I have the same problem like in thread [XFCE Panel Status Tray Menu Location] and the marked solution does not work in my case. Sorry for reposting but I can not append any comments there.
Does anyone else has this problem or another idea or solution to this problem?
Menu opens, hovering over âBeendenâ, which means quit
I release my LMB, but the DE interprets this as another click and immediatelly quits my Teams client
One workaround is to release the left mouse button very quickly (double click delay?), so that the app doesnât quit and the menu is still open and usable, but this can not be an acceptable solution!
This is very annoying in my daily work and I hope someone will read this and give some workaround for this.
Vaniila xfce uses main panel on top not on bottom like manjaro does. This can invite some irritations, i.e. notifications in the tray are not visible because they are shown âunderâ the panel.
So, try with panel on top as a workaround, if you are fine with a slightly different look.
@maycne.sonahoz@banjo: Thanks alot for your input and ideas. I tried them all and played around with several panel and display settings and I somehow fixed my problem. My findings:
Same problem with other themes. Iâm using one of the default themes which ships with Manjaro. Themes seems unrelated to this issue
Panel was already at the very bottom, although the problem definitly occurs if I place the panel somewhere in between top and bottom. So panel and menu overlaps in that case which might make sense for that usecase
Putting the panel on top didnât solve the overlapping problem either. Anyways, thanks for the historical explanation which sounds comprehensible
So, the problem occurs particularly on my external monitor. I toggled several settings in display settings and also panel settings. Itâs working now. No overlapping between panel and menu anymore. I bet I can reproduce it again if I a play around more, so there is a bug when using external monitors.
I leave my settings like that for now and in case it occurs again, I now know how to possibly work around it.
Update: A couple minutes later and the icon menus appear now on the other screen. Quickfix: Panel preferences > Lock panel: Off
