Amarok 2.9.71-1 error when start. org.freedesktop.dbus.error.serviceunknown
Hi there! Today after the download of the [Stable Update] 2022-02-27. Amarok (amarok 2.9.71-1) error when start. org.freedesktop.dbus.error.serviceunknown.
uninstall Amarok completely, and reinstalled (failed installation), any help?
restart your system
reboot computer. uninstall Amarok completely, and reinstalled (failed installation), from AUR package.
av_new_packet
make[2]: *** [src/CMakeFiles/amaroklib.dir/build.make:6678: src/CMakeFiles/amaroklib.dir/musicbrainz/MusicDNSAudioDecoder.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:4296: src/CMakeFiles/amaroklib.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
==> ERROR: A failure occurred in build().
Aborting…
@Nail My AUR in Pamac has had some issues lately. Try installing Yay and getting/updating your AUR packages through there. The only potential downside is that Yay requires you to use the terminal.
I don’t know if it helps, but I found this thread when I was looking after my “problem”.
After I installed the new Amarok it did not start with the following plasma error “org.freedesktop.DBus.Error.ServiceUnknown”.
I now start it with the konsole and it works… not a solution, but at least now I can live with this bug :wink:
Here is a better solution:
https://aur.archlinux.org/packages/amarok
→ works for me
