"xrandr: Configure crtc 4 failed" when second display is plugged in (detected but not working)
I’m a new Manjaro user and installed it with the open source driver which didn’t detect anything that I plug into the HDMI port. So i reinstalled it with the proprietary driver.
I have an Hp Pavilion gaming laptop which has a ryzen 4600h and an nvidia 1650ti.
and here is my problem:
  • the open source driver didn’t detect the display at all no matter what i did (not on xrandr, nor using the “display” settings on the XFCE desktop environment
  • On the proprietary driver, the display is detected in the xrandr output like this:
 Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1920x1080     60.00*+  40.00
   1680x1050     60.00
   1280x1024     60.00
   1440x900      60.00
   1280x800      60.00
   1280x720      60.00
   1024x768      60.00
   800x600       60.00
   640x480       60.00
HDMI-1-0 connected (normal left inverted right x axis y axis)
   1920x1080     60.00 +  59.94    50.00    29.97    23.98
   1440x900      59.89
   1360x768      60.02
   1280x1024     60.02
   1280x720      59.94    50.00
   1024x768      60.00
   800x600       60.32
   720x576       50.00
   720x480       59.94
   640x480       59.94    59.93
but the screen is still off, and executing xrandr --auto (or any xrandr command) shows an error
and the screen on the display manager looks like this
and it stays disabled …
Pressing the enable button (the red one) will only cause this to happen
where in this window no matter what’s your choice the result will be the same and the screen is still disabled.
The output of lspci -k is:
 00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex
	Subsystem: Hewlett-Packard Company Device 87b2
lspci: Unable to load libkmod resources: error -2
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
	Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
	Subsystem: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller
	Kernel driver in use: piix4_smbus
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
	Subsystem: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
	Kernel driver in use: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1)
	DeviceName: NVIDIA Graphics Device
	Kernel driver in use: nvidia
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 16)
	DeviceName: OnBoard Enthernets
	Kernel driver in use: r8169
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
	DeviceName: Realtek Wireless LAN + BT
	Subsystem: Hewlett-Packard Company Device 85f7
	Kernel driver in use: rtw_8822ce
04:00.0 Non-Volatile memory controller: Solid State Storage Technology Corporation Device 9100 (rev 03)
	Subsystem: Silicon Motion, Inc. Device 2263
	Kernel driver in use: nvme
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c7)
	DeviceName:  Onboard IGD
	Kernel driver in use: amdgpu
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
	Kernel driver in use: ccp
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1
	Kernel driver in use: xhci_hcd
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor (rev 01)
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
	Kernel driver in use: snd_hda_intel
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
	Kernel driver in use: ahci
06:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
where i think the line saying
is the actual problem (it’s printed stderr not on stdout) .
The output of xrandr --listproviders is:
Providers: number : 2
Provider 0: id: 0x54 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 1 associated providers: 1 name:Unknown AMD Radeon GPU @ pci:0000:05:00.0
Provider 1: id: 0x1f7 cap: 0x2, Sink Output crtcs: 4 outputs: 1 associated providers: 1 name:NVIDIA-G0
any advice???
Edit 1: and finally the output of inxi --admin --verbosity=7 --filter --no-host --width is as below
  Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=ad7986d8-60b3-497a-ac5c-e463071f46ea rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 87B2 v: 31.21 serial: <filter> UEFI: AMI v: F.20
  date: 11/04/2020
  ID-1: BAT0 charge: 35.1 Wh (76.0%) condition: 46.2/46.2 Wh (100.0%)
  volts: 11.8 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
  serial: N/A status: Discharging cycles: 415
  RAM: total: 7.2 GiB used: 3.57 GiB (49.6%)
  Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64
  type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600106 cache: L2: 3 MiB bogomips: 71896
  Speed: 1432 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz):
  1: 1432 2: 1657 3: 1397 4: 1397 5: 2164 6: 1822 7: 1397 8: 1385 9: 1397
  10: 1397 11: 1397 12: 1397
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
  lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
  nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
  pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
  popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
  skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
  svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
  vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Hewlett-Packard
  driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1f95 class-ID: 0300
  Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
  bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
  Device-3: Luxvisions Innotech Limited HP TrueVision HD Camera type: USB
  driver: uvcvideo bus-ID: 3-3:2 chip-ID: 30c9:0013 class-ID: 0e02
  serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
  loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
  alternate: fbdev,nv,vesa display-ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.53-1-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.1.5 direct render: Yes
  Device-1: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Hewlett-Packard driver: N/A
  alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5
  chip-ID: 1022:15e2 class-ID: 0480
  Device-2: AMD Family 17h HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3
  class-ID: 0403
  Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.32 running: no
  vendor: Hewlett-Packard driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
  vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
  port: d000 bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
  IF-ID-1: anbox0 state: down mac: <filter>
  IP v4: <filter> scope: global
  Device-1: Realtek 802.11ac WLAN Adapter type: USB driver: btusb v: 0.8
  bus-ID: 1-4:2 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 1.05 TiB used: 68.21 GiB (6.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 model: SSSTC CL1-8D128-HP size: 119.24 GiB
  block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  type: SSD serial: <filter> rev: L183 temp: 34.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-60Z10T0
  type: HDD rpm: 5400 serial: <filter> rev: 1A04 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 type: USB model: Multiple Card Reader
  size: 29.11 GiB block-size: physical: 512 B logical: 512 B type: N/A
  serial: <filter> rev: 1.00 scheme: MBR
  ID-1: / raw-size: 181.5 GiB size: 177.59 GiB (97.84%)
  used: 68.15 GiB (38.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: ad7986d8-60b3-497a-ac5c-e463071f46ea
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 62.2 MiB (24.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: SYSTEM uuid: DE07-A8DE
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 107.69 GiB fs: ntfs label: Windows
  uuid: F8FEB79AFEB7501C
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 538 MiB fs: ntfs
  label: Windows RE tools uuid: 9016F4C216F4AA7C
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 512 MiB fs: ext4 label: N/A
  uuid: 490b9b4a-196d-48fb-8c9d-61872934c255
  ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 10.25 GiB fs: ext4 label: N/A
  uuid: faa621de-1874-4a0c-8645-63d82dfa63ea
  ID-6: /dev/sda1 maj-min: 8:1 size: 750.01 GiB fs: ntfs label: DATA
  uuid: 706CFDBD6CFD7E62
  ID-7: /dev/sdb1 maj-min: 8:17 size: 2.42 GiB fs: iso9660
  ID-8: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
  uuid: 0545-B0D1
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 1-4:2 info: Realtek 802.11ac WLAN Adapter type: Bluetooth
  driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 3-3:2 info: Luxvisions Innotech Limited HP TrueVision HD Camera
  type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
  power: 500mA chip-ID: 30c9:0013 class-ID: 0e02 serial: <filter>
  Device-2: 3-4:3 info: Alcor Micro Multi Flash Reader type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
  chip-ID: 058f:6366 class-ID: 0806 serial: <filter>
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 49.5 C mobo: 48.0 C gpu: amdgpu temp: 48.0 C
  Processes: 319 Uptime: 3h 12m wakeups: 1 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1228
  pacman: 1225 lib: 316 flatpak: 0 snap: 3 Shell: Bash v: 5.1.8
  running-in: xfce4-terminal inxi: 3.3.06
Edit 2: I wanted to point out that running from a live USB or reinstalling manjaro on my computer didn’t change anything. I thought this information might be helpful in troubleshooting the problem or knowing it’s source.
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    [HowTo] Provide System Information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
    Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
    Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
    Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
    instead of like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
    (as that makes both our lives much easier)
  4. No need to do anything right now as I’m a moderator here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed. :wink:
:+1:
Has anyone found a solution? I have exactly the same problem and the same hardware (Lenovo ideapad gaming 3, Ryzen 5 4600H, GTX 1650) It was written here that the problem is that a discrete video card can handle HDMI. I will be grateful for the solution.
I found a solution for myself. I had to install optimus-manager to enable the discrete graphics card.
https://wiki.manjaro.org/index.php?title=Optimus_Manager
