Hello everyone,
I’m using Manjaro KDE 21.1.0 & using ibus for typing. When I go to type Bangla Languager, after typing a word, if I give a space, the word becomes triple to quadruple.
How do I fix it, please?
inxi output here:
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3b6d050f-eae8-492b-b64f-ea6dff73e06f rw quiet apparmor=1
security=apparmor resume=UUID=7f727c71-395b-4660-b126-a8688ecdeca8
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop Mobo: Gigabyte model: H310M S2H 2.0 v: x.x serial: <filter>
UEFI-[Legacy]: American Megatrends v: F11 date: 03/08/2019
RAM: total: 7.64 GiB used: 2.57 GiB (33.7%)
Info: Quad Core model: Intel Core i3-8100 bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: B (11) microcode: EA
cache: L2: 6 MiB bogomips: 28808
Speed: 3600 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 3600 2: 3600
3: 1239 4: 3600
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Gigabyte
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e91 class-ID: 0300
Device-2: Cubeternet GL-UPC822 UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 1e4e:0102 class-ID: 0e02
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: DP-1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1")
diag: 470mm (18.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: yes
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.34 running: yes
vendor: Gigabyte driver: r8168 v: 8.049.02-NAPI modules: r8169 port: e000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 111.79 GiB used: 33.36 GiB (29.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: GALAX model: GAMER L TA1D0120A
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 61.3 scheme: MBR
Optical-1: /dev/sr0 vendor: PLDS model: DVD-RW DH16ABSH rev: YL32
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 102.99 GiB size: 100.81 GiB (97.89%)
used: 33.36 GiB (33.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 3b6d050f-eae8-492b-b64f-ea6dff73e06f
dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 7f727c71-395b-4660-b126-a8688ecdeca8
Device-1: 1-5:2 info: Cubeternet GL-UPC822 UVC WebCam type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 100mA
Device-2: 1-7:3 info: SiGma Micro Keyboard type: Keyboard,HID
power: 98mA chip-ID: 1c4f:0026 class-ID: 0300
Device-3: 1-8:4 info: A4Tech USB Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 09da:c10a class-ID: 0301
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 27.8 C mobo: 16.8 C
Processes: 244 Uptime: 2h 20m wakeups: 0 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1512 lib: 436
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: yakuake
inxi: 3.3.06
OS -> Manjaro Linux x86_64
Host -> H310M S2H 2.0
Kernel -> 5.10.59-1-MANJARO
KDE Plasma Version: 5.22.4
KDE Frameworks Version: 5.85.0
session type: X11
IBus version: 1.5.24
Welcome to Manjaro!
to give us more information so we can see what’s really going on.
