Bluetooth Headset profile switches from "HSP/HFP" to "off" after ending a call
I’m using my JLab Play bluetooth headset on a HP Pavilion 23 with Manjaro 20.2.1 and KDE Plasma 5.20.5.
When connecting the headset via bluetooth the A2DP profile is used automatically. Therefore my headset mic isn’t used on Discord voice-chat. I have to manually switch it to HSP/HFP in the advanced audio settings. Looking for a way to make HSP/HFP the default profile, I came about the Bluetooth Headset topic in the ArchLinux Wiki, the link I can not post here aparently, where it say:
“For enabling automatic profile switching from A2DP to HSP when a recording stream appears without any role set, you can append ‘auto_switch=2’ to ‘load-module module-bluetooth-policy’ in ‘/etc/pulse/default.pa’.”
I found this an adquate solution, so I tried it and it worked at first but after ending the call in Discord the profile is automatically changed to off and joining another call won’t switch it to HSP/HFP again.
I wonder if this is some kind of bug, or if I made a mistake or have to set some other options. Can someone please explain or help?
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    [HowTo] Provide System Information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
  3. Please read this:
    [HowTo] Post screenshots and links
  4. Can you provide the output to:
    pacmd dump
    as well?
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel you have, …
Hi, thanks for the welcome and your supportive response. I’m rather new to manjaro and online forums like this, so your patience is highly appreciated. I guess, I could have read more into the beginner advice around here. I will have a look for it, while reading your recommendations and filling my profile. I’m also sorry for my late response. I thought I would receive some form of e-mail notification about a response to my question, but this did not happen. Guess I need to ask for it in the settings somewhere.
However, this is my inxi output:
  Kernel: 5.4.101-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  root=UUID=2bf87580-35fb-47a0-b838-bfaaa00384ce rw quiet udev.log_priority=3
  Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Desktop System: Hewlett-Packard product: 23-f200eg v: 1.00
  serial: <filter> Chassis: type: 3 serial: <filter>
  Mobo: Hewlett-Packard model: 2AF9 v: 1.02 serial: <filter> UEFI: AMI
  v: 80.05 date: 06/07/2013
  Device-1: hid-20:73:ab:10:0d:60-battery model: ID0110 serial: N/A
  charge: N/A status: Discharging
  RAM: total: 5.68 GiB used: 1.98 GiB (34.9%)
  Info: Dual Core model: Intel Core i3-3240 bits: 64 type: MT MCP
  arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
  L2 cache: 3 MiB bogomips: 27149
  Speed: 1597 MHz min/max: 1600/3400 MHz Core speeds (MHz): 1: 1597 2: 1596
  3: 1599 4: 1597
  Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
  constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
  erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs lahf_lm
  lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
  pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp
  rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology
  xtpr
  Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
  Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
  vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
  chip ID: 8086:0152 class ID: 0300
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
  620M/625M/630M/720M]
  vendor: Hewlett-Packard driver: nouveau v: kernel bus ID: 01:00.0
  chip ID: 10de:1140 class ID: 0302
  Device-3: Chicony HP High Definition 1MP Webcam type: USB driver: uvcvideo
  bus ID: 1-1.3:3 chip ID: 04f2:b34a class ID: 0e02
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
  loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
  display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 2500 (IVB GT1)
  v: 4.2 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:1e20 class ID: 0403
  Sound Server: ALSA v: k5.4.101-1-MANJARO
  Device-1: Broadcom BCM43228 802.11a/b/g/n vendor: Hewlett-Packard driver: wl
  v: kernel modules: bcma port: e000 bus ID: 03:00.0 chip ID: 14e4:4359
  class ID: 0280
  IF: wlp3s0 state: down mac: <filter>
  vendor: Hewlett-Packard driver: r8169 v: kernel port: d000 bus ID: 07:00.0
  chip ID: 10ec:8168 class ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Broadcom HP Portable Bumble Bee type: USB driver: btusb v: 0.8
  bus ID: 4-1.7:9 chip ID: 0a5c:21f1 class ID: fe01 serial: <filter>
  Message: Required tool hciconfig not installed. Check --recommends
  Local Storage: total: 975.96 GiB used: 15.73 GiB (1.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: HP33 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB model: USB Flash size: 30 GiB
  block size: physical: 512 B logical: 512 B rotation: SSD serial: <filter>
  rev: 1100 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Philips
  model: USB Flash Drive size: 14.45 GiB block size: physical: 512 B
  logical: 512 B rotation: SSD serial: <filter> rev: PMAP
  Optical-1: /dev/sr0 vendor: hp model: DVDRAM GT80N rev: RA03
  dev-links: cdrom
  ID-1: / raw size: 80 GiB size: 78.24 GiB (97.81%) used: 13.43 GiB (17.2%)
  fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 2bf87580-35fb-47a0-b838-bfaaa00384ce
  ID-2: /boot/efi raw size: 500 MiB size: 499 MiB (99.80%)
  used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: F2A2-74DC
  ID-3: /home raw size: 840 GiB size: 825.82 GiB (98.31%) used: 2.3 GiB (0.3%)
  fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
  uuid: f18438b8-2849-4d91-bc97-65d8583cb916
  ID-1: swap-1 type: partition size: 6 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: 4fc2d4b4-d7d2-4ece-b8ab-3a7a4013df21
  ID-1: /dev/sdb1 maj-min: 8:17 size: 30 GiB fs: vfat label: PHILIPS UFD
  uuid: 02D6-A051
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
  speed: 480 Mb/s chip ID: 8087:0024 class ID: 0900
  Device-1: 1-1.3:3 info: Chicony HP High Definition 1MP Webcam type: Video
  driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b34a
  class ID: 0e02
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-4: 2-3:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip ID: 05e3:0610 class ID: 0900
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  chip ID: 1d6b:0003 class ID: 0900
  Hub-6: 3-3:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
  chip ID: 05e3:0612 class ID: 0900
  Device-1: 3-3.2:3
  info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
  chip ID: 090c:1000 class ID: 0806
  Device-2: 3-3.3:4 info: Kingston SP Mobile C31 (64GB) type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s chip ID: 13fe:6300
  class ID: 0806 serial: <filter>
  Device-3: 3-3.4:5 info: Genesys Logic SD Card Reader and Writer
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
  chip ID: 05e3:0749 class ID: 0806 serial: <filter>
  Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-8: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 4-1.7:9 info: Broadcom HP Portable Bumble Bee type: Bluetooth
  driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip ID: 0a5c:21f1
  Device-2: 4-1.8:4 info: NextWindow Touchscreen type: HID
  driver: hid-generic,hid-multitouch,usbhid interfaces: 3 rev: 2.0
  speed: 12 Mb/s chip ID: 1926:0344 class ID: 0300
  System Temperatures: cpu: 29.8 C mobo: 27.8 C
  Processes: 197 Uptime: 30m wakeups: 2 Init: systemd v: 247 Compilers:
  gcc: N/A Packages: pacman: 1208 lib: 386 Shell: Bash v: 5.1.0
  running in: konsole inxi: 3.3.01
This is my pacmd output:
### Configuration dump generated at Sun Mar 14 08:37:20 2021
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_00_1b.0" card_name="alsa_card.pci-0000_00_1b.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0 xauthority=/home/g/.Xauthority
load-module module-x11-xsmp display=:0 xauthority=/home/g/.Xauthority session_manager=local/Pavilion23:@/tmp/.ICE-unix/4190,unix/Pavilion23:/tmp/.ICE-unix/4190
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_1b.0.analog-stereo 0x8ccb
set-sink-mute alsa_output.pci-0000_00_1b.0.analog-stereo no
suspend-sink alsa_output.pci-0000_00_1b.0.analog-stereo yes
set-source-volume alsa_output.pci-0000_00_1b.0.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1b.0.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1b.0.analog-stereo.monitor yes
set-source-volume alsa_input.pci-0000_00_1b.0.analog-stereo 0xb4b4
set-source-mute alsa_input.pci-0000_00_1b.0.analog-stereo no
suspend-source alsa_input.pci-0000_00_1b.0.analog-stereo yes
set-card-profile alsa_card.pci-0000_00_1b.0 output:analog-stereo+input:analog-stereo
set-default-sink alsa_output.pci-0000_00_1b.0.analog-stereo
set-default-source alsa_input.pci-0000_00_1b.0.analog-stereo
### EOF
The link, I meant to present here, was this one: https://wiki.archlinux.org/index.php/Bluetooth_headset#Switch_between_HSP/HFP_and_A2DP_setting
Thanks for helping me out :slightly_smiling_face:
@nikgnomic I don’t understand half of what’s going on here… :fearful:
Could you have a look, please?
:+1:
Bluetooth headset - ArchWiki
Archwiki suggests setting the card-profile to HSP/HFP using the card number, but the number is very likely to change for a bluetooth device so it would be better to use the card name
But your PulseAudio data is not showing any bluetooth card or profile
Please connect the bluetooth device and use this command
pactl list sinks short
The name should look something like - bluez_card.0A_5C_21_F1_FE_01
(but the hex numbers might be different if they are not based on the chip ID and class ID)
Hi, thanks for joining in :slight_smile:
This is my pactl output:
0       alsa_output.pci-0000_00_1b.0.analog-stereo      module-alsa-card.c      s16le 2ch 44100Hz       SUSPENDED
1       bluez_sink.FC_88_77_09_52_A6.a2dp_sink  module-bluez5-device.c  s16le 2ch 44100Hz       SUSPENDED
So, the second one bluez_sink.FC_88_77_09_52_A6 should be my headset.
What’s next?
I posted the wrong command - it should have been pactl list cards short
but I can adapt from the sink name
Use this command to set the profile to A2DP instead of Off
pacmd set-card-profile bluez_card.FC_88_77_09_52_A6 a2dp_sink
Well, this did not really work out… I will try to describe exactly what I did and observed: I turned on the headphones, they connected automatically and got the a2dp-profile set. I looked it up in the advanced audio settings GUI. Then I joined a discord voice chat and the profile switched to hsp-profile. So far the auto-switch=2-statement in my /etc/pulse/default.pa somehow worked. In fact it seemed to switch multiple times, as I heard the joining sound a couple of times and also saw a pop-up on my screen switching between a (sound?)-card-symbol, and a headphones-symbol. I get this pop-up always when connecting my headphones and the audio switches from build-in speakers to my headphones’ speakers, but usually just once and not switching back and forth a couple of times.
However, in the end it worked out, the hsp-profile was set and I could use my headset-mic. So I ended the call and the headset’s profile in the advanced audio settings GUI was set to ‘off’, just as I described in the beginning of this thread. So I used:
, which gave me this output:
Failed to set card profile to 'a2dp_sink'.
The headset is still connected, as
shows:
0       alsa_card.pci-0000_00_1b.0      module-alsa-card.c
3       bluez_card.FC_88_77_09_52_A6    module-bluez5-device.c
My journalctl output for this whole process shows this:
Mär 20 23:28:19 Pavilion23 bluetoothd[708]: /org/bluez/hci0/dev_FC_88_77_09_52_A6/sep1/fd2: fd(44) ready
Mär 20 23:28:19 Pavilion23 rtkit-daemon[1229]: Supervising 5 threads of 2 processes of 1 users.
Mär 20 23:28:19 Pavilion23 rtkit-daemon[1229]: Successfully made thread 3186 of process 1210 owned by '1000' RT at priority 5.
Mär 20 23:28:19 Pavilion23 rtkit-daemon[1229]: Supervising 6 threads of 2 processes of 1 users.
Mär 20 23:28:19 Pavilion23 kernel: input: JLab Play (AVRCP) as /devices/virtual/input/input60
Mär 20 23:28:19 Pavilion23 systemd-logind[680]: Watching system buttons on /dev/input/event19 (JLab Play (AVRCP))
Mär 20 23:28:25 Pavilion23 rtkit-daemon[1229]: Supervising 5 threads of 2 processes of 1 users.
Mär 20 23:28:25 Pavilion23 rtkit-daemon[1229]: Successfully made thread 3208 of process 1210 owned by '1000' RT at priority 5.
Mär 20 23:28:25 Pavilion23 rtkit-daemon[1229]: Supervising 6 threads of 2 processes of 1 users.
Mär 20 23:28:25 Pavilion23 kdeconnectd[1176]: org.kde.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.a2dp_sink"
Mär 20 23:28:25 Pavilion23 kdeconnectd[1176]: org.kde.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:25 Pavilion23 kdeconnectd[1176]: org.kde.pulseaudio: No object for name "bluez_source.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:25 Pavilion23 plasmashell[1157]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/ListItemBase.qml:153: TypeError: Cannot read property 'ports' of undefined
Mär 20 23:28:25 Pavilion23 plasmashell[1157]: org.kde.plasma.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.a2dp_sink"
Mär 20 23:28:25 Pavilion23 plasmashell[1157]: org.kde.plasma.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:25 Pavilion23 plasmashell[1157]: org.kde.plasma.pulseaudio: No object for name "bluez_source.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:25 Pavilion23 systemsettings5[2747]: org.kde.plasma.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.a2dp_sink"
Mär 20 23:28:25 Pavilion23 kded5[1110]: Registering ":1.100/StatusNotifierItem" to system tray
Mär 20 23:28:25 Pavilion23 rtkit-daemon[1229]: Successfully made thread 3213 of process 1210 owned by '1000' RT at priority 5.
Mär 20 23:28:25 Pavilion23 kded5[1110]: Service  ":1.100" unregistered
Mär 20 23:28:25 Pavilion23 rtkit-daemon[1229]: Successfully made thread 3217 of process 1210 owned by '1000' RT at priority 5.
Mär 20 23:28:25 Pavilion23 systemsettings5[2747]: org.kde.plasma.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:25 Pavilion23 systemsettings5[2747]: org.kde.plasma.pulseaudio: No object for name "bluez_source.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:25 Pavilion23 systemsettings5[2747]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/main.qml:0: ReferenceError: sourceModel is not defined
Mär 20 23:28:25 Pavilion23 kded5[1110]: Registering ":1.101/StatusNotifierItem" to system tray
Mär 20 23:28:25 Pavilion23 rtkit-daemon[1229]: Successfully made thread 3218 of process 1210 owned by '1000' RT at priority 5.
Mär 20 23:28:25 Pavilion23 kded5[1110]: Service  ":1.101" unregistered
Mär 20 23:28:25 Pavilion23 systemsettings5[2747]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:36: TypeError: Cannot read property 'width' of null
Mär 20 23:28:26 Pavilion23 rtkit-daemon[1229]: Supervising 5 threads of 2 processes of 1 users.
Mär 20 23:28:26 Pavilion23 rtkit-daemon[1229]: Successfully made thread 3219 of process 1210 owned by '1000' RT at priority 5.
Mär 20 23:28:26 Pavilion23 rtkit-daemon[1229]: Supervising 6 threads of 2 processes of 1 users.
Mär 20 23:28:26 Pavilion23 systemsettings5[2747]: org.kde.plasma.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:26 Pavilion23 kdeconnectd[1176]: org.kde.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.a2dp_sink"
Mär 20 23:28:26 Pavilion23 systemsettings5[2747]: org.kde.plasma.pulseaudio: No object for name "bluez_source.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:26 Pavilion23 plasmashell[1157]: org.kde.plasma.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:26 Pavilion23 plasmashell[1157]: org.kde.plasma.pulseaudio: No object for name "bluez_source.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:26 Pavilion23 kded5[1110]: Registering ":1.102/StatusNotifierItem" to system tray
Mär 20 23:28:26 Pavilion23 systemsettings5[2747]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/main.qml:0: ReferenceError: sourceModel is not defined
Mär 20 23:28:26 Pavilion23 rtkit-daemon[1229]: Successfully made thread 3221 of process 1210 owned by '1000' RT at priority 5.
Mär 20 23:28:26 Pavilion23 systemsettings5[2747]: org.kde.plasma.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.a2dp_sink"
Mär 20 23:28:26 Pavilion23 plasmashell[1157]: org.kde.plasma.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.a2dp_sink"
Mär 20 23:28:26 Pavilion23 pulseaudio[1210]: Transport TryAcquire() failed for transport /org/bluez/hci0/dev_FC_88_77_09_52_A6/sep1/fd2 (Operation Not Authorized)
Mär 20 23:28:26 Pavilion23 kded5[1110]: Service  ":1.102" unregistered
Mär 20 23:28:26 Pavilion23 systemsettings5[2747]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:36: TypeError: Cannot read property 'width' of null
Mär 20 23:28:26 Pavilion23 rtkit-daemon[1229]: Successfully made thread 3222 of process 1210 owned by '1000' RT at priority 5.
Mär 20 23:28:26 Pavilion23 kdeconnectd[1176]: org.kde.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:26 Pavilion23 kdeconnectd[1176]: org.kde.pulseaudio: No object for name "bluez_source.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:26 Pavilion23 kded5[1110]: Registering ":1.103/StatusNotifierItem" to system tray
Mär 20 23:28:30 Pavilion23 pulseaudio[1210]: Transport Acquire() failed for transport /org/bluez/hci0/dev_FC_88_77_09_52_A6/sep1/fd2 (Operation Not Authorized)
Mär 20 23:28:30 Pavilion23 pulseaudio[1210]: Could not set profile 'a2dp_sink'
Mär 20 23:28:30 Pavilion23 kdeconnectd[1176]: org.kde.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:30 Pavilion23 kdeconnectd[1176]: org.kde.pulseaudio: No object for name "bluez_source.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:30 Pavilion23 plasmashell[1157]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/ListItemBase.qml:153: TypeError: Cannot read property 'ports' of undefined
Mär 20 23:28:30 Pavilion23 plasmashell[1157]: org.kde.plasma.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:30 Pavilion23 plasmashell[1157]: org.kde.plasma.pulseaudio: No object for name "bluez_source.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:30 Pavilion23 kded5[1110]: Service  ":1.103" unregistered
Mär 20 23:28:30 Pavilion23 systemsettings5[2747]: org.kde.plasma.pulseaudio: No object for name "bluez_sink.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:30 Pavilion23 systemsettings5[2747]: org.kde.plasma.pulseaudio: No object for name "bluez_source.FC_88_77_09_52_A6.headset_head_unit"
Mär 20 23:28:30 Pavilion23 systemsettings5[2747]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:36: TypeError: Cannot read property 'width' of null
Mär 20 23:28:36 Pavilion23 systemsettings5[2747]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:36: TypeError: Cannot read property 'width' of null
Mär 20 23:28:48 Pavilion23 pulseaudio[1210]: Transport Acquire() failed for transport /org/bluez/hci0/dev_FC_88_77_09_52_A6/sep1/fd2 (Operation Not Authorized)
If I switch profile to a2dp in GUI also nothing happens. I can switch it there manually back to hsp with full functionality but setting it to a2dp in the GUI again afterwards, sets it straight back to ‘off’.
Hi, do you have any suggestions on this? I’m pretty lost here. Any Advice would be highly appreciated. Or would you recommend another forum for this problem?
