Hi Folks,
I installed xrdp 0.9.21.1-1 and xorgxrdp 0.9.19-2. I started the xrdp service, all OK. When I remotely tried to connect fails. The firewall is disabled for this test.
I tried to connect with another user but failed as well.
netstat -plant |grep xrdp
tcp6 0 0 :::3389 :::* LISTEN 1191/xrdp
tcp6 0 0 ::1:3350 :::* LISTEN 1189/xrdp-sesman
tcp6 9600 0 192.168.1.34:3389 192.168.1.35:54398 ESTABLISHED 1193/xrdp
tcp6 1 0 ::1:43406 ::1:3350 CLOSE_WAIT 1193/xrdp
Feb 14 13:53:55 manjaro xrdp[56151]: [INFO ] login successful for user brad on display 10
Feb 14 13:53:55 manjaro xrdp[56151]: [INFO ] loaded module 'libxup.so' ok, interface size 10296, version 4
Feb 14 13:53:55 manjaro xrdp[56151]: [INFO ] started connecting
Feb 14 13:53:56 manjaro xrdp[56151]: [INFO ] lib_mod_connect: connecting via UNIX socket
Feb 14 13:57:26 manjaro xrdp[56151]: [INFO ] connection problem, giving up
Feb 14 13:57:26 manjaro xrdp[56151]: [INFO ] some problem
Feb 14 13:57:26 manjaro xrdp[56151]: [ERROR] xrdp_wm_log_msg: Error connecting to user session
Feb 14 13:57:26 manjaro xrdp[56151]: [INFO ] Error connecting to user session
Feb 14 13:57:26 manjaro xrdp[56151]: [INFO ] xrdp_caps_process_pointer: client supports new(color) cursor
Feb 14 13:57:27 manjaro xrdp[56151]: [INFO ] xrdp_caps_process_codecs: RemoteFX, codec id 3, properties len 49
