I’m using cinnamon as my DE.
On boot I got lightdm start failure (Failed to start lightdm manager), but if I log in to tty and start lightdm.service manualy, it starts and detects display normaly.
All configs untouched, fresh install of Manjaro Cinnamon.
Inxi
CPU: Info: 6-Core model: AMD Ryzen 5 4600U with Radeon Graphics bits: 64 type: MT MCP arch: Zen rev: 1
L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 50323
Speed: 1397 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397
6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1396
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 03:00.0
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 3-2:2
Display: server: X.org 1.20.9 driver: ati,radeon unloaded: modesetting tty: 160x50
Message: Advanced graphics data unavailable in console. Try -G --display
Xorg.0.log
[ 4.682]
X.Org X Server 1.20.9
[ 4.682] Build Operating System: Linux Manjaro Linux
[ 4.682] Current Operating System: Linux kuzia-laptop 5.9.11-3-MANJARO #1 SMP PREEMPT Sat Nov 28 09:08:57 UTC 2020 x86_64
[ 4.682] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=4b739078-177a-4f98-a6ad-03a0c94e83f5 rw quiet apparmor=1 security=apparmor resume=UUID=70559c71-f87a-4bb3-a3d0-f964c29a0f79 udev.log_priority=3
[ 4.682] Build Date: 20 November 2020 09:03:19PM
[ 4.682]
[ 4.682] Current version of pixman: 0.40.0
[ 4.682] Before reporting problems, check http://wiki.x.org
[ 4.682] Markers: (–) probed, () from config file, (==) default setting,
[ 4.682] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Dec 2 17:26:36 2020
[ 4.682] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 4.682] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 4.682] (==) No Layout section. Using the first Screen section.
[ 4.682] (==) No screen section available. Using defaults.
[ 4.682] () |–>Screen “Default Screen Section” (0)
[ 4.682] (**) | |–>Monitor “”
[ 4.682] (==) No monitor specified for screen “Default Screen Section”.
[ 4.682] (==) Automatically adding devices
[ 4.682] (==) Automatically enabling devices
[ 4.682] (==) Automatically adding GPU devices
[ 4.682] (==) Automatically binding GPU devices
[ 4.682] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 4.682] (WW) fonts.dir' not found (or not valid) in "/usr/share/fonts/misc". [ 4.682] Entry deleted from font path. [ 4.682] (Run 'mkfontdir' on "/usr/share/fonts/misc"). [ 4.682] (WW)
fonts.dir’ not found (or not valid) in “/usr/share/fonts/TTF”.
[ 4.682] (Run ‘mkfontdir’ on “/usr/share/fonts/TTF”).
[ 4.682] (WW) The directory “/usr/share/fonts/OTF” does not exist.
[ 4.682] (WW) The directory “/usr/share/fonts/Type1” does not exist.
[ 4.682] (WW) The directory “/usr/share/fonts/100dpi” does not exist.
[ 4.682] (WW) The directory “/usr/share/fonts/75dpi” does not exist.
[ 4.682] (==) FontPath set to:
[ 4.682] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 4.682] (II) The server relies on udev to provide the list of input devices.
[ 4.682] (II) Module ABI versions:
[ 4.682] X.Org ANSI C Emulation: 0.4
[ 4.682] X.Org Video Driver: 24.1
[ 4.682] X.Org XInput driver : 24.1
[ 4.682] X.Org Server Extension : 10.0
[ 4.683] (++) using VT number 7
[ 4.683] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 4.684] (–) PCI:*(3@0:0:0) 1002:1636:17aa:3811 rev 206, Mem @ 0x460000000/268435456, 0x470000000/2097152, 0xfd300000/524288, I/O @ 0x00001000/256
[ 4.685] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 4.685] (II) LoadModule: “glx”
[ 4.685] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 4.685] (II) Module glx: vendor=“X.Org Foundation”
[ 4.685] compiled for 1.20.9, module version = 1.0.0
[ 4.685] ABI class: X.Org Server Extension, version 10.0
[ 4.685] (==) Matched ati as autoconfigured driver 0
[ 4.685] (==) Matched modesetting as autoconfigured driver 1
[ 4.685] (==) Matched fbdev as autoconfigured driver 2
[ 4.685] (==) Matched vesa as autoconfigured driver 3
[ 4.685] (==) Assigned the driver to the xf86ConfigLayout
[ 4.685] (II) LoadModule: “ati”
[ 4.686] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 4.686] (II) Module ati: vendor=“X.Org Foundation”
[ 4.686] compiled for 1.20.8, module version = 19.1.0
[ 4.686] Module class: X.Org Video Driver
[ 4.686] ABI class: X.Org Video Driver, version 24.1
[ 4.686] (II) LoadModule: “radeon”
[ 4.686] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 4.686] (II) Module radeon: vendor=“X.Org Foundation”
[ 4.686] (II) LoadModule: “modesetting”
[ 4.686] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 4.686] (II) Module modesetting: vendor=“X.Org Foundation”
[ 4.686] compiled for 1.20.9, module version = 1.20.9
[ 4.686] (II) LoadModule: “fbdev”
[ 4.686] (WW) Warning, couldn’t open module fbdev
[ 4.686] (EE) Failed to load module “fbdev” (module does not exist, 0)
[ 4.686] (II) LoadModule: “vesa”
[ 4.687] (WW) Warning, couldn’t open module vesa
[ 4.687] (EE) Failed to load module “vesa” (module does not exist, 0)
[ 4.687] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 4.688] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 4.688] (EE) open /dev/dri/card0: No such file or directory
[ 4.688] (WW) Falling back to old probe method for modesetting
[ 4.688] (EE) Screen 0 deleted because of no matching config section.
[ 4.688] (II) UnloadModule: “modesetting”
[ 4.688] (EE) Device(s) detected, but none match those in the config file.
[ 4.688] (EE)
Fatal server error:
[ 4.688] (EE) no screens found(EE)
[ 4.688] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 4.688] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 4.688] (EE)
[ 4.688] (EE) Server terminated with error (1). Closing log file.
lightdm.log
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.30.0, UID=0 PID=916
[+0.00s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.00s] DEBUG: [VNCServer] contains unknown option user-session
[+0.00s] DEBUG: [VNCServer] contains unknown option session-wrapper
[+0.00s] DEBUG: Registered seat module local
[+0.00s] DEBUG: Registered seat module xremote
[+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: _g_io_module_get_default: Found default implementation local (GLocalVfs) for ‘gio-vfs’
[+0.00s] DEBUG: Monitoring logind for seats
[+0.00s] DEBUG: New seat added from logind: seat0
[+0.00s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.00s] DEBUG: Seat seat0 has property CanMultiSession=no
[+0.00s] DEBUG: Seat seat0: Starting
[+0.00s] DEBUG: Seat seat0: Creating greeter session
[+0.00s] DEBUG: Seat seat0: Creating display server of type x
[+0.00s] DEBUG: Could not run plymouth --ping: Failed to execute child process “plymouth” (No such file or directory)
[+0.00s] DEBUG: Using VT 7
[+0.00s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.00s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.00s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+0.00s] DEBUG: XServer 0: Launching X Server
[+0.00s] DEBUG: Launching process 923: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.00s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.00s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.01s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.01s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+0.02s] DEBUG: Process 923 exited with return value 1
[+0.02s] DEBUG: XServer 0: X server stopped
[+0.02s] DEBUG: Releasing VT 7
[+0.02s] DEBUG: XServer 0: Removing X server authority /run/lightdm/root/:0
[+0.02s] DEBUG: Seat seat0: Display server stopped
[+0.02s] DEBUG: Seat seat0: Stopping session
[+0.02s] DEBUG: Seat seat0: Session stopped
[+0.02s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+0.02s] DEBUG: Seat seat0: Stopping; greeter display server failed to start
[+0.02s] DEBUG: Seat seat0: Stopped
[+0.02s] DEBUG: Required seat has stopped
[+0.02s] DEBUG: Stopping display manager
[+0.02s] DEBUG: Display manager stopped
[+0.02s] DEBUG: Stopping daemon
[+0.02s] DEBUG: Exiting with return value 1
Logs after manual start (systemctl start lightdm.service)
Xorg.0.log
[ 76.122]
[ 76.122] Build Operating System: Linux Manjaro Linux
[ 76.122] Current Operating System: Linux kuzia-laptop 5.9.11-3-MANJARO #1 SMP PREEMPT Sat Nov 28 09:08:57 UTC 2020 x86_64
[ 76.122] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=4b739078-177a-4f98-a6ad-03a0c94e83f5 rw quiet apparmor=1 security=apparmor resume=UUID=70559c71-f87a-4bb3-a3d0-f964c29a0f79 udev.log_priority=3
[ 76.122] Build Date: 20 November 2020 09:03:19PM
[ 76.122]
[ 76.122] Current version of pixman: 0.40.0
[ 76.122] Before reporting problems, check http://wiki.x.org
[ 76.122] Markers: (–) probed, () from config file, (==) default setting,
[ 76.122] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Dec 2 17:46:12 2020
[ 76.122] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 76.122] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 76.122] (==) No Layout section. Using the first Screen section.
[ 76.123] (==) No screen section available. Using defaults.
[ 76.123] () |–>Screen “Default Screen Section” (0)
[ 76.123] (**) | |–>Monitor “”
[ 76.123] (==) No monitor specified for screen “Default Screen Section”.
[ 76.123] (==) Automatically adding devices
[ 76.123] (==) Automatically enabling devices
[ 76.123] (==) Automatically adding GPU devices
[ 76.123] (==) Automatically binding GPU devices
[ 76.123] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 76.123] (WW) fonts.dir' not found (or not valid) in "/usr/share/fonts/misc". [ 76.123] Entry deleted from font path. [ 76.123] (Run 'mkfontdir' on "/usr/share/fonts/misc"). [ 76.123] (WW)
[ 76.123] (Run ‘mkfontdir’ on “/usr/share/fonts/TTF”).
[ 76.123] (WW) The directory “/usr/share/fonts/OTF” does not exist.
[ 76.123] (WW) The directory “/usr/share/fonts/Type1” does not exist.
[ 76.123] (WW) The directory “/usr/share/fonts/100dpi” does not exist.
[ 76.123] (WW) The directory “/usr/share/fonts/75dpi” does not exist.
[ 76.123] (==) FontPath set to:
[ 76.123] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 76.123] (II) The server relies on udev to provide the list of input devices.
[ 76.123] (II) Module ABI versions:
[ 76.123] X.Org ANSI C Emulation: 0.4
[ 76.123] X.Org Video Driver: 24.1
[ 76.123] X.Org XInput driver : 24.1
[ 76.123] X.Org Server Extension : 10.0
[ 76.125] (++) using VT number 7
[ 76.125] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 76.126] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 76.133] (–) PCI:*(3@0:0:0) 1002:1636:17aa:3811 rev 206, Mem @ 0x460000000/268435456, 0x470000000/2097152, 0xfd300000/524288, I/O @ 0x00001000/256
[ 76.133] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 76.133] (II) LoadModule: “glx”
[ 76.133] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 76.135] (II) Module glx: vendor=“X.Org Foundation”
[ 76.135] compiled for 1.20.9, module version = 1.0.0
[ 76.135] ABI class: X.Org Server Extension, version 10.0
[ 76.135] (II) Applying OutputClass “AMDgpu” to /dev/dri/card0
[ 76.135] loading driver: amdgpu
[ 76.135] (==) Matched amdgpu as autoconfigured driver 0
[ 76.135] (==) Matched ati as autoconfigured driver 1
[ 76.135] (==) Matched modesetting as autoconfigured driver 2
[ 76.135] (==) Matched fbdev as autoconfigured driver 3
[ 76.135] (==) Matched vesa as autoconfigured driver 4
[ 76.135] (==) Assigned the driver to the xf86ConfigLayout
[ 76.135] (II) LoadModule: “amdgpu”
[ 76.135] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 76.137] (II) Module amdgpu: vendor=“X.Org Foundation”
[ 76.137] compiled for 1.20.8, module version = 19.1.0
[ 76.137] Module class: X.Org Video Driver
[ 76.137] ABI class: X.Org Video Driver, version 24.1
[ 76.137] (II) LoadModule: “ati”
[ 76.137] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 76.137] (II) Module ati: vendor=“X.Org Foundation”
[ 76.147] (II) LoadModule: “modesetting”
[ 76.147] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 76.148] (II) Module modesetting: vendor=“X.Org Foundation”
[ 76.148] compiled for 1.20.9, module version = 1.20.9
[ 76.148] Module class: X.Org Video Driver
[ 76.148] ABI class: X.Org Video Driver, version 24.1
[ 76.148] (II) LoadModule: “fbdev”
[ 76.148] (WW) Warning, couldn’t open module fbdev
[ 76.148] (EE) Failed to load module “fbdev” (module does not exist, 0)
[ 76.148] (II) LoadModule: “vesa”
[ 76.148] (WW) Warning, couldn’t open module vesa
[ 76.148] (EE) Failed to load module “vesa” (module does not exist, 0)
[ 76.148] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 76.148] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 76.180] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[ 76.183] (WW) Falling back to old probe method for modesetting
[ 76.184] (II) AMDGPU(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 76.184] (==) AMDGPU(0): Depth 24, (–) framebuffer bpp 32
[ 76.184] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 76.184] (==) AMDGPU(0): Default visual is TrueColor
[ 76.184] (==) AMDGPU(0): RGB weight 888
[ 76.184] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 76.184] (–) AMDGPU(0): Chipset: “Unknown AMD Radeon GPU” (ChipID = 0x1636)
[ 76.184] (II) Loading sub module “fb”
[ 76.184] (II) LoadModule: “fb”
[ 76.184] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 76.185] (II) Module fb: vendor=“X.Org Foundation”
[ 76.185] compiled for 1.20.9, module version = 1.0.0
[ 76.185] ABI class: X.Org ANSI C Emulation, version 0.4
[ 76.185] (II) Loading sub module “dri2”
[ 76.185] (II) LoadModule: “dri2”
[ 76.185] (II) Module “dri2” already built-in
[ 76.295] (II) Loading sub module “glamoregl”
[ 76.295] (II) LoadModule: “glamoregl”
[ 76.295] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 76.300] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 76.300] compiled for 1.20.9, module version = 1.0.1
[ 76.300] ABI class: X.Org ANSI C Emulation, version 0.4
[ 76.320] (II) AMDGPU(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.39.0, 5.9.11-3-MANJARO, LLVM 11.0.0)
[ 76.320] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 76.320] (==) AMDGPU(0): TearFree property default: auto
[ 76.320] (==) AMDGPU(0): VariableRefresh: disabled
[ 76.320] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 76.321] (II) AMDGPU(0): Output eDP has no monitor section
[ 76.321] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 76.321] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[ 76.331] (II) AMDGPU(0): EDID for output eDP
[ 76.331] (II) AMDGPU(0): Manufacturer: CMN Model: 13b0 Serial#: 0
[ 76.331] (II) AMDGPU(0): Year: 2019 Week: 42
[ 76.331] (II) AMDGPU(0): EDID Version: 1.4
[ 76.331] (II) AMDGPU(0): Digital Display Input
[ 76.331] (II) AMDGPU(0): 8 bits per channel
[ 76.331] (II) AMDGPU(0): Digital interface is DisplayPort
[ 76.331] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 29 vert.: 18
[ 76.331] (II) AMDGPU(0): Gamma: 2.20
[ 76.331] (II) AMDGPU(0): No DPMS capabilities specified
[ 76.331] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4
[ 76.331] (II) AMDGPU(0): First detailed timing is preferred mode
[ 76.331] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 76.331] (II) AMDGPU(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 76.331] (II) AMDGPU(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 76.331] (II) AMDGPU(0): Manufacturer’s mask: 0
[ 76.331] (II) AMDGPU(0): Supported detailed timing:
[ 76.331] (II) AMDGPU(0): clock: 271.9 MHz Image Size: 286 x 178 mm
[ 76.331] (II) AMDGPU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 76.331] (II) AMDGPU(0): v_active: 1600 v_sync: 1603 v_sync_end 1609 v_blanking: 1666 v_border: 0
[ 76.331] (II) AMDGPU(0): N133GCA-GQ1
[ 76.331] (II) AMDGPU(0): CMN
[ 76.331] (II) AMDGPU(0): EDID (in hex):
[ 76.331] (II) AMDGPU(0): 00ffffffffffff000daeb01300000000
[ 76.331] (II) AMDGPU(0): 2a1d0104a51d127802ee95a3544c9926
[ 76.331] (II) AMDGPU(0): 0f505400000001010101010101010101
[ 76.331] (II) AMDGPU(0): 010101010101366a00a0a04042603020
[ 76.331] (II) AMDGPU(0): 36001eb210000018000000fe004e3133
[ 76.332] (II) AMDGPU(0): 334743412d4751310a20000000fe0043
[ 76.332] (II) AMDGPU(0): 4d4e0a202020202020202020000000fe
[ 76.332] (II) AMDGPU(0): 004e3133334743412d4751310a2000c4
[ 76.332] (II) AMDGPU(0): Printing probed modes for output eDP
[ 76.332] (II) AMDGPU(0): Modeline "2560x1600"x60.0 271.90 2560 2608 2640 2720 1600 1603 1609 1666 -hsync -vsync (100.0 kHz eP)
[ 76.332] (II) AMDGPU(0): Modeline "1920x1200"x60.0 271.90 1920 2608 2640 2720 1200 1603 1609 1666 -hsync -vsync (100.0 kHz e)
[ 76.332] (II) AMDGPU(0): Modeline "1920x1080"x60.0 271.90 1920 2608 2640 2720 1080 1603 1609 1666 -hsync -vsync (100.0 kHz e)
[ 76.332] (II) AMDGPU(0): Modeline "1600x1200"x60.0 271.90 1600 2608 2640 2720 1200 1603 1609 1666 -hsync -vsync (100.0 kHz e)
[ 76.332] (II) AMDGPU(0): Modeline "1680x1050"x60.0 271.90 1680 2608 2640 2720 1050 1603 1609 1666 -hsync -vsync (100.0 kHz e)
[ 76.332] (II) AMDGPU(0): Modeline "1280x1024"x60.0 271.90 1280 2608 2640 2720 1024 1603 1609 1666 -hsync -vsync (100.0 kHz e)
[ 76.332] (II) AMDGPU(0): Modeline "1440x900"x60.0 271.90 1440 2608 2640 2720 900 1603 1609 1666 -hsync -vsync (100.0 kHz e)
[ 76.332] (II) AMDGPU(0): Modeline "1280x800"x60.0 271.90 1280 2608 2640 2720 800 1603 1609 1666 -hsync -vsync (100.0 kHz e)
[ 76.332] (II) AMDGPU(0): Modeline "1280x720"x60.0 271.90 1280 2608 2640 2720 720 1603 1609 1666 -hsync -vsync (100.0 kHz e)
[ 76.332] (II) AMDGPU(0): Modeline "1024x768"x60.0 271.90 1024 2608 2640 2720 768 1603 1609 1666 -hsync -vsync (100.0 kHz e)
[ 76.332] (II) AMDGPU(0): Modeline "800x600"x60.0 271.90 800 2608 2640 2720 600 1603 1609 1666 -hsync -vsync (100.0 kHz e)
[ 76.332] (II) AMDGPU(0): Modeline "640x480"x60.0 271.90 640 2608 2640 2720 480 1603 1609 1666 -hsync -vsync (100.0 kHz e)
[ 76.332] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 76.332] (II) AMDGPU(0): EDID for output DisplayPort-1
[ 76.332] (II) AMDGPU(0): Output eDP connected
[ 76.332] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[ 76.332] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[ 76.332] (II) AMDGPU(0): Using exact sizes for initial modes
[ 76.332] (II) AMDGPU(0): Output eDP using initial mode 2560x1600 +0+0
[ 76.332] (II) AMDGPU(0): mem size init: gart size :bf6b3000 vram size: s:1db6e000 visible:1db6e000
[ 76.332] (==) AMDGPU(0): DPI set to (96, 96)
[ 76.332] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 76.332] (II) Loading sub module “ramdac”
[ 76.332] (II) LoadModule: “ramdac”
[ 76.332] (II) Module “ramdac” already built-in
[ 76.332] (II) UnloadModule: “modesetting”
[ 76.332] (II) Unloading modesetting
[ 76.332] (II) AMDGPU(0): [DRI2] Setup complete
[ 76.332] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 76.332] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 76.371] (II) AMDGPU(0): Front buffer pitch: 10240 bytes
[ 76.373] (II) AMDGPU(0): SYNC extension fences enabled
[ 76.373] (II) AMDGPU(0): Present extension enabled
[ 76.373] (==) AMDGPU(0): DRI3 enabled
[ 76.373] (==) AMDGPU(0): Backing store enabled
[ 76.373] (II) AMDGPU(0): Direct rendering enabled
[ 76.387] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 76.387] (II) AMDGPU(0): Acceleration enabled
[ 76.387] (==) AMDGPU(0): DPMS enabled
[ 76.387] (==) AMDGPU(0): Silken mouse disabled
[ 76.387] (II) AMDGPU(0): Set up textured video (glamor)
[ 76.398] (II) Initializing extension Generic Event Extension
[ 76.399] (II) Initializing extension SHAPE
[ 76.399] (II) Initializing extension MIT-SHM
[ 76.399] (II) Initializing extension XInputExtension
[ 76.399] (II) Initializing extension XTEST
[ 76.399] (II) Initializing extension BIG-REQUESTS
[ 76.400] (II) Initializing extension SYNC
[ 76.400] (II) Initializing extension XKEYBOARD
[ 76.400] (II) Initializing extension XC-MISC
[ 76.401] (II) Initializing extension SECURITY
[ 76.401] (II) Initializing extension XFIXES
[ 76.401] (II) Initializing extension RENDER
[ 76.401] (II) Initializing extension RANDR
[ 76.401] (II) Initializing extension COMPOSITE
[ 76.402] (II) Initializing extension DAMAGE
[ 76.402] (II) Initializing extension MIT-SCREEN-SAVER
[ 76.402] (II) Initializing extension DOUBLE-BUFFER
[ 76.402] (II) Initializing extension RECORD
[ 76.402] (II) Initializing extension DPMS
[ 76.402] (II) Initializing extension Present
[ 76.403] (II) Initializing extension DRI3
[ 76.403] (II) Initializing extension X-Resource
[ 76.403] (II) Initializing extension XVideo
[ 76.403] (II) Initializing extension XVideo-MotionCompensation
[ 76.403] (II) Initializing extension GLX
[ 76.411] (II) AIGLX: Loaded and initialized radeonsi
[ 76.411] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 76.411] (II) Initializing extension XFree86-VidModeExtension
[ 76.411] (II) Initializing extension XFree86-DGA
[ 76.411] (II) Initializing extension XFree86-DRI
[ 76.411] (II) Initializing extension DRI2
[ 76.416] (II) AMDGPU(0): Setting screen physical size to 677 x 423
[ 76.508] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 76.509] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 76.509] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 76.509] () Power Button: Applying InputClass “system-keyboard”
[ 76.509] (II) LoadModule: “libinput”
[ 76.509] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 76.512] (II) Module libinput: vendor=“X.Org Foundation”
[ 76.512] compiled for 1.20.8, module version = 0.30.0
[ 76.512] Module class: X.Org XInput Driver
[ 76.512] ABI class: X.Org XInput driver, version 24.1
[ 76.512] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 76.512] () Power Button: always reports core events
[ 76.512] () Option “Device” “/dev/input/event2”
[ 76.512] () Option “_source” “server/udev”
[ 76.516] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 76.516] (II) event2 - Power Button: device is a keyboard
[ 76.516] (II) event2 - Power Button: device removed
[ 76.556] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2”
[ 76.556] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 76.556] () Option “xkb_model” “pc105”
[ 76.556] () Option “xkb_layout” “us”
[ 76.557] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 76.557] (II) event2 - Power Button: device is a keyboard
[ 76.558] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[ 76.558] () Video Bus: Applying InputClass “evdev keyboard catchall”
[ 76.558] () Video Bus: Applying InputClass “libinput keyboard catchall”
[ 76.558] () Video Bus: Applying InputClass “system-keyboard”
[ 76.558] (II) Using input driver ‘libinput’ for ‘Video Bus’
[ 76.558] () Video Bus: always reports core events
[ 76.558] () Option “Device” “/dev/input/event3”
[ 76.558] () Option “_source” “server/udev”
[ 76.560] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 76.560] (II) event3 - Video Bus: device is a keyboard
[ 76.560] (II) event3 - Video Bus: device removed
[ 76.622] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:05/LNXVIDEO:00/input/input3/event3”
[ 76.622] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 7)
[ 76.622] () Option “xkb_model” “pc105”
[ 76.622] () Option “xkb_layout” “us”
[ 76.624] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 76.624] (II) event3 - Video Bus: device is a keyboard
[ 76.625] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 76.625] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 76.625] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 76.625] () Power Button: Applying InputClass “system-keyboard”
[ 76.625] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 76.626] () Power Button: always reports core events
[ 76.626] () Option “Device” “/dev/input/event1”
[ 76.626] () Option “_source” “server/udev”
[ 76.627] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 76.627] (II) event1 - Power Button: device is a keyboard
[ 76.627] (II) event1 - Power Button: device removed
[ 76.662] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1”
[ 76.662] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 8)
[ 76.662] () Option “xkb_model” “pc105”
[ 76.662] () Option “xkb_layout” “us”
[ 76.664] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 76.664] (II) event1 - Power Button: device is a keyboard
[ 76.665] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 76.665] (II) No input driver specified, ignoring this device.
[ 76.665] (II) This device may have been added with another device file.
[ 76.666] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event7)
[ 76.666] (II) No input driver specified, ignoring this device.
[ 76.666] (II) This device may have been added with another device file.
[ 76.667] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=7 (/dev/input/event8)
[ 76.667] (II) No input driver specified, ignoring this device.
[ 76.667] (II) This device may have been added with another device file.
[ 76.667] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event14)
[ 76.668] () Integrated Camera: Integrated C: Applying InputClass “evdev keyboard catchall”
[ 76.668] () Integrated Camera: Integrated C: Applying InputClass “libinput keyboard catchall”
[ 76.668] () Integrated Camera: Integrated C: Applying InputClass “system-keyboard”
[ 76.668] (II) Using input driver ‘libinput’ for ‘Integrated Camera: Integrated C’
[ 76.668] () Integrated Camera: Integrated C: always reports core events
[ 76.668] () Option “Device” “/dev/input/event14”
[ 76.668] () Option “_source” “server/udev”
[ 76.670] (II) event14 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 76.670] (II) event14 - Integrated Camera: Integrated C: device is a keyboard
[ 76.670] (II) event14 - Integrated Camera: Integrated C: device removed
[ 76.742] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:08.1/0000:03:00.4/usb3/3-2/3-2:1.0/input/input18/event14”
[ 76.742] (II) XINPUT: Adding extended input device “Integrated Camera: Integrated C” (type: KEYBOARD, id 9)
[ 76.742] () Option “xkb_model” “pc105”
[ 76.742] () Option “xkb_layout” “us”
[ 76.745] (II) event14 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 76.745] (II) event14 - Integrated Camera: Integrated C: device is a keyboard
[ 76.746] (II) config/udev: Adding input device Integrated Camera: Integrated I (/dev/input/event15)
[ 76.746] () Integrated Camera: Integrated I: Applying InputClass “evdev keyboard catchall”
[ 76.746] () Integrated Camera: Integrated I: Applying InputClass “libinput keyboard catchall”
[ 76.746] () Integrated Camera: Integrated I: Applying InputClass “system-keyboard”
[ 76.746] (II) Using input driver ‘libinput’ for ‘Integrated Camera: Integrated I’
[ 76.746] () Integrated Camera: Integrated I: always reports core events
[ 76.746] () Option “Device” “/dev/input/event15”
[ 76.746] () Option “_source” “server/udev”
[ 76.748] (II) event15 - Integrated Camera: Integrated I: is tagged by udev as: Keyboard
[ 76.749] (II) event15 - Integrated Camera: Integrated I: device is a keyboard
[ 76.749] (II) event15 - Integrated Camera: Integrated I: device removed
[ 76.809] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:08.1/0000:03:00.4/usb3/3-2/3-2:1.2/input/input19/event15”
[ 76.809] (II) XINPUT: Adding extended input device “Integrated Camera: Integrated I” (type: KEYBOARD, id 10)
[ 76.809] () Option “xkb_model” “pc105”
[ 76.809] () Option “xkb_layout” “us”
[ 76.811] (II) event15 - Integrated Camera: Integrated I: is tagged by udev as: Keyboard
[ 76.812] (II) event15 - Integrated Camera: Integrated I: device is a keyboard
[ 76.812] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event10)
[ 76.813] (II) No input driver specified, ignoring this device.
[ 76.813] (II) This device may have been added with another device file.
[ 76.813] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event11)
[ 76.813] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event9)
[ 76.814] (II) No input driver specified, ignoring this device.
[ 76.814] (II) This device may have been added with another device file.
[ 76.814] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event5)
[ 76.814] () Ideapad extra buttons: Applying InputClass “evdev keyboard catchall”
[ 76.814] () Ideapad extra buttons: Applying InputClass “libinput keyboard catchall”
[ 76.814] () Ideapad extra buttons: Applying InputClass “system-keyboard”
[ 76.814] (II) Using input driver ‘libinput’ for ‘Ideapad extra buttons’
[ 76.814] () Ideapad extra buttons: always reports core events
[ 76.814] () Option “Device” “/dev/input/event5”
[ 76.814] () Option “_source” “server/udev”
[ 76.816] (II) event5 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 76.816] (II) event5 - Ideapad extra buttons: device is a keyboard
[ 76.816] (II) event5 - Ideapad extra buttons: device removed
[ 76.889] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input5/event5”
[ 76.889] (II) XINPUT: Adding extended input device “Ideapad extra buttons” (type: KEYBOARD, id 11)
[ 76.889] () Option “xkb_model” “pc105”
[ 76.889] () Option “xkb_layout” “us”
[ 76.891] (II) event5 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 76.891] (II) event5 - Ideapad extra buttons: device is a keyboard
[ 76.892] (II) config/udev: Adding input device MSFT0001:00 04F3:3138 Mouse (/dev/input/event12)
[ 76.892] () MSFT0001:00 04F3:3138 Mouse: Applying InputClass “evdev pointer catchall”
[ 76.892] () MSFT0001:00 04F3:3138 Mouse: Applying InputClass “libinput pointer catchall”
[ 76.892] (II) Using input driver ‘libinput’ for ‘MSFT0001:00 04F3:3138 Mouse’
[ 76.892] () MSFT0001:00 04F3:3138 Mouse: always reports core events
[ 76.892] () Option “Device” “/dev/input/event12”
[ 76.892] () Option “_source” “server/udev”
[ 76.894] (II) event12 - MSFT0001:00 04F3:3138 Mouse: is tagged by udev as: Mouse Pointingstick
[ 76.895] (II) event12 - MSFT0001:00 04F3:3138 Mouse: device is a pointer
[ 76.896] (II) event12 - MSFT0001:00 04F3:3138 Mouse: device removed
[ 76.956] () Option “config_info” “udev:/sys/devices/platform/AMDI0010:02/i2c-2/i2c-MSFT0001:00/0018:04F3:3138.0001/input/input15/event12”
[ 76.956] (II) XINPUT: Adding extended input device “MSFT0001:00 04F3:3138 Mouse” (type: MOUSE, id 12)
[ 76.956] () Option “AccelerationScheme” “none”
[ 76.956] () MSFT0001:00 04F3:3138 Mouse: (accel) selected scheme none/0
[ 76.956] () MSFT0001:00 04F3:3138 Mouse: (accel) acceleration factor: 2.000
[ 76.956] () MSFT0001:00 04F3:3138 Mouse: (accel) acceleration threshold: 4
[ 76.958] (II) event12 - MSFT0001:00 04F3:3138 Mouse: is tagged by udev as: Mouse Pointingstick
[ 76.959] (II) event12 - MSFT0001:00 04F3:3138 Mouse: device is a pointer
[ 76.961] (II) config/udev: Adding input device MSFT0001:00 04F3:3138 Mouse (/dev/input/mouse0)
[ 76.961] (II) No input driver specified, ignoring this device.
[ 76.961] (II) This device may have been added with another device file.
[ 76.961] (II) config/udev: Adding input device MSFT0001:00 04F3:3138 Touchpad (/dev/input/event13)
[ 76.961] () MSFT0001:00 04F3:3138 Touchpad: Applying InputClass “evdev touchpad catchall”
[ 76.961] () MSFT0001:00 04F3:3138 Touchpad: Applying InputClass “libinput touchpad catchall”
[ 76.961] (II) Using input driver ‘libinput’ for ‘MSFT0001:00 04F3:3138 Touchpad’
[ 76.961] () MSFT0001:00 04F3:3138 Touchpad: always reports core events
[ 76.961] () Option “Device” “/dev/input/event13”
[ 76.961] () Option “_source” “server/udev”
[ 76.963] (II) event13 - MSFT0001:00 04F3:3138 Touchpad: is tagged by udev as: Touchpad
[ 76.966] (II) event13 - MSFT0001:00 04F3:3138 Touchpad: device is a touchpad
[ 76.966] (II) event13 - MSFT0001:00 04F3:3138 Touchpad: device removed
[ 77.023] () Option “config_info” “udev:/sys/devices/platform/AMDI0010:02/i2c-2/i2c-MSFT0001:00/0018:04F3:3138.0001/input/input17/event13”
[ 77.023] (II) XINPUT: Adding extended input device “MSFT0001:00 04F3:3138 Touchpad” (type: TOUCHPAD, id 13)
[ 77.025] () Option “AccelerationScheme” “none”
[ 77.025] () MSFT0001:00 04F3:3138 Touchpad: (accel) selected scheme none/0
[ 77.025] () MSFT0001:00 04F3:3138 Touchpad: (accel) acceleration factor: 2.000
[ 77.025] () MSFT0001:00 04F3:3138 Touchpad: (accel) acceleration threshold: 4
[ 77.027] (II) event13 - MSFT0001:00 04F3:3138 Touchpad: is tagged by udev as: Touchpad
[ 77.029] (II) event13 - MSFT0001:00 04F3:3138 Touchpad: device is a touchpad
[ 77.031] (II) config/udev: Adding input device MSFT0001:00 04F3:3138 Touchpad (/dev/input/mouse1)
[ 77.031] (II) No input driver specified, ignoring this device.
[ 77.031] (II) This device may have been added with another device file.
[ 77.032] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 77.032] () AT Translated Set 2 keyboard: Applying InputClass “evdev keyboard catchall”
[ 77.032] () AT Translated Set 2 keyboard: Applying InputClass “libinput keyboard catchall”
[ 77.032] () AT Translated Set 2 keyboard: Applying InputClass “system-keyboard”
[ 77.032] (II) Using input driver ‘libinput’ for ‘AT Translated Set 2 keyboard’
[ 77.032] () AT Translated Set 2 keyboard: always reports core events
[ 77.032] () Option “Device” “/dev/input/event4”
[ 77.032] () Option “_source” “server/udev”
[ 77.033] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 77.033] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 77.035] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 77.062] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input4/event4”
[ 77.062] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 14)
[ 77.062] () Option “xkb_model” “pc105”
[ 77.062] (**) Option “xkb_layout” “us”
[ 77.064] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 77.065] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 77.067] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 77.067] (II) No input driver specified, ignoring this device.
[ 77.067] (II) This device may have been added with another device file.
[ 81.789] (II) AMDGPU(0): EDID vendor “CMN”, prod id 5040
[ 81.789] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 81.789] (II) AMDGPU(0): Modeline "2560x1600"x0.0 271.90 2560 2608 2640 2720 1600 1603 1609 1666 -hsync -vsync (100.0 kHz eP)
[ 81.793] (II) AMDGPU(0): EDID vendor “CMN”, prod id 5040
[ 81.793] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 81.793] (II) AMDGPU(0): Modeline "2560x1600"x0.0 271.90 2560 2608 2640 2720 1600 1603 1609 1666 -hsync -vsync (100.0 kHz eP)
[ 81.850] (II) AMDGPU(0): EDID vendor “CMN”, prod id 5040
[ 81.850] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 81.850] (II) AMDGPU(0): Modeline "2560x1600"x0.0 271.90 2560 2608 2640 2720 1600 1603 1609 1666 -hsync -vsync (100.0 kHz eP)
[ 81.966] (II) AMDGPU(0): EDID vendor “CMN”, prod id 5040
[ 81.966] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 81.966] (II) AMDGPU(0): Modeline "2560x1600"x0.0 271.90 2560 2608 2640 2720 1600 1603 1609 1666 -hsync -vsync (100.0 kHz eP)
[ 82.063] (EE) AMDGPU(0): drmmode_do_crtc_dpms cannot get last vblank counter
[ 82.064] (II) AMDGPU(0): Allocate new frame buffer 1920x1200
[ 82.065] (II) AMDGPU(0): => pitch 7680 bytes
[ 82.644] (II) AMDGPU(0): EDID vendor “CMN”, prod id 5040
[ 82.644] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 82.644] (II) AMDGPU(0): Modeline "2560x1600"x0.0 271.90 2560 2608 2640 2720 1600 1603 1609 1666 -hsync -vsync (100.0 kHz eP)
[ 83.040] (II) AMDGPU(0): EDID vendor “CMN”, prod id 5040
[ 83.040] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 83.040] (II) AMDGPU(0): Modeline "2560x1600"x0.0 271.90 2560 2608 2640 2720 1600 1603 1609 1666 -hsync -vsync (100.0 kHz eP)
