Yes, But now, I have downgraded the kernel version from 66 to 61, and this version has no issues. It has been running stable for about a week. Here is the report for now:
$ inxi -Fza
Kernel: 6.1.80-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
root=UUID=c88f5257-3476-44bc-8d68-fde2b5aceff8 rw idle=nomwait
processor.max_cstate=1 intel_idle.max_cstate=0 quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 20YM v: Lenovo ThinkBook 16p Gen 2
serial: <superuser required> Chassis: type: 10 v: Lenovo ThinkBook 16p Gen 2
Mobo: LENOVO model: LNVNB161216 v: SDK0L77769 WIN
serial: <superuser required> part-nu: LENOVO_MT_20YM_BU_idea_FM_ThinkBook
16p G2 ACH uuid: <superuser required> UEFI: LENOVO v: GXCN48WW
date: 08/28/2023
ID-1: BAT0 charge: 60.7 Wh (96.0%) condition: 63.2/71.0 Wh (89.0%)
volts: 15.4 min: N/A model: SMP L20M4PD3 type: Li-poly serial: <filter>
status: not charging cycles: 79
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3242 high: 4048 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4048 2: 4046
3: 3987 4: 4038 5: 4046 6: 4048 7: 4048 8: 4046 9: 1200 10: 1200 11: 3817
12: 1200 13: 3847 14: 3876 15: 3237 16: 1200 bogomips: 102242
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 470.239.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-4 empty: DP-3,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:2520
class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-1,DP-2
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 55.0 C
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 04f2:b71f
Display: x11 server: X.Org v: 21.1.11 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia dri: radeonsi gpu: amdgpu,nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1600 s-dpi: 96 s-size: 1184x423mm (46.61x16.65")
s-diag: 1257mm (49.5")
Monitor-1: DP-4 mapped: DP-1-2 note: disabled pos: primary,right
model: Philips PHL 243S7 serial: <filter> built: 2021 res: 1920x1080 hz: 60
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-1 pos: left model-id: CSO 0x1603 built: 2020 res: 2560x1600
hz: 60 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: max: 2560x1600 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: swrast x11: drv: radeonsi
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
renoir LLVM 16.0.6 DRM 3.49 6.1.80-1-MANJARO) device-ID: 1002:1638
memory: 500 MiB unified: no
API: Vulkan v: 1.3.276 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Laptop GPU driver: nvidia v: 470.239.06
device-ID: 10de:2520 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RENOIR) driver: mesa radv
v: 24.0.2-manjaro1.1 device-ID: 1002:1638 surfaces: xcb,xlib
Device-1: NVIDIA GA106 High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228e class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.80-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: vboxnet0 state: up speed: 10 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 8087:0029
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.38 TiB used: 931.56 GiB (66.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-512G-1101 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11190001 temp: 27.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Western Digital
model: WD Blue SN570 1TB SSD size: 931.51 GiB block-size: physical: 512 B
fw-rev: 234100WD temp: 29.9 C scheme: GPT
ID-1: / raw-size: 95.37 GiB size: 93.31 GiB (97.84%) used: 56.17 GiB (60.2%)
fs: ext4 dev: /dev/nvme1n1p5 maj-min: 259:11
ID-2: /boot/efi raw-size: 977 MiB size: 975.1 MiB (99.80%)
used: 14.3 MiB (1.5%) fs: vfat dev: /dev/nvme1n1p4 maj-min: 259:10
ID-3: /home raw-size: 392.79 GiB size: 385.55 GiB (98.16%)
used: 306.26 GiB (79.4%) fs: ext4 dev: /dev/nvme1n1p6 maj-min: 259:12
ID-1: swap-1 type: partition size: 22.89 GiB used: 39.5 MiB (0.2%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:9
System Temperatures: cpu: 65.1 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 24 GiB note: est. available: 22.84 GiB
used: 13.92 GiB (61.0%)
Processes: 431 Power: uptime: 6m states: freeze,mem,disk suspend: s2idle
image: 9.12 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1809 libs: 453
tools: pamac,yay pm: flatpak pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1
Shell: Zsh v: 5.9 default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
and
$ sudo mhwd-kernel -li
Currently running: 6.1.80-1-MANJARO (linux61)
* linux61
* linux65
