Hi, I’m trying to configure my GPU. To do that, i use file named 90-mhwd.conf in /etc/X11/xorg.conf.d.
Now I’m not using any display managers. I use startxfce4 command instead. When I logged as root, x11 correctly loads 90-mhwd.conf, but it doesn’t work for common user. In the last case, X11 just ignores /etc/X11/xorg.conf and 90-mhwd.conf. I can change display settings using xfce-display-settings, but I can’t enable triple buffering with it.
Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ca1f2d18-8fdc-49ee-b82d-a00d58bf21af rw quiet splash apparmor=1
security=apparmor resume=UUID=8c5b963d-7fc6-4254-920b-5384339a4e22
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: xinit Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: B450 Steel Legend serial: <filter>
UEFI: American Megatrends v: P3.40 date: 06/04/2020
System RAM: total: 16 GiB available: 15.55 GiB used: 3.23 GiB (20.8%)
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
data: 64 total: 64 manufacturer: N/A part-no: IRX2666D464L16S/8G
serial: <filter>
Device-2: DIMM 1 type: no module installed
Device-3: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
serial: <filter>
Device-4: DIMM 1 type: no module installed
Info: model: AMD Ryzen 5 2600 socket: AM4 bits: 64 type: MT MCP arch: Zen+
gen: 2 level: v3 note: check built: 2018-21 process: GF 12nm
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2579 high: 3400 min/max: 1550/3400 boost: enabled
base/boost: 3400/3900 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 2800 2: 1550 3: 1550 4: 3400
5: 3400 6: 3400 7: 1550 8: 1550 9: 1550 10: 3400 11: 3400 12: 3400
bogomips: 81466
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] driver: nvidia v: 535.98
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0a:00.0 chip-ID: 10de:1f06 class-ID: 0300
Device-2: KYE Systems (Mouse Systems) Genius Webcam
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-3:2 chip-ID: 0458:6006 class-ID: 0102 serial: <filter>
Display: server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: HDMI-0 res: 3440x1440 dpi: 110 size: 797x333mm (31.38x13.11")
diag: 864mm (34.01") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.98 renderer: NVIDIA GeForce RTX 2060
SUPER/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.3
chip-ID: 1022:1457 class-ID: 0403
Device-3: KYE Systems (Mouse Systems) Genius Webcam
Device-4: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 5-1:2 chip-ID: 1235:8202 class-ID: 0102
API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.77 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.36 TiB used: 48.42 GiB (3.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 38.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD110 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: A8R0 scheme: GPT
ID-1: / raw-size: 448.36 GiB size: 440.26 GiB (98.19%)
used: 48.42 GiB (11.0%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: ca1f2d18-8fdc-49ee-b82d-a00d58bf21af
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 2CDD-361F
ID-1: swap-1 type: partition size: 17.1 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 8c5b963d-7fc6-4254-920b-5384339a4e22
ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: vfat label: N/A
uuid: 39F9-B347
Device-1: 1-3:2 info: KYE Systems (Mouse Systems) Genius Webcam
type: video,audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 256mA
Device-2: 1-7:3 info: Holtek Keyboard LKS02 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 04d9:1702 class-ID: 0300
Device-3: 1-10:4 info: INSTANT USB GAMING MOUSE type: mouse,keyboard
lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:1040 class-ID: 0300
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
type: audio driver: snd-usb-audio interfaces: 4 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 51.8 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 44%
Processes: 297 Uptime: 9m wakeups: 0 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1082 libs: 301 tools: gnome-software,pamac,yay pm: flatpak pkgs: 0
Shell: Zsh (sudo) v: 5.9 running-in: xfce4-terminal inxi: 3.3.29
90-mhwd.conf:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 535.98
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Samsung C34J79x"
HorizSync 30.0 - 152.0
VertRefresh 50.0 - 100.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce RTX 2060 SUPER"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-1"
Option "metamodes" "2560x1440_60 +0+0; 1920x1080_60 +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
UPD: It seems that X11 also ignores /etc/X11/xorg.conf.d
