After screen change graphic is displayed on wrong monitor
Hello together,
I picked out a new operating system today and wanted to start with Manjaro KDE. Everything went fine, but when I wanted to change my monitors (3 of them) I had a very strange problem. So I arranged my monitors in the settings and wanted to confirm the settings. Then I noticed that the graphic on the screen has changed the monitor, so is displayed correctly but not my mouse cursor. My cursor is on one screen and the content is on the other. However, I can click on the content even though my cursor is on the other monitor. Very strange and a bit hard to explain.
Does anyone have a tip, as even with reconnecting the cables it somehow doesn’t work and the keeps swapping the screens.
My components:
GPU: NVIDIA GeForce RTX 3060
CPU: AMD Ryzen 7 5800x
Kernel Version: 5.15.12-1-MANJARO
Graphics platform: X11
KDE Plasma Version: 5.23.4
KDE Framework Version: 5.89.0
Thanks in advance!
Best regards
Nino
Increase your chances of solving your issue:
Provide Information:
Through a tip from a friend, I tried changing it in NVIDIA Config instead of the normal system settings for monitors and everything worked normally.
The post is therefore done. :upside_down_face:
