[root tip] [Utility Script] FreeRDP script template
Background
A couple of months ago I ran into issues with the krdc app and got so frustrated I created a script template to handle my connections thus limiting my dependency to freerdp.
The template handles if session is wayland or x11
#!/usr/bin/env bash
# Script template to open FreeRDP connection
#    This program is free software: you can redistribute it and/or modify
#    it under the terms of the GNU General Public License as published by
#    the Free Software Foundation, either version 3 of the License, or
#    (at your option) any later version.
#    This program is distributed in the hope that it will be useful,
#    but WITHOUT ANY WARRANTY; without even the implied warranty of
#    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#    GNU General Public License for more details.
#    You should have received a copy of the GNU General Public License
#    along with this program.  If not, see <https://www.gnu.org/licenses/>.
# root.nix.dk
# - 2022-11-23 : moved width and height to variables section
# - 2023-03-23 : fixed missing $ at variable in xfreerdp call
#              : added comments to customize section
# - 2024-06-05 : added dependency on 'freerdp2' package
### begin customize
# Documentation
# https://github.com/FreeRDP/FreeRDP/wiki/CommandLineInterface
# to list available keyboards run 'xfreerdp /kbd-list'
# examples
# french => 0x0000040C
# german => 0x00000407
# us     => 0x00000409
# uk     => 0x00000809
# danish => 0x00000406
# set keyboard
KEYBOARD="0x00000406"
# set screen size
WIDTH=1920
HEIGHT=1080
# define host and credentials to be used
REMOTE=""             # hostname or ip-address
USERNAME=""           # login
PASSWORD=""           # passwd
# connnection type - you may need to adjust if you have a slow or poor connection
NETWORK="lan"         # connection type
PORT="3389"           # rdp default
# share - if you don't need then comment the line reading
#             /drive:${SHARENAME},${SHAREPATH} \
SHAREPATH="/home/$USER"      # shared folder
SHARENAME="media"            # share name on remote system
### end customize
# Recent changes with freerdp has split the binaries into package **freerdp2**
if ! [[ $(pacman -Qoq wlfreerdp) =~ "freerdp2" ]]; then
    echo "package 'freerdp2' is not synced"
    echo "this script requires the binaries 'wlfreerdp' and 'xfreerdp'"
    echo "please sync the package using your package manager"
    exit 1
fi
if [[ ${XDG_SESSION_TYPE} = "wayland" ]]; then
        /usr/bin/wlfreerdp /bpp:24 /audio-mode:2 /sound:sys:alsa /rfx /cert-ignore +clipboard \
        -decorations /parent-window:31 \
        /w:${REMOTEW} /h:${REMOTEH} \
        /kbd:${KEYBOARD} \
        /network:${NETWORK} \
        /drive:${SHARE},${SHAREPATH} \
        /u:${USERNAME} /port:${PORT} /v:${REMOTE} /p:${PASSWORD} &
else
        /usr/bin/xfreerdp /bpp:24 /audio-mode:2 /sound:sys:alsa /rfx /cert-ignore  +clipboard \
        /kbd:${KEYBOARD} \
fi
Source code
Usage
Ensure you have the folder ~/.local/bin
mkdir -p ~/.local/bin
Create a new file in the folder and paste the content from template into the new file.
Save the file using a meaningful name e.g. the nickname for the device you are connecting to.
Then adjust the properties at the top of the script - just below the header - to match your connection and save the file.
Make the file executable
chmod +x ~/.local/bin/nickname
Then you can execute from commandline
nickname
If you want a shortcut - with an icon to click - create a desktop file ~/.local/share/applications/nickname.desktop with content
[Desktop Entry]
Name=nickname RDP
Icon=network-server
Comment=Connect to nickname RDP
Exec="~/.local/bin/nickname"
Version=1.0
Type=Application
Terminal=false
StartupNotify=true
NOTE
The template relies on freerdp2 package.
Recent updates has split the newer version 3.x and the older version 2.x.
  • freerdp v2 - package name freerdp2
  • freerdp v3 - package name freerdp
Original post: https://root.nix.dk/utility-scripts/freerdp-script-template
:memo:
This is not a support topic - create a new linked topic if you have questions.
If you spot an error please let me know.
