After Aragorn kindly showed me how to get the modern zsh prompt in an older Manjaro install (by installing manjaro-zsh-config + zsh-theme-powerlevel10k, then copying .zshrc to my home directory from from /etc/skel – see How to make Konsole look like it does on newer installations?), I was able to get the new look on one of my older systems.
But after following the same procedure on a second older install, I ended up with this:
Can you find a image of how it’s suppose to look and post it? I ask cause shortly after install of a Arch based distro I install Xero Welcome and use their ZSH installer and configurator.
I’m probably missing something, but as far as I can tell the only way to set the font for Konsole is in the Profile, and both systems are using Breath, which appears un-editable and so both should be using the same font?
Also, I forgot to mention that I get the same prompt in Yakuake, if that’s any help.
