Random shutdowns with 6 series kernels on HP Victus Laptop
Hi, after updating from LTS kernel I experience random shutdown of my notebook.
After such shutdown it wont boot by first power on, just hangs, so I need to turn it off by holding power button and after this I can turn it on and boot.
Can someone help me to debug this?
I cannot use LTS kernel because my wifi card supported only in 6 series kernel.
OS: Manjaro Linux x86_64
Host: Victus by HP Laptop 16-e0xxx
Kernel: 6.1.1-1-MANJARO
Shell: bash 5.1.16
Resolution: 2560x1440
DE: Plasma 5.26.4
WM: KWin
Theme: [Plasma], Breeze [GTK2/3]
Icons: [Plasma], breeze [GTK2/3]
Terminal: konsole
CPU: AMD Ryzen 7 5800H with Radeon Graphics (16) @ 3.200GHz
GPU: NVIDIA GeForce RTX 3060 Mobile / Max-Q
GPU: AMD ATI Radeon Vega Series / Radeon Vega Mobile Series
Memory: 8142MiB / 63643MiB
I suspect that my problem related to hybrid-graphics dynamic switching.
So I edited /etc/udev/rules.d/90-mhwd-prime-powermanagement.rules file.
And changed:
# Enable runtime PM for NVIDIA VGA/3D controller devices on driver bind
ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030000", TEST=="power/control", ATTR{power/control}="auto"
ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030200", TEST=="power/control", ATTR{power/control}="auto"
to:
ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030000", TEST=="power/control", ATTR{power/control}="on"
ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030200", TEST=="power/control", ATTR{power/control}="on"
Full file content:
# Remove NVIDIA USB xHCI Host Controller devices, if present
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c0330", ATTR{remove}="1"
# Remove NVIDIA USB Type-C UCSI devices, if present
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c8000", ATTR{remove}="1"
# Remove NVIDIA Audio devices, if present (enable it for kernels lower than 5.5)
#ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x040300", ATTR{remove}="1"
# Disable runtime PM for NVIDIA VGA/3D controller devices on driver unbind
ACTION=="unbind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030000", TEST=="power/control", ATTR{power/control}="on"
ACTION=="unbind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030200", TEST=="power/control", ATTR{power/control}="on"
I have no idea whats going on here and what I am doing.
OK. This change nothing, still getting random reboots.
maybe try alternate BIOS acpi, power management settings, HP
messes a lot with the bios usually, also check for bios update.
There is almost none settings in BIOS so nothing to experiment with…
this is a bit complicated, here some ideas:
  1. maybe have a log to the ksystemlog entries and when you have an exact time of the
    “crash” view the kernel, X11 … log entries.
  2. maybe also check gsmartcontrol reading of your harddrive
I updated post.
