pamac build (package_name)
Failed to query https://aur.archlinux.org/rpc/?v=5&type=info&arg[]=(package_name) from AUR: Socket I/O timed out
Error: target not found: (package_name)
I have read Pamac AUR support sucks , has this DDOS issue 17 days ago fixed?
(I cannot answer at the original post as it has been closed)
I use much AUR packages as typora, visual-studio-code-bin (I do not use Code-OSS ), ds9
here is not a ddos problem
you can test good url , for example
curl 'https://aur.archlinux.org/rpc/?v=5&type=info&arg[]=visual-studio-code-bin'
I used to use yay but after:
解决方法是sudo update-desktop-database,但也不一定有用
因为我现在的网易云音乐和VLC就是这个状态,你可以搜索到它再加到收藏里面
Hardware detection seems to be another advantage Manjaro packaging has over yay. Once I used yay for installing video drivers. It worked but the driver info wasn’t showing up on the Hardware Configuration page. Not crucial I guess but definitely annoying.
I switched to pamac
If pamac is so uneasy to use(does not support auto-AUR, sometimes I/O timed out, clicking AUR, I even cannot find vscode the first time till I clicked update and clicked AUR) , maybe I should switch back to yay
I think the maintainers have under-estimated the security of AUR, maybe a few more choices?
So why is the Socket I/O timed out? It does not happen all the time.
pamac 10.2.2-5
Firestar:
timed out ?
server no response (after xx time), its not a pamac error but your connexion or aur server
OK so its my problem, not pamac’s?
Can I set aururl reverse proxy on pamac?
like this
yay --aururl "https://aur.tuna.tsinghua.edu.cn" --save
I do not find any config files or commands on pamac which supports this.
No, but apparently there’s the cause of your socket timeout. Turn off your Great Firewall.
Perhaps open an issue requesting the feature.
Thanks! I use VPN but it seems to do nothing about this.
I have made an issue:
I’m sorry, I’m going to have to refer you to GFW technical support.
It’s neither an issue with Manjaro nor Aurweb.
system
Closed
10 November 2021 15:23
12
