Upon launching the installer, I receive an error “There are no partitions to install on”, and the “Details…” menu tells me that the requirement for at least one disk drive is not satisfied. I have two hard drives physically installed.
The output for inxi -Fazy is as follows:
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2112 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Gigabyte model: Z77X-UD3H serial: <filter> UEFI: American Megatrends
v: F17 date: 08/22/2012
Info: Quad Core model: Intel Core i5-3570K bits: 64 type: MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 27238
Speed: 1602 MHz min/max: 1600/3800 MHz Core speeds (MHz): 1: 1602 2: 1665
3: 1671 4: 2135
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: srbds status: Vulnerable: No microcode
Message: No device data found.
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: AMD VERDE (DRM 2.50.0 5.13.13-1-MANJARO LLVM 12.0.1)
v: 4.5 Mesa 21.2.1 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: Pegatron driver: snd_hda_intel v: kernel bus-ID: 02:00.1
chip-ID: 1002:aab0 class-ID: 0403
Device-3: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
driver: snd_hda_intel v: kernel bus-ID: 04:00.0 chip-ID: 1102:0012
class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
Device-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: Gigabyte
driver: atl1c v: kernel port: d000 bus-ID: 08:00.0 chip-ID: 1969:1083
class-ID: 0200
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 57.68 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 type: USB vendor: PNY model: USB 2.0 FD
size: 57.68 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
Message: No partition data found.
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 61.0 C
Processes: 219 Uptime: 11m wakeups: 0 Memory: 15.59 GiB
used: 1.97 GiB (12.6%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1122 lib: 305 flatpak: 0 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.06
