Can you guys help me?
I have dualboot and the speaker works on windows. The bios doesn’t have fast boot option.
❯ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.4.112-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=e2e43222-b479-4647-9630-d2376c75283f rw quiet
resume=UUID=dfa2496b-3a03-40df-b7b5-a521fac4cd30
Desktop: i3 4.19.1 info: i3bar vt: 7 dm: LightDM 1.30.0
Type: Laptop System: Digibras product: NH4CU03 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Digibras model: NH4CU03 serial: <filter> BIOS: American Megatrends
v: 1.00W date: 04/16/2013
ID-1: BAT0 charge: 17.3 Wh (100.0%) condition: 17.3/31.7 Wh (54.5%)
volts: 16.0 min: 14.4 model: standard type: Li-ion serial: <filter>
status: Full
RAM: total: 3.74 GiB used: 2.02 GiB (54.0%)
Info: Dual Core model: Intel Core i5-3337U bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 3 MiB bogomips: 14368
Speed: 798 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 798 2: 798 3: 798
4: 799
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics
vendor: Holco Enterprise Co /Shuttle driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: xcompmgr driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 2646x1024 s-dpi: 96 s-size: 700x270mm (27.6x10.6")
s-diag: 750mm (29.5")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
Monitor-2: VGA1 res: 1280x1024 hz: 60 dpi: 96 size: 340x270mm (13.4x10.6")
diag: 434mm (17.1")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.0.2 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Holco Enterprise Co /Shuttle driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.4.112-1-MANJARO running: yes
Device-1: Realtek RTL8188EE Wireless Network Adapter vendor: AzureWave
driver: rtl8188ee v: kernel port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8179
class-ID: 0280
vendor: Holco Enterprise Co /Shuttle driver: r8168 v: 8.048.03-NAPI
modules: r8169 port: d000 bus-ID: 02:00.2 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f2 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.59 TiB used: 1.35 TiB (84.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST750LM022 HN-M750MBB
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0002 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Samsung model: S2 Portable
size: 931.51 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SU-208DB rev: TE00
dev-links: cdrom
ID-1: / raw-size: 145.9 GiB size: 142.61 GiB (97.74%)
used: 121.7 GiB (85.3%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: e2e43222-b479-4647-9630-d2376c75283f
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%) used: 4 KiB (0.0%)
fs: vfat dev: /dev/sda7 maj-min: 8:7 label: N/A uuid: 1D1A-E044
ID-3: /mnt/Dados raw-size: 298.54 GiB size: 298.54 GiB (100.00%)
used: 264.88 GiB (88.7%) fs: ntfs dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: EAC8EAE5C8EAAECF
ID-4: /mnt/SAMSUNG raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 925.29 GiB (99.3%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17
label: SAMSUNG uuid: 58A09C08A09BEAB0
ID-5: /mnt/Windows10 raw-size: 249.56 GiB size: 249.56 GiB (100.00%)
used: 66.86 GiB (26.8%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: BCC45565C45522C6
ID-1: swap-1 type: partition size: 4 GiB used: 2 MiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: dfa2496b-3a03-40df-b7b5-a521fac4cd30
ID-1: /dev/sda1 maj-min: 8:1 size: 549 MiB fs: ntfs
label: Reservado pelo Sistema uuid: 92AC44ECAC44CD03
ID-2: /dev/sda3 maj-min: 8:3 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.3:3 info: Samsung Samsung S2 Portable type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 04e8:1f08 class-ID: 0806 serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 2-1.2:3 info: Unknown Manufacturer hub ports: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0a05:7211 class-ID: 0900
Device-1: 2-1.2.3:4 info: SiliconWin mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 0000:3821 class-ID: 0301
Device-2: 2-1.2.4:5 info: SiGma Micro Keyboard TRACER Gamma Ivory
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 98mA chip-ID: 1c4f:0002 class-ID: 0300
System Temperatures: cpu: 42.0 C mobo: 29.8 C
Processes: 165 Uptime: 1h 04m wakeups: 1 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1881
lib: 392 Shell: Zsh v: 5.8 running-in: st inxi: 3.3.04
Screenshot from pulseaudio
https://paste.pics/7ea5e92b587025276e31077c3cf91072
Alsa information
http://alsa-project.org/db/?f=6f047595a66f5cafc6992f6f4ed9128c6bb4ccd6
