My system keeps freezing randomly
My manjaro install keeps freezing randomly. Sometimes it does it while i am using firefox, sometimes when using other programs. I have a dual boot system and dont have any of those problems in windows, and before using manjaro in this partition I was using mint cinnamon without any issues.
Here is the current state of inti -Fxz
inxi -Fxz
  Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    Desktop: KDE Plasma v: 5.26.5 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: HP product: HP Laptop 15-gw0xxx v: Type1ProductConfigId
    serial: <superuser required>
  Mobo: HP model: 87D1 v: 38.25 serial: <superuser required> UEFI: Insyde
    v: F.31 date: 06/16/2022
  ID-1: BAT1 charge: 29.3 Wh (79.6%) condition: 36.8/41.0 Wh (89.6%)
    volts: 11.6 min: 11.4 model: Hewlett-Packard PABAS0241231
    status: discharging
  Info: quad core model: AMD Ryzen 5 3450U with Radeon Vega Mobile Gfx
    bits: 64 type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 384 KiB
    L2: 2 MiB L3: 4 MiB
  Speed (MHz): avg: 1458 high: 2287 min/max: 1400/2100 boost: enabled cores:
    1: 1201 2: 1479 3: 1351 4: 1239 5: 1400 6: 2287 7: 1312 8: 1400
    bogomips: 33550
  Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 bus-ID: 04:00.0
    temp: 42.0 C
  Device-2: Quanta HP Webcam type: USB driver: uvcvideo bus-ID: 3-2.1:3
  Display: x11 server: X.Org v: 21.1.7 driver: X: loaded: amdgpu
    unloaded: modesetting dri: radeonsi gpu: amdgpu resolution: 1366x768~60Hz
  API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon Vega 8 Graphics
    (raven LLVM 15.0.7 DRM 3.49 6.1.12-1-MANJARO) direct-render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 04:00.1
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
    driver: snd_pci_acp3x v: kernel bus-ID: 04:00.5
  Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 04:00.6
  Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
    vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
  Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: 2000 bus-ID: 02:00.0
  Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
    bus-ID: 3-2.3:4
  Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
  Local Storage: total: 238.47 GiB used: 13.89 GiB (5.8%)
  ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG40ZNV256G KIOXIA
    size: 238.47 GiB temp: 44.9 C
  ID-1: / size: 78.2 GiB used: 13.79 GiB (17.6%) fs: ext4 dev: /dev/nvme0n1p5
  ID-2: /boot/efi size: 256 MiB used: 101.4 MiB (39.6%) fs: vfat
    dev: /dev/nvme0n1p1
  System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
  Processes: 248 Uptime: 10m Memory: 3.28 GiB used: 3.06 GiB (93.4%)
  Init: systemd Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1181 Shell: Zsh
  v: 5.9 inxi: 3.3.25
you are running out of ram… 4gb of ram is really nothing… either:
upgrade your ram;
or set up swap - i dont have swap so you have to look it up on how to do it…
disable baloo: system settings/ file search and uncheck all options, click apply
I have 32GB RAM in my computer and a swap partition of 32 GB.
Hi @Vladimirovski, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Please edit your post accordingly. # Hi @, and welcome!
Hope you manage!
pasted text
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
Please also provide the output of:
journalctl --boot=-1 --priority=4 --no-pager
Where:
  • --boot=-1 limits the messages to show to the previous boot’s. Adjust this as neccessary to limit to the last boot you had hanging, -1 for the previous boot, -2 for the one before that, and so on and so forth;
  • --priority=4 limits the output to be errors and warning only;
  • --no-pager eliminates it of being scrollable with the up/down arrows, making it suitable for copy-and-paste to the forum.
Hope you manage!
Necro-bumping is not allowed. Please start a new thread.
