I did this and now it doesnt let me pair my device at all.
Journalctl Log:
The following includes just the stopping and starting of the bluetooth service
Apr 15 18:32:45 raunak-inspiron165630 sudo[16812]: raunak : TTY=pts/0 ; PWD=/home/raunak ; USER=root ; COMMAND=/usr/bin/systemctl stop bluetooth
Apr 15 18:32:45 raunak-inspiron165630 sudo[16812]: pam_unix(sudo:session): session opened for user root(uid=0) by raunak(uid=1000)
Apr 15 18:32:45 raunak-inspiron165630 bluetoothd[16303]: Terminating
Apr 15 18:32:45 raunak-inspiron165630 systemd[1]: Stopping Bluetooth service...
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/ldac
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSink/aptx_hd
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/aptx_hd
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSink/aac
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/aac
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSink/sbc
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/sbc
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSink/sbc_xq
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/sbc_xq
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/faststream
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/faststream_duplex
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSink/opus_05
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/opus_05
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Endpoint unregistered: sender=:1.112 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Battery Provider Manager destroyed
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Stopping SDP server
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16303]: Exit
Apr 15 18:32:46 raunak-inspiron165630 systemd[1]: bluetooth.service: Deactivated successfully.
Apr 15 18:32:46 raunak-inspiron165630 systemd[1]: Stopped Bluetooth service.
Apr 15 18:32:46 raunak-inspiron165630 sudo[16812]: pam_unix(sudo:session): session closed for user root
Apr 15 18:32:46 raunak-inspiron165630 systemd[1]: Starting Bluetooth service...
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Bluetooth daemon 5.72
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Starting SDP server
Apr 15 18:32:46 raunak-inspiron165630 systemd[1]: Started Bluetooth service.
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: src/plugin.c:plugin_init() System does not support csip plugin
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: src/plugin.c:plugin_init() System does not support micp plugin
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: src/plugin.c:plugin_init() System does not support vcp plugin
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: src/plugin.c:plugin_init() System does not support mcp plugin
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: src/plugin.c:plugin_init() System does not support bass plugin
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: src/plugin.c:plugin_init() System does not support bap plugin
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Bluetooth management interface 1.22 initialized
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Battery Provider Manager created
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Failed to clear UUIDs: Failed (0x03)
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Failed to add UUID: Failed (0x03)
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/ldac
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSink/aptx_hd
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/aptx_hd
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSink/aac
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/aac
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSink/sbc
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/sbc
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSink/sbc_xq
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/sbc_xq
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/faststream
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/faststream_duplex
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSink/opus_05
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/opus_05
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Apr 15 18:32:46 raunak-inspiron165630 bluetoothd[16828]: Endpoint registered: sender=:1.112 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Apr 15 18:32:46 raunak-inspiron165630 systemd[1]: Starting Hostname Service...
Apr 15 18:32:46 raunak-inspiron165630 systemd[1]: Started Hostname Service.
Apr 15 18:32:47 raunak-inspiron165630 systemd[1292]: Started Application launched by gsd-media-keys.
Apr 15 18:32:47 raunak-inspiron165630 systemd[1292]: Started VTE child process 16842 launched by gnome-terminal-server process 13811.
Apr 15 18:32:50 raunak-inspiron165630 systemd[1292]: Started Application launched by gsd-media-keys.
Apr 15 18:32:50 raunak-inspiron165630 nautilus[16903]: Connecting to org.freedesktop.Tracker3.Miner.Files
Apr 15 18:32:50 raunak-inspiron165630 systemd[1292]: Started dbus-:1.2-org.gnome.NautilusPreviewer@10.service.
Apr 15 18:33:16 raunak-inspiron165630 systemd[1]: fprintd.service: Deactivated successfully.
Apr 15 18:33:16 raunak-inspiron165630 polkitd[602]: Operator of unix-session:3 successfully authenticated as unix-user:raunak to gain TEMPORARY authorization for action org.gtk.vfs.file-operations for unix-proc>
Apr 15 18:33:18 raunak-inspiron165630 gnome-shell[1427]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
Apr 15 18:33:20 raunak-inspiron165630 systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Apr 15 18:33:27 raunak-inspiron165630 sudo[17081]: raunak : TTY=pts/0 ; PWD=/home/raunak ; USER=root ; COMMAND=/usr/bin/systemctl start bluetooth
Apr 15 18:33:27 raunak-inspiron165630 sudo[17081]: pam_unix(sudo:session): session opened for user root(uid=0) by raunak(uid=1000)
Apr 15 18:33:27 raunak-inspiron165630 sudo[17081]: pam_unix(sudo:session): session closed for user root
Apr 15 18:33:47 raunak-inspiron165630 wpa_supplicant[678]: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-13 noise=9999 txrate=72200
Here is the journalctl log on my trial to pair my earphones
Apr 15 18:36:20 raunak-inspiron165630 gnome-shell[1427]: Window manager warning: last_user_time (10947315) is greater than comparison timestamp (10947311). This most likely represents a buggy client sending inaccurate timestamps in messages such as _NET_ACTIVE_WINDOW. Trying to work around...
Apr 15 18:36:20 raunak-inspiron165630 gnome-shell[1427]: Window manager warning: W181 appears to be one of the offending windows with a timestamp of 10947315. Working around...
Apr 15 18:36:34 raunak-inspiron165630 systemd[1292]: Started Application launched by gnome-shell.
Apr 15 18:36:35 raunak-inspiron165630 gnome-shell[1427]: Object .Gjs_ui_messageTray_Notification (0x5614746ed050), has been already disposed — impossible to emit any signal on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
== Stack trace for context 0x56147258ec50 ==
#0 5614726593f8 i resource:///org/gnome/shell/ui/messageTray.js:500 (2aa8cd42d1a0 @ 74)
#1 561472659350 i resource:///org/gnome/shell/ui/messageTray.js:496 (2aa8cd42d150 @ 56)
#2 5614726592c8 i resource:///org/gnome/shell/ui/calendar.js:812 (2aa8cd436330 @ 22)
#3 561472659238 i resource:///org/gnome/shell/ui/init.js:21 (8d5b2b70ba0 @ 48)
Apr 15 18:36:35 raunak-inspiron165630 gnome-shell[1427]: Object .Gjs_ui_messageTray_Notification (0x5614746ed050), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 5614726593f8 i resource:///org/gnome/shell/ui/messageTray.js:501 (2aa8cd42d1a0 @ 89)
Apr 15 18:36:48 raunak-inspiron165630 gnome-control-c[16316]: Setting up /org/bluez/hci0/dev_F0_BE_25_C9_19_D9 failed: GDBus.Error:org.bluez.Error.AlreadyExists: Already Paired
Apr 15 18:36:50 raunak-inspiron165630 gnome-control-c[16316]: Setting up /org/bluez/hci0/dev_F0_BE_25_C9_19_D9 failed: GDBus.Error:org.bluez.Error.AlreadyExists: Already Paired
Apr 15 18:38:22 raunak-inspiron165630 google-chrome.desktop[12723]: [12765:12770:0415/183822.264980:ERROR:ssl_client_socket_impl.cc(970)] handshake failed; returned -1, SSL error code 1, net_error -100
Apr 15 18:38:22 raunak-inspiron165630 google-chrome.desktop[12723]: [12765:12770:0415/183822.473417:ERROR:ssl_client_socket_impl.cc(970)] handshake failed; returned -1, SSL error code 1, net_error -100
Apr 15 18:38:28 raunak-inspiron165630 google-chrome.desktop[12723]: [12765:12770:0415/183828.492151:ERROR:ssl_client_socket_impl.cc(970)] handshake failed; returned -1, SSL error code 1, net_error -100
Apr 15 18:38:34 raunak-inspiron165630 NetworkManager[600]: <info> [1713186514.4438] manager: NetworkManager state is now CONNECTED_SITE
Apr 15 18:38:34 raunak-inspiron165630 systemd[1]: Starting Network Manager Script Dispatcher Service...
Apr 15 18:38:34 raunak-inspiron165630 systemd[1]: Started Network Manager Script Dispatcher Service.
Apr 15 18:38:42 raunak-inspiron165630 google-chrome.desktop[12723]: [12765:12770:0415/183842.683733:ERROR:ssl_client_socket_impl.cc(970)] handshake failed; returned -1, SSL error code 1, net_error -100
Apr 15 18:38:44 raunak-inspiron165630 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Apr 15 18:38:57 raunak-inspiron165630 NetworkManager[600]: <info> [1713186537.3712] manager: NetworkManager state is now CONNECTED_GLOBAL
Apr 15 18:38:57 raunak-inspiron165630 systemd[1]: Starting Network Manager Script Dispatcher Service...
Apr 15 18:38:57 raunak-inspiron165630 systemd[1]: Started Network Manager Script Dispatcher Service.
Apr 15 18:39:07 raunak-inspiron165630 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
edit : @Nachlese I did start it again, as reflected by the log file as well, where it started.
The output of the command you asked me to run is
â—Ź bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Mon 2024-04-15 18:32:46 IST; 12min ago
Docs: man:bluetoothd(8)
Main PID: 16828 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18775)
Memory: 1.1M (peak: 1.8M)
CPU: 861ms
CGroup: /system.slice/bluetooth.service
└─16828 /usr/lib/bluetooth/bluetoothd
edit 2:
@Nachlese
I did remove that mac address one only. The third one that is
total 12
drwx------ 3 root root 4096 Apr 15 18:33 .
drwxr-xr-x 46 root root 4096 Apr 14 00:33 ..
drwx------ 3 root root 4096 Apr 15 18:50 74:13:EA:4F:E2:86
However, I used Nautilus and not CLI (should not be an issue I think?) [I do have hidden files visibility on]
Yet to check the fast boot thing on Windows, will try and tell if that works
edit 3: Reboot made it connect.
Reboot for the win, now and always.
