Difficulty: ★★☆☆☆
Rootless Graphical Sessions
In many cases the display server may be launched with root privileges.
To verify how Xorg is started you may use:
ps -o user= -C Xorg
This of course can be a security concern.
A somewhat contemporary, albeit far from exhaustive, example would be:
Launching xorg or wayland rootless will require different steps for different display managers.
GDM
GDM will automatically launch X or Wayland rootless if kernel mode setting is configured.
SDDM
Beginning with version 0.20.0 SDDM can launch the display server rootless.
SDDM requires configuration files for xorg and wayland respectively.
X11
Edit
/etc/sddm.conf.d/rootless-x11.conf[General] DisplayServer=x11-user -
Wayland
Edit
/etc/sddm.conf.d/rootless-wayland.conf[General] DisplayServer=wayland GreeterEnvironment=QT_WAYLAND_SHELL_INTEGRATION=layer-shell [Wayland] CompositorCommand="weston --shell=fullscreen-shell.so"NOTE: The default compositor string is contained here.
In the case a different Wayland compositor to render SDDM is desired replace theCompositorCommandstring with the relevant command and arguments.
For KWin you may use:
kwin_wayland --no-lockscreen --no-global-shortcuts
Additional Steps for Everyone
These configurations are for everyone.
They can be considered optional for users of Display Managers, and required for those without one.
xserverrc
You may edit
/etc/X11/xinit/xserverrcdirectly.
But it is advisable to copy it to~/.xserverrc.-
Remove
execfrom the line if it exists to ensure startx is a subprocess of the login shell.
Example:
exec /usr/bin/X -nolisten tcp "$@"
becomes
/usr/bin/X -nolisten tcp "$@" -
Use
-keepttyto keep log redirection.
When X is run rootless logs are directed to~/.local/share/xorg/Xorg.log, but the stdout and stderr output from the Xorg session is not redirected there.
Example:
becomes
/usr/bin/X -nolisten tcp "$@" -keeptty -
Make sure that Xorg uses the correct virtual terminal for permissions, such as by
vt$XDG_VTNR
Example:
becomes
/usr/bin/X -nolisten tcp "$@" -keeptty vt$XDG_VTNR
Proprietary graphics (nvidia)
Kernel Mode Setting will fail unless the following is set in
/etc/X11/Xwrapper.config:
needs_root_rights=no
NOTE: The following was previously reported to sometimes be required. Retained for posterity.
allowed_users=anybody
LightDM
Sorry lightdm users, there is currently no way to launch your display server rootless from lightdm.
A bug thread can be found here: Support non-root X · Issue #18 · ubuntu/lightdm · GitHub ![]()
Final Notes
I use KDE,SDDM,X11 - all else is provided only for testing.
There may be dragons. There may not. -
In the case of SDDM (possibly others) there existed a sometimes-bug resulting in the display handoff not always working as expected. In these cases the user must simply manually switch seats, such as by using Ctrl+Alt+F#
This will be marked a wiki post.
So consider it an evolving work in progress as things change and feel free to correct or fill it out.
