I have a laptop with an Intel Optane H10 drive which is just a combination of two nvme drives, one of which is much faster than the other and is used for accelerating the other which doesn’t work in Linux as Intel did not make a driver for it.
So I have optane acceleration and secure boot disabled and I tried to install Manjaro many times but it did not work so I tried other distributions. List of which worked and which did not:
Ubuntu: Boots
Linux Mint: Boots
Fedora: Boots
Arch: Does not boot
Garuda Linux: Does not boot
Manjaro (Gnome, KDE, Architect): Does not boot
Debian: Does not detect the nvme disks at all
So basically the Arch distros don’t boot
All of the Arch distros had the same error that they could not find the root partition to mount it during boot and then tell the UUID of the root partition.
As I can understand all of the distros I tested use UUID for fstab. I have been trying to troubleshoot this for a very long time.
Any help is much appreciated as Manjaro is my distro of choice and I don’t want to use any of the others.
inxi -Fxxxza
I know that this is from Ubuntu. Read the whole post to understand.
Kernel: 5.11.0-16-generic x86_64 bits: 64 compiler: gcc v: 10.3.0
parameters: BOOT_IMAGE=/casper/vmlinuz file=/cdrom/preseed/ubuntu.seed
maybe-ubiquity quiet splash ---
Desktop: GNOME 3.38.4 tk: GTK 3.24.25 wm: gnome-shell dm: GDM3 3.38.2.1
Distro: Ubuntu 21.04 (Hirsute Hippo)
Type: Convertible System: HP
product: HP Pavilion x360 Convertible 14m-dw1xxx v: N/A serial: <filter>
Chassis: type: 31 serial: <filter>
Mobo: HP model: 87F4 v: 39.25 serial: <filter> UEFI: AMI v: F.11
date: 02/18/2021
ID-1: BAT0 charge: 41.9 Wh (100.0%) condition: 41.9/41.9 Wh (100.0%)
volts: 13.0 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Unknown cycles: 193
Device-1: hid-0018:04F3:2B55.0001-battery model: ELAN2513:00 04F3:2B55
serial: N/A charge: N/A status: N/A
Info: Quad Core model: 11th Gen Intel Core i5-1135G7 socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1
microcode: 6E cache: L1: 320 KiB L2: 8 MiB L3: 8 MiB
bogomips: 38707
Speed: 1101 MHz min/max: 400/4200 MHz base/boost: 2400/4200 volts: 0.7 V
ext-clock: 100 MHz Core speeds (MHz): 1: 1101 2: 1165 3: 1160 4: 1101
5: 1100 6: 1100 7: 1107 8: 1100
Device-1: Intel TigerLake GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 3-6:4 chip-ID: 04f2:b6bb class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting unloaded: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158
size: 309x174mm (12.2x6.9") diag: 355mm (14")
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: sof-audio-pci alternate: snd_hda_intel,snd_sof_pci
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.11.0-16-generic running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Sound Server-3: PipeWire v: 0.3.24 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel port: 3000
bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:6
chip-ID: 8087:0026 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 3.0
lmp-v: 5.2 sub-v: 2279 hci-v: 5.2 rev: 2279
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: slave accept service-classes: rendering, capturing, audio
Hardware-1: Intel Volume Management Device NVMe RAID Controller
driver: vmd v: 0.6 port: 3000 bus-ID: 0000:00:0e.0 chip-ID: 8086.9a0b rev:
class-ID: 0104
Local Storage: total: 519.13 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202AH
size: 476.94 GiB block-size: physical: 512 B logical: 512 B
speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: HPS2
temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Intel model: HBRPEKNX0202AHO
size: 27.25 GiB block-size: physical: 512 B logical: 512 B
speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: HPS3
temp: 53.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: HP model: v236w
size: 14.94 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: N/A size: 3.71 GiB used: 314.2 MiB (8.3%) fs: overlay
source: ERR-102
Missing: Required tool sensors not installed. Check --recommends
Processes: 282 Uptime: 7m wakeups: 822 Memory: 7.42 GiB
used: 2.44 GiB (32.9%) Init: systemd v: 247 runlevel: 5 tool: systemctl
Compilers: gcc: N/A Packages: 1853 apt: 1847 lib: 847 snap: 6
Shell: Bash (sudo) v: 5.1.4 running-in: gnome-terminal inxi: 3.3.06
