[Testing Update] 2024-04-12 - Mesa, KDE Gear, Phosh, Qt6, Kodi 21.0, HHD, HHD-UI
Current promotions
  • image
    We currently have a flash sale with our partner MINISFORUM on the UM790Pro featuring the Manjaro Linux GamingEdition. Use the device either as a MiniPC or Gaming Console! Use our link to get yours. Note: US Market only!
  • Protect your personal data, keep yourself safe with Surfshark VPN: 85% OFF + 2 mo. FREE
Recent News
Previous News
Finding information easier about Manjaro always has been a topic that needed to be solved. With our new search we have put all Manjaro data accessible in one place and divided by sections so it makes it easier to digest: New Manjaro search engine is available | Blog
Notable Package Updates
A list of all package changes can be found here
Additional Info
Info about AUR packages
For help with AUR packages, please create a new topic in AUR and a helpful volunteer may be able to assist you.
Our current supported kernels
  • linux419 4.19.311
  • linux54 5.4.273
  • linux510 5.10.214
  • linux515 5.15.154
  • linux61 6.1.85
  • linux66 6.6.26
  • linux68 6.8.5
  • linux69 6.9.0-rc3
  • linux61-rt 6.1.83_rt28
  • linux66-rt 6.6.23_rt28
  • linux67-rt 6.7_rt6
Package Changes (Fri Apr 12 05:15:45 CEST 2024)
  • testing core x86_64: 23 new and 24 removed package(s)
  • testing extra x86_64: 1049 new and 1053 removed package(s)
  • testing multilib x86_64: 17 new and 17 removed package(s)
A list of package Changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2024-04-12
2024-03-23
Konsole font rendering issue
if you use manjaro-zsh-config on Plasma 6,
please check your Font settings in Konsole:
Konsole: Open Settings → Edit Current Profile → Appearance,
click Select Font and select MesloLGS NF Regular.
2024-03-16
Plasma 6 issues with Manjaro themes & tools
Prepare for a Plasma 6 release (#2) · Issues · Release plan / KDE · GitLab
DKMS fails for v4l2loopback on 6.8 kernel
DKMS fails for v4l2loopback on 6.8 kernel (#2) · Issues · Arch Linux / Packaging / Packages / v4l2loopback · GitLab
New version of kvantum does not support QT5 theme
Install new package kvantum-qt5 for QT5 theme support
required for manjaro-settings-manager and audacious
pamac install kvantum-qt5
If Theme shows wrong colors:
cd $HOME; ln -s .profile .xprofile
Manjaro-settings-manager has light theme instead of dark
issues with auto-mount of ntfs filesystem using Kernel 6.8
The kernel changed default ntfs driver from FUSE one to ntfs3.
These two are not fully compatible, mainly as far as mount options go. If you have custom mount options in the fstab (or any other application, such as VeraCrypt) they need to be changed.
Symptoms:
Mount fails with: Device or resource busy
DMesg reports: Can't open blockdev
Solution:
Migrate your mount options. For me the changes were:
  • allow_otherumask=000
  • default_permissions → [drop]
  • user_id=1000uid=1000
  • group_id=1000gid=1000
2024-02-23
gnome-keyring: ssh component is not included
ssh component is not included (#3) · Issues · Arch Linux / Packaging / Packages / gnome-keyring · GitLab
2024-01-25
polkit update might remove your local modified config
With polkit 124-1 there were changes made to etc/pam.d/polkit-1. So check if you made local changes to the file. See also: https://old.reddit.com/r/archlinux/comments/19bnj0i/todays_update_moved_polkit1_to_polkit1pacsave/kit2v33/
bashrc-manjaro is now merged into bash
Yes, replace bashrc-manjaro with bash
pacman and pacman-contrib changes
pacman-contrib is now split out from pacman. If you have anything installed that depends on pacman-contrib, update with:
sudo pacman -Syu pacman-contrib
2024-01-11
Making dbus-broker our default D-Bus daemon
2024-01-09 - Jan Alexander Steffens
We are making dbus-broker our default implementation of D-Bus, for improved performance, reliability and integration with systemd.
For the foreseeable future we will still support the use of dbus-daemon, the previous implementation. Pacman will ask you whether to install dbus-broker-units or dbus-daemon-units. We recommend picking the default.
For a more detailed rationale, please see our RFC 25.
Arch Linux - News: Making dbus-broker our default D-Bus daemon
Previous testing threads:
seems to be from previous update, since
is a few lines down in this announcement and links to the comparison of april 4 and april 12
Ever since I moved from stable (2024-03-13) to testing (2024-04-04) I’ve had a really bizarre issue with Plymouth. I’ve temporarily removed the quiet boot option to debug this. When I boot into either kernel 6.1 or 6.6, the boot process freezes at :: running hook [plymouth]. However, after forcing a shutdown via the power button and then booting again, the plymouth boot screen runs and I get into my system with no issue. This pattern of every other boot working/failing continues. Booting without splash launches my system with no issues consistently.
The only additional items a failed boot gives me in journalctl -b -1 -p3 --no-pager is
Apr 12 11:13:03 RAESTRON kernel: scsi 3:0:0:1: Wrong diagnostic page; asked for 1 got 8
Apr 12 11:13:03 RAESTRON kernel: scsi 3:0:0:1: Failed to get diagnostic page 0x1
Apr 12 11:13:03 RAESTRON kernel: scsi 3:0:0:1: Failed to bind enclosure -19
/boot/refind_linux.conf
"Boot with standard options"  "root=UUID=b6b8ce65-59d1-423c-9672-d181fb6a1053 rw splash udev.log_priority=3"
"Boot to single-user mode"    "root=UUID=b6b8ce65-59d1-423c-9672-d181fb6a1053 rw quiet splash udev.log_priority=3 single"
"Boot with minimal options"   "ro root=/dev/nvme0n1p1"
inxi -v7azy
  Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: root=UUID=b6b8ce65-59d1-423c-9672-d181fb6a1053 rw splash
    udev.log_priority=3 initrd=boot\initramfs-6.6-x86_64.img
  Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
  Type: Desktop System: Micro-Star product: MS-7D53 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: MPG X570S EDGE MAX WIFI (MS-7D53) v: 1.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 1.70 date: 07/03/2023
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540/K545
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 64 GiB available: 62.72 GiB used: 4.21 GiB (6.7%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 32 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK64GX4M2E3200C16 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 96 MiB
    desc: 1x96 MiB
  Speed (MHz): avg: 2200 min/max: 2200/4549 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
    4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 108859
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti GDDR6X] vendor: Micro-Star MSI
    driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 2d:00.0 chip-ID: 10de:24c9 class-ID: 0300
  Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.4:6
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x333mm (31.57x13.11")
    s-diag: 868mm (34.19")
  Monitor-1: Unknown-1 mapped: HDMI-0 res: 3440x1440 hz: 60 dpi: 109
    size: 800x335mm (31.5x13.19") modes: 3440x1440
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Ti driver: nvidia v: 550.67 device-ID: 10de:24c9
    surfaces: xcb,xlib
  Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 2d:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3
    chip-ID: 0db0:151f class-ID: 0300
  Device-4: Native Instruments KOMPLETE KONTROL A61
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-1.1.4:7 chip-ID: 17cc:1750 class-ID: fe01
    serial: <filter>
  Device-5: Van Ooijen Technische Informatica MIDI Expression RED
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-1.2:4 chip-ID: 16c0:0470 class-ID: 0301
    serial: <filter>
  Device-6: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 27:00.0
  IF: enp39s0 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 28:00.0
    chip-ID: 8086:2725 class-ID: 0280
  IF-ID-1: br-c313e43e014f state: down mac: <filter>
  IF-ID-2: br-d37bfd6ac4d4 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-3: docker0 state: down mac: <filter>
  IF-ID-4: vethce45932 state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 8087:0032
    class-ID: e001
  Local Storage: total: 6.48 TiB used: 920.56 GiB (13.9%)
    model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 620331WD temp: 36.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400M8120G
    size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 62B3 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: SSK model: SSK Storage
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 0209 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD40NMZW-11GX6S1 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 4005 scheme: GPT
  ID-1: / raw-size: 512 GiB size: 502.89 GiB (98.22%) used: 120.1 GiB (23.9%)
    fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: RAESTRON-ROOT
    uuid: b6b8ce65-59d1-423c-9672-d181fb6a1053
    used: 70.9 MiB (13.9%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 26B7-73C9
  ID-3: /home raw-size: 1.32 TiB size: 1.3 TiB (98.35%)
    used: 800.4 GiB (60.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: RAESTRON-HOME uuid: e8d504b4-c2a3-486e-9006-57cb3225607d
  ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required> label: N/A
    uuid: N/A
  ID-2: /dev/sda2 maj-min: 8:2 size: 111.77 GiB fs: ntfs label: RAESTRONW-FS
    uuid: 6C4C47654C472962
  ID-3: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/sdb2 maj-min: 8:18 size: 931.5 GiB fs: ntfs
    label: JAROMANO-SOUNDLIB uuid: D6E655A7E655891F
  ID-5: /dev/sdc1 maj-min: 8:33 size: 512 GiB fs: ntfs
    label: JAROMANO-DATA-ISO uuid: 068A84458A84336B
  ID-6: /dev/sdc2 maj-min: 8:34 size: 2.95 TiB fs: ext4 label: JAROMANO-DATA
    uuid: 6c4ef292-20e3-4480-b149-e9d1fa04785d
  ID-7: /dev/sdc3 maj-min: 8:35 size: 195.31 GiB fs: swap
    label: JAROMANO-XSWAP uuid: 9ff4987f-8434-4a23-beb4-5d3230db83a7
  Hub-2: 1-1:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 1-2:3 info: Micro Star USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
  Device-2: 1-4:4 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 2-1:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-1:2 info: Logitech G502 X type: mouse,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 046d:c099 class-ID: 0300
    serial: <filter>
  Device-2: 3-2:3 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-3: 3-5:4 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d53 class-ID: 0300
    serial: <filter>
  Hub-6: 3-6:5 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-9: 5-1:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
  Hub-10: 5-1.1:3 info: Hitachi ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 045b:0209
  Device-1: 5-1.1.1:5 info: Logitech F310 Gamepad [XInput Mode]
    type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0
    chip-ID: 046d:c21d class-ID: ff00 serial: <filter>
  Device-2: 5-1.1.4:7 info: Native Instruments KOMPLETE KONTROL A61
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 480mA
    chip-ID: 17cc:1750 class-ID: fe01 serial: <filter>
  Device-3: 5-1.2:4 info: Van Ooijen Technische Informatica MIDI Expression
    RED type: audio,HID,keyboard driver: hid-generic,snd-usb-audio,usbhid
    interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 16c0:0470 class-ID: 0301 serial: <filter>
  Device-4: 5-1.4:6 info: Logitech HD Pro Webcam C920 type: video,audio
  Hub-11: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-12: 6-1:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
  Hub-13: 6-1.1:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
  Device-1: 6-1.1.2:4 info: JMicron / USA JMS567 SATA 6Gb/s bridge
    type: mass storage driver: uas interfaces: 1 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
    chip-ID: 152d:0562 class-ID: 0806 serial: <filter>
  Device-2: 6-1.1.3:5 info: Western Digital My Passport (WD40NMZW)
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.1
    chip-ID: 1058:25e2 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 35.2 C mobo: N/A gpu: nvidia temp: 32 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Processes: 351 Power: uptime: 7m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.08 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 1990 pm: pacman pkgs: 1959 libs: 522 tools: pamac,yay pm: flatpak
    pkgs: 18 pm: snap pkgs: 13 Compilers: clang: 17.0.6 gcc: 13.2.1 alt: 12
    Shell: Zsh v: 5.9 default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
I’m not sure how to get a useful plymouth-debug.log (assuming it’s even doing anything) - would booting with minimal options after the failed boot skip plymouth entirely to the point it won’t write that log?
2 posts were split to a new topic: Stuck in emergency mode after installing 6.8.5-1
3 posts were split to a new topic: Issues with tuxedo-drivers-dkms
