I recently switched to Manjaro from Windows, and I noticed that the sound quality was better on Windows (same laptop, HP 15). On Manjaro, the audio sounds like it’s coming from inside a box. I tried uninstalling PipeWire and switching to PulseAudio, but I couldn’t get it to work. I really want to improve the sound quality—can anyone help me?
Hi @iblacking
Please provide some system information (see below), and describe in as much detail as possible the steps you’ve taken.
This will allow a better understanding of your environment for those wishing to help, and discourage duplication of suggestions that you might have already done.
I’m sure someone will help as soon as they are able.
As a new or infrequent forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
Required Reading:
Resources:
Update Announcements:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
inxi --verbosity=8 --filter
Be prepared to provide more information and outputs from other commands when asked.
Thanks for the information. Now, I’ll share some basic details about my PC and what I did.
First, I completely uninstalled PulseAudio to use PipeWire. Then, I did the opposite, but it didn’t work—I couldn’t hear anything. However, when I switched back to PipeWire, my PC was able to produce sound again.
System Information:
- OS: Manjaro Linux x86_64
- Host: Victus by HP Gaming Laptop 15-fb0xxx
- Kernel: Linux 6.6.74-1-MANJARO
- Uptime: 53 mins
- Packages: 1,164 (pacman) [stable]
- Shell: Bash 5.2.37
- Display 1 (BOE0991): 1920x1080 @ 60 Hz (16", Built-in)
- Display 2 (CR240DM): 1920x1080 @ 144 Hz (24", External)
- DE: GNOME 47.3
- WM: Mutter (X11)
- WM Theme: adw-gtk3-dark
- Theme: KvLibadwaitaMaiaDark [Qt], adw-gtk3-dark [GTK2/3/4]
- Icons: Papirus-Dark-Maia [Qt], Papirus-Dark-Maia [GTK2/3/4]
- Font: qt5ct [Qt], Noto Sans (11pt) [GTK2/3/4]
- Terminal: GNOME Terminal 3.54.3
- Terminal Font: MesloLGS NF (11pt)
- CPU: AMD Ryzen 5 5600H (12) @ 4.28 GHz
- GPU 1: NVIDIA GeForce RTX 3050 Mobile (Discrete)
- GPU 2: AMD Radeon Vega Series / Radeon Vega Mobile Series (Integrated)
- Memory: 6.87 GiB / 22.81 GiB (30%)
- Swap: Disabled
- Disk (/): 27.55 GiB / 139.32 GiB (20%) - ext4
Thanks for the effort. However, the best way to obtain useful information for Support purposes is to ask your system directly.
The command to do that was given above:
Please provide the output from this command.
Place it between 2 rows of 3 backtick characters, like so:
[Your pasted command output here]
If you are concerned about privacy, please note that the --filter parameter filters out all personally identifiable information from the command output.
Manjaro has metapackages manjaro-pulse and manjaro-pipewire to switch between PulseAudio and PipeWire audio servers
Specifications for Victus by HP 15.6 inch Gaming Laptop 15-fb0000 shows system has proprietary software “Audio by B&O” to enhance audio to speakers on Windows that is not supported on Linux
Headphones or external speakers plugged in to 3.5mm jack is likely to deliver better audio quality from on board audio codec (Realtek ALC245) without additional processing software
Linux has Easyeffects and JamesDSP to enhance laptop speaker audio
pamac install easyeffects
[How To] Make Linux sound GREAT!
pamac build jamesdsp
[HowTo] Make Linux Sound BETTER, easier, with JamesDSP
System has 2 downward-facing speakers so speaker audio quality would be affected by the type of surface it is placed on
Low quality speaker audio is a common problem for modern thin laptops because speakers are too small to reproduce bass frequencies. Modern laptops also have lower power amplifiers for better battery life
Oh sorry, my bad. I didn’t share it because I thought it was too long, so I sent that one instead.Now I share the correct
Kernel: 6.6.74-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=fb88d279-8a9b-46b1-aff3-ad67ccd15d04 rw quiet splash apparmor=1
Desktop: GNOME v: 47.3 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: HP product: Victus by HP Gaming Laptop 15-fb0xxx v: N/A
Mobo: HP model: 8A3D v: 35.48 serial: <superuser required>
part-nu: 6F7G6LA#ABM uuid: <superuser required> UEFI: AMI v: F.22
date: 07/23/2024
ID-1: BAT0 charge: 58.6 Wh (95.4%) condition: 61.4/61.4 Wh (100.0%)
volts: 17.6 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
status: charging cycles: 222
System RAM: total: 32 GiB available: 30.69 GiB used: 4.3 GiB (14.0%)
Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous
unbuffered (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check
curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Corsair part-no: CMSX16GX4M1A3200C22 serial: N/A
Device-2: Bottom - Slot 2 (right) type: DDR4 detail: synchronous
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
microcode: 0xA500011
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 400 min/max: 400/4280 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 79080
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
affected
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: HDMI-A-1 empty: none bus-ID: 01:00.0
chip-ID: 10de:25a2 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: DP-1 bus-ID: 06:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 51.0 C
Device-3: Quanta HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 0408:5481
Display: x11 server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: amdgpu,fbdev,nouveau,nv,vesa dri: radeonsi
gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: right
model: CR240DM serial: <filter> built: 2022 res: N/A dpi: 92 gamma: 1.2
chroma: red: x: 0.663 y: 0.329 green: x: 0.275 y: 0.616 blue: x: 0.137
y: 0.090 white: x: 0.325 y: 0.373 size: 527x296mm (20.75x11.65")
diag: 658mm (25.9") ratio: 4:3 modes: 1920x1080, 1680x1050, 1600x900,
1280x1024, 1440x900, 1280x960, 1366x768, 1152x864, 1280x720, 1024x768,
800x600, 720x576, 720x480, 640x480
Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x0991 built: 2020
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
x: 0.580 y: 0.365 green: x: 0.349 y: 0.580 blue: x: 0.165 y: 0.137 white:
x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
1280x720, 1024x768, 800x600, 640x480
EDID-Warnings: 1: parse_edid: unknown flag 2
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi gbm: drv: kms_swrast surfaceless:
drv: nvidia x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
renoir LLVM 19.1.7 DRM 3.54 6.6.74-1-MANJARO) device-ID: 1002:1638
memory: 500 MiB unified: no
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xprop,xrandr
Device-1: NVIDIA GA107 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.74-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 0489:e0e0
Local Storage: total: 476.94 GiB used: 36.73 GiB (7.7%)
model: MZVL2512HCJQ-00BH1 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS3NGXH temp: 44.9 C scheme: GPT
ID-1: / raw-size: 142.62 GiB size: 139.32 GiB (97.69%)
used: 36.65 GiB (26.3%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: fb88d279-8a9b-46b1-aff3-ad67ccd15d04
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 81.2 MiB (31.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 3E01-1130
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 333.35 GiB fs: ntfs
label: Windows uuid: 01DB7A88786111D0
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 705 MiB fs: ntfs label: N/A
uuid: 3E4CA2DC4CA28E69
Hub-2: 1-2:4 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
chip-ID: 214b:7250 class-ID: 0900
Device-1: 1-2.4:5 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1bcf:08a0 class-ID: 0301
Device-2: 1-3:2 info: Quanta HP Wide Vision HD Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0408:5481 class-ID: 0e02
serial: <filter>
Device-3: 1-4:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0489:e0e0 class-ID: e001 serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 58.9 C mobo: 48.0 C gpu: amdgpu temp: 49.0 C
Fan Speeds (rpm): fan-1: 2702 fan-2: 2409
Packages: 1261 pm: pacman pkgs: 1254 libs: 345
tools: gnome-software,pamac,yay pm: flatpak pkgs: 7
1: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
4: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
5: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
6: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
7: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
8: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 363
1: cpu: 100% command: ps pid: 4969 mem: 3.88 MiB (0.0%)
2: cpu: 3.5% command: firefox pid: 2530 mem: 534.6 MiB (1.7%)
3: cpu: 2.8% command: gnome-terminal-server pid: 4864 mem: 58.4 MiB (0.1%)
4: cpu: 1.8% command: gnome-shell pid: 1649 mem: 410.2 MiB (1.3%)
5: cpu: 1.8% command: firefox pid: 3619 mem: 273.2 MiB (0.8%)
Memory top: 5 of 363
1: mem: 534.6 MiB (1.7%) command: firefox pid: 2530 cpu: 3.5%
2: mem: 482.1 MiB (1.5%) command: pamac-manager pid: 4496 cpu: 1.6%
3: mem: 410.2 MiB (1.3%) command: gnome-shell pid: 1649 cpu: 1.8%
4: mem: 366.6 MiB (1.1%) command: firefox pid: 2689 cpu: 1.3%
5: mem: 273.2 MiB (0.8%) command: firefox pid: 3619 cpu: 1.8%
Processes: 363 Power: uptime: 35m states: freeze,mem,disk suspend: s2idle
wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 12.25 GiB services: gsd-power, power-profiles-daemon, upowerd
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.37
Mod Edit:- Corrected command output formatting.
edited by nikgnomic to include audio information
Probably, the frequency response of the loudspeakers are linearized by the sound driver.
I suggest use this to show information about audio
inxi -Aa
and edit previous post to show audio information to confirm system is using PipeWire
Driver snd_hda_intel for analog output to speakers does not include any signal processing (DSP) to equalise or “linearize” audio frequencies
Easyeffects and JamesDSP both include a graphic equalizer to adjust audio frequencies
You misread/misunderstood the instructions given. Your post looked virtually no different than before you edited it; that might have indicated something was obviously wrong…
I have corrected the formatting for you.
In future you are expected to do this yourself according to forum guidelines. See the links previously given.
inxi data in post #6 is incomplete and does not include Audio information
Not helpful for this topic
I suggest install JamesDSP to enhance laptop speaker audio
There is the output
base: Arch Linux
date: 07/23/2024
affected
x11: xprop,xrandr
serial: <filter>
Processes:
CPU top: 5 of 363
Your inxi output was incomplete. Please edit your previous post (as linked) so that it contains the full output of;
inxi -zv8
I have edited post #6 to include Audio information. More data will not help with audio quality issue
Data confirms pipewire, pipewire-pulse, and wireplumber are all active
System has pw-jack plugin so it would also be possible to use pipewire-jack Pro Audio profile with professional audio effects
Now is complete I’m so sorry, I trying to understand how it works everything
