Hi there!
Unfortunately I have this problem when trying to update my system with Pacman -Syu
already tried removing old package “adw-gtk3”, but apparently it breaks my system after a while
Hi there!
adw-gtk-theme
conflicts with and replaces adw-gtk3
, so all you have to do is accept the replacement when it prompts.
It does not prompt me like you are saying.
sudo pacman -Syu 1 ✘
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Replace adw-gtk3 with extra/adw-gtk-theme? [Y/n] Y
:: Replace amtk with extra/libgedit-amtk? [Y/n] Y
:: Replace bashrc-manjaro with core/bash? [Y/n] Y
:: Replace dbus-python with extra/python-dbus? [Y/n] Y
:: Replace gnome-shell-extension-arcmenu with extra/gnome-shell-extension-arc-menu? [Y/n] Y
:: Replace kauth with extra/kauth5? [Y/n] Y
:: Replace kcoreaddons with extra/kcoreaddons5? [Y/n] Y
:: Replace kitemmodels with extra/kitemmodels5? [Y/n] Y
:: Replace kwindowsystem with extra/kwindowsystem5? [Y/n] Y
:: Replace manjaro-gdm-branding with extra/manjaro-gnome-settings? [Y/n] Y
:: Replace tepl with extra/libgedit-tepl? [Y/n] Y
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: adw-gtk-theme and adw-gtk3 are in conflict
even tried:
sudo pacman -S adw-gtk-theme 1 ✘ 12s
:: adw-gtk-theme and adw-gtk3 are in conflict. Remove adw-gtk3? [y/N] y
:: removing adw-gtk3 breaks dependency 'adw-gtk3' required by gnome-shell-extension-custom-accent-colors
It did.
However, there should be no unresolvable package conflicts. It’s possible you may be in an unsupported, partial upgrade state. Make sure your mirrors are up to date and try again.
ok, I have to admit that I am using an “old” manjaro image to install my system…
Ok, I removed the “gnome-shell-extension-custom-accent-colors” pkg
now I have this:
:: installing mutter (46.5-1) breaks dependency 'libmutter-11.so=0-64' required by gnome-shell-maia
and then i tried removing it:
sudo pacman -Rns mutter 1 ✘
checking dependencies...
:: removing mutter breaks dependency 'mutter' required by gnome-shell-maia
:: removing mutter breaks dependency 'libmutter-11.so=0-64' required by gnome-shell-maia
You shouldn’t have to manually remove anything. You’re making things worse.
Hoo boy.
That’s quite old. You would probably save more time by installing with a more recent one. However, if you’ve already installed it, then updating your mirrors should take care of things.
Also, please edit your previous reply if no one has responded yet instead of posting twice in a row. I’ve merged your replies.
already tried updating the mirrors with sudo pacman-mirrors --fasttrack && sudo pacman -Syu
I think i will download a new image and start from scratch.
Thanks!
Best idea I think. I also saw this:
… meaning this is indeed a rather old .ISO — means maintenance would be needed such as merging the .pacnew
files.
This is a prompt.
In this instance, this seems like a good idea.
Recommended: Please search the forum for information about .pacsave
and .pacnew
files and system maintenance, generally.
As an infrequent forum user, please take some time to familiarise yourself with Forum requirements; and in particular, the many ways to use the forum to your benefit.
To that end, some or all these links may be invaluable:
Last, but not least, the Update Announcements, which you should check frequently for important update related information.
An issue may be directly related to a particular update; these announcements should generally be checked before posting a request for support.
I hope this is helpful.
Cheers.
