Since the update, it appears that AUR package management is a bit … broken.
auracle: error while loading shared libraries libalpm.so.12: cannot open shared object file: No such file or directory
This is causing the Pacaur command to treat all AUR packages as unavailable
That … didn’t solve the issue it seems.
Only noticed because as part of my startup, I manually launch PulseEffects. I use the AUR version of PulseEffects-Legacy as it is more up to date/works better for me.
After this recent update, it will not launch. No error given in the journal.
omano
13 July 2021 15:04
4
Thank you - my go to is to generally hit up support fora first.
That’s one solved!
omano
13 July 2021 15:51
6
I guess you installed the AUR/GIT version?
If so, would that mean that the Manjaro package needs a rebuild?
Nope, I’m removing it from the repos now.
Yeah, had to use the AUR/GIT version.
Still encountering some errors though - some packages do not appear to be showing up to it even though they are in the AUR.
system
Closed
28 July 2021 16:26
9
