I have a Lenovo L14 (AMD) with a Ryzen 7 4750U and many (all?) programs that require 3d acceleration give the following message:
si_init_perfcounters: max_sh_per_se = 2 not supported (inaccurate performance counters)
3D acceleration still seems to work in most cases though.
System: Kernel: 5.9.1-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: i3 4.18.2 info: i3bar dm: LightDM 1.30.0
Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 20U50001GE v: ThinkPad L14 Gen 1 serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: LENOVO model: 20U50001GE serial: <filter> UEFI: LENOVO v: R19ET26W (1.10 ) date: 06/22/2020
Battery: ID-1: BAT0 charge: 45.2 Wh condition: 45.6/45.7 Wh (100%) volts: 12.6/11.1 model: Celxpert LNV-5B10W13897��
type: Li-poly serial: <filter> status: Charging cycles: 7
Memory: RAM: total: 62.25 GiB used: 1.78 GiB (2.9%)
CPU: Topology: 8-Core model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64 type: MT MCP arch: Zen rev: 1
L2 cache: 4096 KiB bogomips: 54324
Speed: 1398 MHz min/max: 1400/1700 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397
6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1396 13: 1397 14: 1397 15: 1397 16: 1397
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep
sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 06:00.0
chip ID: 1002:1636
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 4-3:2 chip ID: 04f2:b6be serial: <filter>
Display: x11 server: X.Org 1.20.9 driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa resolution:
1: 1920x1080~60Hz 2: 3840x2160~30Hz 3: 2160x3840 s-dpi: 96
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.1-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 06:00.1
chip ID: 1002:1637
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
bus ID: 06:00.5 chip ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 06:00.6 chip ID: 1022:15e3
Device-4: Lenovo type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-1.3.3.2:6 chip ID: 17ef:a396
serial: <filter>
Sound Server: ALSA v: k5.9.1-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 2400
bus ID: 02:00.0 chip ID: 10ec:8168
IF: enp2s0f0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000 bus ID: 03:00.0 chip ID: 8086:2723
Device-3: Lenovo USB3.1 Hub type: USB driver: r8152 bus ID: 3-1.1:3 chip ID: 17ef:a387 serial: <filter>
IF: enp6s0f3u1u1 state: down mac: <filter>
Drives: Local Storage: total: 1.82 TiB used: 557.56 GiB (29.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 2TB size: 1.82 TiB speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 2B2QEXM7 scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / size: 1.79 TiB used: 557.56 GiB (30.4%) fs: ext4 dev: /dev/nvme0n1p2 label: N/A
uuid: a1a3daf1-9cf6-46ba-b0e6-1d76891a3043
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 label: N/A uuid: D2B3-CAA3
Swap: ID-1: swap-1 type: file size: 16.00 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 2-1:2 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip ID: 17ef:a392
Hub: 2-1.3:3 info: Lenovo ports: 4 rev: 2.1 speed: 480 Mb/s chip ID: 17ef:a394
Hub: 2-1.3.3:4 info: Lenovo ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 17ef:a395
Device-1: 2-1.3.3.1:5 info: Lenovo USB2.0 Hub type: Billboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 17ef:a38f serial: <filter>
Device-2: 2-1.3.3.2:6 info: Lenovo type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s chip ID: 17ef:a396 serial: <filter>
Device-3: 2-1.3.3.3:7 info: Cherry type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s chip ID: 046a:0113
Device-4: 2-1.3.3.4:8 info: Cherry type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 046a:b092
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 3-1:2 info: Lenovo USB3.1 Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 17ef:a391
Device-1: 3-1.1:3 info: Lenovo USB3.1 Hub type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
Hub: 3-1.3:4 info: Lenovo ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 17ef:a393
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 4-3:2 info: Chicony Integrated Camera type: Video driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s
Device-2: 4-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
chip ID: 8087:0029
Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 41.9 C mobo: N/A gpu: amdgpu temp: 31 C
Fan Speeds (RPM): fan-1: 0
Info: Processes: 323 Uptime: 2m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1410 Shell: Bash v: 5.0.18
running in: xfce4-terminal inxi: 3.1.05
There are some failures:
[ 0.484891] smp: Bringing up secondary CPUs ...
[ 0.484998] x86: Booting SMP configuration:
[ 0.484999] .... node #0, CPUs: #1
[ 0.486166] TSC synchronization [CPU#0 -> CPU#1]:
[ 0.486166] Measured 6571456641 cycles TSC warp between CPUs, turning off TSC clock.
[ 0.486166] tsc: Marking TSC unstable due to check_tsc_sync_source failed
[ 0.486166] #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15
[ 0.489939] smp: Brought up 1 node, 16 CPUs
[ 2.092611] Intel(R) Wireless WiFi driver for Linux
[ 2.093108] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[ 2.103650] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-56.ucode failed with error -2
[ 2.105000] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 2.105016] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.22
[ 2.105019] iwlwifi 0000:03:00.0: Found debug destination: EXTERNAL_DRAM
[ 2.105020] iwlwifi 0000:03:00.0: Found debug configuration: 0
[ 2.105349] iwlwifi 0000:03:00.0: loaded firmware version 55.d9698065.0 cc-a0-55.ucode op_mode iwlmvm
[ 11.223739] audit: type=1130 audit(1603698592.929:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.243489] audit: type=1130 audit(1603698592.949:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 13.099847] audit: type=1131 audit(1603698594.806:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.682238] audit: type=1100 audit(1603698598.386:85): pid=1781 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="gkraemer" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=failed'
[ 25.072525] audit: type=1100 audit(1603698606.776:86): pid=1839 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="gkraemer" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 25.074575] audit: type=1101 audit(1603698606.779:87): pid=1839 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="gkraemer" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 25.154320] audit: type=1106 audit(1603698606.859:88): pid=1584 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 25.154325] audit: type=1104 audit(1603698606.859:89): pid=1584 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 25.158695] audit: type=1103 audit(1603698606.863:90): pid=1839 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="gkraemer" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 25.158868] audit: type=1006 audit(1603698606.863:91): pid=1839 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 25.204654] audit: type=1130 audit(1603698606.909:92): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 25.215614] audit: type=1101 audit(1603698606.919:93): pid=1845 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="gkraemer" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 25.215620] audit: type=1103 audit(1603698606.919:94): pid=1845 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="gkraemer" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Welcome to Manjaro!
Do not switch branches unless you know what you’re doing!
