Hi, I’ve been searching numerous resources online including the bb archlinux forum about my problem.
The second monitor I have is a Lenovo L97 Wide wired over VGA on an HP 8470p running on an AMD graphics processor. The screen seems to have this yellowish tint on it.
Things I have tried:
1. Calibration through the Monitor’s inbuilt Color Adjustments.
Result: Nothing help on it, except the contrast around 40-50 which really dims my screen but the yellow tint seems to go away.
2. Using redshift manual assignment of the color temperature.
redshift -m randr:crtc=1 -O 16000
Result: Seems it helps but still dims my screen like a lot. I have set the Temp around 16000K, I know but my Eye is comfortable as long as the tint is gone but yeah, the screen really dims.
3. Turning Off Night Mode
Result: NO, just doesn’t help.
4. Tried Gamma correction on the laptop itself
Result: Worth the try bu now bot of the main screen and the Laptop screen is now messed up.
Here’s an actual image, thank god my white balance isn’t flushing it out.
I know, it might not be that much on picture but hell, in real life it is much worst than that.
Talking about hardware info:
System: Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.21.5 Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: Hewlett-Packard product: HP EliteBook 8470p v: A1029D1102 serial: <filter>
Mobo: Hewlett-Packard model: 179B v: KBC Version 42.38 serial: <filter> UEFI: Hewlett-Packard v: 68ICF Ver. F.74
date: 04/11/2019
CPU: Info: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge rev: 9 cache: L2: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20756
Speed: 1224 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1224 2: 1211 3: 1216 4: 1548
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Thames [Radeon HD 7550M/7570M/7650M] vendor: Hewlett-Packard
driver: radeon v: kernel bus-ID: 01:00.0
Device-2: Primax HP HD Webcam [Fixed] type: USB driver: uvcvideo bus-ID: 1-1.3:5
Display: x11 server: X.Org 1.20.11 driver: loaded: ati,radeon unloaded: modesetting resolution: 1: 1600x900~60Hz
2: 900x1440~60Hz
OpenGL: renderer: AMD TURKS (DRM 2.50.0 / 5.10.42-1-MANJARO LLVM 11.1.0) v: 3.3 Mesa 21.0.3 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0
Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series] vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Network: Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard driver: e1000e v: kernel port: 5020 bus-ID: 00:19.0
IF: eth0 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi v: kernel port: 4000 bus-ID: 25:00.0
Bluetooth: Device-1: Broadcom HP Portable SoftSailing type: USB driver: btusb v: 0.8 bus-ID: 2-1.6:3
Drives: Local Storage: total: 298.09 GiB used: 64.43 GiB (21.6%)
ID-1: /dev/sda vendor: Western Digital model: WD3200LPVX-22V0TT0 size: 298.09 GiB
Partition: ID-1: / size: 283.94 GiB used: 64.36 GiB (22.7%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1
Swap: ID-1: swap-1 type: partition size: 8.31 GiB used: 76 MiB (0.9%) dev: /dev/sda3
Sensors: System Temperatures: cpu: 57.0 C mobo: 54.0 C gpu: radeon temp: 55.0 C
Info: Processes: 234 Uptime: 45m Memory: 3.77 GiB used: 2.34 GiB (62.1%) Init: systemd Compilers: gcc: 11.1.0
clang: 11.1.0 Packages: 1611 Shell: Zsh v: 5.8 inxi: 3.3.04
I just hope someone can figure out whats happening on this monitor.
Thanks in advance
