ehhen
27 December 2023 04:43
1
Major update zenity 4.0.0 does not provide gdialog. It was deleted.
Alternative, yes/no branch
○ zenity --question --text=" $PWD :: XX…" && echo yes
✗ gdialog --yesno “$PWD continue…”&& echo yes
Apparently I was a speaker of an ancient language. In my case, a lot of revisions were needed.
I didn’t realize that this subcommand had been deleted, so I ended up restoring it many times.
I would be happy if it was helpful to someone.
Thanks for the warning; I use zenity quite a lot in various scripts.
Fortunately I already use --question rather than gdialog, but at least with your warning I knew I needed to check.
ehhen
29 December 2023 22:38
3
In my case, 66 scripts were applicable.
Cinnamon version. I use it from the right-click menu, not from the terminal.
In the end, for reasons unknown, several tools I use every day stopped working even when started from the terminal. So I downgraded it.
zenity-3.44.2-1-x86_64.pkg.tar.zst 10-Aug-2023 16:58 3M
zenity-3.44.2-1-x86_64.pkg.tar.zst.sig 10-Aug-2023 16:58 141
https://archive.archlinux.org/packages/z/zenity/
