Jonas
7 February 2021 20:59
1
Hello,
I installed Manjaro KDE on an old desktop, Dell Optiplex 9010, most things work fine. However, the screen’s brightness won’t ajust in any way, neither in the DE settings nor with terminal applications like xbacklight. The system kind of pretens like if it is adjusting the brightness, but the actual brightness is unchanged.
$ cat /sys/class/backlight/acpi_video0/brightness
3
What could be wrong?
Thanks in advance.
Fabby
9 February 2021 15:36
2
Welcome to Manjaro!
Please read this:
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
What does:
echo 10 | sudo tee /sys/class/backlight/acpi_video0/brightness
do?
What’s the output of:
grep GRUB_CMDLINE_LINUX_DEFAULT /etc/default/grub
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
Jonas
18 April 2021 10:34
3
It seems like you expect me to know about all these crazy-complicated commands, but very few people do. Please just ask when you need information, but there is no way someone who is not an IT professional could know about all your requirements.
I will answer your questions 1, 2 and 3 when I get home.
Jonas
18 April 2021 10:37
4
If you find it a problem that my profile has too little information, you should probably talk to the administrators of these forums, not me, if they could add the requirements you ask for. In the meanwhile, there is nothing I can do, since I have no idea exactly what information you are asking for on my profile.
Fabby
18 April 2021 12:38
5
After you’ve come home, after you’ve provided the requested information and while you wait for someone to answer, please read this:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the wood for the trees any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
Jonas
28 May 2021 17:30
7
I’m finally home. Your howto-post is not relevant for me as I’ve never been a wizard at Windows. Also, being a Manjaro power user in order to use this forum should not be necessary.
Jonas
28 May 2021 17:36
8
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=5a0d50ac-2042-4891-9af1-3a8a7b665d86 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: Dell product: OptiPlex 9010 v: 01 serial: <filter>
Chassis: type: 15 serial: <filter>
Mobo: Dell model: 051FJ8 v: A01 serial: <filter> UEFI: Dell v: A12
date: 01/10/2013
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540/K545
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M510
status: Discharging
RAM: total: 7.66 GiB used: 2.69 GiB (35.1%)
Info: Quad Core model: Intel Core i5-3470 bits: 64 type: MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 6 MiB bogomips: 25548
Speed: 1597 MHz min/max: 1600/3600 MHz Core speeds (MHz): 1: 1597 2: 1596
3: 1597 4: 1597
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics vendor: Dell
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0152
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI2 res: 1920x1080 dpi: 81 size: 600x340mm (23.6x13.4")
diag: 690mm (27.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 2500 (IVB GT1)
v: 4.2 Mesa 20.3.3 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.10.7-3-MANJARO
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f080 bus ID: 00:19.0 chip ID: 8086:1502
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus ID: 00:1f.2 chip ID: 8086.2822 rev: 04
Local Storage: total: 465.76 GiB used: 86.8 GiB (18.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: KC47
Optical-1: /dev/sr0 vendor: TSSTcorp model: DVD+-RW SN-208BB rev: D500
dev-links: cdrom
ID-1: / raw size: 228.33 GiB size: 223.75 GiB (97.99%)
used: 86.8 GiB (38.8%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 5a0d50ac-2042-4891-9af1-3a8a7b665d86
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 416 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 3899-63A9
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: b6e364b0-9b01-464c-994a-987555562a54
ID-1: /dev/sda2 maj-min: 8:2 size: 228.33 GiB fs: ext4 label: N/A
uuid: 0dd75152-ca35-4253-ad27-a32839371a6d
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
speed: 480 Mb/s chip ID: 8087:0024
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
chip ID: 046d:c52b
Device-2: 3-2:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
chip ID: 0a12:0001
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 179 Uptime: 57m wakeups: 12 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1301 pacman: 1295 lib: 390 flatpak: 6 Shell: Bash
v: 5.1.0 running in: yakuake inxi: 3.2.02
$ echo 10 | sudo tee /sys/class/backlight/acpi_video0/brightness
[sudo] passord for jonas:
10
$ grep GRUB_CMDLINE_LINUX_DEFAULT /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
Fabby
29 May 2021 08:20
9
I’m not expecting you to be if you don’t want to, but at least I’m expecting you to provide the information requested:
Easy to miss at the bottom, took me a while to realise it was there.
Fabby
29 May 2021 20:02
12
This didn’t change the brightness?
If no,
add acpi_backlight=vendor to the end of the line GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3 in file /etc/default/grub
Reboot
Try again.
If yes: don’t do the above and shout out.
Jonas
29 May 2021 22:12
13
Thanks! I did all the steps. Unfortunately it still doesn’t work.
Fabby
30 May 2021 07:00
14
I won’t be able to help you any further then, sorry!
