Audio Trouble (Both PipeWire and PulseAudio)
I have been experiencing an issue with both PulseAudio and Pipewire (I currently have pipewire), where the moment I open an application, my audio stops working and I need to restart the services. I don’t have any masked sockets or services, and pipewire, pipewire-pulse, and wireplumber are enabled. I am new to this so help would be appreciated as I have tried everything I could find online - I imagine it may be a config thing, but should default config not work? I have completely removed pipewire and pulseaudio while troubleshooting (including config), and reinstalled by installing manjaro-pulseaudio, and then manjaro-pipewire which replaced everything necessary.
To get it to work currently I run systemctl --user restart pipewire pipewire-pulse wireplumber whenever the sound stops working.
I feel it may be related to the xdg-portal error seen in the services, but I don’t recall removing an xdg-portal. Is that the xdg-portal-desktop package?
pactlinfo:
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 93
Tile Size: 65472
Server Name: PulseAudio (on PipeWire 0.3.61)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink
Default Source: alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source
Cookie: d689:75d5
Masking:
pipewire-pulse.service                                      enabled   enabled
pipewire-session-manager.service                            alias     -
pipewire.service                                            enabled   enabled
wireplumber.service                                         enabled   enabled
wireplumber@.service                                        disabled  enabled
pipewire-pulse.socket                                       enabled   enabled
pipewire.socket                                             enabled   enabled
Service Status:
wireplumber.service - Multimedia Service Session Manager
     Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
     Active: active (running) since Sun 2022-12-11 18:20:03 EST; 14h ago
   Main PID: 663 (wireplumber)
      Tasks: 5 (limit: 18732)
     Memory: 13.3M
        CPU: 199ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
             └─663 /usr/bin/wireplumber
systemd[640]: Started Multimedia Service Session Manager.
 wireplumber[663]: Can't find xdg-portal: (null)
wireplumber[663]: found session bus but no portal
wireplumber[663]: Failed to set scheduler settings: Operation not permitted
Dec 11 18:20:03 linux-tor-01 wireplumber[663]: [0:00:54.362971133] [663]  INFO Camera camera_manager.cpp:299 libcamera v0.0.2
 pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
TriggeredBy: ● pipewire.socket
   Main PID: 662 (pipewire)
      Tasks: 3 (limit: 18732)
     Memory: 8.5M
        CPU: 132ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
             └─662 /usr/bin/pipewire
systemd[640]: Started PipeWire Multimedia Service.
pipewire[662]: mod.rt: Can't find xdg-portal: (null)
pipewire[662]: mod.rt: found session bus but no portal
pipewire[662]: mod.x11-bell: XOpenDisplay() failed
pipewire[662]: [0:00:54.607443205] [662]  INFO Camera camera_manager.cpp:299
libcamera v0.0.2
pipewire-pulse.service - PipeWire PulseAudio
     Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; preset: enabled)
TriggeredBy: ● pipewire-pulse.socket
   Main PID: 664 (pipewire-pulse)
      Tasks: 2 (limit: 18732)
     Memory: 6.6M
        CPU: 48ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
             └─664 /usr/bin/pipewire-pulse
systemd[640]: Started PipeWire PulseAudio.
pipewire-pulse[664]: mod.rt: Can't find xdg-portal: (null)
pipewire-pulse[664]: mod.rt: found session bus but no portal
pipewire-pulse[677]: 536870912
pactl list cards:
Card #45
        Driver: alsa
        Owner Module: n/a
        Properties:
                api.acp.auto-port = "false"
                api.alsa.card = "0"
                api.alsa.card.longname = "LENOVO-20SA000GUS-ThinkPadX1Yoga4th"
                api.alsa.card.name = "sof-hda-dsp"
                api.alsa.path = "hw:0"
                api.alsa.use-acp = "true"
                device.api = "alsa"
                device.bus = "pci"
                device.bus_path = "pci-0000:00:1f.3-platform-skl_hda_dsp_generic"
                device.description = "Comet Lake PCH-LP cAVS"
                device.enum.api = "udev"
                device.icon_name = "audio-card-analog-pci"
                device.name = "alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic"
                device.nick = "sof-hda-dsp"
                device.plugged.usec = "4491480"
                device.product.id = "0x02c8"
                device.product.name = "Comet Lake PCH-LP cAVS"
                device.subsystem = "sound"
                sysfs.path = "/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0"
                device.vendor.id = "0x8086"
                media.class = "Audio/Device"
                factory.id = "14"
                client.id = "34"
                object.id = "43"
                object.serial = "45"
                object.path = "alsa:pcm:0"
                alsa.card = "0"
                alsa.card_name = "sof-hda-dsp"
                alsa.long_card_name = "LENOVO-20SA000GUS-ThinkPadX1Yoga4th"
                alsa.driver_name = "snd_soc_skl_hda_dsp"
                device.string = "0"
        Profiles:
                off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
                HiFi: Play HiFi quality Music (sinks: 4, sources: 2, priority: 8000, available: yes)
        Active Profile: HiFi
        Ports:
                [Out] HDMI3: HDMI / DisplayPort 3 Output (type: HDMI, priority: 700, latency offset: 0 usec, availability group: HDMI/DP,pcm=5, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "HDMI/DP,pcm=5"
                                card.profile.port = "0"
                        Part of profile(s): HiFi
                [Out] HDMI2: HDMI / DisplayPort 2 Output (type: HDMI, priority: 600, latency offset: 0 usec, availability group: HDMI/DP,pcm=4, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "HDMI/DP,pcm=4"
                                card.profile.port = "1"
                [Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 500, latency offset: 0 usec, availability group: HDMI/DP,pcm=3, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "HDMI/DP,pcm=3"
                                card.profile.port = "2"
                [Out] Speaker: Speaker (type: Speaker, priority: 100, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "speaker"
                                card.profile.port = "3"
                [Out] Headphones: Headphones (type: Headphones, priority: 200, latency offset: 0 usec, availability group: Headphone, not available)
                        Properties:
                                port.type = "headphones"
                                port.availability-group = "Headphone"
                                card.profile.port = "4"
                [In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, latency offset: 0 usec, availability group: Mic, not available)
                        Properties:
                                port.type = "mic"
                                port.availability-group = "Mic"
                                card.profile.port = "5"
                [In] Mic1: Digital Microphone (type: Mic, priority: 100, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "mic"
                                card.profile.port = "6"
Thank you, I will give that a shot! Do you think I should also install whatever package is needed to remove the xdg-portal error in the services? → I have both xdg-desktop-portal and xdg-desktop-portal-kde installed
@ishaan2479 I updated the kernel to the non realtime release of 6 through the GUI, but now my computer is freezing about 30 seconds in to login (or devices are disconnecting). Is there something else I need to do? I have a short window to run a command. → I removed 5.15 now and disconnected bluetooth devices. About to test reconnecting a Bluetooth device. → so far so good. Maybe there was conflict with having the original kernel installed still → so far audio seems to be okay! Will need a little more time to validate, but high hopes. Thank you so much for this advise!
