I just performed a new install and attempted to use the the shortcut ctrl+alt+del to lock the screen. Nothing happened.
I went to the whisker menu and clicked on the lock icon. Nothing happened.
I checked the keyboard application shortcuts and xflock4 is defined for ctrl+alt+del. So I attempted to run xflock4 from the command line. This is what happened:
[cddrew@Orangekarat ~]$ xflock4
/bin/sh: line 1: light-locker-command: command not found
'light-locker-command --lock' exited with status 127
I’m at a loss here. I’ve installed Manjaro with XFCE several times and have never seen this behavior before. Any help would be appreciated.
You’re correct. I guess the issue is that on a fresh install the bash script xflock4 is not “seeing” ‘xfce4-screensaver’, even though I verified that it’s installed and can be configured, and that light-locker is no longer installed by default.
# This list should be kept in sync with XfceScreensaver (libxfce4ui)
xdg-screensaver lock </dev/null 2>/dev/null && exit
for lock_cmd in \
xscreensaver-command \
Is yours missing the reference to light-locker-command ?
for lock_cmd in \
Not sure why it looks for light-locker at all, as the most recent Manjaro ISO doesn’t install it.
Okay, I tried it. Still nothing, but the error in the command line is now different:
** Message: 15:46:10.844: Received error message from the locker: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.ScreenSaver was not provided by any .service files
