I’m having this issue where the screen keeps flashing blue for a slit second. This is a fresh install of Manjaro KDE. I noticed it in the live USB as well. I had Pop!_OS installed right before installing Manjaro and was not happening there. I’ve never had this happen on any distro I’ve ever used. It did not show up on screen recording. I did manually record a video of it but I cant link the video here. I’ve tried changing display cords switching plugs. It doesn’t seem to be happening during anything specific. Just periodically and randomly flashes blue. It’s slow enough to be noticeable but its really just a fraction of a second. I only caught it on a single frame on my phones camera, where it shows the screen completely blue.
Hi @tjrissi, and welcome!
It sounds like some kind of driver issue to me. However, to get a better diagnosis, albeit not from me, much more information is necessary. Please see [HowTo] Provide System Information and, if applicable, [HowTo] post screenshots and links. And please note, the same that goes for screenshots, will be valid for videos.
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=104d0e7c-e6f1-4cb4-8018-35a198d4b173 rw quiet apparmor=1
security=apparmor resume=UUID=bb324b75-9b6c-4781-a71c-863081bc8198
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4010
date: 07/21/2021
Device-1: hidpp_battery_0 model: Logitech PRO X Wireless serial: <filter>
charge: 86% rechargeable: yes status: Discharging
RAM: total: 15.6 GiB used: 1.96 GiB (12.5%)
RAM Report:
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4194 high: 4216 min/max: 2200/5361 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4202 2: 4216
3: 4166 4: 4199 5: 4167 6: 4186 7: 4203 8: 4200 9: 4194 10: 4198 11: 4203
12: 4196 13: 4199 14: 4189 15: 4203 16: 4186 bogomips: 134460
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Gigabyte
driver: amdgpu v: kernel bus-ID: 0b:00.0 chip-ID: 1002:73bf class-ID: 0300
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
OpenGL: renderer: AMD Radeon RX 6800 XT (SIENNA_CICHLID DRM 3.42.0
5.15.12-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.2 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 0b:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0d:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Logitech [G533 Wireless Headset Dongle] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4:2 chip-ID: 046d:0a66
class-ID: 0300
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 5.03 TiB used: 642.89 GiB (12.5%)
model: WD BLACK SN850 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 611100WD temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 31.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDBNCE5000PNC
type: SSD serial: <filter> rev: 20RL scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM024 HN-M101MBB
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Ultra
size: 28.64 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 914.06 GiB size: 898.64 GiB (98.31%)
used: 275.54 GiB (30.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 104d0e7c-e6f1-4cb4-8018-35a198d4b173
label: NO_LABEL uuid: 6C5B-7D1F
ID-3: /run/media/tanner/C0C27451C2744DA2 raw-size: 930.91 GiB
size: 930.91 GiB (100.00%) used: 365.26 GiB (39.2%) fs: ntfs
dev: /dev/nvme1n1p4 maj-min: 259:8 label: N/A uuid: C0C27451C2744DA2
ID-4: /run/media/tanner/HDD raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 71.6 MiB (0.0%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: HDD
uuid: 445d2b65-1fbd-4639-a2a9-af9201fbfb5c
ID-5: /run/media/tanner/QVO raw-size: 1.82 TiB size: 1.79 TiB (98.38%)
used: 1.95 GiB (0.1%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: QVO
uuid: 7d920fba-96a6-4ae6-9755-7b6d6cff3596
ID-6: /run/media/tanner/SDD raw-size: 465.76 GiB size: 457.45 GiB (98.22%)
used: 69.9 MiB (0.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: SDD
uuid: 1c5f2f00-c90d-4ec7-8f13-13cc5d2b9d06
ID-1: swap-1 type: partition size: 17.16 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: bb324b75-9b6c-4781-a71c-863081bc8198
ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 499 MiB fs: ntfs label: N/A
uuid: 9496E8E496E8C836
ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 100 MiB fs: vfat label: N/A
uuid: 2672-EE51
ID-3: /dev/nvme1n1p3 maj-min: 259:7 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdd1 maj-min: 8:49 size: 3.58 GiB fs: iso9660
ID-5: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 8078-6038
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-1:2 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Device-2: 1-2:3 info: Microdia Backlit Gaming Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 0c45:652f class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-4:2 info: SanDisk Ultra type: Mass Storage driver: usb-storage
interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA chip-ID: 0781:5581
class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: Logitech [G533 Wireless Headset Dongle]
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 046d:0a66 class-ID: 0300
Device-2: 3-6:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 5-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-7: 5-2.4:4 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 5-4:3 info: Logitech PowerPlay Wireless Charging System
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 498mA chip-ID: 046d:c53a class-ID: 0300
Hub-8: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-9: 6-2:2 info: Genesys Logic USB3.0 Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 05e3:0617 class-ID: 0900
Hub-10: 6-2.4:3 info: Genesys Logic USB3.0 Hub ports: 4 rev: 3.0
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 40.0 C mem: 36.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 370 Uptime: 0m wakeups: 4 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1302 lib: 387 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11```
Video
https://youtu.be/M1XwYpUh4kA
Read the guide more carefully.
Wrap the text of the output in three backticks (```) before and after the text, as was mentioned in the guide.
Yea i fixed it.
Thank you!
Have you tried using a different kernel? Version 5.10
or 5.4
specifically?
I have not yet. I’ll try that now.
In your case I might also try 5.16 kernel.
By the way … you do also have BIOS update.
It might even be a problem with the cable
Do you use a VGA-cable ?
So after booting 5.10 and logging in, DisplayPort signal stops working. Can only get past login with HDMI.
OK, and 5.4
Trying it now
I think it’s safe to say, that’s a “no”:
that blue flashing haven’t happened yet since switching from 5.15, but 144hz dosnt look like 144hz, looks like 60
Please find your preferred kernel between latest/best-performing of 5.4,5.10,5.15,5.16, then report back with choice and current status (such as the rate thing) and we will go from there.
Maybe repost inxi, as it might change slightly.
I’ll test them then report back.
@cscs @Mirdarthos
5.16 seems to have the same blue flashes that 5.15 has.
5.10 goes black screen after login with DP. With HDMI it gets past login but is not running at 144hz like it claims to be.
5.4 doesn’t boot at all. On boot it shows that nvme0n1p clean files
stuff then does nothing.
I downloaded 5.14 and so far it seems to have no issues at all.
inxi on 5.14
Kernel: 5.14.21-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
udev.log_priority=3
date: 07/21/2021
charge: 85% rechargeable: yes status: Discharging
RAM: total: 15.54 GiB used: 2.29 GiB (14.8%)
RAM Report:
Speed (MHz): avg: 4198 high: 4224 min/max: 2200/5361 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4195 2: 4198
3: 4198 4: 4206 5: 4197 6: 4199 7: 4197 8: 4197 9: 4184 10: 4197 11: 4224
12: 4195 13: 4199 14: 4177 15: 4208 16: 4200 bogomips: 134450
5.14.21-2-MANJARO LLVM 13.0.0)
class-ID: 0403
class-ID: 0403
class-ID: 0300
Sound Server-1: ALSA v: k5.14.21-2-MANJARO running: yes
Local Storage: total: 5 TiB used: 643.93 GiB (12.6%)
rev: 611100WD temp: 38.9 C scheme: GPT
rev: 2B2QEXM7 temp: 35.9 C scheme: GPT
used: 276.58 GiB (30.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
uuid: 2672-EE51
System Temperatures: cpu: 26.1 C mobo: N/A gpu: amdgpu temp: 54.0 C
mem: 52.0 C
Processes: 332 Uptime: 8m wakeups: 4 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1307 lib: 388 flatpak: 0 Shell: Zsh
