This is pretty much identical to this post, # Playback and video not working, But the posted solution doesn’t work; I already had manjaro-pipewire installed to begin with. Removing and reinstalling it didn’t do anything either.
Specifically, after restarting my computer, the first application I launch generally is able to play audio ok. The second I open anything else, no audio is output and YouTube reports the “If playback doesn’t begin shortly, try restarting your device” and Spotify gives back the “Can’t Play this Song Right Now”. Restarting the pipewire-pulse service via systemctl restart --user pipewire-pulse.service will fix it for a few minutes, but then it fails again.
The one thing I have noticed is that the inxi -Fayz output has PulseAudio not running:
❯ inxi -Fayz
Kernel: 5.14.21-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=cec2d4e0-d852-4f58-a084-9d86bcb73abe rw apparmor=1
security=apparmor udev.log_priority=3 apparmor=1 security=apparmor
udev.log_priority=3
resume=/dev/disk/by-uuid/cec2d4e0-d852-4f58-a084-9d86bcb73abe
resume_offset=40210432 mem_sleep_default=deep
Desktop: Qtile v: 0.21.0 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Framework product: Laptop v: A3
serial: <superuser required>
Mobo: Framework model: FRANBMCP03 v: A3 serial: <superuser required>
UEFI: INSYDE v: 03.02 date: 07/01/2021
ID-1: BAT1 charge: 54.0 Wh (100.0%) condition: 54.0/55.0 Wh (98.2%)
volts: 17.6 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
status: discharging
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake built: 2020 process: Intel 10nm family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0x86
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2211 high: 3774 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 733 2: 449 3: 3774
4: 1117 5: 1676 6: 3499 7: 2773 8: 3669 bogomips: 38720
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen12.1 process: Intel 10nm built: 2020-21 ports: active: DP-5,eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-6, DP-7 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Realtek Laptop Camera type: USB driver: uvcvideo bus-ID: 3-7:4
chip-ID: 0bda:5634 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 compositors:
1: Qtile v: 0.21.0 2: Picom v: git-7e568 driver: X: loaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1280 s-dpi: 97 s-size: 1010x337mm (39.76x13.27")
s-diag: 1065mm (41.92")
Monitor-1: DP-5 mapped: DP-4-1 pos: primary,bottom-l
model: Samsung S24E310 serial: <filter> built: 2016 res: 1920x1080 hz: 60
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: top-right model: BOE Display 0x095f built: 2019
res: 1920x1280 hz: 60 dpi: 171 gamma: 1.2 size: 285x190mm (11.22x7.48")
diag: 343mm (13.5") ratio: 3:2 modes: 2256x1504
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
v: kernel bus-ID: 3-6.2.3:9 alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 08bb:2902 class-ID: 0300 chip-ID: 8086:a0c8 class-ID: 0403
Device-2: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-3: Lenovo ThinkPad USB-C Dock Gen2 USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-6.3.3.2:12
chip-ID: 17ef:a396 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.14.21-2-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.56 running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp170s0 state: up mac: <filter>
Device-2: Lenovo USB-C Dock Ethernet type: USB driver: r8152
bus-ID: 2-4.1:9 chip-ID: 17ef:a387 class-ID: 0000 serial: <filter>
IF: enp0s13f0u4u1 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-10:7 chip-ID: 8087:0032 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 1 state: down
bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
Info: acl-mtu: 0:0 sco-mtu: 0:0
Local Storage: total: 931.51 GiB used: 212.92 GiB (22.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 212.91 GiB (23.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 255 Uptime: 12m wakeups: 1 Memory: 31.15 GiB
used: 4.5 GiB (14.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1700
pacman: 1691 lib: 397 flatpak: 9 Shell: Zsh v: 5.9
running-in: xfce4-terminal inxi: 3.3.19
I don’t have a way to start it that I know of, as the pulseaudio command isn’t available. I naively attempted to yay -S pulseaudio, but it’s saying that pipewire-pulse is in conflict with that.
