After update to kernel 5.10, cannot enable external monitor
I’m on a laptop. When I go to the display options, the external monitor shows up, and the information is correct, as far as I can tell. However, I cannot enable it. When I hit the enable button, it asks if I want to keep the current display options or revert. Regardless of what I choose, nothing happens. Any ideas? Here is my basic info:
$ inxi -Fazy
System:    Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.14.3
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Micro-Star product: GF65 Thin 9SD v: REV:1.0 serial: <filter>
           Mobo: Micro-Star model: MS-16W1 v: REV:1.0 serial: <filter> UEFI: American Megatrends
           v: E16W1IMS.108 date: 12/04/2019
Battery:   ID-1: BAT1 charge: 38.5 Wh condition: 48.7/51.3 Wh (95%) model: MSI Corp. MS-16W1
           status: Unknown
           Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
           charge: 55% (should be ignored) status: Discharging
CPU:       Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake
           note: check rev: A L2 cache: 12 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62431
           Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 799 4: 800
           5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Graphics:  Device-1: Intel UHD Graphics 630 vendor: Micro-Star MSI driver: i915 v: kernel
           bus ID: 00:02.0
           Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Micro-Star MSI
           driver: nvidia v: 455.45.01 bus ID: 01:00.0
           Device-3: Acer HD Webcam type: USB driver: uvcvideo bus ID: 1-11:3
           Display: x11 server: X.Org 1.20.10 driver: modesetting,nvidia unloaded: intel,nouveau
           resolution: 1920x1080~120Hz
           OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.1
           direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel
           v: kernel bus ID: 00:1f.3
           Sound Server: ALSA v: k5.10.2-2-MANJARO
Network:   Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 6000
           bus ID: 00:14.3
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
           driver: r8169 v: kernel port: 3000 bus ID: 04:00.0
           IF: enp4s0 state: down mac: <filter>
           IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Drives:    Local Storage: total: 953.88 GiB used: 345.77 GiB (36.2%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLV512HCJH-000L2 size: 476.94 GiB
           temp: 39.9 C
           ID-2: /dev/nvme1n1 vendor: Western Digital model: PC SN530 SDBPNPZ-512G-1032
           size: 476.94 GiB temp: 43.9 C
Partition: ID-1: / size: 125.3 GiB used: 94.51 GiB (75.4%) fs: ext4 dev: /dev/nvme1n1p4
           ID-2: /boot/efi size: 500 MiB used: 26.1 MiB (5.2%) fs: vfat dev: /dev/nvme1n1p1
           ID-3: /home size: 310.67 GiB used: 177.45 GiB (57.1%) fs: ext4 dev: /dev/nvme1n1p3
Swap:      ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) dev: /dev/nvme1n1p2
Sensors:   System Temperatures: cpu: 63.0 C mobo: N/A
Info:      Processes: 341 Uptime: 7m Memory: 31.2 GiB used: 3.54 GiB (11.4%) Init: systemd
           Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: 1902 Client: Unknown Client: wrapper-2.0
           inxi: 3.2.01
$ cat /var/log/Xorg.0.log
[    13.626]
X.Org X Server 1.20.10
[    13.626] Build Operating System: Linux Manjaro Linux
[    13.626] Current Operating System: Linux dragontop 5.10.2-2-MANJARO #1 SMP PREEMPT Tue Dec 22 08:14:42 UTC 2020 x86_64
[    13.626] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=9ce0d192-74cb-480c-a301-5218e56ae9d2 rw apparmor=1 security=apparmor resume=UUID=5b9fd5b9-6a63-41d5-977e-336d40f2ebaf udev.log_priority=3
[    13.626] Build Date: 16 December 2020  10:33:32PM
[    13.626]
[    13.626] Current version of pixman: 0.40.0
[    13.626] 	Before reporting problems, check http://wiki.x.org
[    13.626] Markers: (--) probed, (**) from config file, (==) default setting,
[    13.626] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jan  2 14:13:04 2021
[    13.627] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    13.627] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    13.628] (==) ServerLayout "layout"
[    13.628] (==) No screen section available. Using defaults.
[    13.628] (**) |-->Screen "Default Screen Section" (0)
[    13.628] (**) |   |-->Monitor "<default monitor>"
[    13.628] (==) No monitor specified for screen "Default Screen Section".
[    13.628] (==) Automatically adding devices
[    13.628] (==) Automatically enabling devices
[    13.628] (==) Automatically adding GPU devices
[    13.628] (==) Automatically binding GPU devices
[    13.628] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    13.629] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[    13.629] 	Entry deleted from font path.
[    13.629] 	(Run 'mkfontdir' on "/usr/share/fonts/misc").
[    13.630] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[    13.630] 	Entry deleted from font path.
[    13.630] 	(Run 'mkfontdir' on "/usr/share/fonts/TTF").
[    13.630] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    13.630] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    13.630] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    13.630] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    13.630] (==) FontPath set to:
[    13.630] (==) ModulePath set to "/usr/lib/xorg/modules"
[    13.630] (II) The server relies on udev to provide the list of input devices.
[    13.630] (II) Module ABI versions:
[    13.630] 	X.Org ANSI C Emulation: 0.4
[    13.630] 	X.Org Video Driver: 24.1
[    13.630] 	X.Org XInput driver : 24.1
[    13.630] 	X.Org Server Extension : 10.0
[    13.630] (++) using VT number 7
[    13.630] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    13.631] (II) xfree86: Adding drm device (/dev/dri/card0)
[    13.631] (II) xfree86: Adding drm device (/dev/dri/card1)
[    13.636] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    13.636] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    14.870] (--) PCI:*(0@0:2:0) 8086:3e9b:1462:12aa rev 0, Mem @ 0xa3000000/16777216, 0x80000000/268435456, I/O @ 0x00006000/64, BIOS @ 0x????????/131072
[    14.870] (--) PCI: (1@0:0:0) 10de:2191:1462:12aa rev 161, Mem @ 0xa4000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x????????/524288
[    14.870] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    14.870] (II) LoadModule: "glx"
[    14.874] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    14.878] (II) Module glx: vendor="X.Org Foundation"
[    14.878] 	compiled for 1.20.10, module version = 1.0.0
[    14.878] 	ABI class: X.Org Server Extension, version 10.0
[    14.878] (II) Applying OutputClass "intel" to /dev/dri/card1
[    14.878] 	loading driver: modesetting
[    14.878] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[    14.878] 	loading driver: nvidia
[    14.878] (==) Matched modesetting as autoconfigured driver 0
[    14.878] (==) Matched intel as autoconfigured driver 1
[    14.878] (==) Matched nvidia as autoconfigured driver 2
[    14.878] (==) Matched nouveau as autoconfigured driver 3
[    14.878] (==) Matched nv as autoconfigured driver 4
[    14.878] (==) Matched fbdev as autoconfigured driver 5
[    14.878] (==) Matched vesa as autoconfigured driver 6
[    14.878] (==) Assigned the driver to the xf86ConfigLayout
[    14.878] (II) LoadModule: "modesetting"
[    14.878] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    14.879] (II) Module modesetting: vendor="X.Org Foundation"
[    14.879] 	compiled for 1.20.10, module version = 1.20.10
[    14.879] 	Module class: X.Org Video Driver
[    14.879] 	ABI class: X.Org Video Driver, version 24.1
[    14.879] (II) LoadModule: "intel"
[    14.880] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[    14.881] (II) Module intel: vendor="X.Org Foundation"
[    14.881] 	compiled for 1.20.9, module version = 2.99.917
[    14.881] 	Module class: X.Org Video Driver
[    14.881] 	ABI class: X.Org Video Driver, version 24.1
[    14.881] (II) LoadModule: "nvidia"
[    14.881] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    14.884] (II) Module nvidia: vendor="NVIDIA Corporation"
[    14.884] 	compiled for 1.6.99.901, module version = 1.0.0
[    14.884] 	Module class: X.Org Video Driver
[    14.885] (II) LoadModule: "nouveau"
[    14.885] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    14.886] (II) Module nouveau: vendor="X.Org Foundation"
[    14.886] 	compiled for 1.20.8, module version = 1.0.16
[    14.886] 	Module class: X.Org Video Driver
[    14.886] 	ABI class: X.Org Video Driver, version 24.1
[    14.886] (II) LoadModule: "nv"
[    14.888] (WW) Warning, couldn't open module nv
[    14.888] (EE) Failed to load module "nv" (module does not exist, 0)
[    14.888] (II) LoadModule: "fbdev"
[    14.889] (WW) Warning, couldn't open module fbdev
[    14.889] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    14.889] (II) LoadModule: "vesa"
[    14.890] (WW) Warning, couldn't open module vesa
[    14.890] (EE) Failed to load module "vesa" (module does not exist, 0)
[    14.890] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    14.890] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[    14.890] (II) intel: Driver for Intel(R) HD Graphics
[    14.890] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[    14.890] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[    14.891] (II) NVIDIA dlloader X Driver  455.45.01  Thu Nov  5 23:01:05 UTC 2020
[    14.891] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    14.891] (II) NOUVEAU driver
[    14.891] (II) NOUVEAU driver for NVIDIA chipset families :
[    14.891] 	RIVA TNT            (NV04)
[    14.891] 	RIVA TNT2           (NV05)
[    14.891] 	GeForce 256         (NV10)
[    14.891] 	GeForce 2           (NV11, NV15)
[    14.891] 	GeForce 4MX         (NV17, NV18)
[    14.891] 	GeForce 3           (NV20)
[    14.892] 	GeForce 4Ti         (NV25, NV28)
[    14.892] 	GeForce FX          (NV3x)
[    14.892] 	GeForce 6           (NV4x)
[    14.892] 	GeForce 7           (G7x)
[    14.892] 	GeForce 8           (G8x)
[    14.892] 	GeForce 9           (G9x)
[    14.892] 	GeForce GTX 2xx/3xx (GT2xx)
[    14.892] 	GeForce GTX 4xx/5xx (GFxxx)
[    14.892] 	GeForce GTX 6xx/7xx (GKxxx)
[    14.892] 	GeForce GTX 9xx     (GMxxx)
[    14.892] 	GeForce GTX 10xx    (GPxxx)
[    14.918] (II) modeset(0): using drv /dev/dri/card1
[    14.919] (II) Loading sub module "fb"
[    14.919] (II) LoadModule: "fb"
[    14.919] (II) Loading /usr/lib/xorg/modules/libfb.so
[    14.920] (II) Module fb: vendor="X.Org Foundation"
[    14.920] 	compiled for 1.20.10, module version = 1.0.0
[    14.920] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    14.920] (II) Loading sub module "wfb"
[    14.920] (II) LoadModule: "wfb"
[    14.920] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    14.921] (II) Module wfb: vendor="X.Org Foundation"
[    14.921] 	compiled for 1.20.10, module version = 1.0.0
[    14.921] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    14.921] (II) Loading sub module "ramdac"
[    14.921] (II) LoadModule: "ramdac"
[    14.921] (II) Module "ramdac" already built-in
[    14.923] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    14.923] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    14.923] (==) modeset(0): RGB weight 888
[    14.923] (==) modeset(0): Default visual is TrueColor
[    14.923] (II) Loading sub module "glamoregl"
[    14.923] (II) LoadModule: "glamoregl"
[    14.923] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    14.933] (II) Module glamoregl: vendor="X.Org Foundation"
[    14.933] 	compiled for 1.20.10, module version = 1.0.1
[    14.933] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    15.076] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 630 (CFL GT2)
[    15.076] (II) modeset(0): glamor initialized
[    15.078] (II) modeset(0): Output eDP-1 has no monitor section
[    15.079] (II) modeset(0): EDID for output eDP-1
[    15.079] (II) modeset(0): Manufacturer: AUO  Model: d0ed  Serial#: 0
[    15.079] (II) modeset(0): Year: 2019  Week: 11
[    15.079] (II) modeset(0): EDID Version: 1.4
[    15.079] (II) modeset(0): Digital Display Input
[    15.079] (II) modeset(0): 8 bits per channel
[    15.079] (II) modeset(0): Digital interface is DisplayPort
[    15.079] (II) modeset(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[    15.079] (II) modeset(0): Gamma: 2.20
[    15.079] (II) modeset(0): No DPMS capabilities specified
[    15.079] (II) modeset(0): Supported color encodings: RGB 4:4:4
[    15.079] (II) modeset(0): First detailed timing is preferred mode
[    15.079] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[    15.079] (II) modeset(0): Display is continuous-frequency
[    15.079] (II) modeset(0): redX: 0.560 redY: 0.340   greenX: 0.350 greenY: 0.570
[    15.079] (II) modeset(0): blueX: 0.160 blueY: 0.120   whiteX: 0.313 whiteY: 0.329
[    15.079] (II) modeset(0): Manufacturer's mask: 0
[    15.079] (II) modeset(0): Supported detailed timing:
[    15.079] (II) modeset(0): clock: 290.8 MHz   Image Size:  344 x 193 mm
[    15.079] (II) modeset(0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2120 h_border: 0
[    15.079] (II) modeset(0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1142 v_border: 0
[    15.079] (II) modeset(0): clock: 116.4 MHz   Image Size:  344 x 193 mm
[    15.079] (II) modeset(0): Ranges: V min: 48 V max: 120 Hz, H min: 138 H max: 138 kHz, PixClock max 305 MHz
[    15.079] (II) modeset(0):  B156HAN13.0
[    15.079] (II) modeset(0): EDID (in hex):
[    15.079] (II) modeset(0): 	00ffffffffffff0006afedd000000000
[    15.079] (II) modeset(0): 	0b1d0104a52213780348358f57599229
[    15.079] (II) modeset(0): 	1e505400000001010101010101010101
[    15.079] (II) modeset(0): 	010101010101987180c870383e406c30
[    15.079] (II) modeset(0): 	aa0058c110000018782d80c870383e40
[    15.079] (II) modeset(0): 	6c30aa0058c110000018000000fd0030
[    15.079] (II) modeset(0): 	788a8a1e010a202020202020000000fe
[    15.079] (II) modeset(0): 	004231353648414e31332e30200a00f0
[    15.079] (II) modeset(0): Not using default mode "1920x1080" (bad mode clock/interlace/doublescan)
[    15.079] (II) modeset(0): Printing probed modes for output eDP-1
[    15.079] (II) modeset(0): Modeline "1920x1080"x120.1  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[    15.079] (II) modeset(0): Modeline "1920x1080"x60.0  266.50  1920 1944 1960 2000  1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[    15.079] (II) modeset(0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[    15.079] (II) modeset(0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[    15.079] (II) modeset(0): Modeline "1920x1080"x48.1  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[    15.079] (II) modeset(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[    15.079] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[    15.079] (II) modeset(0): Modeline "1400x1050"x74.8  155.80  1400 1464 1784 1912  1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[    15.079] (II) modeset(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[    15.079] (II) modeset(0): Modeline "1600x900"x60.0  246.00  1600 1728 1900 2200  900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[    15.079] (II) modeset(0): Modeline "1600x900"x59.9  186.50  1600 1624 1640 1680  900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[    15.079] (II) modeset(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz d)
[    15.079] (II) modeset(0): Modeline "1600x900"x59.8   97.50  1600 1648 1680 1760  900 903 908 926 +hsync -vsync (55.4 kHz d)
[    15.079] (II) modeset(0): Modeline "1280x1024"x85.0  157.50  1280 1344 1504 1728  1024 1025 1028 1072 +hsync +vsync (91.1 kHz d)
[    15.079] (II) modeset(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz d)
[    15.079] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[    15.079] (II) modeset(0): Modeline "1400x900"x60.0  103.50  1400 1480 1624 1848  900 903 913 934 -hsync +vsync (56.0 kHz d)
[    15.079] (II) modeset(0): Modeline "1400x900"x59.9   86.50  1400 1448 1480 1560  900 903 913 926 +hsync -vsync (55.4 kHz d)
[    15.079] (II) modeset(0): Modeline "1280x960"x85.0  148.50  1280 1344 1504 1728  960 961 964 1011 +hsync +vsync (85.9 kHz d)
[    15.079] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[    15.079] (II) modeset(0): Modeline "1440x810"x60.0  198.12  1440 1548 1704 1968  810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[    15.079] (II) modeset(0): Modeline "1440x810"x60.0  151.88  1440 1464 1480 1520  810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[    15.079] (II) modeset(0): Modeline "1368x768"x59.9   85.25  1368 1440 1576 1784  768 771 781 798 -hsync +vsync (47.8 kHz d)
[    15.079] (II) modeset(0): Modeline "1368x768"x59.9   72.25  1368 1416 1448 1528  768 771 781 790 +hsync -vsync (47.3 kHz d)
[    15.079] (II) modeset(0): Modeline "1280x800"x60.0  174.25  1280 1380 1516 1752  800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[    15.079] (II) modeset(0): Modeline "1280x800"x60.0  134.25  1280 1304 1320 1360  800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[    15.080] (II) modeset(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz d)
[    15.080] (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz d)
[    15.080] (II) modeset(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz d)
[    15.080] (II) modeset(0): Modeline "1280x720"x60.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[    15.080] (II) modeset(0): Modeline "1280x720"x60.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[    15.080] (II) modeset(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
[    15.080] (II) modeset(0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
[    15.080] (II) modeset(0): Modeline "1024x768"x85.0  194.02  1024 1108 1220 1416  768 768 770 806 doublescan -hsync +vsync (137.0 kHz d)
[    15.080] (II) modeset(0): Modeline "1024x768"x75.0  170.24  1024 1108 1220 1416  768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[    15.080] (II) modeset(0): Modeline "1024x768"x60.0  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[    15.080] (II) modeset(0): Modeline "1024x768"x85.0   94.50  1024 1072 1168 1376  768 769 772 808 +hsync +vsync (68.7 kHz d)
[    15.080] (II) modeset(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz d)
[    15.080] (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz d)
[    15.080] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[    15.080] (II) modeset(0): Modeline "1024x768i"x87.0   44.90  1024 1032 1208 1264  768 768 776 817 interlace +hsync +vsync (35.5 kHz d)
[    15.080] (II) modeset(0): Modeline "960x720"x85.0  170.68  960 1036 1144 1328  720 720 722 756 doublescan -hsync +vsync (128.5 kHz d)
[    15.080] (II) modeset(0): Modeline "960x720"x75.0  148.50  960 1032 1144 1320  720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[    15.080] (II) modeset(0): Modeline "960x720"x60.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[    15.080] (II) modeset(0): Modeline "928x696"x75.0  144.00  928 992 1104 1280  696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[    15.080] (II) modeset(0): Modeline "928x696"x60.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[    15.080] (II) modeset(0): Modeline "896x672"x75.0  130.50  896 944 1052 1228  672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[    15.080] (II) modeset(0): Modeline "896x672"x60.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[    15.080] (II) modeset(0): Modeline "1024x576"x60.0   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[    15.080] (II) modeset(0): Modeline "1024x576"x60.0   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[    15.080] (II) modeset(0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
[    15.080] (II) modeset(0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
[    15.080] (II) modeset(0): Modeline "960x600"x59.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[    15.080] (II) modeset(0): Modeline "960x600"x60.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[    15.080] (II) modeset(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz d)
[    15.080] (II) modeset(0): Modeline "960x540"x60.0   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[    15.080] (II) modeset(0): Modeline "960x540"x60.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[    15.080] (II) modeset(0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
[    15.080] (II) modeset(0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
[    15.080] (II) modeset(0): Modeline "800x600"x85.0  114.75  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (106.2 kHz d)
[    15.080] (II) modeset(0): Modeline "800x600"x75.0  101.25  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[    15.080] (II) modeset(0): Modeline "800x600"x70.0   94.50  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[    15.080] (II) modeset(0): Modeline "800x600"x65.0   87.75  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[    15.080] (II) modeset(0): Modeline "800x600"x60.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[    15.080] (II) modeset(0): Modeline "800x600"x85.1   56.30  800 832 896 1048  600 601 604 631 +hsync +vsync (53.7 kHz d)
[    15.080] (II) modeset(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz d)
[    15.080] (II) modeset(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz d)
[    15.080] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[    15.080] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[    15.080] (II) modeset(0): Modeline "840x525"x60.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[    15.080] (II) modeset(0): Modeline "840x525"x59.9   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[    15.080] (II) modeset(0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
[    15.080] (II) modeset(0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
[    15.080] (II) modeset(0): Modeline "700x525"x74.8   77.90  700 732 892 956  525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[    15.080] (II) modeset(0): Modeline "700x525"x60.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[    15.080] (II) modeset(0): Modeline "800x450"x59.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[    15.080] (II) modeset(0): Modeline "800x450"x59.8   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[    15.080] (II) modeset(0): Modeline "640x512"x85.0   78.75  640 672 752 864  512 512 514 536 doublescan +hsync +vsync (91.1 kHz d)
[    15.080] (II) modeset(0): Modeline "640x512"x75.0   67.50  640 648 720 844  512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[    15.080] (II) modeset(0): Modeline "640x512"x60.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[    15.080] (II) modeset(0): Modeline "700x450"x60.0   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[    15.080] (II) modeset(0): Modeline "700x450"x59.9   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[    15.080] (II) modeset(0): Modeline "640x480"x85.1   74.25  640 672 752 864  480 480 482 505 doublescan +hsync +vsync (85.9 kHz d)
[    15.080] (II) modeset(0): Modeline "640x480"x60.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[    15.080] (II) modeset(0): Modeline "640x480"x85.0   36.00  640 696 752 832  480 481 484 509 -hsync -vsync (43.3 kHz d)
[    15.080] (II) modeset(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz d)
[    15.080] (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz d)
[    15.080] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[    15.080] (II) modeset(0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
[    15.080] (II) modeset(0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
[    15.080] (II) modeset(0): Modeline "720x400"x85.0   35.50  720 756 828 936  400 401 404 446 -hsync +vsync (37.9 kHz d)
[    15.080] (II) modeset(0): Modeline "684x384"x59.9   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[    15.080] (II) modeset(0): Modeline "684x384"x59.9   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[    15.080] (II) modeset(0): Modeline "640x400"x59.9   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[    15.080] (II) modeset(0): Modeline "640x400"x60.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[    15.080] (II) modeset(0): Modeline "640x400"x85.1   31.50  640 672 736 832  400 401 404 445 -hsync +vsync (37.9 kHz d)
[    15.080] (II) modeset(0): Modeline "576x432"x75.0   54.00  576 608 672 800  432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[    15.080] (II) modeset(0): Modeline "640x360"x59.9   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[    15.080] (II) modeset(0): Modeline "640x360"x59.8   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[    15.080] (II) modeset(0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
[    15.080] (II) modeset(0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
[    15.080] (II) modeset(0): Modeline "640x350"x85.1   31.50  640 672 736 832  350 382 385 445 +hsync -vsync (37.9 kHz d)
[    15.080] (II) modeset(0): Modeline "512x384"x85.0   47.25  512 536 584 688  384 384 386 404 doublescan +hsync +vsync (68.7 kHz d)
[    15.080] (II) modeset(0): Modeline "512x384"x75.0   39.38  512 520 568 656  384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[    15.080] (II) modeset(0): Modeline "512x384"x70.1   37.50  512 524 592 664  384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[    15.080] (II) modeset(0): Modeline "512x384"x60.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[    15.080] (II) modeset(0): Modeline "512x384i"x87.1   22.45  512 516 604 632  384 384 388 408 interlace doublescan +hsync +vsync (35.5 kHz d)
[    15.080] (II) modeset(0): Modeline "512x288"x60.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[    15.080] (II) modeset(0): Modeline "512x288"x59.9   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[    15.080] (II) modeset(0): Modeline "416x312"x74.7   28.64  416 432 464 576  312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[    15.080] (II) modeset(0): Modeline "480x270"x59.6   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[    15.080] (II) modeset(0): Modeline "480x270"x59.8   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[    15.080] (II) modeset(0): Modeline "400x300"x85.3   28.15  400 416 448 524  300 300 302 315 doublescan +hsync +vsync (53.7 kHz d)
[    15.080] (II) modeset(0): Modeline "400x300"x72.2   25.00  400 428 488 520  300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[    15.080] (II) modeset(0): Modeline "400x300"x75.1   24.75  400 408 448 528  300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[    15.080] (II) modeset(0): Modeline "400x300"x60.3   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[    15.080] (II) modeset(0): Modeline "400x300"x56.3   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[    15.080] (II) modeset(0): Modeline "432x243"x59.9   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[    15.080] (II) modeset(0): Modeline "432x243"x59.6   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[    15.080] (II) modeset(0): Modeline "320x240"x85.2   18.00  320 348 376 416  240 240 242 254 doublescan -hsync -vsync (43.3 kHz d)
[    15.080] (II) modeset(0): Modeline "320x240"x72.8   15.75  320 332 352 416  240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[    15.080] (II) modeset(0): Modeline "320x240"x75.0   15.75  320 328 360 420  240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[    15.080] (II) modeset(0): Modeline "320x240"x60.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[    15.080] (II) modeset(0): Modeline "360x202"x59.5   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[    15.080] (II) modeset(0): Modeline "360x202"x59.1   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[    15.080] (II) modeset(0): Modeline "360x200"x85.0   17.75  360 378 414 468  200 200 202 223 doublescan -hsync +vsync (37.9 kHz d)
[    15.080] (II) modeset(0): Modeline "320x200"x85.3   15.75  320 336 368 416  200 200 202 222 doublescan -hsync +vsync (37.9 kHz d)
[    15.080] (II) modeset(0): Modeline "320x180"x59.8    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[    15.080] (II) modeset(0): Modeline "320x180"x59.3    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[    15.080] (II) modeset(0): Modeline "320x175"x85.3   15.75  320 336 368 416  175 191 192 222 doublescan +hsync -vsync (37.9 kHz d)
[    15.080] (II) modeset(0): Output eDP-1 connected
[    15.080] (II) modeset(0): Using exact sizes for initial modes
[    15.080] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[    15.080] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    15.080] (==) modeset(0): DPI set to (96, 96)
[    15.080] (II) Loading sub module "fb"
[    15.080] (II) LoadModule: "fb"
[    15.081] (II) Loading /usr/lib/xorg/modules/libfb.so
[    15.081] (II) Module fb: vendor="X.Org Foundation"
[    15.081] 	compiled for 1.20.10, module version = 1.0.0
[    15.081] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    15.081] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[    15.081] (==) NVIDIA(G0): RGB weight 888
[    15.081] (==) NVIDIA(G0): Default visual is TrueColor
[    15.081] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[    15.081] (**) Option "AllowNVIDIAGpuScreens"
[    15.081] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[    15.081] (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
[    15.081] (**) NVIDIA(G0): Enabling 2D acceleration
[    15.081] (II) Loading sub module "glxserver_nvidia"
[    15.081] (II) LoadModule: "glxserver_nvidia"
[    15.081] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[    15.115] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[    15.115] 	compiled for 1.6.99.901, module version = 1.0.0
[    15.115] 	Module class: X.Org Server Extension
[    15.115] (II) NVIDIA GLX Module  455.45.01  Thu Nov  5 22:58:18 UTC 2020
[    15.116] (II) NVIDIA: The X server supports PRIME Render Offload.
[    17.150] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[    17.150] (--) NVIDIA(0):     DFP-0 (boot)
[    17.150] (II) NVIDIA(G0): NVIDIA GPU GeForce GTX 1660 Ti (TU116-A) at PCI:1:0:0 (GPU-0)
[    17.150] (--) NVIDIA(G0): Memory: 6291456 kBytes
[    17.150] (--) NVIDIA(G0): VideoBIOS: 90.16.35.00.10
[    17.150] (II) NVIDIA(G0): Detected PCI Express Link width: 16X
[    17.180] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[    17.180] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[    17.180] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[    17.221] (II) NVIDIA(G0): Validated MetaModes:
[    17.221] (II) NVIDIA(G0):     "NULL"
[    17.221] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[    17.273] (WW) NVIDIA(G0): Cannot find size of first mode for LG Electronics LG FULL HD
[    17.273] (WW) NVIDIA(G0):     (DFP-0); cannot compute DPI from LG Electronics LG FULL HD
[    17.273] (WW) NVIDIA(G0):     (DFP-0)'s EDID.
[    17.273] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[    17.273] (II) UnloadModule: "intel"
[    17.273] (II) Unloading intel
[    17.273] (II) UnloadModule: "nouveau"
[    17.273] (II) Unloading nouveau
[    17.287] (==) modeset(0): Backing store enabled
[    17.287] (==) modeset(0): Silken mouse disabled
[    17.324] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    17.324] (==) modeset(0): DPMS enabled
[    17.324] (II) modeset(0): [DRI2] Setup complete
[    17.324] (II) modeset(0): [DRI2]   DRI driver: iris
[    17.324] (II) modeset(0): [DRI2]   VDPAU driver: va_gl
[    17.324] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[    17.324] (II) NVIDIA:     access.
[    17.333] (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    17.333] (II) NVIDIA(G0):     may not be running or the "AcpidSocketPath" X
[    17.333] (II) NVIDIA(G0):     configuration option may not be set correctly.  When the
[    17.333] (II) NVIDIA(G0):     ACPI event daemon is available, the NVIDIA X driver will
[    17.333] (II) NVIDIA(G0):     try to use it to receive ACPI event notifications.  For
[    17.333] (II) NVIDIA(G0):     details, please see the "ConnectToAcpid" and
[    17.333] (II) NVIDIA(G0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    17.333] (II) NVIDIA(G0):     Config Options in the README.
[    17.346] (II) NVIDIA(G0): Setting mode "NULL"
[    17.354] (==) NVIDIA(G0): Disabling shared memory pixmaps
[    17.354] (==) NVIDIA(G0): Backing store enabled
[    17.354] (==) NVIDIA(G0): Silken mouse disabled
[    17.354] (==) NVIDIA(G0): DPMS enabled
[    17.354] (II) Loading sub module "dri2"
[    17.354] (II) LoadModule: "dri2"
[    17.354] (II) Module "dri2" already built-in
[    17.354] (II) NVIDIA(G0): [DRI2] Setup complete
[    17.354] (II) NVIDIA(G0): [DRI2]   VDPAU driver: nvidia
[    17.354] (II) Initializing extension Generic Event Extension
[    17.354] (II) Initializing extension SHAPE
[    17.354] (II) Initializing extension MIT-SHM
[    17.354] (II) Initializing extension XInputExtension
[    17.354] (II) Initializing extension XTEST
[    17.354] (II) Initializing extension BIG-REQUESTS
[    17.354] (II) Initializing extension SYNC
[    17.354] (II) Initializing extension XKEYBOARD
[    17.354] (II) Initializing extension XC-MISC
[    17.354] (II) Initializing extension SECURITY
[    17.355] (II) Initializing extension XFIXES
[    17.355] (II) Initializing extension RENDER
[    17.355] (II) Initializing extension RANDR
[    17.355] (II) Initializing extension COMPOSITE
[    17.355] (II) Initializing extension DAMAGE
[    17.355] (II) Initializing extension MIT-SCREEN-SAVER
[    17.355] (II) Initializing extension DOUBLE-BUFFER
[    17.355] (II) Initializing extension RECORD
[    17.355] (II) Initializing extension DPMS
[    17.355] (II) Initializing extension Present
[    17.355] (II) Initializing extension DRI3
[    17.355] (II) Initializing extension X-Resource
[    17.355] (II) Initializing extension XVideo
[    17.355] (II) Initializing extension XVideo-MotionCompensation
[    17.355] (II) Initializing extension GLX
[    17.355] (II) Indirect GLX disabled.
[    17.361] (II) AIGLX: Loaded and initialized iris
[    17.361] (II) GLX: Initialized DRI2 GL provider for screen 0
[    17.361] (II) Initializing extension XFree86-VidModeExtension
[    17.361] (II) Initializing extension XFree86-DGA
[    17.361] (II) Initializing extension XFree86-DRI
[    17.361] (II) Initializing extension DRI2
[    17.361] (II) Initializing extension NV-GLX
[    17.361] (II) Initializing extension NV-CONTROL
[    17.364] (II) modeset(0): Damage tracking initialized
[    17.364] (II) modeset(0): Setting screen physical size to 508 x 285
[    17.394] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    17.394] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    17.394] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    17.394] (**) Power Button: Applying InputClass "system-keyboard"
[    17.394] (II) LoadModule: "libinput"
[    17.394] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    17.396] (II) Module libinput: vendor="X.Org Foundation"
[    17.396] 	compiled for 1.20.8, module version = 0.30.0
[    17.396] 	Module class: X.Org XInput Driver
[    17.396] 	ABI class: X.Org XInput driver, version 24.1
[    17.396] (II) Using input driver 'libinput' for 'Power Button'
[    17.396] (**) Power Button: always reports core events
[    17.396] (**) Option "Device" "/dev/input/event3"
[    17.396] (**) Option "_source" "server/udev"
[    17.401] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    17.401] (II) event3  - Power Button: device is a keyboard
[    17.401] (II) event3  - Power Button: device removed
[    17.428] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[    17.428] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    17.428] (**) Option "xkb_model" "pc105"
[    17.428] (**) Option "xkb_layout" "us"
[    17.429] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    17.429] (II) event3  - Power Button: device is a keyboard
[    17.429] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[    17.429] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    17.429] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    17.430] (**) Video Bus: Applying InputClass "system-keyboard"
[    17.430] (II) Using input driver 'libinput' for 'Video Bus'
[    17.430] (**) Video Bus: always reports core events
[    17.430] (**) Option "Device" "/dev/input/event7"
[    17.430] (**) Option "_source" "server/udev"
[    17.430] (II) event7  - Video Bus: is tagged by udev as: Keyboard
[    17.430] (II) event7  - Video Bus: device is a keyboard
[    17.430] (II) event7  - Video Bus: device removed
[    17.495] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12/event7"
[    17.495] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    17.495] (**) Option "xkb_model" "pc105"
[    17.495] (**) Option "xkb_layout" "us"
[    17.499] (II) event7  - Video Bus: is tagged by udev as: Keyboard
[    17.499] (II) event7  - Video Bus: device is a keyboard
[    17.501] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[    17.502] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    17.502] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    17.502] (**) Video Bus: Applying InputClass "system-keyboard"
[    17.502] (II) Using input driver 'libinput' for 'Video Bus'
[    17.502] (**) Video Bus: always reports core events
[    17.502] (**) Option "Device" "/dev/input/event8"
[    17.502] (**) Option "_source" "server/udev"
[    17.506] (II) event8  - Video Bus: is tagged by udev as: Keyboard
[    17.506] (II) event8  - Video Bus: device is a keyboard
[    17.507] (II) event8  - Video Bus: device removed
[    17.601] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input13/event8"
[    17.602] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    17.602] (**) Option "xkb_model" "pc105"
[    17.602] (**) Option "xkb_layout" "us"
[    17.606] (II) event8  - Video Bus: is tagged by udev as: Keyboard
[    17.607] (II) event8  - Video Bus: device is a keyboard
[    17.609] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    17.609] (II) No input driver specified, ignoring this device.
[    17.609] (II) This device may have been added with another device file.
[    17.610] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    17.610] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    17.611] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    17.611] (**) Power Button: Applying InputClass "system-keyboard"
[    17.611] (II) Using input driver 'libinput' for 'Power Button'
[    17.611] (**) Power Button: always reports core events
[    17.611] (**) Option "Device" "/dev/input/event2"
[    17.611] (**) Option "_source" "server/udev"
[    17.614] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    17.614] (II) event2  - Power Button: device is a keyboard
[    17.615] (II) event2  - Power Button: device removed
[    17.655] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[    17.655] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[    17.655] (**) Option "xkb_model" "pc105"
[    17.655] (**) Option "xkb_layout" "us"
[    17.656] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    17.656] (II) event2  - Power Button: device is a keyboard
[    17.656] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[    17.656] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    17.656] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    17.656] (**) Sleep Button: Applying InputClass "system-keyboard"
[    17.656] (II) Using input driver 'libinput' for 'Sleep Button'
[    17.656] (**) Sleep Button: always reports core events
[    17.656] (**) Option "Device" "/dev/input/event1"
[    17.656] (**) Option "_source" "server/udev"
[    17.657] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    17.657] (II) event1  - Sleep Button: device is a keyboard
[    17.657] (II) event1  - Sleep Button: device removed
[    17.695] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[    17.695] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[    17.695] (**) Option "xkb_model" "pc105"
[    17.695] (**) Option "xkb_layout" "us"
[    17.696] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    17.696] (II) event1  - Sleep Button: device is a keyboard
[    17.698] (II) config/udev: Adding input device HD Webcam: HD Webcam (/dev/input/event26)
[    17.698] (**) HD Webcam: HD Webcam: Applying InputClass "evdev keyboard catchall"
[    17.698] (**) HD Webcam: HD Webcam: Applying InputClass "libinput keyboard catchall"
[    17.698] (**) HD Webcam: HD Webcam: Applying InputClass "system-keyboard"
[    17.698] (II) Using input driver 'libinput' for 'HD Webcam: HD Webcam'
[    17.698] (**) HD Webcam: HD Webcam: always reports core events
[    17.698] (**) Option "Device" "/dev/input/event26"
[    17.698] (**) Option "_source" "server/udev"
[    17.700] (II) event26 - HD Webcam: HD Webcam: is tagged by udev as: Keyboard
[    17.700] (II) event26 - HD Webcam: HD Webcam: device is a keyboard
[    17.700] (II) event26 - HD Webcam: HD Webcam: device removed
[    17.788] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/input/input31/event26"
[    17.788] (II) XINPUT: Adding extended input device "HD Webcam: HD Webcam" (type: KEYBOARD, id 11)
[    17.788] (**) Option "xkb_model" "pc105"
[    17.788] (**) Option "xkb_layout" "us"
[    17.793] (II) event26 - HD Webcam: HD Webcam: is tagged by udev as: Keyboard
[    17.794] (II) event26 - HD Webcam: HD Webcam: device is a keyboard
[    17.797] (II) config/udev: Adding input device Microsoft Microsoft Nano Transceiver 1.1 (/dev/input/event20)
[    17.797] (**) Microsoft Microsoft Nano Transceiver 1.1: Applying InputClass "evdev keyboard catchall"
[    17.797] (**) Microsoft Microsoft Nano Transceiver 1.1: Applying InputClass "libinput keyboard catchall"
[    17.797] (**) Microsoft Microsoft Nano Transceiver 1.1: Applying InputClass "system-keyboard"
[    17.797] (II) Using input driver 'libinput' for 'Microsoft Microsoft Nano Transceiver 1.1'
[    17.797] (**) Microsoft Microsoft Nano Transceiver 1.1: always reports core events
[    17.797] (**) Option "Device" "/dev/input/event20"
[    17.797] (**) Option "_source" "server/udev"
[    17.802] (II) event20 - Microsoft Microsoft Nano Transceiver 1.1: is tagged by udev as: Keyboard
[    17.803] (II) event20 - Microsoft Microsoft Nano Transceiver 1.1: device is a keyboard
[    17.804] (II) event20 - Microsoft Microsoft Nano Transceiver 1.1: device removed
[    17.841] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.2/1-3.2:1.0/0003:045E:07FD.0002/input/input25/event20"
[    17.841] (II) XINPUT: Adding extended input device "Microsoft Microsoft Nano Transceiver 1.1" (type: KEYBOARD, id 12)
[    17.841] (**) Option "xkb_model" "pc105"
[    17.841] (**) Option "xkb_layout" "us"
[    17.843] (II) event20 - Microsoft Microsoft Nano Transceiver 1.1: is tagged by udev as: Keyboard
[    17.843] (II) event20 - Microsoft Microsoft Nano Transceiver 1.1: device is a keyboard
[    17.844] (II) config/udev: Adding input device Microsoft Microsoft Nano Transceiver 1.1 Consumer Control (/dev/input/event21)
[    17.844] (**) Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: Applying InputClass "evdev keyboard catchall"
[    17.844] (**) Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: Applying InputClass "libinput keyboard catchall"
[    17.844] (**) Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: Applying InputClass "system-keyboard"
[    17.844] (II) Using input driver 'libinput' for 'Microsoft Microsoft Nano Transceiver 1.1 Consumer Control'
[    17.844] (**) Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: always reports core events
[    17.844] (**) Option "Device" "/dev/input/event21"
[    17.844] (**) Option "_source" "server/udev"
[    17.845] (II) event21 - Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: is tagged by udev as: Keyboard
[    17.846] (II) event21 - Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: device is a keyboard
[    17.846] (II) event21 - Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: device removed
[    17.882] (II) libinput: Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: needs a virtual subdevice
[    17.882] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.2/1-3.2:1.1/0003:045E:07FD.0003/input/input26/event21"
[    17.882] (II) XINPUT: Adding extended input device "Microsoft Microsoft Nano Transceiver 1.1 Consumer Control" (type: MOUSE, id 13)
[    17.882] (**) Option "AccelerationScheme" "none"
[    17.882] (**) Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: (accel) selected scheme none/0
[    17.882] (**) Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: (accel) acceleration factor: 2.000
[    17.882] (**) Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: (accel) acceleration threshold: 4
[    17.886] (II) event21 - Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: is tagged by udev as: Keyboard
[    17.886] (II) event21 - Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: device is a keyboard
[    17.889] (II) config/udev: Adding input device Microsoft Microsoft Nano Transceiver 1.1 System Control (/dev/input/event22)
[    17.889] (**) Microsoft Microsoft Nano Transceiver 1.1 System Control: Applying InputClass "evdev keyboard catchall"
[    17.889] (**) Microsoft Microsoft Nano Transceiver 1.1 System Control: Applying InputClass "libinput keyboard catchall"
[    17.889] (**) Microsoft Microsoft Nano Transceiver 1.1 System Control: Applying InputClass "system-keyboard"
[    17.889] (II) Using input driver 'libinput' for 'Microsoft Microsoft Nano Transceiver 1.1 System Control'
[    17.889] (**) Microsoft Microsoft Nano Transceiver 1.1 System Control: always reports core events
[    17.889] (**) Option "Device" "/dev/input/event22"
[    17.889] (**) Option "_source" "server/udev"
[    17.894] (II) event22 - Microsoft Microsoft Nano Transceiver 1.1 System Control: is tagged by udev as: Keyboard
[    17.895] (II) event22 - Microsoft Microsoft Nano Transceiver 1.1 System Control: device is a keyboard
[    17.895] (II) event22 - Microsoft Microsoft Nano Transceiver 1.1 System Control: device removed
[    17.921] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.2/1-3.2:1.1/0003:045E:07FD.0003/input/input27/event22"
[    17.922] (II) XINPUT: Adding extended input device "Microsoft Microsoft Nano Transceiver 1.1 System Control" (type: KEYBOARD, id 14)
[    17.922] (**) Option "xkb_model" "pc105"
[    17.922] (**) Option "xkb_layout" "us"
[    17.928] (II) event22 - Microsoft Microsoft Nano Transceiver 1.1 System Control: is tagged by udev as: Keyboard
[    17.928] (II) event22 - Microsoft Microsoft Nano Transceiver 1.1 System Control: device is a keyboard
[    17.931] (II) config/udev: Adding input device Microsoft Microsoft Nano Transceiver 1.1 (/dev/input/event23)
[    17.931] (**) Microsoft Microsoft Nano Transceiver 1.1: Applying InputClass "evdev keyboard catchall"
[    17.931] (**) Microsoft Microsoft Nano Transceiver 1.1: Applying InputClass "libinput keyboard catchall"
[    17.931] (**) Microsoft Microsoft Nano Transceiver 1.1: Applying InputClass "system-keyboard"
[    17.931] (II) Using input driver 'libinput' for 'Microsoft Microsoft Nano Transceiver 1.1'
[    17.931] (**) Microsoft Microsoft Nano Transceiver 1.1: always reports core events
[    17.932] (**) Option "Device" "/dev/input/event23"
[    17.932] (**) Option "_source" "server/udev"
[    17.937] (II) event23 - Microsoft Microsoft Nano Transceiver 1.1: is tagged by udev as: Keyboard
[    17.937] (II) event23 - Microsoft Microsoft Nano Transceiver 1.1: device is a keyboard
[    17.938] (II) event23 - Microsoft Microsoft Nano Transceiver 1.1: device removed
[    18.068] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.2/1-3.2:1.1/0003:045E:07FD.0003/input/input28/event23"
[    18.068] (II) XINPUT: Adding extended input device "Microsoft Microsoft Nano Transceiver 1.1" (type: KEYBOARD, id 15)
[    18.068] (**) Option "xkb_model" "pc105"
[    18.068] (**) Option "xkb_layout" "us"
[    18.074] (II) event23 - Microsoft Microsoft Nano Transceiver 1.1: is tagged by udev as: Keyboard
[    18.075] (II) event23 - Microsoft Microsoft Nano Transceiver 1.1: device is a keyboard
[    18.078] (II) config/udev: Adding input device Microsoft Microsoft Nano Transceiver 1.1 (/dev/input/event24)
[    18.078] (**) Microsoft Microsoft Nano Transceiver 1.1: Applying InputClass "evdev pointer catchall"
[    18.078] (**) Microsoft Microsoft Nano Transceiver 1.1: Applying InputClass "libinput pointer catchall"
[    18.078] (II) Using input driver 'libinput' for 'Microsoft Microsoft Nano Transceiver 1.1'
[    18.078] (**) Microsoft Microsoft Nano Transceiver 1.1: always reports core events
[    18.078] (**) Option "Device" "/dev/input/event24"
[    18.078] (**) Option "_source" "server/udev"
[    18.136] (II) event24 - Microsoft Microsoft Nano Transceiver 1.1: is tagged by udev as: Mouse
[    18.136] (II) event24 - Microsoft Microsoft Nano Transceiver 1.1: device is a pointer
[    18.136] (II) event24 - Microsoft Microsoft Nano Transceiver 1.1: device removed
[    18.228] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.2/1-3.2:1.2/0003:045E:07FD.0004/input/input29/event24"
[    18.228] (II) XINPUT: Adding extended input device "Microsoft Microsoft Nano Transceiver 1.1" (type: MOUSE, id 16)
[    18.228] (**) Option "AccelerationScheme" "none"
[    18.228] (**) Microsoft Microsoft Nano Transceiver 1.1: (accel) selected scheme none/0
[    18.228] (**) Microsoft Microsoft Nano Transceiver 1.1: (accel) acceleration factor: 2.000
[    18.228] (**) Microsoft Microsoft Nano Transceiver 1.1: (accel) acceleration threshold: 4
[    18.288] (II) event24 - Microsoft Microsoft Nano Transceiver 1.1: is tagged by udev as: Mouse
[    18.288] (II) event24 - Microsoft Microsoft Nano Transceiver 1.1: device is a pointer
[    18.289] (II) config/udev: Adding input device Microsoft Microsoft Nano Transceiver 1.1 (/dev/input/mouse3)
[    18.289] (II) No input driver specified, ignoring this device.
[    18.289] (II) This device may have been added with another device file.
[    18.290] (II) config/udev: Adding input device Logitech K360 (/dev/input/event25)
[    18.290] (**) Logitech K360: Applying InputClass "evdev keyboard catchall"
[    18.290] (**) Logitech K360: Applying InputClass "libinput keyboard catchall"
[    18.290] (**) Logitech K360: Applying InputClass "system-keyboard"
[    18.290] (II) Using input driver 'libinput' for 'Logitech K360'
[    18.290] (**) Logitech K360: always reports core events
[    18.290] (**) Option "Device" "/dev/input/event25"
[    18.290] (**) Option "_source" "server/udev"
[    18.291] (II) event25 - Logitech K360: is tagged by udev as: Keyboard
[    18.291] (II) event25 - Logitech K360: device is a keyboard
[    18.291] (II) event25 - Logitech K360: device removed
[    18.322] (II) libinput: Logitech K360: needs a virtual subdevice
[    18.322] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.3/1-3.3:1.2/0003:046D:C52B.0007/0003:046D:4004.0008/input/input42/event25"
[    18.322] (II) XINPUT: Adding extended input device "Logitech K360" (type: MOUSE, id 17)
[    18.322] (**) Option "AccelerationScheme" "none"
[    18.322] (**) Logitech K360: (accel) selected scheme none/0
[    18.322] (**) Logitech K360: (accel) acceleration factor: 2.000
[    18.322] (**) Logitech K360: (accel) acceleration threshold: 4
[    18.323] (II) event25 - Logitech K360: is tagged by udev as: Keyboard
[    18.323] (II) event25 - Logitech K360: device is a keyboard
[    18.324] (II) config/udev: Adding input device CUST0001:00 06CB:7E7E Mouse (/dev/input/event11)
[    18.324] (**) CUST0001:00 06CB:7E7E Mouse: Applying InputClass "evdev pointer catchall"
[    18.324] (**) CUST0001:00 06CB:7E7E Mouse: Applying InputClass "libinput pointer catchall"
[    18.324] (II) Using input driver 'libinput' for 'CUST0001:00 06CB:7E7E Mouse'
[    18.324] (**) CUST0001:00 06CB:7E7E Mouse: always reports core events
[    18.324] (**) Option "Device" "/dev/input/event11"
[    18.324] (**) Option "_source" "server/udev"
[    18.326] (II) event11 - CUST0001:00 06CB:7E7E Mouse: is tagged by udev as: Mouse Pointingstick
[    18.326] (II) event11 - CUST0001:00 06CB:7E7E Mouse: device is a pointer
[    18.328] (II) event11 - CUST0001:00 06CB:7E7E Mouse: device removed
[    18.415] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-2/i2c-CUST0001:00/0018:06CB:7E7E.0001/input/input15/event11"
[    18.415] (II) XINPUT: Adding extended input device "CUST0001:00 06CB:7E7E Mouse" (type: MOUSE, id 18)
[    18.415] (**) Option "AccelerationScheme" "none"
[    18.415] (**) CUST0001:00 06CB:7E7E Mouse: (accel) selected scheme none/0
[    18.415] (**) CUST0001:00 06CB:7E7E Mouse: (accel) acceleration factor: 2.000
[    18.415] (**) CUST0001:00 06CB:7E7E Mouse: (accel) acceleration threshold: 4
[    18.417] (II) event11 - CUST0001:00 06CB:7E7E Mouse: is tagged by udev as: Mouse Pointingstick
[    18.417] (II) event11 - CUST0001:00 06CB:7E7E Mouse: device is a pointer
[    18.419] (II) config/udev: Adding input device CUST0001:00 06CB:7E7E Mouse (/dev/input/mouse1)
[    18.419] (II) No input driver specified, ignoring this device.
[    18.419] (II) This device may have been added with another device file.
[    18.420] (II) config/udev: Adding input device CUST0001:00 06CB:7E7E Touchpad (/dev/input/event12)
[    18.420] (**) CUST0001:00 06CB:7E7E Touchpad: Applying InputClass "evdev touchpad catchall"
[    18.420] (**) CUST0001:00 06CB:7E7E Touchpad: Applying InputClass "libinput touchpad catchall"
[    18.420] (II) Using input driver 'libinput' for 'CUST0001:00 06CB:7E7E Touchpad'
[    18.420] (**) CUST0001:00 06CB:7E7E Touchpad: always reports core events
[    18.420] (**) Option "Device" "/dev/input/event12"
[    18.420] (**) Option "_source" "server/udev"
[    18.422] (II) event12 - CUST0001:00 06CB:7E7E Touchpad: is tagged by udev as: Touchpad
[    18.424] (II) event12 - CUST0001:00 06CB:7E7E Touchpad: device is a touchpad
[    18.424] (II) event12 - CUST0001:00 06CB:7E7E Touchpad: device removed
[    18.536] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-2/i2c-CUST0001:00/0018:06CB:7E7E.0001/input/input16/event12"
[    18.536] (II) XINPUT: Adding extended input device "CUST0001:00 06CB:7E7E Touchpad" (type: TOUCHPAD, id 19)
[    18.542] (**) Option "AccelerationScheme" "none"
[    18.542] (**) CUST0001:00 06CB:7E7E Touchpad: (accel) selected scheme none/0
[    18.542] (**) CUST0001:00 06CB:7E7E Touchpad: (accel) acceleration factor: 2.000
[    18.542] (**) CUST0001:00 06CB:7E7E Touchpad: (accel) acceleration threshold: 4
[    18.547] (II) event12 - CUST0001:00 06CB:7E7E Touchpad: is tagged by udev as: Touchpad
[    18.554] (II) event12 - CUST0001:00 06CB:7E7E Touchpad: device is a touchpad
[    18.557] (II) config/udev: Adding input device CUST0001:00 06CB:7E7E Touchpad (/dev/input/mouse2)
[    18.557] (II) No input driver specified, ignoring this device.
[    18.557] (II) This device may have been added with another device file.
[    18.558] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event13)
[    18.558] (II) No input driver specified, ignoring this device.
[    18.558] (II) This device may have been added with another device file.
[    18.559] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event14)
[    18.560] (II) No input driver specified, ignoring this device.
[    18.560] (II) This device may have been added with another device file.
[    18.561] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event15)
[    18.561] (II) No input driver specified, ignoring this device.
[    18.561] (II) This device may have been added with another device file.
[    18.562] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event16)
[    18.562] (II) No input driver specified, ignoring this device.
[    18.562] (II) This device may have been added with another device file.
[    18.563] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event17)
[    18.563] (II) No input driver specified, ignoring this device.
[    18.563] (II) This device may have been added with another device file.
[    18.565] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event18)
[    18.565] (II) No input driver specified, ignoring this device.
[    18.565] (II) This device may have been added with another device file.
[    18.566] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event19)
[    18.566] (II) No input driver specified, ignoring this device.
[    18.566] (II) This device may have been added with another device file.
[    18.567] (II) config/udev: Adding input device gpio-keys (/dev/input/event9)
[    18.567] (II) No input driver specified, ignoring this device.
[    18.567] (II) This device may have been added with another device file.
[    18.569] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[    18.569] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    18.569] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    18.569] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    18.569] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    18.569] (**) AT Translated Set 2 keyboard: always reports core events
[    18.569] (**) Option "Device" "/dev/input/event4"
[    18.569] (**) Option "_source" "server/udev"
[    18.571] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    18.572] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    18.575] (II) event4  - AT Translated Set 2 keyboard: device removed
[    18.628] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[    18.628] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 20)
[    18.628] (**) Option "xkb_model" "pc105"
[    18.628] (**) Option "xkb_layout" "us"
[    18.630] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    18.630] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    18.631] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event5)
[    18.631] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[    18.631] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[    18.631] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[    18.631] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    18.631] (**) Option "Device" "/dev/input/event5"
[    18.632] (**) Option "_source" "server/udev"
[    18.633] (II) event5  - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[    18.633] (II) event5  - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[    18.634] (II) event5  - SynPS/2 Synaptics TouchPad: device is a touchpad
[    18.635] (II) event5  - SynPS/2 Synaptics TouchPad: device removed
[    18.736] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input6/event5"
[    18.736] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 21)
[    18.740] (**) Option "AccelerationScheme" "none"
[    18.740] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[    18.740] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    18.740] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    18.744] (II) event5  - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[    18.746] (II) event5  - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[    18.750] (II) event5  - SynPS/2 Synaptics TouchPad: device is a touchpad
[    18.753] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[    18.753] (II) No input driver specified, ignoring this device.
[    18.753] (II) This device may have been added with another device file.
[    18.754] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[    18.754] (II) No input driver specified, ignoring this device.
[    18.755] (II) This device may have been added with another device file.
[    18.762] (II) config/udev: Adding input device MSI WMI hotkeys (/dev/input/event10)
[    18.763] (**) MSI WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    18.763] (**) MSI WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    18.763] (**) MSI WMI hotkeys: Applying InputClass "system-keyboard"
[    18.763] (II) Using input driver 'libinput' for 'MSI WMI hotkeys'
[    18.763] (**) MSI WMI hotkeys: always reports core events
[    18.763] (**) Option "Device" "/dev/input/event10"
[    18.763] (**) Option "_source" "server/udev"
[    18.765] (II) event10 - MSI WMI hotkeys: is tagged by udev as: Keyboard
[    18.766] (II) event10 - MSI WMI hotkeys: device is a keyboard
[    18.767] (II) event10 - MSI WMI hotkeys: device removed
[    18.808] (**) Option "config_info" "udev:/sys/devices/virtual/input/input14/event10"
[    18.808] (II) XINPUT: Adding extended input device "MSI WMI hotkeys" (type: KEYBOARD, id 22)
[    18.808] (**) Option "xkb_model" "pc105"
[    18.808] (**) Option "xkb_layout" "us"
[    18.809] (II) event10 - MSI WMI hotkeys: is tagged by udev as: Keyboard
[    18.809] (II) event10 - MSI WMI hotkeys: device is a keyboard
[    18.826] (**) Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: Applying InputClass "evdev keyboard catchall"
[    18.826] (**) Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: Applying InputClass "libinput keyboard catchall"
[    18.826] (**) Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: Applying InputClass "system-keyboard"
[    18.826] (II) Using input driver 'libinput' for 'Microsoft Microsoft Nano Transceiver 1.1 Consumer Control'
[    18.826] (**) Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: always reports core events
[    18.826] (**) Option "Device" "/dev/input/event21"
[    18.826] (**) Option "_source" "_driver/libinput"
[    18.826] (II) libinput: Microsoft Microsoft Nano Transceiver 1.1 Consumer Control: is a virtual subdevice
[    18.826] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.2/1-3.2:1.1/0003:045E:07FD.0003/input/input26/event21"
[    18.826] (II) XINPUT: Adding extended input device "Microsoft Microsoft Nano Transceiver 1.1 Consumer Control" (type: KEYBOARD, id 23)
[    18.826] (**) Option "xkb_model" "pc105"
[    18.826] (**) Option "xkb_layout" "us"
[    18.826] (**) Logitech K360: Applying InputClass "evdev keyboard catchall"
[    18.826] (**) Logitech K360: Applying InputClass "libinput keyboard catchall"
[    18.826] (**) Logitech K360: Applying InputClass "system-keyboard"
[    18.826] (II) Using input driver 'libinput' for 'Logitech K360'
[    18.826] (**) Logitech K360: always reports core events
[    18.826] (**) Option "Device" "/dev/input/event25"
[    18.826] (II) libinput: Logitech K360: is a virtual subdevice
[    18.826] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.3/1-3.3:1.2/0003:046D:C52B.0007/0003:046D:4004.0008/input/input42/event25"
[    18.826] (II) XINPUT: Adding extended input device "Logitech K360" (type: KEYBOARD, id 24)
[   332.653] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   332.653] (II) modeset(0): Using EDID range info for horizontal sync
[   332.653] (II) modeset(0): Using EDID range info for vertical refresh
[   332.653] (II) modeset(0): Printing DDC gathered Modelines:
[   332.653] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   332.653] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   332.655] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   332.655] (II) modeset(0): Using hsync ranges from config file
[   332.655] (II) modeset(0): Using vrefresh ranges from config file
[   332.655] (II) modeset(0): Printing DDC gathered Modelines:
[   332.655] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   332.655] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   332.684] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   332.684] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   332.684] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   332.837] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   332.837] (II) modeset(0): Using hsync ranges from config file
[   332.837] (II) modeset(0): Using vrefresh ranges from config file
[   332.837] (II) modeset(0): Printing DDC gathered Modelines:
[   332.837] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   332.837] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   332.842] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   332.842] (II) modeset(0): Using hsync ranges from config file
[   332.842] (II) modeset(0): Using vrefresh ranges from config file
[   332.842] (II) modeset(0): Printing DDC gathered Modelines:
[   332.842] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   332.842] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   332.871] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   332.871] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   332.871] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   333.129] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   333.129] (II) modeset(0): Using hsync ranges from config file
[   333.129] (II) modeset(0): Using vrefresh ranges from config file
[   333.129] (II) modeset(0): Printing DDC gathered Modelines:
[   333.129] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   333.129] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   333.130] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   333.130] (II) modeset(0): Using hsync ranges from config file
[   333.130] (II) modeset(0): Using vrefresh ranges from config file
[   333.130] (II) modeset(0): Printing DDC gathered Modelines:
[   333.130] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   333.131] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   333.160] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   333.160] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   333.160] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   333.842] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   333.842] (II) modeset(0): Using hsync ranges from config file
[   333.842] (II) modeset(0): Using vrefresh ranges from config file
[   333.842] (II) modeset(0): Printing DDC gathered Modelines:
[   333.842] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   333.842] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   333.843] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   333.843] (II) modeset(0): Using hsync ranges from config file
[   333.843] (II) modeset(0): Using vrefresh ranges from config file
[   333.843] (II) modeset(0): Printing DDC gathered Modelines:
[   333.843] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   333.843] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   333.873] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   333.873] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   333.873] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   334.299] (II) modeset(0): Allocate new frame buffer 3840x1080 stride
[   334.354] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   334.354] (II) modeset(0): Using hsync ranges from config file
[   334.354] (II) modeset(0): Using vrefresh ranges from config file
[   334.354] (II) modeset(0): Printing DDC gathered Modelines:
[   334.354] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   334.354] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   334.355] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   334.355] (II) modeset(0): Using hsync ranges from config file
[   334.355] (II) modeset(0): Using vrefresh ranges from config file
[   334.355] (II) modeset(0): Printing DDC gathered Modelines:
[   334.355] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   334.355] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   334.385] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   334.385] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   334.385] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   334.445] randr: failed to create shared pixmap
[   334.445] (EE) NVIDIA(G0): Failed to configure Reverse PRIME on output HDMI-1-0.
[   334.711] (II) NVIDIA(G0): Setting mode "NULL"
[   334.715] (II) NVIDIA(G0): Setting mode "NULL"
[   334.718] (II) NVIDIA(G0): Setting mode "NULL"
[   334.722] (II) NVIDIA(G0): Setting mode "NULL"
[   335.599] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   335.599] (II) modeset(0): Using hsync ranges from config file
[   335.599] (II) modeset(0): Using vrefresh ranges from config file
[   335.599] (II) modeset(0): Printing DDC gathered Modelines:
[   335.599] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   335.599] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   335.600] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   335.600] (II) modeset(0): Using hsync ranges from config file
[   335.600] (II) modeset(0): Using vrefresh ranges from config file
[   335.600] (II) modeset(0): Printing DDC gathered Modelines:
[   335.600] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   335.600] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   335.630] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   335.630] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   335.630] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   335.641] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   335.641] (II) modeset(0): Using hsync ranges from config file
[   335.641] (II) modeset(0): Using vrefresh ranges from config file
[   335.641] (II) modeset(0): Printing DDC gathered Modelines:
[   335.641] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   335.641] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   335.642] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   335.642] (II) modeset(0): Using hsync ranges from config file
[   335.642] (II) modeset(0): Using vrefresh ranges from config file
[   335.642] (II) modeset(0): Printing DDC gathered Modelines:
[   335.642] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   335.642] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   335.672] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   335.672] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   335.672] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   338.806] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   338.806] (II) modeset(0): Using hsync ranges from config file
[   338.806] (II) modeset(0): Using vrefresh ranges from config file
[   338.806] (II) modeset(0): Printing DDC gathered Modelines:
[   338.806] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   338.806] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   338.808] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   338.808] (II) modeset(0): Using hsync ranges from config file
[   338.808] (II) modeset(0): Using vrefresh ranges from config file
[   338.808] (II) modeset(0): Printing DDC gathered Modelines:
[   338.808] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   338.808] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   338.838] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   338.838] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   338.838] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   338.857] (II) modeset(0): Allocate new frame buffer 1920x1080 stride
[   338.909] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   338.909] (II) modeset(0): Using hsync ranges from config file
[   338.909] (II) modeset(0): Using vrefresh ranges from config file
[   338.909] (II) modeset(0): Printing DDC gathered Modelines:
[   338.909] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   338.909] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   338.910] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   338.910] (II) modeset(0): Using hsync ranges from config file
[   338.910] (II) modeset(0): Using vrefresh ranges from config file
[   338.910] (II) modeset(0): Printing DDC gathered Modelines:
[   338.910] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   338.910] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   338.940] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   338.940] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   338.940] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   341.070] (--) NVIDIA(GPU-0): DFP-0: disconnected
[   341.070] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[   341.070] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[   341.075] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   341.075] (II) modeset(0): Using hsync ranges from config file
[   341.075] (II) modeset(0): Using vrefresh ranges from config file
[   341.075] (II) modeset(0): Printing DDC gathered Modelines:
[   341.075] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   341.075] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   341.076] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   341.076] (II) modeset(0): Using hsync ranges from config file
[   341.076] (II) modeset(0): Using vrefresh ranges from config file
[   341.076] (II) modeset(0): Printing DDC gathered Modelines:
[   341.076] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   341.076] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   341.077] (--) NVIDIA(GPU-0): DFP-0: disconnected
[   341.077] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[   341.077] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[   343.914] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   343.914] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   343.914] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   343.923] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   343.923] (II) modeset(0): Using hsync ranges from config file
[   343.923] (II) modeset(0): Using vrefresh ranges from config file
[   343.923] (II) modeset(0): Printing DDC gathered Modelines:
[   343.923] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   343.923] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   343.924] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   343.924] (II) modeset(0): Using hsync ranges from config file
[   343.924] (II) modeset(0): Using vrefresh ranges from config file
[   343.924] (II) modeset(0): Printing DDC gathered Modelines:
[   343.924] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   343.924] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   343.954] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   343.954] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   343.954] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   343.957] randr: failed to create shared pixmap
[   343.957] (EE) NVIDIA(G0): Failed to configure Reverse PRIME on output HDMI-1-0.
[   344.019] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   344.019] (II) modeset(0): Using hsync ranges from config file
[   344.019] (II) modeset(0): Using vrefresh ranges from config file
[   344.019] (II) modeset(0): Printing DDC gathered Modelines:
[   344.019] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   344.019] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   344.020] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   344.020] (II) modeset(0): Using hsync ranges from config file
[   344.020] (II) modeset(0): Using vrefresh ranges from config file
[   344.020] (II) modeset(0): Printing DDC gathered Modelines:
[   344.020] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   344.020] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   344.050] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   344.050] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   344.050] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   347.030] (II) modeset(0): Allocate new frame buffer 3840x1080 stride
[   347.060] randr: failed to create shared pixmap
[   347.060] (EE) NVIDIA(G0): Failed to configure Reverse PRIME on output HDMI-1-0.
[   347.063] randr: failed to create shared pixmap
[   347.063] (EE) NVIDIA(G0): Failed to configure Reverse PRIME on output HDMI-1-0.
[   347.079] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   347.079] (II) modeset(0): Using hsync ranges from config file
[   347.079] (II) modeset(0): Using vrefresh ranges from config file
[   347.079] (II) modeset(0): Printing DDC gathered Modelines:
[   347.079] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   347.079] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   347.080] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   347.080] (II) modeset(0): Using hsync ranges from config file
[   347.080] (II) modeset(0): Using vrefresh ranges from config file
[   347.080] (II) modeset(0): Printing DDC gathered Modelines:
[   347.080] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   347.080] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   347.110] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   347.110] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   347.110] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   347.110] (EE) client bug: timer event24 debounce: scheduled expiry is in the past (-3ms), your system is too slow
[   350.856] (II) modeset(0): Allocate new frame buffer 1920x1080 stride
[   350.902] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   350.902] (II) modeset(0): Using hsync ranges from config file
[   350.902] (II) modeset(0): Using vrefresh ranges from config file
[   350.902] (II) modeset(0): Printing DDC gathered Modelines:
[   350.902] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   350.902] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   350.903] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   350.903] (II) modeset(0): Using hsync ranges from config file
[   350.903] (II) modeset(0): Using vrefresh ranges from config file
[   350.903] (II) modeset(0): Printing DDC gathered Modelines:
[   350.903] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   350.903] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   350.933] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   350.933] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   350.933] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   350.933] (EE) client bug: timer event24 debounce: scheduled expiry is in the past (-2ms), your system is too slow
[   351.888] (II) modeset(0): Allocate new frame buffer 3840x1080 stride
[   351.914] randr: failed to create shared pixmap
[   351.914] (EE) NVIDIA(G0): Failed to configure Reverse PRIME on output HDMI-1-0.
[   351.924] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   351.924] (II) modeset(0): Using hsync ranges from config file
[   351.924] (II) modeset(0): Using vrefresh ranges from config file
[   351.924] (II) modeset(0): Printing DDC gathered Modelines:
[   351.924] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   351.924] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   351.925] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   351.925] (II) modeset(0): Using hsync ranges from config file
[   351.925] (II) modeset(0): Using vrefresh ranges from config file
[   351.925] (II) modeset(0): Printing DDC gathered Modelines:
[   351.925] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   351.925] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   351.955] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   351.955] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   351.955] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   353.796] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   353.796] (II) modeset(0): Using hsync ranges from config file
[   353.796] (II) modeset(0): Using vrefresh ranges from config file
[   353.796] (II) modeset(0): Printing DDC gathered Modelines:
[   353.796] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   353.796] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   353.797] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   353.797] (II) modeset(0): Using hsync ranges from config file
[   353.797] (II) modeset(0): Using vrefresh ranges from config file
[   353.797] (II) modeset(0): Printing DDC gathered Modelines:
[   353.797] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   353.797] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   353.827] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   353.827] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   353.827] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   353.827] (EE) event24 - Microsoft Microsoft Nano Transceiver 1.1: client bug: event processing lagging behind by 27ms, your system is too slow
[   353.842] randr: failed to create shared pixmap
[   353.842] (EE) NVIDIA(G0): Failed to configure Reverse PRIME on output HDMI-1-0.
[   356.369] (II) modeset(0): Allocate new frame buffer 1920x1080 stride
[   356.418] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   356.418] (II) modeset(0): Using hsync ranges from config file
[   356.418] (II) modeset(0): Using vrefresh ranges from config file
[   356.418] (II) modeset(0): Printing DDC gathered Modelines:
[   356.418] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   356.418] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   356.420] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   356.420] (II) modeset(0): Using hsync ranges from config file
[   356.420] (II) modeset(0): Using vrefresh ranges from config file
[   356.420] (II) modeset(0): Printing DDC gathered Modelines:
[   356.420] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   356.420] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   356.449] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   356.449] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   356.449] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   356.451] (II) modeset(0): Allocate new frame buffer 1920x1081 stride
[   356.490] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   356.490] (II) modeset(0): Using hsync ranges from config file
[   356.490] (II) modeset(0): Using vrefresh ranges from config file
[   356.490] (II) modeset(0): Printing DDC gathered Modelines:
[   356.490] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   356.490] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   356.491] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   356.491] (II) modeset(0): Using hsync ranges from config file
[   356.491] (II) modeset(0): Using vrefresh ranges from config file
[   356.491] (II) modeset(0): Printing DDC gathered Modelines:
[   356.491] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   356.491] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   356.521] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   356.521] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   356.521] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   356.530] (II) modeset(0): Allocate new frame buffer 1920x1080 stride
[   356.574] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   356.574] (II) modeset(0): Using hsync ranges from config file
[   356.574] (II) modeset(0): Using vrefresh ranges from config file
[   356.574] (II) modeset(0): Printing DDC gathered Modelines:
[   356.574] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   356.574] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   356.576] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   356.576] (II) modeset(0): Using hsync ranges from config file
[   356.576] (II) modeset(0): Using vrefresh ranges from config file
[   356.576] (II) modeset(0): Printing DDC gathered Modelines:
[   356.576] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   356.576] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   356.605] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   356.605] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   356.605] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   365.086] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   365.086] (II) modeset(0): Using hsync ranges from config file
[   365.086] (II) modeset(0): Using vrefresh ranges from config file
[   365.086] (II) modeset(0): Printing DDC gathered Modelines:
[   365.086] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   365.086] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   365.087] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   365.087] (II) modeset(0): Using hsync ranges from config file
[   365.087] (II) modeset(0): Using vrefresh ranges from config file
[   365.087] (II) modeset(0): Printing DDC gathered Modelines:
[   365.087] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   365.087] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   365.117] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   365.117] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   365.117] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   378.803] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   378.803] (II) modeset(0): Using hsync ranges from config file
[   378.803] (II) modeset(0): Using vrefresh ranges from config file
[   378.803] (II) modeset(0): Printing DDC gathered Modelines:
[   378.803] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   378.803] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   378.805] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   378.805] (II) modeset(0): Using hsync ranges from config file
[   378.805] (II) modeset(0): Using vrefresh ranges from config file
[   378.805] (II) modeset(0): Printing DDC gathered Modelines:
[   378.805] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   378.805] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   378.836] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   378.836] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   378.836] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   378.857] (II) modeset(0): Allocate new frame buffer 3840x1080 stride
[   378.891] randr: failed to create shared pixmap
[   378.891] (EE) NVIDIA(G0): Failed to configure Reverse PRIME on output HDMI-1-0.
[   378.914] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   378.914] (II) modeset(0): Using hsync ranges from config file
[   378.914] (II) modeset(0): Using vrefresh ranges from config file
[   378.914] (II) modeset(0): Printing DDC gathered Modelines:
[   378.914] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   378.914] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   378.915] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   378.915] (II) modeset(0): Using hsync ranges from config file
[   378.915] (II) modeset(0): Using vrefresh ranges from config file
[   378.915] (II) modeset(0): Printing DDC gathered Modelines:
[   378.915] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   378.915] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   378.945] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   378.945] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   378.945] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   461.102] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   461.102] (II) modeset(0): Using hsync ranges from config file
[   461.102] (II) modeset(0): Using vrefresh ranges from config file
[   461.102] (II) modeset(0): Printing DDC gathered Modelines:
[   461.102] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   461.102] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   461.103] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   461.103] (II) modeset(0): Using hsync ranges from config file
[   461.103] (II) modeset(0): Using vrefresh ranges from config file
[   461.103] (II) modeset(0): Printing DDC gathered Modelines:
[   461.103] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   461.103] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   461.223] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   461.223] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   461.223] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   497.291] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   497.291] (II) modeset(0): Using hsync ranges from config file
[   497.291] (II) modeset(0): Using vrefresh ranges from config file
[   497.291] (II) modeset(0): Printing DDC gathered Modelines:
[   497.291] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   497.291] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   497.292] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   497.292] (II) modeset(0): Using hsync ranges from config file
[   497.292] (II) modeset(0): Using vrefresh ranges from config file
[   497.292] (II) modeset(0): Printing DDC gathered Modelines:
[   497.292] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   497.292] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   499.127] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   499.127] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   499.127] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
[   504.712] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   504.712] (II) modeset(0): Using hsync ranges from config file
[   504.712] (II) modeset(0): Using vrefresh ranges from config file
[   504.712] (II) modeset(0): Printing DDC gathered Modelines:
[   504.712] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   504.712] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   504.713] (II) modeset(0): EDID vendor "AUO", prod id 53485
[   504.713] (II) modeset(0): Using hsync ranges from config file
[   504.713] (II) modeset(0): Using vrefresh ranges from config file
[   504.713] (II) modeset(0): Printing DDC gathered Modelines:
[   504.713] (II) modeset(0): Modeline "1920x1080"x0.0  290.80  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (137.2 kHz eP)
[   504.713] (II) modeset(0): Modeline "1920x1080"x0.0  116.40  1920 2028 2076 2120  1080 1090 1100 1142 -hsync -vsync (54.9 kHz e)
[   504.742] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): connected
[   504.742] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): Internal TMDS
[   504.742] (--) NVIDIA(GPU-0): LG Electronics LG FULL HD (DFP-0): 600.0 MHz maximum pixel clock
I’m experiencing the same problem. There are workarounds, fortunately:
  1. downgrade to the 5.4 kernel (or any version, really, but preferably an LTS version) if you can (that’s the simplest); or
  2. use the beta NVIDIA drivers from AUR (nvidia-utils-dkms, nvidia-beta-dkms); or
  3. use optimus-manager and switch to the “nvidia” mode, but note that PRIME synchronization is seemingly non-functioning with NVIDIA 455.45.01 + Linux 5.10, and using the NVIDIA GPU to do all rendering has implications on the battery life
PCI-Express power management also does not work from 5.10 on as it should, so I really recommend the first option for the time being.
Downgrading to 5.4 worked. Thanks!
And apparently snaps are now broken on Linux 5.4.Snaps stopped working after 2020-12-30 update Linux 5.9 seems to work for now until 5.10 gets ironed out.
Damn, this really is an inconvenient situation.
Shure it is.
I’m having the same problem on my work setup.
Will try the kernel downgrade, too.
**Edit: **
Booting 5.9 from grub works like a charm. Good temporarily solution.
I hope this will get fixed soon.
