I had the “wrong password” problem when logging in for the first time after installing manjaro. Just by chance, decided to try tying my password with caps lock on…. It worked! I was in.
Sigh, then I tried to install some software from the repository and my password didn’t work, caps lock or not.
But this must be a bug I guess. Something to do with the caps lock?
Good luck developers!
Probably not a bug.
PEBCAC maybe …
Rather a problem with the default keymap and the one you use.
The effect is:
what you think you are typing is not what the OS gets to see.
My only guess for now is:
switch to a TTY and test whether what you type actually corresponds with what is printed to screen.
Good luck, user!
… if your DE (which is rather an OS) is indeed what it says in your description
then this forum is the wrong one for sure …
Hello @Worjools, if you entered a wrong password several times ( I guess 3 times) the login with this user is locked for a few minutes ( I guess 15 min). You can use the program ‘faillock
’ to reset this by using this command:
faillock --user username --reset
I know this doesn’t help you with you caps-problem, but perhaps with you authentication-problem while install something.
