Xorg session disappeared after update
I might as well say at once that I am not sure about this.
I think up until some time ago (mabe up unitl the major update of three days ago), I was running Gnome on xorg, and had Wayland installed but unused. I also observe that I now only have Gnome on Wayland and Gnome Classic available before logging in (that much is certain).
So it seems the update has removed my xorg session and defaulted me to Wayland……? This sounds crazy even to me who doesn’t know much, but the thing is, I’ve been experiencing unusual slowness and lagging when jumping workspaces, and navigating my browser with keyboard shortcuts. I’ve had the feeling frames and top bar proportion have slightly changed too, and some display-related things (such as previewing images in ranger) have stopped working from one day to the next without any change to configuration.
Please help me figure out if I’m crazy and have always been on Wayland for the past one and a half year, or if I’m right. I hope there’s a simple way to find out…
Infinite thanks.
Below the output of inxi -zv8. Please let me know if any additional info is required to help.
  Kernel: 6.17.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.17-x86_64
    root=UUID=ccf1bd5a-96d0-48ce-b352-228bc163669c rw quiet splash apparmor=1
    security=apparmor resume=UUID=f18e1fcf-8c17-46de-84fc-4c543a06dffe
    udev.log_priority=3
  Desktop: GNOME v: 49.2 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy avail: i3lock,xss-lock dm: GDM v: 49.2
  Type: Laptop System: ASUSTeK product: Zenbook UX3402ZA_UX3402ZA v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: UX3402ZA v: 1.0 serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: UX3402ZA.310 date: 12/14/2022
  ID-1: BAT0 charge: 40.5 Wh (59%) condition: 68.6/75.1 Wh (91.4%) volts: 7.97
    min: 7.97 model: ASUSTeK UX3402ZA type: Li-ion serial: <filter> charging:
    status: charging control: start: N/A end: 80% cycles: 117
  System RAM: total: 16 GiB available: 15.24 GiB used: 3.69 GiB (24.2%)
  Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
    size: 2 GiB speed: spec: 6400 MT/s actual: 4800 MT/s volts: curr: 0.5
    min: 0.5 max: 0.5 width (bits): data: 16 total: 16 manufacturer: SK Hynix
    part-no: H9JCNNNCP3MLYR-N6E serial: N/A
  Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
  Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
  Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
  Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
  Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
  Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
  Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
  Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
    microcode: 0x43A
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
    st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
    KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 400 min/max: 400/4700:3400 scaling: driver: intel_pstate
    governor: performance cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400
    7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400
    16: 400 bogomips: 79872
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
    conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2021-22+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
    HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
  Device-2: Sonix USB2.0 FHD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3 chip-ID: 3277:0010
    class-ID: 0e02
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: Samsung 0x4171 built: 2020 res: 2880x1800 dpi: 242
    gamma: 1.2 chroma: red: x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue:
    x: 0.137 y: 0.047 white: x: 0.314 y: 0.329 size: 302x189mm (11.89x7.44")
    diag: 356mm (14") ratio: 16:10 modes: 2880x1800
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (ADL
    GT2) device-ID: 8086:46a6 memory: 14.89 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.4.328 layers: 13 device: 0 type: integrated-gpu
    name: Intel Iris Xe Graphics (ADL GT2) driver: mesa intel v: 25.3.1-arch1.2
    device-ID: 8086:46a6 surfaces: N/A
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo gpu: nvidia-smi
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
    driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
    snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 0000:00:1f.3
    chip-ID: 8086:51c8 class-ID: 0401
  API: ALSA v: k6.17.11-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
    class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 476.94 GiB used: 288.36 GiB (60.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 MTFDKBA512TFH
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: P7MA002 temp: 32.9 C
    scheme: GPT
  ID-1: / raw-size: 459.87 GiB size: 451.58 GiB (98.20%)
    used: 288.29 GiB (63.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: ccf1bd5a-96d0-48ce-b352-228bc163669c
  ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.80%)
    used: 164 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: ESP
    uuid: 0B5D-03B0
  ID-1: swap-1 type: partition size: 16.78 GiB used: 70.6 MiB (0.4%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: f18e1fcf-8c17-46de-84fc-4c543a06dffe
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-6:2 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 04f3:0c6e class-ID: 0000
  Device-2: 3-8:3 info: Sonix USB2.0 FHD UVC WebCam type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 3277:0010 class-ID: 0e02
  Device-3: 3-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  System Temperatures: cpu: 43.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 2536 pm: pacman pkgs: 2530 libs: 535 tools: gnome-software,pamac
    pm: flatpak pkgs: 6
    1: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    2: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    3: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    4: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    5: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    6: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    7: https://manjaro.grena.ge/stable/$repo/$arch
    8: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 382
  1: cpu: 13.6% command: vivaldi-bin pid: 68516 mem: 283.8 MiB (1.8%)
  2: cpu: 13.0% command: vivaldi-bin pid: 68369 mem: 641.7 MiB (4.1%)
  3: cpu: 5.7% command: vivaldi-bin pid: 69479 mem: 288.6 MiB (1.8%)
  4: cpu: 4.9% command: gnome-terminal-server pid: 70152
    mem: 81.7 MiB (0.5%)
  5: cpu: 3.1% command: gnome-shell pid: 66489 mem: 553.6 MiB (3.5%)
  Memory top: 5 of 382
  1: mem: 641.7 MiB (4.1%) command: vivaldi-bin pid: 68369 cpu: 13.0%
  2: mem: 553.6 MiB (3.5%) command: gnome-shell pid: 66489 cpu: 3.1%
  3: mem: 343.7 MiB (2.2%) command: vivaldi-bin pid: 68479 cpu: 1.6%
  4: mem: 309.1 MiB (1.9%) command: vivaldi-bin pid: 68789 cpu: 1.7%
  5: mem: 288.6 MiB (1.8%) command: vivaldi-bin pid: 69479 cpu: 5.7%
  Processes: 382 Power: uptime: 11h 46m states: freeze,mem,disk
    suspend: s2idle avail: deep wakeups: 1 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 6.08 GiB services: gsd-power,upowerd
    Init: systemd v: 258 default: graphical tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 alt: 13/14 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.40
:backhand_index_pointing_down:
