Hi,
I have the following problem. On certain packages, I can install (compile) packages only using
sudo pamac build PACKAGENAME
If I try to use the command
yay -S PACKAGENAME
I got some kind of error.
Hi,
yay -S PACKAGENAME
You shouldn’t use sudo with pamac.
What error?
Which packages? Which errors?
Dear Judge,
here is a complete description of the case. I was only waiting to have the opportunity to provide complete documentation. I enjoy that it is not a diffuse problem. I am glad to you and the other team guys for helping me to understand the problem.
I need to perform some tries before providing a complete answer. I have the same problem if I try to use yay directly and I execute the following commands before executing yay.
sudo pacman -Rsn $(pacman -Qdtq)
sudo pacman -Scc
sudo rm /var/lib/systemd/coredump/.
sudo journalctl --vacuum-size=50M
A package that creates problems on a single machine is ocrmypdf.
As first I tried to execute
yay -Suuyy ocrmypdf
and I got errors with python-coloredlogs
After I executed
sudo pamac build python-coloredlogs
and I installed the new version of the package.
After python-coloredlogs installation I try to execute
yay -S ocrmypdf
and, again, I got an error on python-coloredlogs.
To complete the installation I have to execute
sudo pamac build ocrmypdf
Follows the outputs of the first command
yay -Suuyy ocrmypdf
-1-
:: e[1mControllando la presenza di conflitti...e[0m
:: e[1mControllando la presenza di conflitti interni...e[0m
[Aur:2] python-coloredlogs-15.0.1-3 ocrmypdf-13.4.4-1
:: e[1mPKGBUILD aggiornato, saltando (2/0): python-coloredlogs, ocrmypdfe[0m
:: e[1m(1/2) Analizzando SRCINFO: python-coloredlogse[0m
:: e[1m(2/2) Analizzando SRCINFO: ocrmypdfe[0m
==> Making package: python-coloredlogs 15.0.1-3 (Mon May 16 10:46:57 2022)
==> Retrieving sources...
==> Making package: ocrmypdf 13.4.4-1 (Mon May 16 10:46:57 2022)
-> Found 15.0.1.tar.gz
15.0.1.tar.gz ... -> Found ocrmypdf-13.4.4.tar.gz
Passed
ocrmypdf-13.4.4.tar.gz ... Passed
15.0.1.tar.gz ... Passed
==> Extracting sources...
-> Extracting 15.0.1.tar.gz with bsdtar
==> Sources are ready.
==> Making package: python-coloredlogs 15.0.1-3 (Mon May 16 10:46:58 2022)
==> WARNING: Using existing $srcdir/ tree
==> Removing existing $pkgdir/ directory...
==> Starting build()...
/media/data/users/home/marco/.cache/yay/python-coloredlogs/src/python-coloredlogs-15.0.1/setup.py:24: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
import distutils.sysconfig
/media/data/users/home/marco/.cache/yay/python-coloredlogs/src/python-coloredlogs-15.0.1/setup.py:24: DeprecationWarning: The distutils.sysconfig module is deprecated, use sysconfig instead
running build
running build_py
creating build
creating build/lib
creating build/lib/coloredlogs
copying coloredlogs/demo.py -> build/lib/coloredlogs
copying coloredlogs/cli.py -> build/lib/coloredlogs
copying coloredlogs/__init__.py -> build/lib/coloredlogs
copying coloredlogs/syslog.py -> build/lib/coloredlogs
copying coloredlogs/tests.py -> build/lib/coloredlogs
creating build/lib/coloredlogs/converter
copying coloredlogs/converter/colors.py -> build/lib/coloredlogs/converter
copying coloredlogs/converter/__init__.py -> build/lib/coloredlogs/converter
Running Sphinx v4.5.0
loading translations [en]... fatto
Extension error:
Could not import extension sphinx.builders.linkcheck (exception: cannot import name 'Mapping' from 'collections' (/usr/lib/python3.10/collections/__init__.py))
==> ERROR: A failure occurred in build().
Aborting...
-> errore nella creazione: python-coloredlogs
[Aur:1] python-coloredlogs-15.0.1-3
:: e[1mPKGBUILD aggiornato, saltando (1/0): python-coloredlogse[0m
:: e[1m(1/1) Analizzando SRCINFO: python-coloredlogse[0m
==> Making package: python-coloredlogs 15.0.1-3 (Mon May 16 10:47:40 2022)
==> Making package: python-coloredlogs 15.0.1-3 (Mon May 16 10:47:41 2022)
==> Making package: python-coloredlogs 15.0.1-3 (Mon May 16 10:47:42 2022)
running build
running build_py
creating build
creating build/lib
Extension error:
Aborting...
and the ouput of the following commands that permits to me to install ocrmypdf
-2-
Running as unit: run-u564.service
fatal: non è un repository Git (né lo è alcun genitore fino al punto di mount /var/cache/private)
Mi fermo al limite del filesystem (l'opzione GIT_DISCOVERY_ACROSS_FILESYSTEM non è impostata).
Finished with result: exit-code
Main processes terminated with: code=exited/status=128
Service runtime: 16ms
CPU time consumed: 15ms
Running as unit: run-u565.service
Finished with result: success
Main processes terminated with: code=exited/status=0
CPU time consumed: 13ms
Running as unit: run-u566.service
Service runtime: 549ms
CPU time consumed: 47ms
Running as unit: run-u567.service
Service runtime: 815ms
CPU time consumed: 922ms
Warning: Building packages as dynamic user
Warning: Setting build directory to /var/cache/pamac
Preparing...
Cloning python-coloredlogs build files...
Generating python-coloredlogs information...
Checking python-coloredlogs dependencies...
Warning: python-coloredlogs-15.0.1-3 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
To build (1):
python-coloredlogs 15.0.1-3 AUR
Edit build files : [e]
Apply transaction ? [e/y/N] Running as unit: run-u568.service
==> Creazione del pacchetto: python-coloredlogs 15.0.1-3 (lun 16 mag 2022, 10:48:31)
==> Controllo delle dipendenze durante l'avvio in corso...
==> Controllo delle dipendenze durante la compilazione in corso...
==> Download dei sorgenti in corso...
-> Download di 15.0.1.tar.gz in corso...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 14565 0 14565 0 0 18756 0 --:--:-- --:--:-- --:--:-- 18756
100 270k 0 270k 0 0 305k 0 --:--:-- --:--:-- --:--:-- 2372k
==> Validazione di source file con sha256sums...
15.0.1.tar.gz ... Verificato
==> Rimozione dell'esistente directory $srcdir/ in corso...
==> Estrazione dei sorgenti in corso...
-> Estrazione di 15.0.1.tar.gz usando bsdtar in corso...
==> Avvio di build() in corso...
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/setup.py:24: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/setup.py:24: DeprecationWarning: The distutils.sysconfig module is deprecated, use sysconfig instead
running build
running build_py
creating build
creating build/lib
making output directory... fatto
loading intersphinx inventory from https://docs.python.org/2/objects.inv...
loading intersphinx inventory from https://docs.python.org/3/objects.inv...
loading intersphinx inventory from https://capturer.readthedocs.io/en/latest/objects.inv...
loading intersphinx inventory from https://humanfriendly.readthedocs.io/en/latest/objects.inv...
building [mo]: targets for 0 po files that are out of date
building [html]: targets for 4 source files that are out of date
updating environment: [new config] 4 added, 0 changed, 0 removed
reading sources... [ 25%] api
reading sources... [ 50%] changelog
reading sources... [ 75%] index
reading sources... [100%] readme
looking for now-outdated files... none found
pickling environment... fatto
checking consistency... fatto
preparing documents... fatto
writing output... [ 25%] api
writing output... [ 50%] changelog
writing output... [ 75%] index
writing output... [100%] readme
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs:146: WARNING: py:data reference target not found: logging.WARNING
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs:146: WARNING: py:data reference target not found: logging.INFO
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs:159: WARNING: py:data reference target not found: logging.NOTSET
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs:161: WARNING: py:data reference target not found: logging.NOTSET
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs:161: WARNING: py:func reference target not found: logging.Logger.getEffectiveLevel
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs:165: WARNING: py:data reference target not found: logging.WARNING
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs:169: WARNING: py:data reference target not found: logging.WARNING
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs:179: WARNING: py:func reference target not found: logging.Logger.getEffectiveLevel
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs:182: WARNING: py:data reference target not found: logging.INFO
docstring of coloredlogs.DEFAULT_LOG_LEVEL:1: WARNING: py:data reference target not found: logging.INFO
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs.adjust_level:11: WARNING: py:func reference target not found: logging.Logger.getEffectiveLevel
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs.find_handler:15: WARNING: py:class reference target not found: logging.Logger.handlers
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs.walk_propagation_tree:7: WARNING: py:class reference target not found: logging.Logger.parent
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs.BasicFormatter.formatTime:7: WARNING: py:func reference target not found: logging.Formatter.formatTime
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs.ColoredFormatter.format:4: WARNING: py:func reference target not found: logging.Formatter.format
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/__init__.py:docstring of coloredlogs.ColoredFormatter.format:6: WARNING: py:func reference target not found: logging.Formatter.format
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/converter/__init__.py:docstring of coloredlogs.converter.convert:7: WARNING: py:func reference target not found: str.expandtabs
/var/cache/private/pamac/python-coloredlogs/src/python-coloredlogs-15.0.1/coloredlogs/converter/__init__.py:docstring of coloredlogs.converter.encode_whitespace:4: WARNING: py:func reference target not found: str.expandtabs
generating indices... genindex py-modindex fatto
highlighting module code... [ 33%] coloredlogs
highlighting module code... [ 66%] coloredlogs.converter
highlighting module code... [100%] coloredlogs.syslog
writing additional pages... search fatto
copying images... [ 25%] images/defaults.png
copying images... [ 50%] images/custom-log-format.png
copying images... [ 75%] images/custom-datetime-format.png
copying images... [100%] images/custom-colors.png
copying static files... fatto
copying extra files... fatto
dumping search index in English (code: en)... fatto
dumping object inventory... fatto
build succeeded, 18 warnings.
The HTML pages are in build/html.
==> Entro nell'ambiente fakeroot...
==> Avvio di package() in corso...
running install
/usr/lib/python3.10/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
running install_lib
creating /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr
creating /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib
creating /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10
creating /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages
creating /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs
copying build/lib/coloredlogs/demo.py -> /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs
copying build/lib/coloredlogs/tests.py -> /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs
creating /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs/converter
copying build/lib/coloredlogs/converter/colors.py -> /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs/converter
copying build/lib/coloredlogs/converter/__init__.py -> /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs/converter
copying build/lib/coloredlogs/cli.py -> /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs
copying build/lib/coloredlogs/__init__.py -> /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs
copying build/lib/coloredlogs/syslog.py -> /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs
byte-compiling /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs/demo.py to demo.cpython-310.pyc
byte-compiling /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs/tests.py to tests.cpython-310.pyc
byte-compiling /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs/converter/colors.py to colors.cpython-310.pyc
byte-compiling /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs/converter/__init__.py to __init__.cpython-310.pyc
byte-compiling /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs/cli.py to cli.cpython-310.pyc
byte-compiling /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs/__init__.py to __init__.cpython-310.pyc
byte-compiling /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs/syslog.py to syslog.cpython-310.pyc
writing byte-compilation script '/tmp/tmp25h6domw.py'
/usr/bin/python -Wignore:The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives:DeprecationWarning /tmp/tmp25h6domw.py
removing /tmp/tmp25h6domw.py
running install_data
copying coloredlogs.pth -> /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages
running install_egg_info
running egg_info
creating coloredlogs.egg-info
writing coloredlogs.egg-info/PKG-INFO
writing dependency_links to coloredlogs.egg-info/dependency_links.txt
writing entry points to coloredlogs.egg-info/entry_points.txt
writing requirements to coloredlogs.egg-info/requires.txt
writing top-level names to coloredlogs.egg-info/top_level.txt
writing manifest file 'coloredlogs.egg-info/SOURCES.txt'
reading manifest file 'coloredlogs.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
adding license file 'LICENSE.txt'
Copying coloredlogs.egg-info to /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/lib/python3.10/site-packages/coloredlogs-15.0.1-py3.10.egg-info
running install_scripts
Installing coloredlogs script to /var/cache/private/pamac/python-coloredlogs/pkg/python-coloredlogs/usr/bin
==> Rimozione dei dati superflui in corso...
-> Rimozione dei file libtool in corso...
-> Eliminazione dei file indesiderati in corso...
-> Rimozione dei file dalle librerie statiche...
-> Rimozione dei simboli non necessari dai binari e dalle librerie in corso...
-> Compressione delle pagine man ed info in corso...
==> Controllo per il rilascio dei pacchetti in corso...
==> Creazione del pacchetto "python-coloredlogs" in corso...
-> Generazione del file .PKGINFO in corso...
-> Generazione del file .BUILDINFO in corso...
-> Creazione del file .MTREE in corso...
-> Compressione del pacchetto in corso...
==> Uscita dall'ambiente di fakeroot.
==> Compilazione terminata: python-coloredlogs 15.0.1-3 (lun 16 mag 2022, 10:48:41)
==> Pulizia in corso...
Service runtime: 11.633s
CPU time consumed: 10.716s
Running as unit: run-u569.service
Service runtime: 719ms
CPU time consumed: 813ms
Building python-coloredlogs...
Checking keyring... [0/1]
Checking keyring... [1/1]
Checking integrity... [0/1]
Checking integrity... [1/1]
Loading packages files... [0/1]
Loading packages files... [1/1]
Checking file conflicts... [0/1]
Checking file conflicts... [1/1]
Checking available disk space... [0/1]
Checking available disk space... [1/1]
Reinstalling python-coloredlogs (15.0.1-3)... [1/1]
Arming ConditionNeedsUpdate... [1/3]
Refreshing PackageKit... [2/3]
Checking which packages need to be rebuilt [3/3]
foreign neuron
foreign pandoc-citeproc
foreign python-giturlparse
==> Making package: ocrmypdf 13.4.4-1 (Mon May 16 10:49:05 2022)
==> Making package: python-coloredlogs 15.0.1-3 (Mon May 16 10:49:05 2022)
ocrmypdf-13.4.4.tar.gz ... -> Found 15.0.1.tar.gz
Passed
==> Making package: python-coloredlogs 15.0.1-3 (Mon May 16 10:49:06 2022)
running build
running build_py
creating build
creating build/lib
Extension error:
Aborting...
Running as unit: run-u585.service
Service runtime: 13ms
Running as unit: run-u586.service
Service runtime: 49ms
CPU time consumed: 12ms
Running as unit: run-u587.service
Service runtime: 560ms
CPU time consumed: 54ms
Running as unit: run-u588.service
Service runtime: 1.054s
CPU time consumed: 1.201s
Preparing...
Cloning ocrmypdf build files...
Generating ocrmypdf information...
Checking ocrmypdf dependencies...
To build (1):
ocrmypdf 13.4.4-1 (13.4.3-1) AUR
Apply transaction ? [e/y/N] Running as unit: run-u589.service
==> Creazione del pacchetto: ocrmypdf 13.4.4-1 (lun 16 mag 2022, 11:11:36)
-> Download di ocrmypdf-13.4.4.tar.gz in corso...
72 7714k 72 5559k 0 0 5475k 0 0:00:01 0:00:01 --:--:-- 5475k
100 7714k 100 7714k 0 0 5697k 0 0:00:01 0:00:01 --:--:-- 6376k
ocrmypdf-13.4.4.tar.gz ... Verificato
-> Estrazione di ocrmypdf-13.4.4.tar.gz usando bsdtar in corso...
running install
warnings.warn(
running build
running build_py
creating build
creating build/lib
creating build/lib/ocrmypdf
copying src/ocrmypdf/_logging.py -> build/lib/ocrmypdf
copying src/ocrmypdf/_pipeline.py -> build/lib/ocrmypdf
copying src/ocrmypdf/pluginspec.py -> build/lib/ocrmypdf
copying src/ocrmypdf/_graft.py -> build/lib/ocrmypdf
copying src/ocrmypdf/_plugin_manager.py -> build/lib/ocrmypdf
copying src/ocrmypdf/exceptions.py -> build/lib/ocrmypdf
copying src/ocrmypdf/pdfa.py -> build/lib/ocrmypdf
copying src/ocrmypdf/__main__.py -> build/lib/ocrmypdf
copying src/ocrmypdf/optimize.py -> build/lib/ocrmypdf
copying src/ocrmypdf/_concurrent.py -> build/lib/ocrmypdf
copying src/ocrmypdf/helpers.py -> build/lib/ocrmypdf
copying src/ocrmypdf/_jobcontext.py -> build/lib/ocrmypdf
copying src/ocrmypdf/cli.py -> build/lib/ocrmypdf
copying src/ocrmypdf/__init__.py -> build/lib/ocrmypdf
copying src/ocrmypdf/_version.py -> build/lib/ocrmypdf
copying src/ocrmypdf/quality.py -> build/lib/ocrmypdf
copying src/ocrmypdf/hocrtransform.py -> build/lib/ocrmypdf
copying src/ocrmypdf/_sync.py -> build/lib/ocrmypdf
copying src/ocrmypdf/_validation.py -> build/lib/ocrmypdf
copying src/ocrmypdf/api.py -> build/lib/ocrmypdf
creating build/lib/ocrmypdf/builtin_plugins
copying src/ocrmypdf/builtin_plugins/ghostscript.py -> build/lib/ocrmypdf/builtin_plugins
copying src/ocrmypdf/builtin_plugins/tesseract_ocr.py -> build/lib/ocrmypdf/builtin_plugins
copying src/ocrmypdf/builtin_plugins/concurrency.py -> build/lib/ocrmypdf/builtin_plugins
copying src/ocrmypdf/builtin_plugins/default_filters.py -> build/lib/ocrmypdf/builtin_plugins
copying src/ocrmypdf/builtin_plugins/__init__.py -> build/lib/ocrmypdf/builtin_plugins
creating build/lib/ocrmypdf/_exec
copying src/ocrmypdf/_exec/tesseract.py -> build/lib/ocrmypdf/_exec
copying src/ocrmypdf/_exec/jbig2enc.py -> build/lib/ocrmypdf/_exec
copying src/ocrmypdf/_exec/ghostscript.py -> build/lib/ocrmypdf/_exec
copying src/ocrmypdf/_exec/__init__.py -> build/lib/ocrmypdf/_exec
copying src/ocrmypdf/_exec/pngquant.py -> build/lib/ocrmypdf/_exec
copying src/ocrmypdf/_exec/unpaper.py -> build/lib/ocrmypdf/_exec
creating build/lib/ocrmypdf/pdfinfo
copying src/ocrmypdf/pdfinfo/layout.py -> build/lib/ocrmypdf/pdfinfo
copying src/ocrmypdf/pdfinfo/info.py -> build/lib/ocrmypdf/pdfinfo
copying src/ocrmypdf/pdfinfo/__init__.py -> build/lib/ocrmypdf/pdfinfo
creating build/lib/ocrmypdf/data
copying src/ocrmypdf/data/__init__.py -> build/lib/ocrmypdf/data
creating build/lib/ocrmypdf/subprocess
copying src/ocrmypdf/subprocess/__init__.py -> build/lib/ocrmypdf/subprocess
copying src/ocrmypdf/subprocess/_windows.py -> build/lib/ocrmypdf/subprocess
creating build/lib/ocrmypdf/extra_plugins
copying src/ocrmypdf/extra_plugins/__init__.py -> build/lib/ocrmypdf/extra_plugins
copying src/ocrmypdf/extra_plugins/semfree.py -> build/lib/ocrmypdf/extra_plugins
running egg_info
writing src/ocrmypdf.egg-info/PKG-INFO
writing dependency_links to src/ocrmypdf.egg-info/dependency_links.txt
writing entry points to src/ocrmypdf.egg-info/entry_points.txt
writing requirements to src/ocrmypdf.egg-info/requires.txt
writing top-level names to src/ocrmypdf.egg-info/top_level.txt
reading manifest file 'src/ocrmypdf.egg-info/SOURCES.txt'
adding license file 'LICENSE'
writing manifest file 'src/ocrmypdf.egg-info/SOURCES.txt'
copying src/ocrmypdf/RELEASE.md -> build/lib/ocrmypdf
copying src/ocrmypdf/py.typed -> build/lib/ocrmypdf
copying src/ocrmypdf/data/sRGB.icc -> build/lib/ocrmypdf/data
running install_lib
creating /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr
creating /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib
creating /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10
creating /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages
creating /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/_logging.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/_pipeline.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/pluginspec.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/_graft.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/_plugin_manager.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/exceptions.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/pdfa.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
creating /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/builtin_plugins
copying build/lib/ocrmypdf/builtin_plugins/ghostscript.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/builtin_plugins
copying build/lib/ocrmypdf/builtin_plugins/tesseract_ocr.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/builtin_plugins
copying build/lib/ocrmypdf/builtin_plugins/concurrency.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/builtin_plugins
copying build/lib/ocrmypdf/builtin_plugins/default_filters.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/builtin_plugins
copying build/lib/ocrmypdf/builtin_plugins/__init__.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/builtin_plugins
copying build/lib/ocrmypdf/__main__.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/optimize.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
creating /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec
copying build/lib/ocrmypdf/_exec/tesseract.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec
copying build/lib/ocrmypdf/_exec/jbig2enc.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec
copying build/lib/ocrmypdf/_exec/ghostscript.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec
copying build/lib/ocrmypdf/_exec/__init__.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec
copying build/lib/ocrmypdf/_exec/pngquant.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec
copying build/lib/ocrmypdf/_exec/unpaper.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec
copying build/lib/ocrmypdf/_concurrent.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/helpers.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
creating /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/pdfinfo
copying build/lib/ocrmypdf/pdfinfo/layout.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/pdfinfo
copying build/lib/ocrmypdf/pdfinfo/info.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/pdfinfo
copying build/lib/ocrmypdf/pdfinfo/__init__.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/pdfinfo
creating /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/data
copying build/lib/ocrmypdf/data/sRGB.icc -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/data
copying build/lib/ocrmypdf/data/__init__.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/data
copying build/lib/ocrmypdf/_jobcontext.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/RELEASE.md -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/cli.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/__init__.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/_version.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/quality.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/py.typed -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
creating /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/subprocess
copying build/lib/ocrmypdf/subprocess/__init__.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/subprocess
copying build/lib/ocrmypdf/subprocess/_windows.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/subprocess
copying build/lib/ocrmypdf/hocrtransform.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/_sync.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
creating /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/extra_plugins
copying build/lib/ocrmypdf/extra_plugins/__init__.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/extra_plugins
copying build/lib/ocrmypdf/extra_plugins/semfree.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/extra_plugins
copying build/lib/ocrmypdf/_validation.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
copying build/lib/ocrmypdf/api.py -> /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_logging.py to _logging.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_pipeline.py to _pipeline.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/pluginspec.py to pluginspec.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_graft.py to _graft.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_plugin_manager.py to _plugin_manager.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/exceptions.py to exceptions.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/pdfa.py to pdfa.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/builtin_plugins/ghostscript.py to ghostscript.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/builtin_plugins/tesseract_ocr.py to tesseract_ocr.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/builtin_plugins/concurrency.py to concurrency.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/builtin_plugins/default_filters.py to default_filters.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/builtin_plugins/__init__.py to __init__.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/__main__.py to __main__.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/optimize.py to optimize.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec/tesseract.py to tesseract.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec/jbig2enc.py to jbig2enc.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec/ghostscript.py to ghostscript.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec/__init__.py to __init__.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec/pngquant.py to pngquant.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_exec/unpaper.py to unpaper.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_concurrent.py to _concurrent.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/helpers.py to helpers.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/pdfinfo/layout.py to layout.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/pdfinfo/info.py to info.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/pdfinfo/__init__.py to __init__.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/data/__init__.py to __init__.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_jobcontext.py to _jobcontext.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/cli.py to cli.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/__init__.py to __init__.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_version.py to _version.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/quality.py to quality.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/subprocess/__init__.py to __init__.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/subprocess/_windows.py to _windows.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/hocrtransform.py to hocrtransform.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_sync.py to _sync.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/extra_plugins/__init__.py to __init__.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/extra_plugins/semfree.py to semfree.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/_validation.py to _validation.cpython-310.pyc
byte-compiling /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf/api.py to api.cpython-310.pyc
writing byte-compilation script '/tmp/tmpnqttcexy.py'
/usr/bin/python -Wignore:The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives:DeprecationWarning /tmp/tmpnqttcexy.py
removing /tmp/tmpnqttcexy.py
Copying src/ocrmypdf.egg-info to /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/lib/python3.10/site-packages/ocrmypdf-13.4.4-py3.10.egg-info
Installing ocrmypdf script to /var/cache/private/pamac/ocrmypdf/pkg/ocrmypdf/usr/bin
==> Creazione del pacchetto "ocrmypdf" in corso...
-> Aggiunta del file install in corso...
==> Compilazione terminata: ocrmypdf 13.4.4-1 (lun 16 mag 2022, 11:11:43)
Service runtime: 8.013s
CPU time consumed: 7.343s
Running as unit: run-u590.service
Service runtime: 937ms
CPU time consumed: 1.069s
Building ocrmypdf...
Upgrading ocrmypdf (13.4.3-1 -> 13.4.4-1)... [1/1]
foreign neuron
Any suggestions?
Why I shouldn’t use sudo with pamac?
Because you don’t need to. You will be asked your password when necessary.
Thanks
