[Posting Again] new bluetooth adapter problem. I tested it windows 7+10+11 and It was working perfectly. But it didn’t work on my manjaro-i3 machine. This is what i’ve done so far,
installed
bluez,bluez-utils,blueberry -
loaded the btusb module
lsmod | grep "btusb"
btusb 69632 0
btrtl 28672 1 btusb
btbcm 20480 1 btusb
btintel 32768 1 btusb
bluetooth 733184 12 btrtl,btintel,btbcm,bnep,btusb
- start/enable bluetooth.service
systemctl status bluetooth
output :
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: di>
Active: active (running) since Thu 2022-01-27 16:09:28 +06; 3h 3min ago
Docs: man:bluetoothd(8)
Main PID: 694 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 14210)
Memory: 2.1M
CPU: 18ms
CGroup: /system.slice/bluetooth.service
└─694 /usr/lib/bluetooth/bluetoothd
Jan 27 16:09:28 Devil-PC systemd[1]: Starting Bluetooth service...
Jan 27 16:09:28 Devil-PC bluetoothd[694]: Bluetooth daemon 5.63
Jan 27 16:09:28 Devil-PC systemd[1]: Started Bluetooth service.
Jan 27 16:09:28 Devil-PC bluetoothd[694]: Starting SDP server
Jan 27 16:09:28 Devil-PC bluetoothd[694]: Bluetooth management interface 1.20 initialized
lines 1-17/17 (END)
- bluetoothctl show
No default controller available
- blueberry output
(blueberry.py:29072): com.linuxmint.blueberry-WARNING **: 19:17:28.671: Could not retrieve the BT adapter name with 'bt-adapter -i': Command '['timeout', '2s', 'bt-adapter', '-i']' died with <Signals.SIGABRT: 6>.
ERROR:lib/bluez/adapter.c:165:adapter_get_dbus_object_path: assertion failed: (ADAPTER_IS(self))
timeout: the monitored command dumped core
(blueberry.py:29072): com.linuxmint.blueberry-WARNING **: 19:17:28.808: Could not retrieve the BT adapter name with 'bt-adapter -i': Command '['timeout', '2s', 'bt-adapter', '-i']' died with <Signals.SIGABRT: 6>.
Additional Information
- lspci’s output
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 630 (rev 04)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller
00:16.0 Communication controller: Intel Corporation 200 Series PCH CSME HECI #1
00:17.0 SATA controller: Intel Corporation 200 Series PCH SATA controller [AHCI mode]
00:1b.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #21 (rev f0)
00:1c.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #5 (rev f0)
00:1c.5 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #6 (rev f0)
00:1c.6 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #7 (rev f0)
00:1c.7 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #8 (rev f0)
00:1d.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #9 (rev f0)
00:1f.0 ISA bridge: Intel Corporation 200 Series PCH LPC Controller (B250)
00:1f.2 Memory controller: Intel Corporation 200 Series/Z370 Chipset Family Power Management Controller
00:1f.3 Audio device: Intel Corporation 200 Series PCH HD Audio
00:1f.4 SMBus: Intel Corporation 200 Series/Z370 Chipset Family SMBus Controller
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
- Journalctl -b | grep -i Blue
Jan 27 12:56:02 Devil-PC kernel: Bluetooth: Core ver 2.22
Jan 27 12:56:02 Devil-PC kernel: Bluetooth: HCI device and connection manager initialized
Jan 27 12:56:02 Devil-PC kernel: Bluetooth: HCI socket layer initialized
Jan 27 12:56:02 Devil-PC kernel: Bluetooth: L2CAP socket layer initialized
Jan 27 12:56:02 Devil-PC kernel: Bluetooth: SCO socket layer initialized
Jan 27 12:56:02 Devil-PC kernel: Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once...
Jan 27 16:09:28 Devil-PC dbus-daemon[697]: Encountered error 'Unknown element <policy> at root of configuration file' while parsing '/etc/dbus-1/system.d/bluetooth.conf'
Jan 27 16:09:28 Devil-PC dbus-daemon[697]: dbus-daemon[697]: Encountered error 'Unknown element <policy> at root of configuration file' while parsing '/etc/dbus-1/system.d/bluetooth.conf'
Jan 27 16:09:28 Devil-PC audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 27 16:09:28 Devil-PC systemd[1]: Reached target Bluetooth Support.
Jan 27 16:09:28 Devil-PC kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jan 27 16:09:28 Devil-PC kernel: Bluetooth: BNEP filters: protocol multicast
Jan 27 16:09:28 Devil-PC kernel: Bluetooth: BNEP socket layer initialized
Jan 27 16:09:28 Devil-PC NetworkManager[698]: <info> [1643278168.5624] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-bluetooth.so)
Jan 27 16:09:33 Devil-PC kernel: Bluetooth: hci0: CSR: Failed to suspend the device for our Barrot 8041a02 receive-issue workaround
Jan 27 16:09:38 Devil-PC kernel: Bluetooth: hci0: setting interface failed (110)
System Information
inxi -F
Host: Devil-PC Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 Desktop: i3 4.20.1
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: B250M-D2V v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B250M-D2V-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F8 date: 04/10/2018
Info: quad core model: Intel Core i5-7400 bits: 64 type: MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 1024 min/max: 800/3500 cores: 1: 800 2: 800 3: 800
4: 1699
Device-1: Intel HD Graphics 630 driver: i915 v: kernel
Display: x11 server: X.Org 1.21.1.3 driver: loaded: modesetting
resolution: 1366x768~60Hz
Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
Device-2: C-Media USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
driver: r8169
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: e0:d5:5e:d0:e7:ca
driver: btusb
Report: bt-adapter ID: hci0 state: up address: N/A
Local Storage: total: 1.13 TiB used: 748.67 GiB (64.8%)
ID-1: /dev/sda vendor: Toshiba model: HDWD110 size: 931.51 GiB
ID-2: /dev/sdb vendor: GALAX model: GAMER L TA1D0240A size: 223.57 GiB
ID-1: / size: 110.94 GiB used: 92.65 GiB (83.5%) fs: ext4 dev: /dev/sdb5
ID-2: /boot/efi size: 297 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/sdb7
ID-1: swap-1 type: partition size: 10 GiB used: 0 KiB (0.0%) dev: /dev/sdb6
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 177 Uptime: 39m Memory: 11.58 GiB used: 2.2 GiB (19.0%)
Shell: Zsh inxi: 3.3.12
