Bluetooth issues after sleep (loose my adapter)
Of course :slight_smile:
    [connor@StarReach ~]$ lsusb -tv
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 10000M
    ID 1d6b:0003 Linux Foundation 3.0 root hub
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/12p, 480M
    ID 1d6b:0002 Linux Foundation 2.0 root hub
    |__ Port 5: Dev 3, If 0, Class=Vendor Specific Class, Driver=, 12M
        ID 04f3:0c4b Elan Microelectronics Corp.
    |__ Port 6: Dev 4, If 0, Class=Video, Driver=uvcvideo, 480M
        ID 04ca:7070 Lite-On Technology Corp.
    |__ Port 6: Dev 4, If 1, Class=Video, Driver=uvcvideo, 480M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 10000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
I wonder which one of these are the Bluetooth adapter… I assume bus one , as i sort of recognize the vendor…
May you try sudo usb_modeswitch -R -v 1d6b -p 0002 , please?
You would know better than me :laughing:
[connor@StarReach ~]$ sudo usb_modeswitch -R -v 1d6b -p 0002
Look for default devices ...
 Found devices in default mode (2)
Access device 001 on bus 001
Get the current device configuration ...
Current configuration number is 1
Use interface number 0
 with class 9
Warning: no switching method given. See documentation
Reset USB device ...........Reset USB device failed with error -99 Reset USB device failed with error -99-> Run lsusb to note any changes. Bye!
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 04ca:7070 Lite-On Technology Corp. Integrated Camera
Bus 003 Device 003: ID 04f3:0c4b Elan Microelectronics Corp. ELAN:Fingerprint
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Kernel 5.9, may I ask? :sweat_smile:
I am running
Linux StarReach 5.9.1-1-MANJARO #1 SMP PREEMPT Sat Oct 17 11:44:44 UTC 2020 x86_64 GNU/Linux
:grin:
Oh, indeed, the kernel 5.9 Bluetooth stack tries to use link-layer privacy on BLE connections…
Please try to run sudo rfkill unblock bluetooth , see if it works…
Else, enter sudo -i in the terminal , then enter cd /var/lib/bluetooth/ , then provide me the output of ls, please!
rfkill unblock bluetooth Never did anything :frowning:
The command just reports the one
94:E7:0B:C9:8D:7A
Thanks for the help btw :slight_smile:
Sweet! still in the terminal, may now enter cd /var/lib/bluetooth/94:E7:0B:C9:8D:7A, then provide me once again the output of ls! :grin:
It returns:
cache FB:2C:98:B7:B4:3C settings
Great! Now, once again still in the terminal, enter nano /var/lib/bluetooth/94:E7:0B:C9:8D:7A/FB:2C:98:B7:B4:3C/info , then remove the lines that looks like this:
[IdentityResolvingKey]
Key=...
After that, press ctrl + s to save, then ctrl + x to exit.
Then enter nano /etc/bluetooth/main.conf and set:
[Policy]
AutoEnable=true
After that, press ctrl + s to save, then ctrl + x to exit. Then you may type in exit to exit from sudo.
Then, you may execute pulseaudio --k , followed by sudo systemctl restart bluetooth.service to then execute pulseaudio --start.
This wont work … it needs sudo.
But really should use sudoedit … and I assume the env var is not set (or set to vi), so to be sure:
SUDO_EDITOR=nano sudoedit /var/lib/bluetooth/94:E7:0B:C9:8D:7A/FB:2C:98:B7:B4:3C/info
He is still in the su environment!
I ran through it all with adapter is still MIA, one command seemed not to work though.
    [connor@StarReach 94:E7:0B:C9:8D:7A]$ pulseaudio --k
    E: [pulseaudio] main.c: Failed to kill daemon: No such process
Oh, you need to exit from sudo! :smile:
ah!:slight_smile:
All commands went through no issues, adapter is still missing :frowning:
May I please ask what sudo lsmod | grep bluetooth returns, as well as sudo dmesg | grep Bluetooth and sudo rfkill list plus mkinitcpio -M ?
sudo lsmod | grep bluetooth returns:
sudo dmesg | grep Bluetooth returns:
[connor@StarReach ~]$ sudo dmesg | grep Bluetooth
[    3.301974] Bluetooth: Core ver 2.22
[    3.301990] Bluetooth: HCI device and connection manager initialized
[    3.301992] Bluetooth: HCI socket layer initialized
[    3.301993] Bluetooth: L2CAP socket layer initialized
[    3.301995] Bluetooth: SCO socket layer initialized
[    3.310509] Bluetooth: hci0: Bootloader revision 0.4 build 0 week 11 2017
[    3.311535] Bluetooth: hci0: Device revision is 2
[    3.311536] Bluetooth: hci0: Secure boot is enabled
[    3.311536] Bluetooth: hci0: OTP lock is enabled
[    3.311537] Bluetooth: hci0: API lock is enabled
[    3.311537] Bluetooth: hci0: Debug lock is disabled
[    3.311538] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[    3.313791] Bluetooth: hci0: Found device firmware: intel/ibt-19-32-4.sfi
[    3.330428] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.330429] Bluetooth: BNEP filters: protocol multicast
[    3.330431] Bluetooth: BNEP socket layer initialized
[    4.935636] Bluetooth: hci0: Waiting for firmware download to complete
[    4.936632] Bluetooth: hci0: Firmware loaded in 1588304 usecs
[    4.936643] Bluetooth: hci0: Waiting for device to boot
[    4.951587] Bluetooth: hci0: Device booted in 14600 usecs
[    4.951810] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-19-32-4.ddc
[    4.953675] Bluetooth: hci0: Applying Intel DDC parameters completed
[    4.956690] Bluetooth: hci0: Firmware revision 0.0 build 121 week 36 2020
[   14.743868] Bluetooth: RFCOMM TTY layer initialized
[   14.743874] Bluetooth: RFCOMM socket layer initialized
[   14.743878] Bluetooth: RFCOMM ver 1.11
[   68.008772] Bluetooth: hci0: Timed out waiting for suspend events
[   68.008774] Bluetooth: hci0: command 0x0c05 tx timeout
[   68.008777] Bluetooth: hci0: Suspend timeout bit: 5
[   68.008780] Bluetooth: hci0: Suspend notifier action (4) failed: -110
and finally:
==> Modules autodetected
8250_dw
ac
acpi_cpufreq
acpi_tad
aesni_intel
atkbd
battery
coretemp
crc32c_intel
crc32_pclmul
crct10dif_pclmul
ee1004
elan_i2c
evdev
ext4
fjes
ghash_clmulni_intel
hid_generic
hid_logitech_dj
hid_logitech_hidpp
i2c_designware_platform
i2c_hid
i2c_i801
i8042
i915
ideapad_laptop
idma64
input_leds
int3400_thermal
int3403_thermal
intel_cstate
intel_lpss_pci
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_spi_pci
intel_uncore
intel_wmi_thunderbolt
iTCO_wdt
iwlwifi
joydev
kvm_intel
mac_hid
mei_hdcp
mei_me
mousedev
pcc_cpufreq
pcspkr
processor_thermal_device
r8169
rapl
rtc_cmos
rtsx_pci
rtsx_pci_sdmmc
serio_raw
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_intel
snd_sof_pci
tpm_crb
tpm_tis
ucsi_acpi
usbhid
uvcvideo
wmi
wmi_bmof
x86_pkg_temp_thermal
xhci_pci
Hmm, have TLP installed?
Okay lets try with this one… sudo usb_modeswitch -R -v 04f3 -p 0c4b
And for now, lets try to kill bluetooth. Enter sudo systemctl disable bluetooth , then reboot to then re enable it sudo systemctl enable bluetooth … Its a firmware mismatch between two loaders…
Er I think so.
Ran through it all, but the problem still persists after sleep :frowning:
 Found devices in default mode (1)
Access device 003 on bus 003
 with class 255
Reset USB device .
 Device was reset
Bus 003 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Let’s try to sudo systemctl disable tlp
oh, have you restarted, may I ask?
