When I updated my system last, I noticed that I was actually using an unsupported kernel version (5.14.21-2). I tried to update to the 5.15.28-1, but my wifi card doesn’t work with this kernel. The hardware is detected fine via lshw
5.15:
> sudo lshw -c network
[sudo] password for jrwrigh:
*-network
description: Network controller
product: Wi-Fi 6 AX210/AX211/AX411 160MHz
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:aa:00.0
version: 1a
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: irq:17 memory:7a200000-7a203fff
5.14:
❯ sudo lshw -c network
*-network
description: Wireless interface
physical id: 0
logical name: wlp170s0
version: 1a
serial: f4:7b:09:9b:dd:81
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.14.21-2-MANJARO firmware=63.c04f3485.0 ty-a0-gf-a0-63.uc ip=192.168.0.9 latency=0 link=yes multicast=yes wireless=IEEE 802.11
(Note the different description:
between the two). There are also errors in dmesg
. It appears that iwlwifi
is having problems working, but I can’t really see any messages in there that say what is going wrong. The only different thing I can spot between them is that FSEQ Version
is different between the two; 5.15 has 0.63.2.2
while 5.14 has 0.0.2.25
5.15:
> dmesg | grep iwlwifi
[ 2.875130] iwlwifi 0000:aa:00.0: enabling device (0000 -> 0002)
[ 2.885039] iwlwifi 0000:aa:00.0: api flags index 2 larger than supported by driver
[ 2.885051] iwlwifi 0000:aa:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.63.2.2
[ 2.885251] iwlwifi 0000:aa:00.0: loaded firmware version 66.f1c864e0.0 ty-a0-gf-a0-66.ucode op_mode iwlmvm
[ 3.079367] iwlwifi 0000:aa:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 4.104382] iwlwifi 0000:aa:00.0: SecBoot CPU1 Status: 0x7663, CPU2 Status: 0xb03
[ 4.104424] iwlwifi 0000:aa:00.0: UMAC PC: 0x8047f600
[ 4.104449] iwlwifi 0000:aa:00.0: LMAC PC: 0x0
[ 4.104456] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 4.104620] iwlwifi 0000:aa:00.0: Loaded firmware version: 66.f1c864e0.0 ty-a0-gf-a0-66.ucode
[ 4.104625] iwlwifi 0000:aa:00.0: 0x00000000 | ADVANCED_SYSASSERT
[ 4.104630] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status0
[ 4.104634] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status1
[ 4.104638] iwlwifi 0000:aa:00.0: 0x00000000 | branchlink2
[ 4.104642] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink1
[ 4.104646] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink2
[ 4.104650] iwlwifi 0000:aa:00.0: 0x00000000 | data1
[ 4.104654] iwlwifi 0000:aa:00.0: 0x00000000 | data2
[ 4.104657] iwlwifi 0000:aa:00.0: 0x00000000 | data3
[ 4.104661] iwlwifi 0000:aa:00.0: 0x00000000 | beacon time
[ 4.104665] iwlwifi 0000:aa:00.0: 0x00000000 | tsf low
[ 4.104669] iwlwifi 0000:aa:00.0: 0x00000000 | tsf hi
[ 4.104673] iwlwifi 0000:aa:00.0: 0x00000000 | time gp1
[ 4.104676] iwlwifi 0000:aa:00.0: 0x00000000 | time gp2
[ 4.104680] iwlwifi 0000:aa:00.0: 0x00000000 | uCode revision type
[ 4.104684] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version major
[ 4.104688] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version minor
[ 4.104692] iwlwifi 0000:aa:00.0: 0x00000000 | hw version
[ 4.104695] iwlwifi 0000:aa:00.0: 0x00000000 | board version
[ 4.104699] iwlwifi 0000:aa:00.0: 0x00000000 | hcmd
[ 4.104703] iwlwifi 0000:aa:00.0: 0x00000000 | isr0
[ 4.104706] iwlwifi 0000:aa:00.0: 0x00000000 | isr1
[ 4.104710] iwlwifi 0000:aa:00.0: 0x00000000 | isr2
[ 4.104714] iwlwifi 0000:aa:00.0: 0x00000000 | isr3
[ 4.104717] iwlwifi 0000:aa:00.0: 0x00000000 | isr4
[ 4.104721] iwlwifi 0000:aa:00.0: 0x00000000 | last cmd Id
[ 4.104725] iwlwifi 0000:aa:00.0: 0x00000000 | wait_event
[ 4.104729] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_control
[ 4.104733] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_duration
[ 4.104736] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_mhvalid
[ 4.104740] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_addr_match
[ 4.104744] iwlwifi 0000:aa:00.0: 0x00000000 | lmpm_pmg_sel
[ 4.104747] iwlwifi 0000:aa:00.0: 0x00000000 | timestamp
[ 4.104751] iwlwifi 0000:aa:00.0: 0x00000000 | flow_handler
[ 4.104827] iwlwifi 0000:aa:00.0: Start IWL Error Log Dump:
[ 4.104831] iwlwifi 0000:aa:00.0: Transport status: 0x00000042, valid: 7
[ 4.104836] iwlwifi 0000:aa:00.0: 0x201013F2 | ADVANCED_SYSASSERT
[ 4.104841] iwlwifi 0000:aa:00.0: 0x00000000 | umac branchlink1
[ 4.104845] iwlwifi 0000:aa:00.0: 0x8045DFC6 | umac branchlink2
[ 4.104849] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink1
[ 4.104853] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink2
[ 4.104856] iwlwifi 0000:aa:00.0: 0x0000000C | umac data1
[ 4.104859] iwlwifi 0000:aa:00.0: 0x00040000 | umac data2
[ 4.104864] iwlwifi 0000:aa:00.0: 0xDEADBEEF | umac data3
[ 4.104867] iwlwifi 0000:aa:00.0: 0x00000042 | umac major
[ 4.104871] iwlwifi 0000:aa:00.0: 0xF1C864E0 | umac minor
[ 4.104875] iwlwifi 0000:aa:00.0: 0x00012190 | frame pointer
[ 4.104879] iwlwifi 0000:aa:00.0: 0xC0887F34 | stack pointer
[ 4.104883] iwlwifi 0000:aa:00.0: 0x00000000 | last host cmd
[ 4.104887] iwlwifi 0000:aa:00.0: 0x00000000 | isr status reg
[ 4.104933] iwlwifi 0000:aa:00.0: IML/ROM dump:
[ 4.104936] iwlwifi 0000:aa:00.0: 0x00000B03 | IML/ROM error/state
[ 4.104986] iwlwifi 0000:aa:00.0: 0x00007663 | IML/ROM data1
[ 4.105009] iwlwifi 0000:aa:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 4.105027] iwlwifi 0000:aa:00.0: Fseq Registers:
[ 4.105041] iwlwifi 0000:aa:00.0: 0x60000100 | FSEQ_ERROR_CODE
[ 4.105063] iwlwifi 0000:aa:00.0: 0x00440005 | FSEQ_TOP_INIT_VERSION
[ 4.105101] iwlwifi 0000:aa:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 4.105121] iwlwifi 0000:aa:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 4.105141] iwlwifi 0000:aa:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 4.105156] iwlwifi 0000:aa:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 4.105169] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVI_ID
[ 4.105184] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVR_ID
[ 4.105199] iwlwifi 0000:aa:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 4.105224] iwlwifi 0000:aa:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 4.105245] iwlwifi 0000:aa:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 4.105267] iwlwifi 0000:aa:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 4.105289] iwlwifi 0000:aa:00.0: Failed to start RT ucode: -110
[ 4.105295] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 5.667458] iwlwifi 0000:aa:00.0: Failed to run INIT ucode: -110
[ 5.680817] iwlwifi 0000:aa:00.0: retry init count 0
[ 5.689167] iwlwifi 0000:aa:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 6.717780] iwlwifi 0000:aa:00.0: SecBoot CPU1 Status: 0x7665, CPU2 Status: 0xb03
[ 6.717830] iwlwifi 0000:aa:00.0: UMAC PC: 0x8047f600
[ 6.717846] iwlwifi 0000:aa:00.0: LMAC PC: 0x0
[ 6.717848] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 6.717988] iwlwifi 0000:aa:00.0: Loaded firmware version: 66.f1c864e0.0 ty-a0-gf-a0-66.ucode
[ 6.717990] iwlwifi 0000:aa:00.0: 0x00000000 | ADVANCED_SYSASSERT
[ 6.717992] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status0
[ 6.717994] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status1
[ 6.717995] iwlwifi 0000:aa:00.0: 0x00000000 | branchlink2
[ 6.717996] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink1
[ 6.717997] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink2
[ 6.717998] iwlwifi 0000:aa:00.0: 0x00000000 | data1
[ 6.718000] iwlwifi 0000:aa:00.0: 0x00000000 | data2
[ 6.718001] iwlwifi 0000:aa:00.0: 0x00000000 | data3
[ 6.718002] iwlwifi 0000:aa:00.0: 0x00000000 | beacon time
[ 6.718003] iwlwifi 0000:aa:00.0: 0x00000000 | tsf low
[ 6.718004] iwlwifi 0000:aa:00.0: 0x00000000 | tsf hi
[ 6.718006] iwlwifi 0000:aa:00.0: 0x00000000 | time gp1
[ 6.718007] iwlwifi 0000:aa:00.0: 0x00000000 | time gp2
[ 6.718008] iwlwifi 0000:aa:00.0: 0x00000000 | uCode revision type
[ 6.718009] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version major
[ 6.718010] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version minor
[ 6.718012] iwlwifi 0000:aa:00.0: 0x00000000 | hw version
[ 6.718013] iwlwifi 0000:aa:00.0: 0x00000000 | board version
[ 6.718014] iwlwifi 0000:aa:00.0: 0x00000000 | hcmd
[ 6.718015] iwlwifi 0000:aa:00.0: 0x00000000 | isr0
[ 6.718016] iwlwifi 0000:aa:00.0: 0x00000000 | isr1
[ 6.718017] iwlwifi 0000:aa:00.0: 0x00000000 | isr2
[ 6.718018] iwlwifi 0000:aa:00.0: 0x00000000 | isr3
[ 6.718020] iwlwifi 0000:aa:00.0: 0x00000000 | isr4
[ 6.718021] iwlwifi 0000:aa:00.0: 0x00000000 | last cmd Id
[ 6.718022] iwlwifi 0000:aa:00.0: 0x00000000 | wait_event
[ 6.718023] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_control
[ 6.718024] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_duration
[ 6.718025] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_mhvalid
[ 6.718027] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_addr_match
[ 6.718028] iwlwifi 0000:aa:00.0: 0x00000000 | lmpm_pmg_sel
[ 6.718029] iwlwifi 0000:aa:00.0: 0x00000000 | timestamp
[ 6.718030] iwlwifi 0000:aa:00.0: 0x00000000 | flow_handler
[ 6.718097] iwlwifi 0000:aa:00.0: Start IWL Error Log Dump:
[ 6.718098] iwlwifi 0000:aa:00.0: Transport status: 0x00000042, valid: 7
[ 6.718100] iwlwifi 0000:aa:00.0: 0x201013F2 | ADVANCED_SYSASSERT
[ 6.718102] iwlwifi 0000:aa:00.0: 0x00000000 | umac branchlink1
[ 6.718103] iwlwifi 0000:aa:00.0: 0x8045DFC6 | umac branchlink2
[ 6.718105] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink1
[ 6.718106] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink2
[ 6.718107] iwlwifi 0000:aa:00.0: 0x0000000C | umac data1
[ 6.718108] iwlwifi 0000:aa:00.0: 0x00040000 | umac data2
[ 6.718109] iwlwifi 0000:aa:00.0: 0xDEADBEEF | umac data3
[ 6.718111] iwlwifi 0000:aa:00.0: 0x00000042 | umac major
[ 6.718112] iwlwifi 0000:aa:00.0: 0xF1C864E0 | umac minor
[ 6.718113] iwlwifi 0000:aa:00.0: 0x00012115 | frame pointer
[ 6.718114] iwlwifi 0000:aa:00.0: 0xC0887F34 | stack pointer
[ 6.718116] iwlwifi 0000:aa:00.0: 0x00000000 | last host cmd
[ 6.718117] iwlwifi 0000:aa:00.0: 0x00000000 | isr status reg
[ 6.718157] iwlwifi 0000:aa:00.0: IML/ROM dump:
[ 6.718158] iwlwifi 0000:aa:00.0: 0x00000B03 | IML/ROM error/state
[ 6.718174] iwlwifi 0000:aa:00.0: 0x00007665 | IML/ROM data1
[ 6.718185] iwlwifi 0000:aa:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 6.718193] iwlwifi 0000:aa:00.0: Fseq Registers:
[ 6.718200] iwlwifi 0000:aa:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 6.718212] iwlwifi 0000:aa:00.0: 0x00440005 | FSEQ_TOP_INIT_VERSION
[ 6.718224] iwlwifi 0000:aa:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 6.718236] iwlwifi 0000:aa:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 6.718248] iwlwifi 0000:aa:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 6.718259] iwlwifi 0000:aa:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 6.718271] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVI_ID
[ 6.718283] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVR_ID
[ 6.718295] iwlwifi 0000:aa:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 6.718309] iwlwifi 0000:aa:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 6.718323] iwlwifi 0000:aa:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 6.718337] iwlwifi 0000:aa:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 6.718349] iwlwifi 0000:aa:00.0: Failed to start RT ucode: -110
[ 6.718351] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 8.277200] iwlwifi 0000:aa:00.0: Failed to run INIT ucode: -110
[ 8.290460] iwlwifi 0000:aa:00.0: retry init count 1
[ 8.296544] iwlwifi 0000:aa:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 9.331191] iwlwifi 0000:aa:00.0: SecBoot CPU1 Status: 0x7674, CPU2 Status: 0xb03
[ 9.331253] iwlwifi 0000:aa:00.0: UMAC PC: 0x8047f600
[ 9.331274] iwlwifi 0000:aa:00.0: LMAC PC: 0x0
[ 9.331279] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 9.331484] iwlwifi 0000:aa:00.0: Loaded firmware version: 66.f1c864e0.0 ty-a0-gf-a0-66.ucode
[ 9.331488] iwlwifi 0000:aa:00.0: 0x00000000 | ADVANCED_SYSASSERT
[ 9.331492] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status0
[ 9.331495] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status1
[ 9.331497] iwlwifi 0000:aa:00.0: 0x00000000 | branchlink2
[ 9.331499] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink1
[ 9.331502] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink2
[ 9.331504] iwlwifi 0000:aa:00.0: 0x00000000 | data1
[ 9.331506] iwlwifi 0000:aa:00.0: 0x00000000 | data2
[ 9.331508] iwlwifi 0000:aa:00.0: 0x00000000 | data3
[ 9.331510] iwlwifi 0000:aa:00.0: 0x00000000 | beacon time
[ 9.331513] iwlwifi 0000:aa:00.0: 0x00000000 | tsf low
[ 9.331515] iwlwifi 0000:aa:00.0: 0x00000000 | tsf hi
[ 9.331517] iwlwifi 0000:aa:00.0: 0x00000000 | time gp1
[ 9.331519] iwlwifi 0000:aa:00.0: 0x00000000 | time gp2
[ 9.331521] iwlwifi 0000:aa:00.0: 0x00000000 | uCode revision type
[ 9.331524] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version major
[ 9.331526] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version minor
[ 9.331528] iwlwifi 0000:aa:00.0: 0x00000000 | hw version
[ 9.331531] iwlwifi 0000:aa:00.0: 0x00000000 | board version
[ 9.331533] iwlwifi 0000:aa:00.0: 0x00000000 | hcmd
[ 9.331535] iwlwifi 0000:aa:00.0: 0x00000000 | isr0
[ 9.331537] iwlwifi 0000:aa:00.0: 0x00000000 | isr1
[ 9.331539] iwlwifi 0000:aa:00.0: 0x00000000 | isr2
[ 9.331542] iwlwifi 0000:aa:00.0: 0x00000000 | isr3
[ 9.331544] iwlwifi 0000:aa:00.0: 0x00000000 | isr4
[ 9.331546] iwlwifi 0000:aa:00.0: 0x00000000 | last cmd Id
[ 9.331548] iwlwifi 0000:aa:00.0: 0x00000000 | wait_event
[ 9.331550] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_control
[ 9.331553] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_duration
[ 9.331555] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_mhvalid
[ 9.331557] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_addr_match
[ 9.331559] iwlwifi 0000:aa:00.0: 0x00000000 | lmpm_pmg_sel
[ 9.331562] iwlwifi 0000:aa:00.0: 0x00000000 | timestamp
[ 9.331564] iwlwifi 0000:aa:00.0: 0x00000000 | flow_handler
[ 9.331645] iwlwifi 0000:aa:00.0: Start IWL Error Log Dump:
[ 9.331647] iwlwifi 0000:aa:00.0: Transport status: 0x00000042, valid: 7
[ 9.331650] iwlwifi 0000:aa:00.0: 0x201013F2 | ADVANCED_SYSASSERT
[ 9.331654] iwlwifi 0000:aa:00.0: 0x00000000 | umac branchlink1
[ 9.331656] iwlwifi 0000:aa:00.0: 0x8045DFC6 | umac branchlink2
[ 9.331659] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink1
[ 9.331661] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink2
[ 9.331663] iwlwifi 0000:aa:00.0: 0x0000000C | umac data1
[ 9.331666] iwlwifi 0000:aa:00.0: 0x00040000 | umac data2
[ 9.331668] iwlwifi 0000:aa:00.0: 0xDEADBEEF | umac data3
[ 9.331671] iwlwifi 0000:aa:00.0: 0x00000042 | umac major
[ 9.331673] iwlwifi 0000:aa:00.0: 0xF1C864E0 | umac minor
[ 9.331675] iwlwifi 0000:aa:00.0: 0x000121A8 | frame pointer
[ 9.331678] iwlwifi 0000:aa:00.0: 0xC0887F34 | stack pointer
[ 9.331680] iwlwifi 0000:aa:00.0: 0x00000000 | last host cmd
[ 9.331682] iwlwifi 0000:aa:00.0: 0x00000000 | isr status reg
[ 9.331734] iwlwifi 0000:aa:00.0: IML/ROM dump:
[ 9.331736] iwlwifi 0000:aa:00.0: 0x00000B03 | IML/ROM error/state
[ 9.331757] iwlwifi 0000:aa:00.0: 0x00007674 | IML/ROM data1
[ 9.331779] iwlwifi 0000:aa:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 9.331795] iwlwifi 0000:aa:00.0: Fseq Registers:
[ 9.331807] iwlwifi 0000:aa:00.0: 0x60000100 | FSEQ_ERROR_CODE
[ 9.331820] iwlwifi 0000:aa:00.0: 0x00440005 | FSEQ_TOP_INIT_VERSION
[ 9.331832] iwlwifi 0000:aa:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 9.331845] iwlwifi 0000:aa:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 9.331857] iwlwifi 0000:aa:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 9.331870] iwlwifi 0000:aa:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 9.331882] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVI_ID
[ 9.331894] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVR_ID
[ 9.331906] iwlwifi 0000:aa:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 9.331920] iwlwifi 0000:aa:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 9.331935] iwlwifi 0000:aa:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 9.331949] iwlwifi 0000:aa:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 9.331961] iwlwifi 0000:aa:00.0: Failed to start RT ucode: -110
[ 9.331965] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 10.893764] iwlwifi 0000:aa:00.0: Failed to run INIT ucode: -110
[ 10.907171] iwlwifi 0000:aa:00.0: retry init count 2
5.14:
❯ sudo dmesg | grep iwlwifi
[ 2.780154] iwlwifi 0000:aa:00.0: enabling device (0000 -> 0002)
[ 2.796447] iwlwifi 0000:aa:00.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-64.ucode failed with error -2
[ 2.798422] iwlwifi 0000:aa:00.0: api flags index 2 larger than supported by driver
[ 2.798439] iwlwifi 0000:aa:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.25
[ 2.798660] iwlwifi 0000:aa:00.0: loaded firmware version 63.c04f3485.0 ty-a0-gf-a0-63.ucode op_mode iwlmvm
[ 3.063488] iwlwifi 0000:aa:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 3.215474] iwlwifi 0000:aa:00.0: loaded PNVM version 0x5a8dfca
[ 3.226926] iwlwifi 0000:aa:00.0: Detected RF GF, rfid=0x10d000
[ 3.296035] iwlwifi 0000:aa:00.0: base HW address: f4:7b:09:9b:dd:81
[ 3.313513] iwlwifi 0000:aa:00.0 wlp170s0: renamed from wlan0
Here’s the other Hardware info:
❯ inxi -Fza
Kernel: 5.14.21-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=cec2d4e0-d852-4f58-a084-9d86bcb73abe rw apparmor=1
security=apparmor udev.log_priority=3 apparmor=1 security=apparmor
udev.log_priority=3
resume=/dev/disk/by-uuid/cec2d4e0-d852-4f58-a084-9d86bcb73abe
resume_offset=40210432 mem_sleep_default=deep
Desktop: Qtile 0.20.0 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Framework product: Laptop v: A3
serial: <superuser required>
Mobo: Framework model: FRANBMCP03 v: A3 serial: <superuser required>
UEFI: INSYDE v: 03.02 date: 07/01/2021
ID-1: BAT1 charge: 51.5 Wh (94.1%) condition: 54.7/55.0 Wh (99.5%)
volts: 16.8 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
status: Discharging
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x86
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 702 high: 1074 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 474 2: 570 3: 481
4: 1074 5: 764 6: 938 7: 451 8: 867 bogomips: 38720
Type: spectre_v2
mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Realtek Laptop Camera type: USB driver: uvcvideo bus-ID: 3-7:3
chip-ID: 0bda:5634 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositors: 1: Qtile v: 0.20.0
2: Picom v: git-7e568 driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2256x1504 s-dpi: 96 s-size: 596x397mm (23.5x15.6")
s-diag: 716mm (28.2")
Monitor-1: eDP-1 model: BOE Display built: 2019 res: 2256x1504 hz: 60
dpi: 201 gamma: 1.2 size: 285x190mm (11.2x7.5") diag: 343mm (13.5")
ratio: 3:2 modes: 2256x1504
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.21-2-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: no
Sound Server-3: PipeWire v: 0.3.48 running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp170s0 state: up mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-10:5 chip-ID: 8087:0032 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 1 state: down
bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
Info: acl-mtu: 0:0 sco-mtu: 0:0
Local Storage: total: 931.51 GiB used: 164.76 GiB (17.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
temp: 31.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 164.76 GiB (18.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 35.8 C mobo: N/A
Processes: 239 Uptime: 5m wakeups: 1 Memory: 31.15 GiB
used: 1.43 GiB (4.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1654 pacman: 1645 lib: 383 flatpak: 9
Shell: Zsh v: 5.8.1 running-in: xfce4-terminal inxi: 3.3.13
