.1.240 on wlp0s20f3.IPv4.
Nov 01 20:52:38 StarReach avahi-daemon[602]: Withdrawing address record for 192.168.1.240 on wlp0s20f3.
Nov 01 20:52:38 StarReach avahi-daemon[602]: Leaving mDNS multicast group on interface wlp0s20f3.IPv4 with address 192.168.1.240.
Nov 01 20:52:38 StarReach avahi-daemon[602]: Interface wlp0s20f3.IPv4 no longer relevant for mDNS.
Nov 01 20:52:38 StarReach NetworkManager[605]: <info> [1604263958.0039] device (wlp0s20f3): supplicant interface state: disconnected -> interface_disabled
Nov 01 20:52:38 StarReach NetworkManager[605]: <info> [1604263958.0040] device (wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 01 20:52:38 StarReach NetworkManager[605]: <info> [1604263958.0183] device (wlp0s20f3): set-hw-addr: reset MAC address to 94:E7:0B:C9:8D:76 (unmanage)
Nov 01 20:52:38 StarReach systemd[1]: Reached target Sleep.
Nov 01 20:52:38 StarReach systemd[1]: Starting Suspend...
Nov 01 20:52:38 StarReach wpa_supplicant[798]: wlp0s20f3: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=WORLD
Nov 01 20:52:38 StarReach systemd-sleep[4413]: Suspending system...
Nov 01 20:52:38 StarReach kernel: PM: suspend entry (deep)
Nov 01 20:52:38 StarReach kernel: Filesystems sync: 0.004 seconds
Nov 01 20:52:45 StarReach kernel: Freezing user space processes ... (elapsed 0.001 seconds) done.
Nov 01 20:52:45 StarReach kernel: OOM killer disabled.
lines 1-56...skipping...
Nov 01 20:52:06 StarReach kernel: audit: type=1106 audit(1604263926.871:79): pid=2163 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Nov 01 20:52:06 StarReach kernel: audit: type=1104 audit(1604263926.871:80): pid=2163 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Nov 01 20:52:37 StarReach dbus-daemon[604]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=605 comm="/usr/bin/NetworkManager --no-daemon ")
Nov 01 20:52:37 StarReach kernel: audit: type=1130 audit(1604263957.767:81): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:45 StarReach kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Nov 01 20:52:45 StarReach kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Nov 01 20:52:45 StarReach kernel: ACPI: EC: interrupt blocked
Nov 01 20:52:45 StarReach kernel: ACPI: Preparing to enter system sleep state S3
Nov 01 20:52:45 StarReach kernel: ACPI: EC: event blocked
Nov 01 20:52:45 StarReach kernel: ACPI: EC: EC stopped
Nov 01 20:52:45 StarReach kernel: PM: Saving platform NVS memory
lines 1-63...skipping...
Nov 01 20:52:45 StarReach kernel: Disabling non-boot CPUs ...
Nov 01 20:52:45 StarReach kernel: IRQ 141: no longer affine to CPU1
Nov 01 20:52:45 StarReach kernel: smpboot: CPU 1 is now offline
Nov 01 20:52:45 StarReach kernel: IRQ 142: no longer affine to CPU2
Nov 01 20:52:45 StarReach kernel: smpboot: CPU 2 is now offline
lines 1-68...skipping...
Nov 01 20:52:45 StarReach kernel: IRQ 143: no longer affine to CPU3
Nov 01 20:52:45 StarReach kernel: smpboot: CPU 3 is now offline
Nov 01 20:52:45 StarReach kernel: IRQ 144: no longer affine to CPU4
Nov 01 20:52:45 StarReach kernel: smpboot: CPU 4 is now offline
Nov 01 20:52:45 StarReach kernel: IRQ 145: no longer affine to CPU5
Nov 01 20:52:45 StarReach kernel: smpboot: CPU 5 is now offline
Nov 01 20:52:45 StarReach kernel: IRQ 146: no longer affine to CPU6
Nov 01 20:52:45 StarReach kernel: smpboot: CPU 6 is now offline
Nov 01 20:52:45 StarReach kernel: IRQ 147: no longer affine to CPU7
Nov 01 20:52:45 StarReach kernel: smpboot: CPU 7 is now offline
Nov 01 20:52:45 StarReach kernel: ACPI: Low-level resume complete
lines 1-79...skipping...
Nov 01 20:52:06 StarReach kernel: audit: type=1106 audit(1604263926.871:79): pid=2163 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" e>
Nov 01 20:52:06 StarReach kernel: audit: type=1104 audit(1604263926.871:80): pid=2163 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" e>
Nov 01 20:52:06 StarReach audit[2163]: USER_END pid=2163 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=?>
Nov 01 20:52:45 StarReach kernel: ACPI: EC: EC started
Nov 01 20:52:45 StarReach kernel: PM: Restoring platform NVS memory
Nov 01 20:52:45 StarReach kernel: smpboot: Scheduler frequency invariance went wobbly, disabling!
Nov 01 20:52:45 StarReach kernel: Enabling non-boot CPUs ...
Nov 01 20:52:45 StarReach kernel: x86: Booting SMP configuration:
Nov 01 20:52:45 StarReach kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Nov 01 20:52:45 StarReach kernel: CPU1 is up
Nov 01 20:52:45 StarReach kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
Nov 01 20:52:45 StarReach kernel: CPU2 is up
Nov 01 20:52:45 StarReach kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
Nov 01 20:52:45 StarReach kernel: CPU3 is up
Nov 01 20:52:45 StarReach kernel: smpboot: Booting Node 0 Processor 4 APIC 0x1
Nov 01 20:52:45 StarReach kernel: CPU4 is up
Nov 01 20:52:45 StarReach kernel: smpboot: Booting Node 0 Processor 5 APIC 0x3
Nov 01 20:52:45 StarReach kernel: CPU5 is up
Nov 01 20:52:45 StarReach kernel: smpboot: Booting Node 0 Processor 6 APIC 0x5
Nov 01 20:52:45 StarReach kernel: CPU6 is up
Nov 01 20:52:45 StarReach kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
Nov 01 20:52:45 StarReach kernel: CPU7 is up
Nov 01 20:52:45 StarReach kernel: ACPI: Waking up from system sleep state S3
Nov 01 20:52:45 StarReach kernel: ACPI: EC: interrupt unblocked
Nov 01 20:52:45 StarReach kernel: ACPI: EC: event unblocked
Nov 01 20:52:45 StarReach kernel: usb usb1: root hub lost power or was reset
Nov 01 20:52:45 StarReach kernel: usb usb2: root hub lost power or was reset
Nov 01 20:52:45 StarReach kernel: nvme nvme0: Shutdown timeout set to 8 seconds
Nov 01 20:52:45 StarReach kernel: nvme nvme0: 8/0/0 default/read/poll queues
Nov 01 20:52:45 StarReach kernel: usb 3-6: reset high-speed USB device number 3 using xhci_hcd
Nov 01 20:52:45 StarReach kernel: ata2: SATA link down (SStatus 4 SControl 300)
Nov 01 20:52:45 StarReach kernel: acpi LNXPOWER:05: Turning OFF
Nov 01 20:52:45 StarReach kernel: acpi LNXPOWER:04: Turning OFF
Nov 01 20:52:45 StarReach kernel: acpi LNXPOWER:03: Turning OFF
Nov 01 20:52:45 StarReach kernel: OOM killer enabled.
Nov 01 20:52:45 StarReach kernel: Restarting tasks ... done.
Nov 01 20:52:45 StarReach kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Nov 01 20:52:45 StarReach wpa_supplicant[798]: wlp0s20f3: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=WORLD
Nov 01 20:52:46 StarReach kernel: usb 3-10: USB disconnect, device number 4
Nov 01 20:52:46 StarReach wpa_supplicant[798]: nl80211: deinit ifname=wlp0s20f3 disabled_11b_rates=0
Nov 01 20:52:48 StarReach systemd-sleep[4413]: System resumed.
Nov 01 20:52:48 StarReach bluetoothd[678]: Endpoint unregistered: sender=:1.205 path=/MediaEndpoint/A2DPSink/sbc
Nov 01 20:52:48 StarReach bluetoothd[678]: Endpoint unregistered: sender=:1.205 path=/MediaEndpoint/A2DPSource/sbc
Nov 01 20:52:48 StarReach kernel: Bluetooth: hci0: Timed out waiting for suspend events
Nov 01 20:52:48 StarReach kernel: Bluetooth: hci0: Suspend timeout bit: 5
Nov 01 20:52:48 StarReach kernel: Bluetooth: hci0: Suspend notifier action (4) failed: -110
Nov 01 20:52:48 StarReach kernel: PM: suspend exit
Nov 01 20:52:48 StarReach systemd[1]: Starting Load/Save RF Kill Switch Status...
Nov 01 20:52:48 StarReach systemd[1]: Stopped target Bluetooth.
Nov 01 20:52:48 StarReach audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:48 StarReach systemd[1]: Started Load/Save RF Kill Switch Status.
Nov 01 20:52:48 StarReach kernel: audit: type=1130 audit(1604263968.020:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:48 StarReach systemd[1]: systemd-suspend.service: Succeeded.
Nov 01 20:52:48 StarReach systemd[1]: Finished Suspend.
Nov 01 20:52:48 StarReach audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:48 StarReach audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:48 StarReach systemd[1]: Stopped target Sleep.
Nov 01 20:52:48 StarReach systemd[1]: Reached target Suspend.
Nov 01 20:52:48 StarReach systemd[1]: Stopped target Suspend.
Nov 01 20:52:48 StarReach systemd-logind[607]: Operation 'sleep' finished.
Nov 01 20:52:48 StarReach NetworkManager[605]: <info> [1604263968.2105] manager: sleep: wake requested (sleeping: yes enabled: yes)
Nov 01 20:52:48 StarReach ModemManager[627]: <info> [sleep-monitor] system is resuming
Nov 01 20:52:48 StarReach kernel: audit: type=1130 audit(1604263968.206:83): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:48 StarReach kernel: audit: type=1131 audit(1604263968.206:84): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:48 StarReach NetworkManager[605]: <info> [1604263968.2106] device (enp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Nov 01 20:52:48 StarReach kernel: Generic FE-GE Realtek PHY r8169-100:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-100:00, irq=IGNORE)
Nov 01 20:52:48 StarReach NetworkManager[605]: <info> [1604263968.4281] device (wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Nov 01 20:52:48 StarReach kernel: r8169 0000:01:00.0 enp1s0: Link is Down
Nov 01 20:52:48 StarReach NetworkManager[605]: <info> [1604263968.4302] device (p2p-dev-wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Nov 01 20:52:48 StarReach NetworkManager[605]: <info> [1604263968.4308] manager: NetworkManager state is now DISCONNECTED
Nov 01 20:52:48 StarReach wpa_supplicant[798]: nl80211: kernel reports: Attribute failed policy validation
Nov 01 20:52:48 StarReach wpa_supplicant[798]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Nov 01 20:52:48 StarReach wpa_supplicant[798]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Nov 01 20:52:48 StarReach wpa_supplicant[798]: P2P: Failed to enable P2P Device interface
Nov 01 20:52:48 StarReach wpa_supplicant[798]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Interface.P2PDevice dbus_property=P2PDeviceConfig getter failed
Nov 01 20:52:48 StarReach NetworkManager[605]: <info> [1604263968.4961] device (wlp0s20f3): supplicant interface state: internal-starting -> disconnected
Nov 01 20:52:48 StarReach NetworkManager[605]: <info> [1604263968.4962] device (p2p-dev-wlp0s20f3): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Nov 01 20:52:48 StarReach NetworkManager[605]: <info> [1604263968.4971] Wi-Fi P2P device controlled by interface wlp0s20f3 created
Nov 01 20:52:48 StarReach NetworkManager[605]: <info> [1604263968.4974] manager: (p2p-dev-wlp0s20f3): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/5)
Nov 01 20:52:48 StarReach NetworkManager[605]: <info> [1604263968.4979] device (p2p-dev-wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 01 20:52:48 StarReach NetworkManager[605]: <info> [1604263968.4990] device (wlp0s20f3): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 01 20:52:48 StarReach NetworkManager[605]: <info> [1604263968.5001] device (p2p-dev-wlp0s20f3): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 01 20:52:48 StarReach NetworkManager[605]: <warn> [1604263968.5031] sup-iface[32bbe84add43f963,1,wlp0s20f3]: call-p2p-cancel: failed with P2P cancel failed
Nov 01 20:52:50 StarReach ModemManager[627]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
Nov 01 20:52:50 StarReach ModemManager[627]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1d.0/0000:01:00.0': not supported by any plugin
Nov 01 20:52:51 StarReach wpa_supplicant[798]: wlp0s20f3: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=GB
Nov 01 20:52:52 StarReach systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Nov 01 20:52:52 StarReach audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:52 StarReach kernel: audit: type=1131 audit(1604263972.280:85): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:53 StarReach systemd[1]: systemd-rfkill.service: Succeeded.
Nov 01 20:52:53 StarReach audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:53 StarReach kernel: audit: type=1131 audit(1604263973.023:86): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5882] policy: auto-activating connection 'BTWholeHome-GZS' (313ed120-b9f3-4dd9-bd03-e34f5c315772)
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5889] device (wlp0s20f3): Activation: starting connection 'BTWholeHome-GZS' (313ed120-b9f3-4dd9-bd03-e34f5c315772)
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5890] device (wlp0s20f3): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5892] manager: NetworkManager state is now CONNECTING
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5894] device (wlp0s20f3): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5895] device (wlp0s20f3): Activation: (wifi) access point 'BTWholeHome-GZS' has security, but secrets are required.
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5895] device (wlp0s20f3): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5979] device (wlp0s20f3): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5981] device (wlp0s20f3): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5983] device (wlp0s20f3): Activation: (wifi) connection 'BTWholeHome-GZS' has security, and secrets exist. No new secrets needed.
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5983] Config: added 'ssid' value 'BTWholeHome-GZS'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5984] Config: added 'scan_ssid' value '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5984] Config: added 'bgscan' value 'simple:30:-70:86400'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5984] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5984] Config: added 'auth_alg' value 'OPEN'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.5984] Config: added 'psk' value '<hidden>'
Nov 01 20:52:53 StarReach wpa_supplicant[798]: wlp0s20f3: SME: Trying to authenticate with ec:f4:51:64:d6:c8 (SSID='BTWholeHome-GZS' freq=5220 MHz)
Nov 01 20:52:53 StarReach kernel: wlp0s20f3: authenticate with ec:f4:51:64:d6:c8
Nov 01 20:52:53 StarReach kernel: wlp0s20f3: send auth to ec:f4:51:64:d6:c8 (try 1/3)
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.6066] device (wlp0s20f3): supplicant interface state: disconnected -> authenticating
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.6067] device (p2p-dev-wlp0s20f3): supplicant management interface state: disconnected -> authenticating
Nov 01 20:52:53 StarReach wpa_supplicant[798]: wlp0s20f3: Trying to associate with ec:f4:51:64:d6:c8 (SSID='BTWholeHome-GZS' freq=5220 MHz)
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.6381] device (wlp0s20f3): supplicant interface state: authenticating -> associating
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.6381] device (p2p-dev-wlp0s20f3): supplicant management interface state: authenticating -> associating
Nov 01 20:52:53 StarReach kernel: wlp0s20f3: authenticated
Nov 01 20:52:53 StarReach kernel: wlp0s20f3: associate with ec:f4:51:64:d6:c8 (try 1/3)
Nov 01 20:52:53 StarReach kernel: wlp0s20f3: RX AssocResp from ec:f4:51:64:d6:c8 (capab=0x1031 status=0 aid=8)
Nov 01 20:52:53 StarReach kernel: wlp0s20f3: associated
Nov 01 20:52:53 StarReach wpa_supplicant[798]: wlp0s20f3: Associated with ec:f4:51:64:d6:c8
Nov 01 20:52:53 StarReach wpa_supplicant[798]: wlp0s20f3: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.6714] device (wlp0s20f3): supplicant interface state: associating -> associated
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.6714] device (p2p-dev-wlp0s20f3): supplicant management interface state: associating -> associated
Nov 01 20:52:53 StarReach kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
Nov 01 20:52:53 StarReach wpa_supplicant[798]: wlp0s20f3: WPA: Key negotiation completed with ec:f4:51:64:d6:c8 [PTK=CCMP GTK=CCMP]
Nov 01 20:52:53 StarReach wpa_supplicant[798]: wlp0s20f3: CTRL-EVENT-CONNECTED - Connection to ec:f4:51:64:d6:c8 completed [id=0 id_str=]
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.7681] device (wlp0s20f3): supplicant interface state: associated -> completed
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.7681] device (wlp0s20f3): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "BTWholeHome-GZS"
Nov 01 20:52:53 StarReach wpa_supplicant[798]: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-51 noise=9999 txrate=0
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.7682] device (p2p-dev-wlp0s20f3): supplicant management interface state: associated -> completed
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.7685] device (wlp0s20f3): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.7693] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
Nov 01 20:52:53 StarReach avahi-daemon[602]: Joining mDNS multicast group on interface wlp0s20f3.IPv6 with address fe80::b8da:eb76:f10e:1579.
Nov 01 20:52:53 StarReach avahi-daemon[602]: New relevant interface wlp0s20f3.IPv6 for mDNS.
Nov 01 20:52:53 StarReach avahi-daemon[602]: Registering new address record for fe80::b8da:eb76:f10e:1579 on wlp0s20f3.*.
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8011] dhcp4 (wlp0s20f3): option dhcp_lease_time => '86400'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8011] dhcp4 (wlp0s20f3): option domain_name => 'home'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8012] dhcp4 (wlp0s20f3): option domain_name_servers => '192.168.1.254'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8012] dhcp4 (wlp0s20f3): option expiry => '1604350373'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8012] dhcp4 (wlp0s20f3): option ip_address => '192.168.1.240'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8012] dhcp4 (wlp0s20f3): option requested_broadcast_address => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8012] dhcp4 (wlp0s20f3): option requested_domain_name => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8012] dhcp4 (wlp0s20f3): option requested_domain_name_servers => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8013] dhcp4 (wlp0s20f3): option requested_domain_search => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8013] dhcp4 (wlp0s20f3): option requested_host_name => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8013] dhcp4 (wlp0s20f3): option requested_interface_mtu => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8013] dhcp4 (wlp0s20f3): option requested_ms_classless_static_routes => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8013] dhcp4 (wlp0s20f3): option requested_nis_domain => '1'
Nov 01 20:52:53 StarReach avahi-daemon[602]: Joining mDNS multicast group on interface wlp0s20f3.IPv4 with address 192.168.1.240.
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8013] dhcp4 (wlp0s20f3): option requested_nis_servers => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8014] dhcp4 (wlp0s20f3): option requested_ntp_servers => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8014] dhcp4 (wlp0s20f3): option requested_rfc3442_classless_static_routes => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8014] dhcp4 (wlp0s20f3): option requested_root_path => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8014] dhcp4 (wlp0s20f3): option requested_routers => '1'
Nov 01 20:52:53 StarReach avahi-daemon[602]: New relevant interface wlp0s20f3.IPv4 for mDNS.
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8014] dhcp4 (wlp0s20f3): option requested_static_routes => '1'
Nov 01 20:52:53 StarReach avahi-daemon[602]: Registering new address record for 192.168.1.240 on wlp0s20f3.IPv4.
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8014] dhcp4 (wlp0s20f3): option requested_subnet_mask => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8014] dhcp4 (wlp0s20f3): option requested_time_offset => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8015] dhcp4 (wlp0s20f3): option requested_wpad => '1'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8015] dhcp4 (wlp0s20f3): option routers => '192.168.1.254'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8015] dhcp4 (wlp0s20f3): option subnet_mask => '255.255.255.0'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8015] dhcp4 (wlp0s20f3): state changed unknown -> bound
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8049] device (wlp0s20f3): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 01 20:52:53 StarReach dbus-daemon[604]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=605 comm="/usr/bin/NetworkManager --no-daemon ")
Nov 01 20:52:53 StarReach systemd[1]: Starting Network Manager Script Dispatcher Service...
Nov 01 20:52:53 StarReach dbus-daemon[604]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 01 20:52:53 StarReach systemd[1]: Started Network Manager Script Dispatcher Service.
Nov 01 20:52:53 StarReach audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:53 StarReach kernel: audit: type=1130 audit(1604263973.813:87): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8194] device (wlp0s20f3): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8199] device (wlp0s20f3): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8208] manager: NetworkManager state is now CONNECTED_LOCAL
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8227] manager: NetworkManager state is now CONNECTED_SITE
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8228] policy: set 'BTWholeHome-GZS' (wlp0s20f3) as default for IPv4 routing and DNS
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.8264] device (wlp0s20f3): Activation: successful, device activated.
Nov 01 20:52:53 StarReach NetworkManager[605]: <info> [1604263973.9949] manager: NetworkManager state is now CONNECTED_GLOBAL
Nov 01 20:52:56 StarReach NetworkManager[605]: <info> [1604263976.5416] dhcp6 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
Nov 01 20:52:56 StarReach avahi-daemon[602]: Leaving mDNS multicast group on interface wlp0s20f3.IPv6 with address fe80::b8da:eb76:f10e:1579.
Nov 01 20:52:56 StarReach avahi-daemon[602]: Joining mDNS multicast group on interface wlp0s20f3.IPv6 with address fdaa:bbcc:ddee:0:4637:3cd8:ae54:9d1b.
Nov 01 20:52:56 StarReach avahi-daemon[602]: Registering new address record for fdaa:bbcc:ddee:0:4637:3cd8:ae54:9d1b on wlp0s20f3.*.
Nov 01 20:52:56 StarReach avahi-daemon[602]: Withdrawing address record for fe80::b8da:eb76:f10e:1579 on wlp0s20f3.
Nov 01 20:52:56 StarReach avahi-daemon[602]: Registering new address record for 2a00:23c8:303:c500:d449:2161:800e:1c48 on wlp0s20f3.*.
Nov 01 20:52:56 StarReach NetworkManager[605]: <info> [1604263976.5428] policy: set 'BTWholeHome-GZS' (wlp0s20f3) as default for IPv6 routing and DNS
Nov 01 20:52:56 StarReach NetworkManager[605]: <info> [1604263976.8656] dhcp6 (wlp0s20f3): option dhcp6_domain_search => 'home'
Nov 01 20:52:56 StarReach NetworkManager[605]: <info> [1604263976.8656] dhcp6 (wlp0s20f3): state changed unknown -> bound
lines 185-263/263 (END)
