Hello ARM community.
First update after our 22.06 release!
Plasma 5.25 is here!
Some highlights:
- Most of our kernels got updated
- Firefox updated to 102.0.1
- Thunderbird updated to 91.11.0
- QT5 updated to 5.15.5
- KDE Plasma updated to 5.25.2
- Plasma Mobile Gear updated to 22.06
- Gnome updated to 42.3
- Megapixels updated to 1.5.2
- Element Desktop updated to 1.11.0
- Added Mattermost Desktopo to repository
- Lots of updated packages for our Mobile offerings
- The regular Python updates
- And regular updates from upstream
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installed. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
Chromium will loose sync support in early March:
Arch Linux - News: Chromium losing Sync support in early March
ghostpcl>=9.53.2-2 and ghostxps>=9.53.2-2 updates require manual intervention:
The nss and zn_poly packages requires manual intervention:
Arch Linux - News: zn_poly 0.9.2-2 update requires manual intervention
The packages hplip and firewalld requires manual intervention:
Package changes:
(Sun Jul 10 18:57:09 CEST 2022)
- arm-stable community aarch64: 788 new and 760 removed package(s)
- arm-stable core aarch64: 60 new and 60 removed package(s)
- arm-stable extra aarch64: 577 new and 670 removed package(s)
- arm-stable kde-unstable aarch64: 394 new and 393 removed package(s)
See the full package list here
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #manjaro-arm:arm-testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
Donation
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Poll
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
