World of Warcraft - WotLK "OpenVR: failed to locate module & DXVK Error"
Hi guys :wink:
Recently i switched to Manjaro XFCE from Windows while assuming using Linux would be way smoother and less taxing on resources
I exclusivly use my machine to play World of Warcraft Wrath of the Lich King on private server called Warmane
My machine is a Dell Vostro 3500 and I heared that I would get better experience while I play WoW then before
so I installed all the requirements to start playing WoW and i got errors when I try launching WoW from Lutris according to logs
OpenVR: Failed to locate module & DXVK Error
I heared that DXVK doesn’t support well the games(old games) that run with a DirectX9
Running /home/desktop/.local/share/lutris/runners/wine/lutris-5.7-8-x86_64/bin/wine /home/desktop/Games/world-of-warcraft-wrath-of-the-lich-king/drive_c/world_of_warcraft_wrath_of_the_lich_king/Wow.exe
Initial process has started with pid 5408
Game is considered started.
esync: up and running.
info:  Game: Wow.exe
info:  DXVK: v1.7-81-g3322da4b
info:  Built-in extension providers:
info:    Win32 WSI
info:    OpenVR
warn:  OpenVR: Failed to locate module
info:  Enabled instance extensions:
info:    VK_KHR_get_surface_capabilities2
info:    VK_KHR_surface
info:    VK_KHR_win32_surface
terminate called after throwing an instance of 'dxvk::DxvkError'
Game is considered exited.
Initial process has exited.
All monitored processes have exited.
Exit with returncode 768
inb4: [OpenVR: Failed to locate module - Technical Issues and Assistance / Applications - Manjaro Linux Forum]
in previous forum a topic was discussing the same issue i assume and someone found that the solution wich was he needed to disable a specific dll file or something similar so that OpenVR could work, unfortunatly he neither explained how to do it nor how to find it
ps: sorry for my English im not a native speaker, you help is beyond than welcomed.
OpenVR is acually not the problem, but the initialization of your GPU.
Here is an example how it looks like when i run Gothic 3 for example:
Lutris log
lutris-wrapper: Gothic 3
Running gamemoderun mangohud /home/henuk/.local/share/lutris/runners/wine/lutris-5.7-8-x86_64/bin/wine /home/henuk/Games/gothic-3/drive_c/GOG Games/Gothic 3/Gothic3.exe
Initial process has started with pid 135541
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
gamemodeauto:
fsync: up and running.
info:  Game: Gothic3.exe
info:  DXVK: v1.7.1-2-g743f3092
info:  Found built-in config:
info:  Effective configuration:
info:    d3d9.allowLockFlagReadonly = False
info:    d3d9.supportDFFormats = False
info:    Win32 WSI
info:    OpenVR
warn:  D3D9: VK_FORMAT_D16_UNORM_S8_UINT -> VK_FORMAT_D24_UNORM_S8_UINT
warn:  D3D9: VK_FORMAT_A4R4G4B4_UNORM_PACK16_EXT -> VK_FORMAT_B4G4R4A4_UNORM_PACK16
info:  GeForce GTX 1050 Ti:
info:    Driver: 450.57.0
info:    Vulkan: 1.2.133
info:    Memory Heap[0]:
info:      Size: 4096 MiB
info:      Flags: 0x1
info:      Memory Type[7]: Property Flags = 0x1
info:    Memory Heap[1]:
info:      Size: 5990 MiB
info:      Flags: 0x0
info:      Memory Type[0]: Property Flags = 0x0
info:      Memory Type[1]: Property Flags = 0x0
info:      Memory Type[2]: Property Flags = 0x0
info:      Memory Type[3]: Property Flags = 0x0
info:      Memory Type[4]: Property Flags = 0x0
info:      Memory Type[5]: Property Flags = 0x0
info:      Memory Type[6]: Property Flags = 0x0
info:      Memory Type[8]: Property Flags = 0x6
info:      Memory Type[9]: Property Flags = 0xe
info:    Memory Heap[2]:
info:      Size: 246 MiB
info:      Flags: 0x1
info:      Memory Type[10]: Property Flags = 0x7
info:      Flags: 0x1
info:      Flags: 0x0
info:      Size: 246 MiB
info:      Flags: 0x1
info:  Process set as DPI aware
info:    Win32 WSI
info:    OpenVR
info:      Flags: 0x1
info:      Flags: 0x0
info:      Size: 246 MiB
info:      Flags: 0x1
info:      Flags: 0x1
info:      Flags: 0x0
info:      Size: 246 MiB
info:      Flags: 0x1
info:    Win32 WSI
info:    OpenVR
info:      Flags: 0x1
info:      Flags: 0x0
info:      Size: 246 MiB
info:      Flags: 0x1
info:      Flags: 0x1
info:      Flags: 0x0
info:      Size: 246 MiB
info:      Flags: 0x1
info:  Device properties:
info:    Device name:     : GeForce GTX 1050 Ti
info:    Driver version   : 450.57.0
info:  Enabled device extensions:
info:    VK_EXT_custom_border_color
info:    VK_EXT_depth_clip_enable
info:    VK_EXT_full_screen_exclusive
info:    VK_EXT_host_query_reset
info:    VK_EXT_shader_demote_to_helper_invocation
info:    VK_EXT_shader_viewport_index_layer
info:    VK_EXT_transform_feedback
info:    VK_EXT_vertex_attribute_divisor
info:    VK_KHR_create_renderpass2
info:    VK_KHR_depth_stencil_resolve
info:    VK_KHR_draw_indirect_count
info:    VK_KHR_driver_properties
info:    VK_KHR_image_format_list
info:    VK_KHR_sampler_mirror_clamp_to_edge
info:    VK_KHR_swapchain
info:  Device features:
info:    robustBufferAccess                     : 1
info:    fullDrawIndexUint32                    : 1
info:    imageCubeArray                         : 1
info:    independentBlend                       : 1
info:    geometryShader                         : 1
info:    tessellationShader                     : 0
info:    sampleRateShading                      : 1
info:    dualSrcBlend                           : 0
info:    logicOp                                : 0
info:    multiDrawIndirect                      : 0
info:    drawIndirectFirstInstance              : 0
info:    depthClamp                             : 1
info:    depthBiasClamp                         : 1
info:    fillModeNonSolid                       : 1
info:    depthBounds                            : 1
info:    multiViewport                          : 1
info:    samplerAnisotropy                      : 1
info:    textureCompressionBC                   : 1
info:    occlusionQueryPrecise                  : 1
info:    pipelineStatisticsQuery                : 1
info:    vertexPipelineStoresAndAtomics         : 1
info:    fragmentStoresAndAtomics               : 0
info:    shaderImageGatherExtended              : 0
info:    shaderStorageImageExtendedFormats      : 1
info:    shaderStorageImageReadWithoutFormat    : 0
info:    shaderStorageImageWriteWithoutFormat   : 1
info:    shaderClipDistance                     : 1
info:    shaderCullDistance                     : 1
info:    shaderFloat64                          : 0
info:    shaderInt64                            : 0
info:    variableMultisampleRate                : 0
info:  VK_EXT_conditional_rendering
info:    conditionalRendering                   : 0
info:  VK_EXT_4444_formats
info:    formatA4R4G4B4                         : 0
info:    formatA4B4G4R4                         : 0
info:    customBorderColors                     : 1
info:    customBorderColorWithoutFormat         : 1
info:    depthClipEnable                        : 1
info:  VK_EXT_extended_dynamic_state
info:    extendedDynamicState                   : 0
info:    hostQueryReset                         : 1
info:  VK_EXT_memory_priority
info:    memoryPriority                         : 0
info:  VK_EXT_robustness2
info:    robustBufferAccess2                    : 0
info:    robustImageAccess2                     : 0
info:    nullDescriptor                         : 0
info:    shaderDemoteToHelperInvocation         : 1
info:    transformFeedback                      : 0
info:    geometryStreams                        : 0
info:    vertexAttributeInstanceRateDivisor     : 1
info:    vertexAttributeInstanceRateZeroDivisor : 1
info:  Queue families:
info:    Graphics : 0
info:    Transfer : 1
MANGOHUD: Uploading is disabled (permit_upload = 0)
info:  DXVK: Read 5943 valid state cache entries
info:  DXVK: Using 2 compiler threads
info:  D3D9DeviceEx::ResetSwapChain:
info:    Requested Presentation Parameters
info:      - Width:              1920
info:      - Height:             1200
info:      - Format:             D3D9Format::X8R8G8B8
info:      - Auto Depth Stencil: true
info:                  ^ Format: D3D9Format::D24S8
info:      - Windowed:           false
warn:  winevulkan detected, disabling exclusive fullscreen support
info:  Presenter: Actual swap chain properties:
info:    Format:       VK_FORMAT_B8G8R8A8_UNORM
info:    Present mode: VK_PRESENT_MODE_IMMEDIATE_KHR
info:    Buffer size:  1920x1200
info:    Image count:  2
info:    Exclusive FS: 0
info:  Setting display mode: 1920x1200@60
info:  Restoring display mode: 1920x1200@60
Unable to find any Athena Hardware devices!
Exit with returncode 256
Sometimes you need the
d3dcompiler_42
d3dcompiler_43
d3dcompiler_47
installed also.
Also check if your GPU is vulkan compatible. Install vulkan-tools and run vulkaninfo in a terminal.
Eh… DXVK works great on WoW. And works great on any DX9 games I throw at it. Works even better than running DX9 on Windows from my experience.
That’s your main issue.
Install vulkan-tools, then run vkcube and vulkaninfo in the terminal to see if vulkan is working correctly.
I installed both vulkan-tools & vkcube
Restarted my computer then I opened the terminal and i typed ā€œvulkaninfoā€ and I got this:
ERROR: [Loader Message] Code 0 : /usr/lib32/libvulkan_radeon.so: wrong ELF class: ELFCLASS32
ERROR: [Loader Message] Code 0 : /usr/lib32/libvulkan_intel.so: wrong ELF class: ELFCLASS32
ERROR at /build/vulkan-tools/src/Vulkan-Tools-1.2.146/vulkaninfo/vulkaninfo.h:240:vkEnumerateInstanceExtensionProperties failed with ERROR_INITIALIZATION_FAILED
And then i typed ā€œvkcubeā€:
Segmentation fault (core dumped)
Please post the output of inxi -Fza
  Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=cd787d5f-85fb-48e5-a023-18636b5177bf rw quiet
  cryptdevice=UUID=d431e775-6eec-4eff-970f-f57bd2a67ebd:luks-d431e775-6eec-4eff-970f-f57bd2a67ebd
  root=/dev/mapper/luks-d431e775-6eec-4eff-970f-f57bd2a67ebd apparmor=1
  Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Portable System: Dell product: Vostro 3500 v: A12 serial: <filter>
  Mobo: Dell model: 0G2R51 v: A12 serial: <filter> BIOS: Dell v: A12
  date: 04/08/2014
  Topology: Dual Core model: Intel Core i3 M 380 bits: 64 type: MT MCP
  arch: Nehalem family: 6 model-id: 25 (37) stepping: 5 microcode: 7
  L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20222
  Speed: 1102 MHz min/max: 931/2527 MHz Core speeds (MHz): 1: 1463 2: 1490
  3: 1542 4: 1483
  Type: l1tf
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
  SMT vulnerable
  Device-1: Intel Core Processor Integrated Graphics vendor: Dell
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0046
  Device-2: Microdia type: USB driver: uvcvideo bus ID: 2-1.8:5
  chip ID: 0c45:6421
  Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting
  alternate: fbdev,vesa display ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK) v: 2.1 Mesa 20.1.6
  direct render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Dell
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:3b56
  Sound Server: ALSA v: k5.8.3-2-MANJARO
  Device-1: Broadcom and subsidiaries BCM4313 802.11bgn Wireless Network
  Adapter
  vendor: Dell Inspiron M5010 / XPS 8300 driver: wl v: kernel modules: bcma
  port: f000 bus ID: 12:00.0 chip ID: 14e4:4727
  IF: wlp18s0 state: up mac: <filter>
  vendor: Dell driver: r8169 v: kernel port: e000 bus ID: 13:00.0
  chip ID: 10ec:8168
  IF: enp19s0 state: down mac: <filter>
  Local Storage: total: 417.18 GiB used: 102.31 GiB (24.5%)
  ID-1: /dev/sda vendor: Western Digital model: WD3200BEKT-75PVMT0
  size: 298.09 GiB block size: physical: 512 B logical: 512 B
  speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
  ID-2: /dev/sdb type: USB vendor: Generic model: Multi-Card
  size: 119.08 GiB block size: physical: 512 B logical: 512 B
  serial: <filter> rev: 1.00
  ID-1: / raw size: 120.06 GiB size: 117.67 GiB (98.01%)
  used: 102.31 GiB (86.9%) fs: ext4 dev: /dev/dm-0
  System Temperatures: cpu: 57.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 4080
  Processes: 219 Uptime: 15m Memory: 2.79 GiB used: 1.34 GiB (47.9%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1346 pacman: 1339
  lib: 416 flatpak: 0 snap: 7 Shell: Bash v: 5.0.18
  running in: xfce4-terminal inxi: 3.1.05
Seems to be a similar problem like this one here:
Vulkan seems to need DRI3, which is not enabled by default. If you are really sure, that your Intel Chipset supports vulkan, then add this
Section "Device"
   Identifier  "Intel Graphics"
   Driver      "intel"
   Option      "DRI"    "3"
EndSection
Source
to your /etc/X11/xorg.conf.d/20-intel.conf. If not there, create one and reboot. Check vulkaninfo again.
Alos keep sure that you have installed vulkan-intel and vulkan-icd-loader.
You can’t use Vulkan on your iGPU. It’s too old (2010). Vulkan is only supported on Ivy Bridge (2012) and forward.
And it looks like you don’t have a dGPU, only an iGPU.
You can try to run the game without DXVK, which will translate the game to OpenGL
I have them installed, but I’m not sure that I succeeded to follow these instructions in my terminal seemed like they are invalid commands :arrow_down:
I disabled DXVK / VKD3D and started WoW but felt like I was only using Wine to run it(without the benefits using Lutris), and it felt way worse than the time I was playing on windows, it’s sucks that Vulkan doesn’t support old GPUs
I remembered the solution in that topic so his game could lunch, he needed to disable a file or something like that called ā€œlib32ā€ sorry i can’t remember what was it but I’m sure ā€œlib32ā€ is involved maybe it could help
