As @anon33601770 said, to install/compile something like this from the AUR, there are quite some prerequisites.
Firstly, you need the kernel headers for your installed kernel(s). You also need the dkms package. Then you can go ahead.
Installing headers for currently installed kernels
pamac install $(pamac list --installed --quiet | grep "^linux" | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
Then you also need at least thee dkms package, but that sh0ould be installed when building the drivers, IIRC.
The drivers themselves are in the AUR:
$ pamac search 8812au
rtl8812au-dkms-git 5.13.6.r129.g0fe44f8-1 AUR
rtl8812AU chipset driver with firmware v5.13.6
So to build them, theoretically you need to run:
pamac build rtl8812au-dkms-git
Hope this helps!
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or 3 (three) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Also, if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
